SimplexTemplateTagAssigner.cpp
00001 #include "SimplexTemplateTagAssigner.hpp"
00002
00003 #include "EdgeSizeEvaluator.hpp"
00004 #include "moab/Interface.hpp"
00005 #include "RefinerTagManager.hpp"
00006 #include "SimplexTemplateRefiner.hpp"
00007
00008 #include <vector>
00009
00010 #include <cmath>
00011
00012 namespace moab
00013 {
00014
00015 using namespace std;
00016
00017 /// Construct a template tag assigner.
00018 SimplexTemplateTagAssigner::SimplexTemplateTagAssigner( SimplexTemplateRefiner* r )
00019 {
00020     this->mesh_refiner = r;
00021     this->tag_manager  = 0;
00022 }
00023
00024 /// Empty destructor for good form.
00025 SimplexTemplateTagAssigner::~SimplexTemplateTagAssigner() {}
00026
00027 /**\brief Given endpoint coordinates and tag values plus midpoint coordinates, compute midpoint tag
00028  * values.
00029  *
00030  * Normally, this function will be invoked by the EntityRefiner before evaluate_edge is called.
00031  * However, if evaluate_edge() changes the parametric coordinates of the midpoint,
00032  * it should call evaluate_tags_at_midpoint() again to update any tag values;
00033  * that is why this function is a member of EdgeSizeEvaluator and not EntityRefiner.
00034  *
00035  * @param[in] c0 Pointer to endpoint 0 coordinates. The parametric coordinates (3) are followed by
00036  * world coordinates (3).
00037  * @param[in] t0 Pointer to endpoint 0 tag values.
00038  * @param[in] cm Pointer to midpoint coordinates. The parametric coordinates (3) are followed by
00039  * world coordinates (3).
00040  * @param[out] tm Pointer to midpoint tag values.
00041  * @param[in] c1 Pointer to endpoint 1 coordinates. The parametric coordinates (3) are followed by
00042  * world coordinates (3).
00043  * @param[in] t1 Pointer to endpoint 1 tag values.
00044  */
00045 void SimplexTemplateTagAssigner::operator()( const double* c0,
00046                                              const void* t0,
00047                                              EntityHandle h0,
00048                                              const double* cm,
00049                                              void* tm,
00050                                              const double* c1,
00051                                              const void* t1,
00052                                              EntityHandle h1 )
00053 {
00054     double c0m_squared = 0.;
00055     double c01_squared = 0.;
00056     for( int i = 0; i < 3; ++i )
00057     {
00058         double tmp = cm[i] - c0[i];
00059         c0m_squared += tmp * tmp;
00060         tmp = c1[i] - c0[i];
00061         c01_squared += tmp * tmp;
00062     }
00063     double lambda           = sqrt( c0m_squared / c01_squared );
00064     double one_minus_lambda = 1. - lambda;
00065
00066     DataType data_type;
00067     int tag_size;
00068     int num_components;
00069     int num_tags = this->tag_manager->get_number_of_vertex_tags();
00070     Tag tag_handle;
00071     int tag_offset;
00072     for( int i = 0; i < num_tags; ++i )
00073     {
00074         this->tag_manager->get_input_vertex_tag( i, tag_handle, tag_offset );
00075         this->tag_manager->get_input_mesh()->tag_get_data_type( tag_handle, data_type );
00076         this->tag_manager->get_input_mesh()->tag_get_bytes( tag_handle, tag_size );
00077
00078         switch( data_type )
00079         {
00080             case MB_TYPE_DOUBLE: {
00081                 num_components = tag_size / sizeof( double );
00082                 double* t0i    = (double*)( (char*)t0 + tag_offset );
00083                 double* tmi    = (double*)( (char*)tm + tag_offset );
00084                 double* t1i    = (double*)( (char*)t1 + tag_offset );
00085                 for( int j = 0; j < num_components; ++j )
00086                     tmi[j] = one_minus_lambda * t0i[j] + lambda * t1i[j];
00087             }
00088             break;
00089             default:
00090                 memcpy( (char*)tm + tag_offset, (char*)( h0 < h1 ? t0 : t1 ) + tag_offset, tag_size );
00091                 break;
00092         }
00093     }
00094 }
00095
00096 void SimplexTemplateTagAssigner::operator()( const void* t0, const void* t1, const void* t2, void* tp )
00097 {
00098     (void)t0;
00099     (void)t1;
00100     (void)t2;
00101     (void)tp;
00102 }
00103
00104 void SimplexTemplateTagAssigner::set_tag_manager( RefinerTagManager* tmgr )
00105 {
00106     this->tag_manager = tmgr;
00107 }
00108
00109 }  // namespace moab
