ReadParallel.cpp
00001 #include "ReadParallel.hpp"
00002 #include "moab/Core.hpp"
00003 #include "moab/ProcConfig.hpp"
00004 #include "moab/FileOptions.hpp"
00005 #include "moab/Error.hpp"
00006 #include "moab/ReaderWriterSet.hpp"
00007 #include "moab/ReadUtilIface.hpp"
00008 #include "moab/ParallelComm.hpp"
00009 #include "MBParallelConventions.h"
00010
00011 #include <iostream>
00012 #include <iomanip>
00013 #include <iterator>
00014 #include <sstream>
00015 #include <algorithm>
00016 #include <cassert>
00017
00018 namespace moab
00019 {
00020
00021 const bool debug = false;
00022
00023 const char* ReadParallel::ParallelActionsNames[] = { "PARALLEL READ",
00024                                                      "PARALLEL READ PART",
00025                                                      "PARALLEL BROADCAST",
00026                                                      "PARALLEL DELETE NONLOCAL",
00027                                                      "PARALLEL CHECK_GIDS_SERIAL",
00028                                                      "PARALLEL GET_FILESET_ENTS",
00029                                                      "PARALLEL RESOLVE_SHARED_ENTS",
00030                                                      "PARALLEL EXCHANGE_GHOSTS",
00031                                                      "PARALLEL RESOLVE_SHARED_SETS",
00032                                                      "PARALLEL_AUGMENT_SETS_WITH_GHOSTS",
00033                                                      "PARALLEL PRINT_PARALLEL",
00034                                                      "PARALLEL_CREATE_TRIVIAL_PARTITION",
00035                                                      "PARALLEL_CORRECT_THIN_GHOST_LAYERS" };
00036
00037 const char* ReadParallel::parallelOptsNames[] = { "NONE", "BCAST", "BCAST_DELETE", "READ_DELETE", "READ_PART", "", 0 };
00038
00039 ReadParallel::ReadParallel( Interface* impl, ParallelComm* pc )
00040     : mbImpl( impl ), myPcomm( pc ), myDebug( "ReadPara", std::cerr )
00041 {
00042     if( !myPcomm )
00043     {
00044         myPcomm = ParallelComm::get_pcomm( mbImpl, 0 );
00045         if( NULL == myPcomm ) myPcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
00046     }
00047     myDebug.set_rank( myPcomm->proc_config().proc_rank() );
00048     if( debug )  // For backwards compatibility, enable all debug output if constant is true
00049         myDebug.set_verbosity( 10 );
00050
00051     impl->query_interface( mError );
00052 }
00053
00054 ErrorCode ReadParallel::load_file( const char** file_names,
00055                                    const int num_files,
00056                                    const EntityHandle* file_set,
00057                                    const FileOptions& opts,
00058                                    const ReaderIface::SubsetList* subset_list,
00059                                    const Tag* file_id_tag )
00060 {
00061     int tmpval;
00062     if( MB_SUCCESS == opts.get_int_option( "DEBUG_PIO", 1, tmpval ) )
00063     {
00064         myDebug.set_verbosity( tmpval );
00065         myPcomm->set_debug_verbosity( tmpval );
00066     }
00067     myDebug.tprint( 1, "Setting up...\n" );
00068
00069     // Get parallel settings
00070     int parallel_mode;
00071     ErrorCode result = opts.match_option( "PARALLEL", parallelOptsNames, parallel_mode );
00072     if( MB_FAILURE == result )
00073     {
00074         MB_SET_ERR( MB_FAILURE, "Unexpected value for 'PARALLEL' option" );
00075     }
00076     else if( MB_ENTITY_NOT_FOUND == result )
00077     {
00078         parallel_mode = 0;
00079     }
00080
00081     // Get partition setting
00082     bool distrib;
00083     std::string partition_tag_name;
00084     result = opts.get_option( "PARTITION", partition_tag_name );
00085     if( MB_ENTITY_NOT_FOUND == result )
00086     {
00087         distrib            = false;
00088         partition_tag_name = "";
00089     }
00090     else
00091     {
00092         distrib = true;
00093         if( partition_tag_name.empty() ) partition_tag_name = PARALLEL_PARTITION_TAG_NAME;
00094
00095         // Also get deprecated PARTITION_DISTRIBUTE option
00096         // so that higher-level code doesn't return an error
00097         // due to an unrecognized option
00098         opts.get_null_option( "PARTITION_DISTRIBUTE" );
00099     }
00100
00101     // Get partition tag value(s), if any, and whether they're to be
00102     // distributed or assigned
00103     std::vector< int > partition_tag_vals;
00104     opts.get_ints_option( "PARTITION_VAL", partition_tag_vals );
00105
00106     // see if partition tag name is "TRIVIAL", if the tag exists
00107     bool create_trivial_partition = false;
00108     if( partition_tag_name == std::string( "TRIVIAL" ) )
00109     {
00110         Tag ttag;  // see if the trivial tag exists
00111         result = mbImpl->tag_get_handle( partition_tag_name.c_str(), ttag );
00112         if( MB_TAG_NOT_FOUND == result ) create_trivial_partition = true;
00113     }
00114     // See if we need to report times
00115     bool cputime = false;
00116     result       = opts.get_null_option( "CPUTIME" );
00117     if( MB_SUCCESS == result ) cputime = true;
00118
00119     // See if we need to report times
00120     bool print_parallel = false;
00121     result              = opts.get_null_option( "PRINT_PARALLEL" );
00122     if( MB_SUCCESS == result ) print_parallel = true;
00123
00124     // Get ghosting options
00125     std::string ghost_str;
00126     int bridge_dim, ghost_dim = -1, num_layers, addl_ents = 0;
00127     result = opts.get_str_option( "PARALLEL_GHOSTS", ghost_str );
00128     if( MB_TYPE_OUT_OF_RANGE == result )
00129     {
00130         ghost_dim  = 3;
00131         bridge_dim = 0;
00132         num_layers = 1;
00133     }
00134     else if( MB_SUCCESS == result )
00135     {
00136         int num_fields = sscanf( ghost_str.c_str(), "%d.%d.%d.%d", &ghost_dim, &bridge_dim, &num_layers, &addl_ents );
00137         if( 3 > num_fields )
00138         {
00139             MB_SET_ERR( MB_FAILURE, "Didn't read 3 fields from PARALLEL_GHOSTS string" );
00140         }
00141     }
00142
00143     // Get resolve_shared_ents option
00144     std::string shared_str;
00145     int resolve_dim = -2, shared_dim = -1;
00146     result = opts.get_str_option( "PARALLEL_RESOLVE_SHARED_ENTS", shared_str );
00147     if( MB_TYPE_OUT_OF_RANGE == result )
00148     {
00149         resolve_dim = -1;
00150         shared_dim  = -1;
00151     }
00152     else if( MB_SUCCESS == result )
00153     {
00154         int num_fields = sscanf( shared_str.c_str(), "%d.%d", &resolve_dim, &shared_dim );
00155         if( 2 != num_fields )
00156         {
00157             MB_SET_ERR( MB_FAILURE, "Didn't read 2 fields from PARALLEL_RESOLVE_SHARED_ENTS string" );
00158         }
00159     }
00160
00161     // Get skip augmenting with ghosts option
00162     bool skip_augment = false;
00163     result            = opts.get_null_option( "SKIP_AUGMENT_WITH_GHOSTS" );
00164     if( MB_SUCCESS == result ) skip_augment = true;
00165
00166     bool correct_thin_ghosts = false;
00167     result                   = opts.get_null_option( "PARALLEL_THIN_GHOST_LAYER" );
00168     if( MB_SUCCESS == result ) correct_thin_ghosts = true;
00169
00170     // Get MPI IO processor rank
00171     int reader_rank;
00172     result = opts.get_int_option( "MPI_IO_RANK", reader_rank );
00173     if( MB_ENTITY_NOT_FOUND == result )
00174         reader_rank = 0;
00175     else if( MB_SUCCESS != result )
00176     {
00177         MB_SET_ERR( MB_FAILURE, "Unexpected value for 'MPI_IO_RANK' option" );
00178     }
00179
00180     // Now that we've parsed all the parallel options, make an instruction queue
00181     std::vector< int > pa_vec;
00182     bool is_reader = ( reader_rank == (int)myPcomm->proc_config().proc_rank() );
00183
00184     bool partition_by_rank = false;
00185     if( MB_SUCCESS == opts.get_null_option( "PARTITION_BY_RANK" ) )
00186     {
00187         partition_by_rank = true;
00188         if( !partition_tag_vals.empty() )
00189         {
00190             MB_SET_ERR( MB_FAILURE, "Cannot specify both PARTITION_VALS and PARTITION_BY_RANK" );
00191         }
00192     }
00193
00194     double factor_seq;
00195     if( MB_SUCCESS == opts.get_real_option( "PARALLEL_SEQUENCE_FACTOR", factor_seq ) )
00196     {
00197         if( factor_seq < 1. ) MB_SET_ERR( MB_FAILURE, "cannot have sequence factor less than 1." );
00198         mbImpl->set_sequence_multiplier( factor_seq );
00199     }
00200     switch( parallel_mode )
00201     {
00202         case POPT_BCAST:
00203             myDebug.print( 1, "Read mode is BCAST\n" );
00204             if( is_reader )
00205             {
00206                 pa_vec.push_back( PA_READ );
00207                 pa_vec.push_back( PA_CHECK_GIDS_SERIAL );
00208                 pa_vec.push_back( PA_GET_FILESET_ENTS );
00209             }
00210             pa_vec.push_back( PA_BROADCAST );
00211             if( !is_reader ) pa_vec.push_back( PA_GET_FILESET_ENTS );
00212             break;
00213
00214         case POPT_BCAST_DELETE:
00215             myDebug.print( 1, "Read mode is BCAST_DELETE\n" );
00216             if( is_reader )
00217             {
00218                 pa_vec.push_back( PA_READ );
00219                 pa_vec.push_back( PA_CHECK_GIDS_SERIAL );
00220                 pa_vec.push_back( PA_GET_FILESET_ENTS );
00221                 if( create_trivial_partition ) pa_vec.push_back( PA_CREATE_TRIVIAL_PARTITION );
00222             }
00223             pa_vec.push_back( PA_BROADCAST );
00224             if( !is_reader ) pa_vec.push_back( PA_GET_FILESET_ENTS );
00225             pa_vec.push_back( PA_DELETE_NONLOCAL );
00226             break;
00227
00228         case POPT_DEFAULT:
00229         case POPT_READ_DELETE:
00230             myDebug.print( 1, "Read mode is READ_DELETE\n" );
00231             pa_vec.push_back( PA_READ );
00232             pa_vec.push_back( PA_CHECK_GIDS_SERIAL );
00233             pa_vec.push_back( PA_GET_FILESET_ENTS );
00234             pa_vec.push_back( PA_DELETE_NONLOCAL );
00235             break;
00236
00237         case POPT_READ_PART:
00238             myDebug.print( 1, "Read mode is READ_PART\n" );
00239             pa_vec.push_back( PA_READ_PART );
00240             break;
00241
00242         default:
00243             MB_SET_ERR( MB_FAILURE, "Unexpected parallel read mode" );
00244     }
00245
00246     if( -2 != resolve_dim ) pa_vec.push_back( PA_RESOLVE_SHARED_ENTS );
00247
00248     if( -1 != ghost_dim ) pa_vec.push_back( PA_EXCHANGE_GHOSTS );
00249
00250     if( -2 != resolve_dim )
00251     {
00252         pa_vec.push_back( PA_RESOLVE_SHARED_SETS );
00253         if( -1 != ghost_dim && !skip_augment ) pa_vec.push_back( PA_AUGMENT_SETS_WITH_GHOSTS );
00254         if( -1 != ghost_dim && correct_thin_ghosts ) pa_vec.push_back( PA_CORRECT_THIN_GHOSTS );
00255     }
00256
00257     if( print_parallel ) pa_vec.push_back( PA_PRINT_PARALLEL );
00258
00259     result = load_file( file_names, num_files, file_set, parallel_mode, partition_tag_name, partition_tag_vals, distrib,
00260                         partition_by_rank, pa_vec, opts, subset_list, file_id_tag, reader_rank, cputime, resolve_dim,
00261                         shared_dim, ghost_dim, bridge_dim, num_layers, addl_ents );MB_CHK_ERR( result );
00262
00263     if( parallel_mode == POPT_BCAST_DELETE && !is_reader ) opts.mark_all_seen();
00264
00265     return MB_SUCCESS;
00266 }
00267
00268 ErrorCode ReadParallel::load_file( const char** file_names,
00269                                    const int num_files,
00270                                    const EntityHandle* file_set_ptr,
00271                                    int /*parallel_mode*/,
00272                                    std::string& partition_tag_name,
00273                                    std::vector< int >& partition_tag_vals,
00274                                    bool distrib,
00275                                    bool partition_by_rank,
00276                                    std::vector< int >& pa_vec,
00277                                    const FileOptions& opts,
00278                                    const ReaderIface::SubsetList* subset_list,
00279                                    const Tag* file_id_tag,
00280                                    const int reader_rank,
00281                                    const bool cputime,
00282                                    const int resolve_dim,
00283                                    const int shared_dim,
00284                                    const int ghost_dim,
00285                                    const int bridge_dim,
00286                                    const int num_layers,
00287                                    const int addl_ents )
00288 {
00289     ErrorCode result = MB_SUCCESS;
00290     if( myPcomm == NULL ) myPcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
00291
00292     Range entities;
00293     Tag file_set_tag = 0;
00294     int other_sets   = 0;
00295     ReaderWriterSet::iterator iter;
00296     Range other_file_sets, file_sets;
00297     Core* impl = dynamic_cast< Core* >( mbImpl );
00298
00299     std::vector< double > act_times( pa_vec.size() + 1 );
00300     std::vector< int >::iterator vit;
00301     int i, j;
00302     act_times[0] = MPI_Wtime();
00303
00304     // Make a new set for the parallel read
00305     EntityHandle file_set;
00306     if( !file_set_ptr || !( *file_set_ptr ) )
00307     {
00308         result = mbImpl->create_meshset( MESHSET_SET, file_set );MB_CHK_SET_ERR( result, "Trouble creating file set" );
00309     }
00310     else
00311         file_set = *file_set_ptr;
00312
00313     bool i_read     = false;
00314     Tag id_tag      = 0;
00315     bool use_id_tag = false;
00316     Range ents;
00317
00318     for( i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); ++vit, i++ )
00319     {
00320         ErrorCode tmp_result = MB_SUCCESS;
00321         switch( *vit )
00322         {
00323                 //==================
00324             case PA_READ:
00325                 i_read = true;
00326
00327                 for( j = 0; j < num_files; j++ )
00328                 {
00329                     myDebug.tprintf( 1, "Reading file: \"%s\"\n", file_names[j] );
00330
00331                     EntityHandle new_file_set;
00332                     result = mbImpl->create_meshset( MESHSET_SET, new_file_set );MB_CHK_SET_ERR( result, "Trouble creating file set" );
00333                     tmp_result = impl->serial_load_file( file_names[j], &new_file_set, opts, subset_list, file_id_tag );
00334                     if( MB_SUCCESS != tmp_result ) break;
00335
00336                     // Put the contents of each file set for the reader into the
00337                     // file set for the parallel read
00338                     assert( 0 != new_file_set );
00339                     Range all_ents;
00340                     tmp_result = mbImpl->get_entities_by_handle( new_file_set, all_ents );
00341                     if( MB_SUCCESS != tmp_result ) break;
00342                     all_ents.insert( new_file_set );
00343                     tmp_result = mbImpl->add_entities( file_set, all_ents );
00344                     if( MB_SUCCESS != tmp_result ) break;
00345                 }
00346                 if( MB_SUCCESS != tmp_result ) break;
00347
00348                 // Mark the file set for this parallel reader
00349                 tmp_result = mbImpl->tag_get_handle( "__file_set", 1, MB_TYPE_INTEGER, file_set_tag,
00350                                                      MB_TAG_SPARSE | MB_TAG_CREAT );
00351                 if( MB_SUCCESS != tmp_result ) break;
00352
00353                 tmp_result = mbImpl->tag_set_data( file_set_tag, &file_set, 1, &other_sets );
00354                 break;
00355
00356                 //==================
00357             case PA_READ_PART: {
00358                 myDebug.tprintf( 1, "Reading file: \"%s\"\n", file_names[0] );
00359
00360                 i_read = true;
00361                 if( num_files != 1 )
00362                 {
00363                     MB_SET_ERR( MB_NOT_IMPLEMENTED, "Multiple file read not supported for READ_PART" );
00364                 }
00365
00366                 // If we're going to resolve shared entities, then we need
00367                 // to ask the file reader to populate a tag with unique ids
00368                 // (typically file ids/indices/whatever.)
00369                 if( std::find( pa_vec.begin(), pa_vec.end(), PA_RESOLVE_SHARED_ENTS ) != pa_vec.end() )
00370                 {
00371                     use_id_tag = true;
00372                     if( !file_id_tag )
00373                     {
00374                         // This tag is really used for resolving shared entities with crystal router
00375                         // In the end, this is an identifier that gets converted to long
00376                         // In hdf5 file reader, we also convert from hdf5 file id type to long
00377                         tmp_result = mbImpl->tag_get_handle( "", sizeof( long ), MB_TYPE_OPAQUE, id_tag,
00378                                                              MB_TAG_DENSE | MB_TAG_CREAT );
00379                         if( MB_SUCCESS != tmp_result ) break;
00380                         file_id_tag = &id_tag;
00381                     }
00382                 }
00383
00384                 ReaderIface::IDTag parts = { partition_tag_name.c_str(), 0, 0 };
00385                 ReaderIface::SubsetList sl;
00386                 sl.num_parts = 0;
00387                 int rank     = myPcomm->rank();
00388                 if( partition_by_rank )
00389                 {
00390                     assert( partition_tag_vals.empty() );
00391                     parts.tag_values     = &rank;
00392                     parts.num_tag_values = 1;
00393                 }
00394                 else
00395                 {
00396                     sl.num_parts   = myPcomm->size();
00397                     sl.part_number = myPcomm->rank();
00398                     if( !partition_tag_vals.empty() )
00399                     {
00400                         parts.tag_values     = &partition_tag_vals[0];
00401                         parts.num_tag_values = partition_tag_vals.size();
00402                     }
00403                 }
00404                 std::vector< ReaderIface::IDTag > subset;
00405                 if( subset_list )
00406                 {
00407                     std::vector< ReaderIface::IDTag > tmplist( subset_list->tag_list,
00408        subset_list->tag_list + subset_list->tag_list_length );
00409                     tmplist.push_back( parts );
00410                     subset.swap( tmplist );
00411                     sl.tag_list        = &subset[0];
00412                     sl.tag_list_length = subset.size();
00413                 }
00414                 else
00415                 {
00416                     sl.tag_list        = &parts;
00417                     sl.tag_list_length = 1;
00418                 }
00419                 tmp_result = impl->serial_load_file( *file_names, &file_set, opts, &sl, file_id_tag );
00420                 if( MB_SUCCESS != tmp_result ) break;
00421
00422                 if( !partition_tag_name.empty() )
00423                 {
00424                     Tag part_tag;
00425                     tmp_result = impl->tag_get_handle( partition_tag_name.c_str(), 1, MB_TYPE_INTEGER, part_tag );
00426                     if( MB_SUCCESS != tmp_result ) break;
00427
00428                     tmp_result = impl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &part_tag, 0, 1,
00429        myPcomm->partition_sets() );
00430                 }
00431             }
00432             break;
00433
00434                 //==================
00435             case PA_GET_FILESET_ENTS:
00436                 myDebug.tprint( 1, "Getting fileset entities.\n" );
00437
00438                 // Get entities in the file set, and add actual file set to it;
00439                 // mark the file set to make sure any receiving procs know which it is
00440                 tmp_result = mbImpl->get_entities_by_handle( file_set, entities );
00441                 if( MB_SUCCESS != tmp_result )
00442                 {
00443                     entities.clear();
00444                     break;
00445                 }
00446
00447                 // Add actual file set to entities too
00448                 entities.insert( file_set );
00449                 break;
00450                 //==================
00451             case PA_CREATE_TRIVIAL_PARTITION: {
00452                 myDebug.tprint( 1, "create trivial partition, for higher dim entities.\n" );
00453                 // get high dim entities (2 or 3)
00454                 Range hi_dim_ents = entities.subset_by_dimension( 3 );
00455                 if( hi_dim_ents.empty() ) hi_dim_ents = entities.subset_by_dimension( 2 );
00456                 if( hi_dim_ents.empty() ) hi_dim_ents = entities.subset_by_dimension( 1 );
00457                 if( hi_dim_ents.empty() ) MB_SET_ERR( MB_FAILURE, "there are no elements of dim 1-3" );
00458
00459                 size_t num_hi_ents     = hi_dim_ents.size();
00460                 unsigned int num_parts = myPcomm->size();
00461
00462                 // create first the trivial partition tag
00463                 int dum_id = -1;
00464                 Tag ttag;  // trivial tag
00465                 tmp_result = mbImpl->tag_get_handle( partition_tag_name.c_str(), 1, MB_TYPE_INTEGER, ttag,
00466                                                      MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id );MB_CHK_SET_ERR( tmp_result, "Can't create trivial partition tag" );
00467
00468                 // Compute the number of high dim entities on each part
00469                 size_t nPartEnts = num_hi_ents / num_parts;
00470
00471                 // Number of extra entities after equal split over parts
00472                 int iextra          = num_hi_ents % num_parts;
00473                 Range::iterator itr = hi_dim_ents.begin();
00474                 for( int k = 0; k < (int)num_parts; k++ )
00475                 {
00476                     // create a mesh set, insert a subrange of entities
00477                     EntityHandle part_set;
00478                     tmp_result = mbImpl->create_meshset( MESHSET_SET, part_set );MB_CHK_SET_ERR( tmp_result, "Can't create part set" );
00479                     entities.insert( part_set );
00480
00481                     tmp_result = mbImpl->tag_set_data( ttag, &part_set, 1, &k );MB_CHK_SET_ERR( tmp_result, "Can't set trivial partition tag" );
00482                     Range subrange;
00483                     size_t num_ents_in_part = nPartEnts;
00484                     if( i < iextra ) num_ents_in_part++;
00485                     for( size_t i1 = 0; i1 < num_ents_in_part; i1++, itr++ )
00486                         subrange.insert( *itr );
00487                     tmp_result = mbImpl->add_entities( part_set, subrange );MB_CHK_SET_ERR( tmp_result, "Can't add entities to trivial part " << k );
00488                     myDebug.tprintf( 1, "create trivial part %d with %lu entities \n", k, num_ents_in_part );
00489                     tmp_result = mbImpl->add_entities( file_set, &part_set, 1 );MB_CHK_SET_ERR( tmp_result, "Can't add trivial part to file set " << k );
00490                 }
00491             }
00492
00493             break;
00494                 //==================
00495             case PA_BROADCAST:
00496                 // Do the actual broadcast; if single-processor, ignore error
00497                 myDebug.tprint( 1, "Broadcasting mesh.\n" );
00498
00499                 if( myPcomm->proc_config().proc_size() > 1 )
00500                 {
00501                     tmp_result = myPcomm->broadcast_entities( reader_rank, entities );
00502                     if( MB_SUCCESS != tmp_result ) break;
00503                 }
00504
00505                 if( debug )
00506                 {
00507                     std::cerr << "Bcast done; entities:" << std::endl;
00508                     mbImpl->list_entities( 0, 0 );
00509                 }
00510
00511                 // Add the received entities to this fileset if I wasn't the reader
00512                 if( !i_read && MB_SUCCESS == tmp_result ) tmp_result = mbImpl->add_entities( file_set, entities );
00513
00514                 break;
00515
00516                 //==================
00517             case PA_DELETE_NONLOCAL:
00518                 myDebug.tprint( 1, "Deleting nonlocal entities.\n" );
00519
00520                 tmp_result = delete_nonlocal_entities( partition_tag_name, partition_tag_vals, distrib, file_set );
00521                 if( debug )
00522                 {
00523                     std::cerr << "Delete nonlocal done; entities:" << std::endl;
00524                     mbImpl->list_entities( 0, 0 );
00525                 }
00526
00527                 if( MB_SUCCESS == tmp_result ) tmp_result = create_partition_sets( partition_tag_name, file_set );
00528
00529                 break;
00530
00531                 //==================
00532             case PA_CHECK_GIDS_SERIAL:
00533                 myDebug.tprint( 1, "Checking global IDs.\n" );
00534
00535                 tmp_result = myPcomm->check_global_ids( file_set, 0, 1, true, false );
00536                 break;
00537
00538                 //==================
00539             case PA_RESOLVE_SHARED_ENTS:
00540                 myDebug.tprint( 1, "Resolving shared entities.\n" );
00541
00542                 if( 1 == myPcomm->size() )
00543                     tmp_result = MB_SUCCESS;
00544                 else
00545                     tmp_result =
00546                         myPcomm->resolve_shared_ents( file_set, resolve_dim, shared_dim, use_id_tag ? file_id_tag : 0 );
00547                 if( MB_SUCCESS != tmp_result ) break;
00548
00549 #ifndef NDEBUG
00550                 // check number of owned vertices through pcomm's public interface
00551                 tmp_result = mbImpl->get_entities_by_type( 0, MBVERTEX, ents );
00552                 if( MB_SUCCESS == tmp_result )
00553                     tmp_result = myPcomm->filter_pstatus( ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );
00554                 if( MB_SUCCESS == tmp_result )
00555                     myDebug.tprintf( 1, "Proc %u reports %lu owned vertices.\n", myPcomm->proc_config().proc_rank(),
00556                                      ents.size() );
00557 #endif
00558                 break;
00559
00560                 //==================
00561             case PA_EXCHANGE_GHOSTS:
00562                 myDebug.tprint( 1, "Exchanging ghost entities.\n" );
00563
00564                 tmp_result = myPcomm->exchange_ghost_cells( ghost_dim, bridge_dim, num_layers, addl_ents, true, true,
00565                                                             &file_set );
00566                 break;
00567
00568                 //==================
00569             case PA_RESOLVE_SHARED_SETS:
00570                 myDebug.tprint( 1, "Resolving shared sets.\n" );
00571
00572                 if( 1 == myPcomm->size() )
00573                     tmp_result = MB_SUCCESS;
00574                 else
00575                     tmp_result = myPcomm->resolve_shared_sets( file_set, use_id_tag ? file_id_tag : 0 );
00576                 break;
00577
00578                 //==================
00579             case PA_AUGMENT_SETS_WITH_GHOSTS:
00580                 myDebug.tprint( 1, "Augmenting sets with ghost entities.\n" );
00581
00582                 if( 1 == myPcomm->size() )
00583                     tmp_result = MB_SUCCESS;
00584                 else
00585                     tmp_result = myPcomm->augment_default_sets_with_ghosts( file_set );
00586                 break;
00587                 //==================
00588             case PA_CORRECT_THIN_GHOSTS:
00589                 myDebug.tprint( 1, "correcting thin ghost layers.\n" );
00590                 if( 2 >= myPcomm->size() )  // it is a problem only for multi-shared entities
00591                     tmp_result = MB_SUCCESS;
00592                 else
00593                     tmp_result = myPcomm->correct_thin_ghost_layers();
00594                 break;
00595             case PA_PRINT_PARALLEL:
00596                 myDebug.tprint( 1, "Printing parallel information.\n" );
00597
00598                 tmp_result = myPcomm->list_entities( 0, -1 );
00599                 break;
00600
00601                 //==================
00602             default:
00603                 MB_SET_ERR( MB_FAILURE, "Unexpected parallel action" );
00604         }  // switch (*vit)
00605
00606         if( MB_SUCCESS != tmp_result )
00607         {
00608             MB_SET_ERR( MB_FAILURE, "Failed in step " << ParallelActionsNames[*vit] );
00609         }
00610
00611         if( cputime ) act_times[i] = MPI_Wtime();
00612     }  // for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); ++vit, i++)
00613
00614     if( use_id_tag )
00615     {
00616         result = mbImpl->tag_delete( id_tag );MB_CHK_SET_ERR( result, "Trouble deleting id tag" );
00617     }
00618
00619     if( cputime )
00620     {
00621         for( i = pa_vec.size(); i > 0; i-- )
00622             act_times[i] -= act_times[i - 1];
00623
00624         // Replace initial time with overall time
00625         act_times[0] = MPI_Wtime() - act_times[0];
00626         // Get the maximum over all procs
00627         if( 0 != myPcomm->proc_config().proc_rank() )
00628         {
00629             MPI_Reduce( &act_times[0], 0, pa_vec.size() + 1, MPI_DOUBLE, MPI_MAX, 0,
00630                         myPcomm->proc_config().proc_comm() );
00631         }
00632         else
00633         {
00634 #if( MPI_VERSION >= 2 )
00635             MPI_Reduce( MPI_IN_PLACE, &act_times[0], pa_vec.size() + 1, MPI_DOUBLE, MPI_MAX, 0,
00636                         myPcomm->proc_config().proc_comm() );
00637 #else
00638             // Note, extra comm-size allocation is required
00639             std::vector< double > act_times_tmp( pa_vec.size() + 1 );
00640             MPI_Reduce( &act_times[0], &act_times_tmp[0], pa_vec.size() + 1, MPI_DOUBLE, MPI_MAX, 0,
00641                         myPcomm->proc_config().proc_comm() );
00642             act_times = act_times_tmp;  // extra copy here too
00643 #endif
00644             std::cout << "Parallel Read times: " << std::endl;
00645             for( i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); ++vit, i++ )
00646                 std::cout << "  " << act_times[i] << " " << ParallelActionsNames[*vit] << std::endl;
00647             std::cout << "  " << act_times[0] << " PARALLEL TOTAL" << std::endl;
00648         }
00649     }
00650
00651     return MB_SUCCESS;
00652 }
00653
00654 ErrorCode ReadParallel::delete_nonlocal_entities( std::string& ptag_name,
00655                                                   std::vector< int >& ptag_vals,
00656                                                   bool distribute,
00657                                                   EntityHandle file_set )
00658 {
00659     Range partition_sets;
00660
00661     Tag ptag;
00662     ErrorCode result = mbImpl->tag_get_handle( ptag_name.c_str(), 1, MB_TYPE_INTEGER, ptag );MB_CHK_SET_ERR( result, "Failed getting tag handle in delete_nonlocal_entities" );
00663
00664     result = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &ptag, NULL, 1, myPcomm->partition_sets() );MB_CHK_SET_ERR( result, "Failed to get sets with partition-type tag" );
00665
00666     int proc_sz = myPcomm->proc_config().proc_size();
00667     int proc_rk = myPcomm->proc_config().proc_rank();
00668
00669     if( !ptag_vals.empty() )
00670     {
00671         // Values input, get sets with those values
00672         Range tmp_sets;
00673         std::vector< int > tag_vals( myPcomm->partition_sets().size() );
00674         result = mbImpl->tag_get_data( ptag, myPcomm->partition_sets(), &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to get tag data for partition vals tag" );
00675         for( std::vector< int >::iterator pit = tag_vals.begin(); pit != tag_vals.end(); ++pit )
00676         {
00677             std::vector< int >::iterator pit2 = std::find( ptag_vals.begin(), ptag_vals.end(), *pit );
00678             if( pit2 != ptag_vals.end() ) tmp_sets.insert( myPcomm->partition_sets()[pit - tag_vals.begin()] );
00679         }
00680
00681         myPcomm->partition_sets().swap( tmp_sets );
00682     }
00683
00684     if( distribute )
00685     {
00686         // For now, require that number of partition sets be greater
00687         // than number of procs
00688         if( myPcomm->partition_sets().size() < (unsigned int)proc_sz )
00689         {
00690             MB_SET_ERR( MB_FAILURE, "Too few parts; P = " << proc_rk << ", tag = " << ptag
00691                                                           << ", # sets = " << myPcomm->partition_sets().size() );
00692         }
00693
00694         Range tmp_sets;
00695         // Distribute the partition sets
00696         unsigned int num_sets     = myPcomm->partition_sets().size() / proc_sz;
00697         unsigned int num_leftover = myPcomm->partition_sets().size() % proc_sz;
00698         int begin_set             = 0;
00699         if( proc_rk < (int)num_leftover )
00700         {
00701             num_sets++;
00702             begin_set = num_sets * proc_rk;
00703         }
00704         else
00705             begin_set = proc_rk * num_sets + num_leftover;
00706
00707         for( unsigned int i = 0; i < num_sets; i++ )
00708             tmp_sets.insert( myPcomm->partition_sets()[begin_set + i] );
00709
00710         myPcomm->partition_sets().swap( tmp_sets );
00711     }
00712
00713     myDebug.print( 1, "My partition sets: ", myPcomm->partition_sets() );
00714
00715     result = delete_nonlocal_entities( file_set );MB_CHK_ERR( result );
00716
00717     return MB_SUCCESS;
00718 }
00719
00720 ErrorCode ReadParallel::create_partition_sets( std::string& ptag_name, EntityHandle file_set )
00721 {
00722     int proc_rk      = myPcomm->proc_config().proc_rank();
00723     ErrorCode result = MB_SUCCESS;
00724
00725     Tag ptag;
00726
00727     // Tag the partition sets with a standard tag name
00728     if( ptag_name.empty() ) ptag_name = PARALLEL_PARTITION_TAG_NAME;
00729     bool tag_created = false;
00730     result = mbImpl->tag_get_handle( ptag_name.c_str(), 1, MB_TYPE_INTEGER, ptag, MB_TAG_SPARSE | MB_TAG_CREAT, 0,
00731                                      &tag_created );MB_CHK_SET_ERR( result, "Trouble getting PARALLEL_PARTITION tag" );
00732
00733     if( !tag_created )
00734     {
00735         // This tag already exists; better check to see that tagged sets
00736         // agree with this partition
00737         Range tagged_sets;
00738         int* proc_rk_ptr = &proc_rk;
00739         result = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &ptag, (const void* const*)&proc_rk_ptr,
00740                                                        1, tagged_sets );MB_CHK_SET_ERR( result, "Trouble getting tagged sets" );
00741         if( !tagged_sets.empty() && tagged_sets != myPcomm->partition_sets() )
00742         {
00743             result = mbImpl->tag_delete_data( ptag, tagged_sets );MB_CHK_SET_ERR( result, "Trouble deleting data of PARALLEL_PARTITION tag" );
00744         }
00745         else if( tagged_sets == myPcomm->partition_sets() )
00746             return MB_SUCCESS;
00747     }
00748
00749     // If we get here, we need to assign the tag
00750     std::vector< int > values( myPcomm->partition_sets().size() );
00751     for( unsigned int i = 0; i < myPcomm->partition_sets().size(); i++ )
00752         values[i] = proc_rk;
00753     result = mbImpl->tag_set_data( ptag, myPcomm->partition_sets(), &values[0] );MB_CHK_SET_ERR( result, "Trouble setting data to PARALLEL_PARTITION tag" );
00754
00755     return MB_SUCCESS;
00756 }
00757
00758 ErrorCode ReadParallel::delete_nonlocal_entities( EntityHandle file_set )
00759 {
00760     // Get partition entities and ents related to/used by those
00761     // get ents in the partition
00762     ReadUtilIface* read_iface;
00763     mbImpl->query_interface( read_iface );
00764     Range partition_ents, all_sets;
00765
00766     myDebug.tprint( 2, "Gathering related entities.\n" );
00767
00768     ErrorCode result = read_iface->gather_related_ents( myPcomm->partition_sets(), partition_ents, &file_set );MB_CHK_SET_ERR( result, "Failure gathering related entities" );
00769
00770     // Get pre-existing entities
00771     Range file_ents;
00772     result = mbImpl->get_entities_by_handle( file_set, file_ents );MB_CHK_SET_ERR( result, "Couldn't get pre-existing entities" );
00773
00774     if( 0 == myPcomm->proc_config().proc_rank() )
00775     {
00776         myDebug.print( 2, "File entities: ", file_ents );
00777     }
00778
00779     // Get deletable entities by subtracting partition ents from file ents
00780     Range deletable_ents = subtract( file_ents, partition_ents );
00781
00782     // Cache deletable vs. keepable sets
00783     Range deletable_sets = deletable_ents.subset_by_type( MBENTITYSET );
00784     Range keepable_sets  = subtract( file_ents.subset_by_type( MBENTITYSET ), deletable_sets );
00785
00786     myDebug.tprint( 2, "Removing deletable entities from keepable sets.\n" );
00787
00788     // Remove deletable ents from all keepable sets
00789     for( Range::iterator rit = keepable_sets.begin(); rit != keepable_sets.end(); ++rit )
00790     {
00791         result = mbImpl->remove_entities( *rit, deletable_ents );MB_CHK_SET_ERR( result, "Failure removing deletable entities" );
00792     }
00793     result = mbImpl->remove_entities( file_set, deletable_ents );MB_CHK_SET_ERR( result, "Failure removing deletable entities" );
00794
00795     myDebug.tprint( 2, "Deleting deletable entities.\n" );
00796
00797     if( 0 == myPcomm->proc_config().proc_rank() )
00798     {
00799         myDebug.print( 2, "Deletable sets: ", deletable_sets );
00800     }
00801
00802     // Delete sets, then ents
00803     if( !deletable_sets.empty() )
00804     {
00805         result = mbImpl->delete_entities( deletable_sets );MB_CHK_SET_ERR( result, "Failure deleting sets in delete_nonlocal_entities" );
00806     }
00807
00808     deletable_ents -= deletable_sets;
00809
00810     if( 0 == myPcomm->proc_config().proc_rank() )
00811     {
00812         myDebug.print( 2, "Deletable entities: ", deletable_ents );
00813     }
00814
00815     if( !deletable_ents.empty() )
00816     {
00817         result = mbImpl->delete_entities( deletable_ents );MB_CHK_SET_ERR( result, "Failure deleting entities in delete_nonlocal_entities" );
00818     }
00819
00820     return MB_SUCCESS;
00821 }
00822
00823 }  // namespace moab
