SetsNTags.cpp
Description: Get the sets representing materials and Dirichlet/Neumann boundary conditions and list their contents.
This example shows how to get entity sets, and tags on those sets.
To run: ./SetsNTags [meshfile]
(default values can run if users don't specify a mesh file)
/** @example SetsNTags.cpp
 * Description: Get the sets representing materials and Dirichlet/Neumann boundary conditions and
 * list their contents.\n This example shows how to get entity sets, and tags on those sets.
 * To run: ./SetsNTags [meshfile]\n
 * (default values can run if users don't specify a mesh file)
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/Range.hpp"
#include "MBTagConventions.hpp"
#include <iostream>
using namespace moab;
using namespace std;
#ifndef MESH_DIR
#define MESH_DIR "."
#endif
string test_file_name = string( MESH_DIR ) + string( "/hex01.vtk" );
// Tag names for these conventional tags come from MBTagConventions.hpp
const char* tag_nms[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME };
int main( int argc, char** argv )
    // Get the material set tag handle
    Tag mtag;
    ErrorCode rval;
    Range sets, set_ents;
    // Get MOAB instance
    Interface* mb = new( std::nothrow ) Core;
    if( NULL == mb ) return 1;
    // Need option handling here for input filename
    if( argc > 1 )
        // User has input a mesh file
        test_file_name = argv[1];
    // Load a file
    rval = mb->load_file( test_file_name.c_str() );MB_CHK_ERR( rval );
    // Loop over set types
    for( int i = 0; i < 3; i++ )
        // Get the tag handle for this tag name; tag should already exist (it was created during
        // file read)
        rval = mb->tag_get_handle( tag_nms[i], 1, MB_TYPE_INTEGER, mtag );MB_CHK_ERR( rval );
        // Get all the sets having that tag (with any value for that tag)
        sets.clear();
        rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &mtag, NULL, 1, sets );MB_CHK_ERR( rval );
        // Iterate over each set, getting the entities and printing them
        Range::iterator set_it;
        for( set_it = sets.begin(); set_it != sets.end(); ++set_it )
            // Get the id for this set
            int set_id;
            rval = mb->tag_get_data( mtag, &( *set_it ), 1, &set_id );MB_CHK_ERR( rval );
            // Get the entities in the set, recursively
            rval = mb->get_entities_by_handle( *set_it, set_ents, true );MB_CHK_ERR( rval );
            cout << tag_nms[i] << " " << set_id << " has " << set_ents.size() << " entities:" << endl;
            set_ents.print( "   " );
            set_ents.clear();
    delete mb;
    return 0;
