SetIterator.hpp
00001 #ifndef MB_SETITERATOR_HPP
00002 #define MB_SETITERATOR_HPP
00003
00004 #include "moab/Interface.hpp"
00005
00006 namespace moab
00007 {
00008
00009 class Core;
00010
00011 /** \class Meshset iterator
00012  * \brief A class to iterator over MOAB Meshsets
00013  */
00014 class SetIterator
00015 {
00016   public:
00017     friend class Core;
00018
00019     //! destructor
00020     virtual ~SetIterator();
00021
00022     //! get the ent set for this iterator
00023     inline EntityHandle ent_set() const
00024     {
00025         return entSet;
00026     };
00027
00028     //! get the chunk size of this iterator
00029     inline unsigned int chunk_size() const
00030     {
00031         return chunkSize;
00032     };
00033
00034     //! get the entity type for this iterator
00035     inline EntityType ent_type() const
00036     {
00037         return entType;
00038     };
00039
00040     //! get the dimension for this iterator
00041     inline int ent_dimension() const
00042     {
00043         return entDimension;
00044     };
00045
00046     /** \brief get the next chunkSize entities
00047      * Return the next chunkSize entities.
00048      * \param arr Array of entities returned.
00049      * \param atend Returns true if iterator is at the end of iterable values, otherwise false
00050      */
00051     virtual ErrorCode get_next_arr( std::vector< EntityHandle >& arr, bool& atend ) = 0;
00052
00053     //! reset the iterator to the beginning of the set
00054     virtual ErrorCode reset() = 0;
00055
00056   protected:
00057     /** \brief Constructor
00058      * \param core MOAB Core instance
00059      * \param ent_set EntitySet to which this iterator corresponds
00060      * \param chunk_size Chunk size of this iterator
00061      * \param ent_type Entity type for this iterator
00062      * \param ent_dim Entity dimension for this iterator
00063      */
00064     inline SetIterator( Core* core,
00065                         EntityHandle eset,
00066                         unsigned int chunk_sz,
00067                         EntityType ent_tp,
00068                         int ent_dim,
00069                         bool check_valid = false )
00070         : myCore( core ), entSet( eset ), chunkSize( chunk_sz ), entType( ent_tp ), entDimension( ent_dim ),
00071           checkValid( check_valid ){};
00072
00073     //! Core instance
00074     Core* myCore;
00075
00076     //! handle for entity set corresponding to this iterator
00077     EntityHandle entSet;
00078
00079     //! chunk size of this iterator
00080     unsigned int chunkSize;
00081
00082     //! entity type this iterator iterates over
00083     EntityType entType;
00084
00085     //! dimension this iterator iterates over
00086     int entDimension;
00087
00088     //! check for entity validity before returning handles
00089     bool checkValid;
00090 };
00091
00092 /** \class Set-type set iterator
00093  * \brief A class to iterator over MOAB set-type meshsets
00094  */
00095 class RangeSetIterator : public SetIterator
00096 {
00097   public:
00098     friend class Core;
00099
00100     /** \brief Destructor
00101      */
00102     virtual ~RangeSetIterator();
00103
00104     /** \brief get the next chunkSize entities
00105      * Return the next chunkSize entities.
00106      * \param arr Array of entities returned.
00107      * \param atend Returns true if iterator is at the end of iterable values, otherwise false
00108      */
00109     virtual ErrorCode get_next_arr( std::vector< EntityHandle >& arr, bool& atend );
00110
00111     //! reset the iterator to the beginning of the set
00112     virtual ErrorCode reset();
00113
00114   protected:
00115     /** \brief Constructor
00116      * \param core MOAB Core instance
00117      * \param ent_set EntitySet to which this iterator corresponds
00118      * \param chunk_size Chunk size of this iterator
00119      * \param ent_type Entity type for this iterator
00120      * \param ent_dim Entity dimension for this iterator
00121      */
00122     RangeSetIterator( Core* core,
00123                       EntityHandle ent_set,
00124                       int chunk_size,
00125                       EntityType ent_type,
00126                       int ent_dimension,
00127                       bool check_valid = false );
00128
00129   private:
00130     ErrorCode get_next_by_type( const EntityHandle*& ptr, int count, std::vector< EntityHandle >& arr, bool& atend );
00131
00132     ErrorCode get_next_by_dimension( const EntityHandle*& ptr,
00133                                      int count,
00134                                      std::vector< EntityHandle >& arr,
00135                                      bool& atend );
00136
00137     //! Build the special pair vector for the root set
00138     ErrorCode build_pair_vec();
00139
00140     //! Current iterator position, 0 if at beginning
00141     EntityHandle iterPos;
00142
00143     //! Special range pair ptr for root set
00144     EntityHandle* pairPtr;
00145
00146     //! Number of range pairs
00147     int numPairs;
00148 };
00149
00150 /** \class List-type set iterator
00151  * \brief A class to iterator over MOAB list-type meshsets
00152  */
00153 class VectorSetIterator : public SetIterator
00154 {
00155   public:
00156     friend class Core;
00157
00158     /** \brief get the next chunkSize entities
00159      * Return the next chunkSize entities.
00160      * \param arr Array of entities returned.
00161      * \param atend Returns true if iterator is at the end of iterable values, otherwise false
00162      */
00163     virtual ErrorCode get_next_arr( std::vector< EntityHandle >& arr, bool& atend );
00164
00165     //! reset the iterator to the beginning of the set
00166     virtual ErrorCode reset();
00167
00168     //! decrement the position by the specified number; returns MB_FAILURE if resulting index is < 0
00169     inline ErrorCode decrement( int num );
00170
00171   protected:
00172     /** \brief Constructor
00173      * \param core MOAB Core instance
00174      * \param ent_set EntitySet to which this iterator corresponds
00175      * \param chunk_size Chunk size of this iterator
00176      * \param ent_type Entity type for this iterator
00177      * \param ent_dim Entity dimension for this iterator
00178      */
00179     inline VectorSetIterator( Core* core,
00180                               EntityHandle eset,
00181                               int chunk_sz,
00182                               EntityType ent_tp,
00183                               int ent_dim,
00184                               bool check_valid = false )
00185         : SetIterator( core, eset, chunk_sz, ent_tp, ent_dim, check_valid ), iterPos( 0 )
00186     {
00187     }
00188
00189   private:
00190     //! Current iterator position, 0 if at beginning
00191     int iterPos;
00192 };
00193
00194 inline ErrorCode VectorSetIterator::decrement( int num )
00195 {
00196     iterPos -= num;
00197     return ( iterPos < 0 ? MB_FAILURE : MB_SUCCESS );
00198 }
00199
00200 }  // namespace moab
00201
00202 #endif
