ReadWriteTest.cpp File Reference
#include "moab/Core.hpp"
#include <iostream>
#include <ctime>
+ Include dependency graph for ReadWriteTest.cpp:
Functions
int main (int argc, char **argv)
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 25 of file ReadWriteTest.cpp.
References moab::Interface::create_meshset(), ErrorCode, input_file, moab::Interface::load_file(), mb, MB_CHK_ERR, MESH_DIR, MESHSET_SET, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), and moab::Interface::write_file().
#ifdef MOAB_HAVE_MPI
    string input_file, output_file, read_opts, write_opts;
    MPI_Init( &argc, &argv );
    // Need option handling here for input filename
    if( argc < 3 )
#ifdef MOAB_HAVE_NETCDF
        input_file  = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" );
        output_file = "ReadWriteTestOut.h5m";
        read_opts   = "PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U";
        write_opts  = "PARALLEL=WRITE_PART";
#else
        cout << "Usage: mpiexec -n $NP ReadWriteTest [input] [output] -O <read_opts> -o "
                "<write_opts>\n";
        return 0;
#endif
    else
        input_file  = argv[1];
        output_file = argv[2];
    if( argc > 3 )
        int index = 3;
        while( index < argc )
            if( !strcmp( argv[index], "-O" ) )  // This is for reading options, optional
                read_opts = argv[++index];
            if( !strcmp( argv[index], "-o" ) ) write_opts = argv[++index];
            index++;
    // Get MOAB instance
    Interface* mb = new( std::nothrow ) Core;
    if( NULL == mb ) return 1;
    // Get the ParallelComm instance
    ParallelComm* pcomm = new ParallelComm( mb, MPI_COMM_WORLD );
    int nprocs          = pcomm->proc_config().proc_size();
    int rank            = pcomm->proc_config().proc_rank();
    EntityHandle set;
    ErrorCode rval = mb->create_meshset( MESHSET_SET, set );MB_CHK_ERR( rval );
    clock_t tt = clock();
    if( 0 == rank )
        cout << "Reading file " << input_file << "\n with options: " << read_opts << "\n on " << nprocs
             << " processors\n";
    // Read the file with the specified options
    rval = mb->load_file( input_file.c_str(), &set, read_opts.c_str() );MB_CHK_ERR( rval );
    if( 0 == rank )
        cout << "Time: " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl;
        tt = clock();
    // Write back the file with the specified options
    rval = mb->write_file( output_file.c_str(), 0, write_opts.c_str(), &set, 1 );MB_CHK_ERR( rval );
    if( 0 == rank )
        cout << "Writing file " << output_file << "\n with options: " << write_opts << endl;
        tt = clock();
    delete mb;
    MPI_Finalize();
#else
    std::cout << " compile MOAB with mpi for this example to work\n";
#endif
    return 0;
