SharedSetData.hpp
00001 /** \file   SharedSetData.hpp
00002  *  \author Jason Kraftcheck
00003  *  \date   2011-06-23
00004  */
00005
00006 #ifndef moab_SHARED_SET_DATA_HPP
00007 #define moab_SHARED_SET_DATA_HPP
00008
00009 #include "moab/Types.hpp"
00010 #include "moab/RangeMap.hpp"
00011
00012 #define STRINGIFY_( X ) #X
00013 #define STRINGIFY( X )  STRINGIFY_( X )
00014 #ifdef MOAB_HAVE_UNORDERED_MAP
00015 #include STRINGIFY( MOAB_HAVE_UNORDERED_MAP )
00016 #include STRINGIFY( MOAB_HAVE_UNORDERED_SET )
00017 #else
00018 #include <map>
00019 #include <set>
00020 #endif
00021
00022 #include <vector>
00023
00024 namespace moab
00025 {
00026
00027 class Interface;
00028
00029 /**\brief ParallelComm data about shared entity sets */
00030 class SharedSetData
00031 {
00032   public:
00033     SharedSetData( Interface& moab, int pcID, unsigned rank );
00034
00035     ~SharedSetData();
00036
00037     /**\brief Get ranks of sharing procs
00038      *
00039      * Get list of all process ranks that own at least one set that
00040      * is shared with this process.
00041      */
00042     ErrorCode get_owning_procs( std::vector< unsigned >& ranks_out ) const;
00043
00044     /**\brief Get ranks of sharing procs
00045      *
00046      * Get list of all process ranks with which this process the passed set.
00047      * Returns an empty list for non-shared sets.
00048      */
00049     ErrorCode get_sharing_procs( EntityHandle entity_set, std::vector< unsigned >& ranks_out ) const;
00050
00051     /**\brief Get handles for all shared sets */
00052     ErrorCode get_shared_sets( Range& sets_out ) const;
00053
00054     /**\brief Get handles for all sets shared with specified process */
00055     ErrorCode get_shared_sets( unsigned rank, Range& sets_out ) const;
00056
00057     /**\brief Get owner and owner's handle for shared set */
00058     ErrorCode get_owner( EntityHandle set, unsigned& rank_out, EntityHandle& remote_handle_out ) const;
00059
00060     /**\brief Get owner of shared set */
00061     ErrorCode get_owner( EntityHandle set, unsigned& rank_out ) const
00062     {
00063         EntityHandle h;
00064         return get_owner( set, rank_out, h );
00065     }
00066
00067     /**\brief Get owner's handle for shared set */
00068     ErrorCode get_owner_handle( EntityHandle set, EntityHandle& handle_out ) const
00069     {
00070         unsigned rank;
00071         return get_owner( set, rank, handle_out );
00072     }
00073
00074     /**\brief Get local handle for shared set */
00075     ErrorCode get_local_handle( unsigned owner_rank, EntityHandle remote_handle, EntityHandle& local_handle_out ) const;
00076
00077     ErrorCode set_owner( EntityHandle set, unsigned owner_rank, EntityHandle owner_handle );
00078
00079     /**\brief set/update sharing list for a set
00080      *
00081      *\NOTE sorts \c ranks vector
00082      */
00083     ErrorCode set_sharing_procs( EntityHandle set_handle, std::vector< unsigned >& ranks );
00084
00085   private:
00086     Interface& mb;
00087
00088     /**\brief per-set tag data */
00089     struct SharedSetTagData
00090     {
00091         unsigned ownerRank;
00092         EntityHandle ownerHandle;
00093         const std::vector< unsigned >* sharingProcs;
00094     };
00095
00096     /** Shared set data: opaque tag containing struct SharedSetTagData */
00097     Tag sharedSetTag;
00098
00099     /** Map type for lookup of local handle given remote handle */
00100     typedef RangeMap< EntityHandle, EntityHandle > ProcHandleMapType;
00101
00102     static void append_local_handles( const ProcHandleMapType& map, Range& append_to_this );
00103
00104     /** Map type for lookup of ProcHandleMapType instance by rank */
00105 #ifdef MOAB_HAVE_UNORDERED_MAP
00106     struct hash_vect
00107     {
00108         // Copied (more or less) from Boost
00109         template < typename T >
00110         static void hash_combine( size_t& seed, T val )
00111         {
00112             seed ^= MOAB_UNORDERED_MAP_NS::hash< T >().operator()( val ) + 0x9e3779b9 + ( seed << 6 ) + ( seed >> 2 );
00113         }
00114         template < typename IT >
00115         static size_t hash_range( IT it, IT last )
00116         {
00117             size_t seed = 0;
00118             for( ; it != last; ++it )
00119                 hash_combine( seed, *it );
00120             return seed;
00121         }
00122         size_t operator()( const std::vector< unsigned >& v ) const
00123         {
00124             return hash_range( v.begin(), v.end() );
00125         }
00126     };
00127
00128     typedef MOAB_UNORDERED_MAP_NS::unordered_map< unsigned, ProcHandleMapType > RHMap;
00129     typedef MOAB_UNORDERED_MAP_NS::unordered_set< std::vector< unsigned >, hash_vect > RProcMap;
00130 #else
00131     struct less_vect
00132     {
00133         bool operator()( const std::vector< unsigned >& a, const std::vector< unsigned >& b ) const
00134         {
00135             // sort by size first
00136             if( a.size() != b.size() ) return a.size() < b.size();
00137             // if same size, sort by first non-equal value
00138             size_t i = 0;
00139             while( i != a.size() && a[i] == b[i] )
00140                 ++i;
00141             return i != a.size() && a[i] < b[i];
00142         }
00143     };
00144
00145     typedef std::map< unsigned, ProcHandleMapType > RHMap;
00146     typedef std::set< std::vector< unsigned >, less_vect > RProcMap;
00147 #endif
00148
00149     /** Map for lookup of ProcHandleMapType instance by rank */
00150     RHMap handleMap;
00151
00152     /** Storage of sharing lists */
00153     RProcMap procListMap;
00154 };
00155
00156 }  // namespace moab
00157
00158 #endif  // moab_SHARED_SET_DATA_HPP
