StructuredElementSeq.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #include "StructuredElementSeq.hpp"
00017 #include "ScdVertexData.hpp"
00018 #include "ScdElementData.hpp"
00019 #include "moab/Interface.hpp"
00020 #include "moab/ReadUtilIface.hpp"
00021 #include "moab/CN.hpp"
00022 #include "Internals.hpp"
00023
00024 namespace moab
00025 {
00026
00027 StructuredElementSeq::StructuredElementSeq( EntityHandle shandle,
00028                                             const int imin,
00029                                             const int jmin,
00030                                             const int kmin,
00031                                             const int imax,
00032                                             const int jmax,
00033                                             const int kmax,
00034                                             int* is_per )
00035     : ElementSequence( shandle,
00036                        ScdElementData::calc_num_entities( shandle, imax - imin, jmax - jmin, kmax - kmin, is_per ),
00037                        CN::VerticesPerEntity( TYPE_FROM_HANDLE( shandle ) ),
00038                        new ScdElementData( shandle, imin, jmin, kmin, imax, jmax, kmax, is_per ) )
00039 {
00040 }
00041
00042 StructuredElementSeq::~StructuredElementSeq() {}
00043
00044 ErrorCode StructuredElementSeq::get_connectivity( EntityHandle handle,
00045                                                   std::vector< EntityHandle >& connect,
00046                                                   bool /*topological*/ ) const
00047 {
00048     int i, j, k;
00049     ErrorCode rval = get_params( handle, i, j, k );
00050     if( MB_SUCCESS == rval ) rval = get_params_connectivity( i, j, k, connect );
00051     return rval;
00052 }
00053
00054 ErrorCode StructuredElementSeq::get_connectivity( EntityHandle handle,
00055                                                   EntityHandle const*& connect,
00056                                                   int& connect_length,
00057                                                   bool topo,
00058                                                   std::vector< EntityHandle >* storage ) const
00059 {
00060     if( !storage )
00061     {
00062         connect        = 0;
00063         connect_length = 0;
00064         return MB_STRUCTURED_MESH;
00065     }
00066
00067     storage->clear();
00068     ErrorCode rval = get_connectivity( handle, *storage, topo );
00069     connect        = &( *storage )[0];
00070     connect_length = storage->size();
00071     return rval;
00072 }
00073
00074 ErrorCode StructuredElementSeq::set_connectivity( EntityHandle, EntityHandle const*, int )
00075 {
00076     return MB_STRUCTURED_MESH;
00077 }
00078
00079 EntityHandle* StructuredElementSeq::get_connectivity_array()
00080 {
00081     return 0;
00082 }
00083
00084 int StructuredElementSeq::values_per_entity() const
00085 {
00086     return -1;
00087 }  // never reuse freed handles for structured elements
00088
00089 EntitySequence* StructuredElementSeq::split( EntityHandle here )
00090 {
00091     return new StructuredElementSeq( *this, here );
00092 }
00093
00094 SequenceData* StructuredElementSeq::create_data_subset( EntityHandle, EntityHandle ) const
00095 {
00096     return 0;
00097 }
00098
00099 void StructuredElementSeq::get_const_memory_use( unsigned long& bytes_per_entity, unsigned long& sequence_size ) const
00100 {
00101     sequence_size    = sizeof( *this );
00102     bytes_per_entity = sdata()->get_memory_use() / sdata()->size();
00103 }
00104
00105 }  // namespace moab
