ReduceExchangeTags.cpp
00001 /** @example ReduceExchangeTags.cpp
00002  * \brief Example program that shows the use case for performing tag data exchange
00003  * between parallel processors in order to sync data on shared entities. The reduction
00004  * operation on tag data is also shown where the user can perform any of the actions supported
00005  * by MPI_Op on data residing on shared entities. \n
00006  *
00007  * <b>This example </b>:
00008  *    -# Initialize MPI and instantiate MOAB
00009  *    -# Get user options: Input mesh file name, tag name (default: USERTAG), tag value
00010  * (default: 1.0)
00011  *    -# Create the root and partition sets
00012  *    -# Instantiate ParallelComm and read the mesh file in parallel using appropriate options
00013  *    -# Create two tags: USERTAG_EXC (exchange) and USERTAG_RED (reduction)
00014  *    -# Set tag data and exchange shared entity information between processors
00015  *      -# Get entities in all dimensions and set local (current rank, dimension) dependent data for
00016  *     exchange tag (USERTAG_EXC)
00017  *      -# Perform exchange of tag data so that data on shared entities are synced via
00018  * ParallelCommunicator.
00019  *    -#  Set tag data and reduce shared entity information between processors using MPI_SUM
00020  *      -#  Get higher dimensional entities in the current partition and set local (current rank)
00021  *     dependent data for reduce tag (USERTAG_EXC)
00022  *      -#  Perform the reduction operation (MPI_SUM) on shared entities via ParallelCommunicator.
00023  *    -#  Destroy the MOAB instance and finalize MPI
00024  *
00025  * <b>To run:</b> \n mpiexec -n 2 ./ReduceExchangeTags <mesh_file> <tag_name> <tag_value> \n
00026  * <b>Example:</b> \n mpiexec -n 2 ./ReduceExchangeTags ../MeshFiles/unittest/64bricks_1khex.h5m
00027  * USERTAG 100 \n
00028  *
00029  */
00030
00031 #include "moab/Core.hpp"
00032 #ifdef MOAB_HAVE_MPI
00033 #include "moab/ParallelComm.hpp"
00034 #endif
00035 #include "MBParallelConventions.h"
00036 #include <iostream>
00037 #include <string>
00038 #include <sstream>
00039
00040 using namespace moab;
00041 using namespace std;
00042
00043 // Error routines for use with MPI API
00044 #define MPICHKERR( CODE, MSG )       \
00045     do                               \
00046     {                                \
00047         if( 0 != ( CODE ) )          \
00048         {                            \
00049             cerr << ( MSG ) << endl; \
00050             MPI_Finalize();          \
00051         }                            \
00052     } while( false )
00053
00054 #define dbgprint( MSG )                      \
00055     do                                       \
00056     {                                        \
00057         if( !rank ) cerr << ( MSG ) << endl; \
00058     } while( false )
00059
00060 #define dbgprintall( MSG )                               \
00061     do                                                   \
00062     {                                                    \
00063         cerr << "[" << rank << "]: " << ( MSG ) << endl; \
00064     } while( false )
00065
00066 // Function to parse input parameters
00067 ErrorCode get_file_options( int argc, char** argv, string& filename, string& tagName, double& tagValues )
00068 {
00069     // Get mesh filename
00070     if( argc > 1 )
00071         filename = string( argv[1] );
00072     else
00073         filename = string( MESH_DIR ) + string( "/64bricks_1khex.h5m" );
00074
00075     // Get tag selection options
00076     if( argc > 2 )
00077         tagName = string( argv[2] );
00078     else
00079         tagName = "USERTAG";
00080
00081     if( argc > 3 )
00082         tagValues = atof( argv[3] );
00083     else
00084         tagValues = 1.0;
00085
00086     return MB_SUCCESS;
00087 }
00088
00089 //
00090 // Start of main test program
00091 //
00092 int main( int argc, char** argv )
00093 {
00094 #ifdef MOAB_HAVE_MPI
00095     ErrorCode err;
00096     int ierr, rank;
00097     string filename, tagName;
00098     double tagValue;
00099     MPI_Comm comm = MPI_COMM_WORLD;
00100     /// Parallel Read options:
00101     ///   PARALLEL = type {READ_PART}
00102     ///   PARTITION = PARALLEL_PARTITION : Partition as you read
00103     ///   PARALLEL_RESOLVE_SHARED_ENTS : Communicate to all processors to get the shared adjacencies
00104     ///   consistently in parallel PARALLEL_GHOSTS : a.b.c
00105     ///                   : a = 3 - highest dimension of entities
00106     ///                   : b = 0 -
00107     ///                   : c = 1 - number of layers
00108     ///   PARALLEL_COMM = index
00109     string read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_"
00110                           "ENTS;PARTITION_DISTRIBUTE;PARALLEL_GHOSTS=3.0.1;PARALLEL_COMM=0";
00111
00112     // Print usage if not enough arguments
00113     if( argc < 1 )
00114     {
00115         cerr << "Usage: ";
00116         cerr << argv[0] << " <file_name> <tag_name> <tag_value>" << endl;
00117         cerr << "file_name    : mesh file name" << endl;
00118         cerr << "tag_name     : name of tag to add to mesh" << endl;
00119         cerr << "tag_value    : a double valued string to set for highest-dimensional entities in "
00120                 "the mesh for the named tag"
00121              << endl;
00122
00123         ierr = MPI_Finalize();
00124         MPICHKERR( ierr, "MPI_Finalize failed; Aborting" );
00125
00126         return 1;
00127     }
00128
00129     // Initialize MPI first
00130     ierr = MPI_Init( &argc, &argv );
00131     MPICHKERR( ierr, "MPI_Init failed" );
00132
00133     ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00134     MPICHKERR( ierr, "MPI_Comm_rank failed" );
00135
00136     dbgprint( "********** reduce_exchange_tags **********\n" );
00137
00138     // Create the moab instance
00139     Interface* mbi = new( std::nothrow ) Core;
00140     if( NULL == mbi ) return 1;
00141
00142     // Get the input options
00143     err = get_file_options( argc, argv, filename, tagName, tagValue );MB_CHK_SET_ERR( err, "get_file_options failed" );
00144
00145     // Print out the input parameters
00146     dbgprint( " Input Parameters - " );
00147     dbgprint( "   Filenames: " << filename );
00148     dbgprint( "   Tag: Name=" << tagName << " Value=" << tagValue << endl );
00149
00150     // Create root sets for each mesh.  Then pass these
00151     // to the load_file functions to be populated.
00152     EntityHandle rootset, partnset;
00153     err = mbi->create_meshset( MESHSET_SET, rootset );MB_CHK_SET_ERR( err, "Creating root set failed" );
00154     err = mbi->create_meshset( MESHSET_SET, partnset );MB_CHK_SET_ERR( err, "Creating partition set failed" );
00155
00156     // Create the parallel communicator object with the partition handle associated with MOAB
00157     ParallelComm* parallel_communicator = ParallelComm::get_pcomm( mbi, partnset, &comm );
00158
00159     // Load the file from disk with given options
00160     err = mbi->load_file( filename.c_str(), &rootset, read_options.c_str() );MB_CHK_SET_ERR( err, "MOAB::load_file failed" );
00161
00162     // Create two tag handles: Exchange and Reduction operations
00163     dbgprint( "-Creating tag handle " << tagName << "..." );
00164     Tag tagReduce, tagExchange;
00165     {
00166         stringstream sstr;
00167         // Create the exchange tag: default name = USERTAG_EXC
00168         sstr << tagName << "_EXC";
00169         err = mbi->tag_get_handle( sstr.str().c_str(), 1, MB_TYPE_INTEGER, tagExchange, MB_TAG_CREAT | MB_TAG_DENSE,
00170                                    &tagValue );MB_CHK_SET_ERR( err, "Retrieving tag handles failed" );
00171
00172         // Create the exchange tag: default name = USERTAG_RED
00173         sstr.str( "" );
00174         sstr << tagName << "_RED";
00175         err = mbi->tag_get_handle( sstr.str().c_str(), 1, MB_TYPE_DOUBLE, tagReduce, MB_TAG_CREAT | MB_TAG_DENSE,
00176                                    &tagValue );MB_CHK_SET_ERR( err, "Retrieving tag handles failed" );
00177     }
00178
00179     // Perform exchange tag data
00180     dbgprint( "-Exchanging tags between processors " );
00181     {
00182         Range partEnts, dimEnts;
00183         for( int dim = 0; dim <= 3; dim++ )
00184         {
00185             // Get all entities of dimension = dim
00186             err = mbi->get_entities_by_dimension( rootset, dim, dimEnts, false );MB_CHK_ERR( err );
00187
00188             vector< int > tagValues( dimEnts.size(), static_cast< int >( tagValue ) * ( rank + 1 ) * ( dim + 1 ) );
00189             // Set local tag data for exchange
00190             err = mbi->tag_set_data( tagExchange, dimEnts, &tagValues[0] );MB_CHK_SET_ERR( err, "Setting local tag data failed during exchange phase" );
00191             // Merge entities into parent set
00192             partEnts.merge( dimEnts );
00193         }
00194
00195         // Exchange tags between processors
00196         err = parallel_communicator->exchange_tags( tagExchange, partEnts );MB_CHK_SET_ERR( err, "Exchanging tags between processors failed" );
00197     }
00198
00199     // Perform reduction of tag data
00200     dbgprint( "-Reducing tags between processors " );
00201     {
00202         Range partEnts;
00203         // Get all higher dimensional entities belonging to current partition
00204         err = parallel_communicator->get_part_entities( partEnts );MB_CHK_SET_ERR( err, "ParallelComm::get_part_entities failed" );
00205
00206         // Output what is in current partition sets
00207         dbgprintall( "Number of Partitioned entities: " << partEnts.size() );
00208         MPI_Barrier( comm );
00209
00210         // Set local tag data for reduction
00211         vector< double > tagValues( partEnts.size(), tagValue * ( rank + 1 ) );
00212         err = mbi->tag_set_data( tagReduce, partEnts, &tagValues[0] );MB_CHK_SET_ERR( err, "Setting local tag data failed during reduce phase" );
00213
00214         Range dummy;
00215         // Reduce tag data using MPI_SUM on the interface between partitions
00216         err = parallel_communicator->reduce_tags( tagReduce, MPI_SUM, dummy /*partEnts*/ );MB_CHK_SET_ERR( err, "Reducing tags between processors failed" );
00217     }
00218     // Write out to output file to visualize reduction/exchange of tag data
00219     err = mbi->write_file( "test.h5m", "H5M", "PARALLEL=WRITE_PART" );MB_CHK_ERR( err );
00220
00221     // Done, cleanup
00222     delete mbi;
00223
00224     dbgprint( "\n********** reduce_exchange_tags DONE! **********" );
00225
00226     MPI_Finalize();
00227 #else
00228     std::cout << " compile with MPI and HDF5 for this example to work \n";
00229 #endif
00230     return 0;
00231 }
