SysUtil.cpp File Reference
#include "SysUtil.hpp"
#include <fstream>
#include <algorithm>
#include <cassert>
#include "moab/EntityHandle.hpp"
+ Include dependency graph for SysUtil.cpp:
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
namespace  moab::SysUtil
Functions
void moab::SysUtil::setmem (void *mem, const void *value, unsigned value_size, size_t num_elem)
 Similar to memset, but accepts values larger than 1 char.
long moab::SysUtil::filesize (FILE *filp)
 Get size of file (if it is a regular file)
long moab::SysUtil::filesize (std::ifstream &str)
void moab::SysUtil::byteswap (void *data, unsigned value_size, size_t num_elem)
 Swap byte order (e.g. change from big-endian to little-endian)
static uint16_t moab::SysUtil::swap_bytes (uint16_t value)
static uint32_t moab::SysUtil::swap_bytes (uint32_t value)
static uint64_t moab::SysUtil::swap_bytes (uint64_t value)
void moab::SysUtil::byteswap2 (void *data, size_t num_elem)
 Alternate byteswap optimized for 2-byte values.
void moab::SysUtil::byteswap4 (void *data, size_t num_elem)
 Alternate byteswap optimized for 4-byte values.
void moab::SysUtil::byteswap8 (void *data, size_t num_elem)
 Alternate byteswap optimized for 8-byte values.
Variables
const uint64_t moab::SysUtil::m64b1 = 0xFF
const uint64_t moab::SysUtil::m64b2 = m64b1 << 8
const uint64_t moab::SysUtil::m64b3 = m64b1 << 16
const uint64_t moab::SysUtil::m64b4 = m64b1 << 24
const uint64_t moab::SysUtil::m64b5 = m64b1 << 32
const uint64_t moab::SysUtil::m64b6 = m64b1 << 40
const uint64_t moab::SysUtil::m64b7 = m64b1 << 48
