ReadUtil.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifndef MB_READ_UTIL_HPP
00017 #define MB_READ_UTIL_HPP
00018
00019 #ifndef IS_BUILDING_MB
00020 #error "ReadUtil.hpp isn't supposed to be included into an application"
00021 #endif
00022
00023 #include "moab/ReadUtilIface.hpp"
00024
00025 namespace moab
00026 {
00027
00028 class Core;
00029 class Error;
00030
00031 class ReadUtil : public ReadUtilIface
00032 {
00033   private:
00034     //! Pointer to the Core
00035     Core* mMB;
00036
00037   public:
00038     //! Constructor takes Core pointer
00039     ReadUtil( Core* mdb, Error* error_handler );
00040
00041     //! Destructor
00042     ~ReadUtil() {}
00043
00044     //! Get arrays for coordinate data from the MB
00045     ErrorCode get_node_coords( const int num_arrays,
00046                                const int num_nodes,
00047                                const int preferred_start_id,
00048                                EntityHandle& actual_start_handle,
00049                                std::vector< double* >& arrays,
00050                                int sequence_size = -1 );
00051
00052     //! Get array for connectivity data from the MB
00053     ErrorCode get_element_connect( const int num_elements,
00054                                    const int verts_per_element,
00055                                    const EntityType mdb_type,
00056                                    const int preferred_start_id,
00057                                    EntityHandle& actual_start_handle,
00058                                    EntityHandle*& array,
00059                                    int sequence_size = -1 );
00060
00061     /**
00062      *\brief Gather entities related to those in the partition
00063      * Gather entities related to those in the input partition. Related
00064      * means down-adjacent to, contained in, etc.
00065      * \param partition Entities for which to gather related entities
00066      * \param related_ents Related entities
00067      * \param all_sets If non-NULL, all sets in mesh instance are returned
00068      * in the pointed-to range
00069      */
00070     ErrorCode gather_related_ents( Range& partition, Range& related_ents, EntityHandle* file_set = NULL );
00071
00072     ErrorCode create_entity_sets( EntityID num_sets,
00073                                   const unsigned* set_flags,
00074                                   EntityID preffered_start_id,
00075                                   EntityHandle& actual_start_handle );
00076
00077     //! Tell MB which elements have been added to the database
00078     ErrorCode update_adjacencies( const EntityHandle start_handle,
00079                                   const int number_elements,
00080                                   const int number_vertices_per_element,
00081                                   const EntityHandle* conn_array );
00082
00083     //! Given an ordered list of bounding entities and the sense of
00084     //! those entities, return an ordered list of vertices
00085     ErrorCode get_ordered_vertices( EntityHandle* bound_ents,
00086                                     int* sense,
00087                                     int num_bound,
00088                                     int dim,
00089                                     EntityHandle* bound_verts,
00090                                     EntityType& etype );
00091
00092     ErrorCode assign_ids( Tag id_tag, const Range& ents, int start = 0 );
00093
00094     ErrorCode assign_ids( Tag id_tag, const EntityHandle* ents, size_t num_ents, int start = 0 );
00095
00096     //! Create a new gather set with tag GATHER_SET
00097     ErrorCode create_gather_set( EntityHandle& gather_set );
00098
00099     //! Get entity handle of an existing gather set
00100     ErrorCode get_gather_set( EntityHandle& gather_set );
00101 };
00102
00103 }  // namespace moab
00104
00105 #endif
