ReadWriteTest.cpp
00001 /** @example ReadWriteTest.cpp \n
00002  * \brief Read mesh into MOAB and write some back \n
00003  *
00004  * <b>To run</b>: mpiexec -np 4 ReadWriteTest [input] [output] -O [read_opts] -o [write_opts]\n
00005  *
00006  * used for stress test of reader/writer
00007  *  report times to read and write
00008  *
00009  *  example ReadWriteTest ../MeshFiles/io/fv3x46x72.t.3.nc out.nc  \
00010  *  -O PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U;  \
00011  *  -o PARALLEL=WRITE_PART;VARIABLE=T,U
00012  */
00013
00014 #include "moab/Core.hpp"
00015 #ifdef MOAB_HAVE_MPI
00016 #include "moab/ParallelComm.hpp"
00017 #include "MBParallelConventions.h"
00018 #endif
00019 #include <iostream>
00020 #include <ctime>
00021
00022 using namespace moab;
00023 using namespace std;
00024
00025 int main( int argc, char** argv )
00026 {
00027 #ifdef MOAB_HAVE_MPI
00028     string input_file, output_file, read_opts, write_opts;
00029
00030     MPI_Init( &argc, &argv );
00031
00032     // Need option handling here for input filename
00033     if( argc < 3 )
00034     {
00035 #ifdef MOAB_HAVE_NETCDF
00036         input_file  = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" );
00037         output_file = "ReadWriteTestOut.h5m";
00038         read_opts   = "PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U";
00039         write_opts  = "PARALLEL=WRITE_PART";
00040 #else
00041         cout << "Usage: mpiexec -n $NP ReadWriteTest [input] [output] -O <read_opts> -o "
00042                 "<write_opts>\n";
00043         return 0;
00044 #endif
00045     }
00046     else
00047     {
00048         input_file  = argv[1];
00049         output_file = argv[2];
00050     }
00051
00052     if( argc > 3 )
00053     {
00054         int index = 3;
00055         while( index < argc )
00056         {
00057             if( !strcmp( argv[index], "-O" ) )  // This is for reading options, optional
00058                 read_opts = argv[++index];
00059             if( !strcmp( argv[index], "-o" ) ) write_opts = argv[++index];
00060             index++;
00061         }
00062     }
00063
00064     // Get MOAB instance
00065     Interface* mb = new( std::nothrow ) Core;
00066     if( NULL == mb ) return 1;
00067
00068     // Get the ParallelComm instance
00069     ParallelComm* pcomm = new ParallelComm( mb, MPI_COMM_WORLD );
00070     int nprocs          = pcomm->proc_config().proc_size();
00071     int rank            = pcomm->proc_config().proc_rank();
00072
00073     EntityHandle set;
00074     ErrorCode rval = mb->create_meshset( MESHSET_SET, set );MB_CHK_ERR( rval );
00075
00076     clock_t tt = clock();
00077
00078     if( 0 == rank )
00079         cout << "Reading file " << input_file << "\n with options: " << read_opts << "\n on " << nprocs
00080              << " processors\n";
00081
00082     // Read the file with the specified options
00083     rval = mb->load_file( input_file.c_str(), &set, read_opts.c_str() );MB_CHK_ERR( rval );
00084
00085     if( 0 == rank )
00086     {
00087         cout << "Time: " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl;
00088         tt = clock();
00089     }
00090
00091     // Write back the file with the specified options
00092     rval = mb->write_file( output_file.c_str(), 0, write_opts.c_str(), &set, 1 );MB_CHK_ERR( rval );
00093
00094     if( 0 == rank )
00095     {
00096         cout << "Writing file " << output_file << "\n with options: " << write_opts << endl;
00097         cout << "Time:  " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl;
00098         tt = clock();
00099     }
00100
00101     delete mb;
00102
00103     MPI_Finalize();
00104 #else
00105     std::cout << " compile MOAB with mpi for this example to work\n";
00106 #endif
00107
00108     return 0;
00109 }
