SequenceData.hpp
00001 #ifndef SEQUENCE_DATA_HPP
00002 #define SEQUENCE_DATA_HPP
00003
00004 #include "TypeSequenceManager.hpp"
00005
00006 #include <vector>
00007 #include <cstdlib>
00008 #include <cstring>
00009
00010 namespace moab
00011 {
00012
00013 class SequenceData
00014 {
00015   public:
00016     typedef std::vector< EntityHandle >* AdjacencyDataType;
00017
00018     /**\param num_sequence_arrays Number of data arrays needed by the EntitySequence
00019      * \param start               First handle in this SequenceData
00020      * \param end                 Last handle in this SequenceData
00021      */
00022     inline SequenceData( int num_sequence_arrays, EntityHandle start, EntityHandle end );
00023
00024     virtual ~SequenceData();
00025
00026     /**\return first handle in this sequence data */
00027     EntityHandle start_handle() const
00028     {
00029         return startHandle;
00030     }
00031
00032     /**\return last handle in this sequence data */
00033     EntityHandle end_handle() const
00034     {
00035         return endHandle;
00036     }
00037
00038     EntityID size() const
00039     {
00040         return endHandle + 1 - startHandle;
00041     }
00042
00043     /**\return ith array of EnitySequence-specific data */
00044     void* get_sequence_data( int array_num )
00045     {
00046         return arraySet[-1 - array_num];
00047     }
00048     /**\return ith array of EnitySequence-specific data */
00049     void const* get_sequence_data( int array_num ) const
00050     {
00051         return arraySet[-1 - array_num];
00052     }
00053
00054     /**\return array of adjacency data, or NULL if none. */
00055     AdjacencyDataType* get_adjacency_data()
00056     {
00057         return reinterpret_cast< AdjacencyDataType* >( arraySet[0] );
00058     }
00059     /**\return array of adjacency data, or NULL if none. */
00060     AdjacencyDataType const* get_adjacency_data() const
00061     {
00062         return reinterpret_cast< AdjacencyDataType const* >( arraySet[0] );
00063     }
00064
00065     /**\return array of dense tag data, or NULL if none. */
00066     void* get_tag_data( unsigned tag_num )
00067     {
00068         return tag_num < numTagData ? arraySet[tag_num + 1] : 0;
00069     }
00070     /**\return array of dense tag data, or NULL if none. */
00071     void const* get_tag_data( unsigned tag_num ) const
00072     {
00073         return tag_num < numTagData ? arraySet[tag_num + 1] : 0;
00074     }
00075
00076     /**\brief Allocate array of sequence-specific data
00077      *
00078      * Allocate an array of EntitySequence-specific data.
00079      *\param array_num Index for which to allocate array.
00080      *                 Must be in [0,num_sequence_arrays], where
00081      *                 num_sequence_arrays is constructor argument.
00082      *\param bytes_per_ent  Bytes to allocate for each entity.
00083      *\param initial_val Value to initialize array with.  If non-null, must
00084      *                   be bytes_per_ent long.  If NULL, array will be zeroed.
00085      *\return The newly allocated array, or NULL if error.
00086      */
00087     void* create_sequence_data( int array_num, int bytes_per_ent, const void* initial_val = 0 );
00088
00089     /**\brief Allocate array of sequence-specific data
00090      *
00091      * Allocate an array of EntitySequence-specific data.
00092      *\param array_num Index for which to allocate array.
00093      *                 Must be in [0,num_sequence_arrays], where
00094      *                 num_sequence_arrays is constructor argument.
00095      *\return The newly allocated array, or NULL if error.
00096      */
00097     void* create_custom_data( int array_num, size_t total_bytes );
00098
00099     /**\brief Allocate array for storing adjacency data.
00100      *
00101      * Allocate array for storing adjacency data.
00102      *\return The newly allocated array, or NULL if already allocated.
00103      */
00104     AdjacencyDataType* allocate_adjacency_data();
00105
00106     /**\brief Allocate array of dense tag data
00107      *
00108      * Allocate an array of dense tag data.
00109      *\param index        Dense tag ID for which to allocate array.
00110      *\param bytes_per_ent  Bytes to allocate for each entity.
00111      *\return The newly allocated array, or NULL if error.
00112      */
00113     void* allocate_tag_array( int index, int bytes_per_ent, const void* default_value = 0 );
00114
00115     /**\brief Create new SequenceData that is a copy of a subset of this one
00116      *
00117      * Create a new SequenceData that is a copy of a subset of this one.
00118      * This function is intended for use in subdividing a SequenceData
00119      * for operations such as changing the number of nodes in a block of
00120      * elements.
00121      *\param start  First handle for resulting subset
00122      *\param end    Last handle for resulting subset
00123      *\param sequence_data_sizes Bytes-per-entity for sequence-specific data.
00124      *\NOTE Does not copy tag data.
00125      */
00126     SequenceData* subset( EntityHandle start, EntityHandle end, const int* sequence_data_sizes ) const;
00127
00128     /**\brief SequenceManager data */
00129     TypeSequenceManager::SequenceDataPtr seqManData;
00130
00131     /**\brief Move tag data for a subset of this sequences to specified sequence */
00132     void move_tag_data( SequenceData* destination, const int* tag_sizes, int num_tag_sizes );
00133
00134     /**\brief Free all tag data arrays */
00135     void release_tag_data( const int* tag_sizes, int num_tag_sizes );
00136     /**\brief Free specified tag data array */
00137     void release_tag_data( int index, int tag_size );
00138
00139   protected:
00140     SequenceData( const SequenceData* subset_from,
00141                   EntityHandle start,
00142                   EntityHandle end,
00143                   const int* sequence_data_sizes );
00144
00145   private:
00146     void increase_tag_count( unsigned by_this_many );
00147
00148     void* create_data( int index, int bytes_per_ent, const void* initial_val = 0 );
00149     void copy_data_subset( int index, int size_per_ent, const void* source, size_t offset, size_t count );
00150
00151     const int numSequenceData;
00152     unsigned numTagData;
00153     void** arraySet;
00154     EntityHandle startHandle, endHandle;
00155 };
00156
00157 inline SequenceData::SequenceData( int num_sequence_arrays, EntityHandle start, EntityHandle end )
00158     : numSequenceData( num_sequence_arrays ), numTagData( 0 ), startHandle( start ), endHandle( end )
00159 {
00160     const size_t sz = sizeof( void* ) * ( num_sequence_arrays + 1 );
00161     void** data     = (void**)malloc( sz );
00162     memset( data, 0, sz );
00163     arraySet = data + num_sequence_arrays;
00164 }
00165
00166 }  // namespace moab
00167
00168 #endif
