MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) [email protected] 00024 00025 ***************************************************************** */ 00026 00027 /** \file TUntangleBeta.cpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "TUntangleBeta.hpp" 00034 #include "TMPDerivs.hpp" 00035 #include "TMPCommon.hpp" 00036 00037 namespace MBMesquite 00038 { 00039 00040 TUntangleBeta::~TUntangleBeta() {} 00041 00042 std::string TUntangleBeta::get_name() const 00043 { 00044 return "untangle beta"; 00045 } 00046 00047 template < unsigned DIM > 00048 inline bool TUntangleBeta::eval( const MsqMatrix< DIM, DIM >& T, double& result ) 00049 { 00050 double tau = det( T ); 00051 double d = tau - mGamma; 00052 double f = fabs( d ) - d; 00053 result = 0.125 * f * f * f; 00054 return true; 00055 } 00056 00057 template < unsigned DIM > 00058 inline bool TUntangleBeta::grad( const MsqMatrix< DIM, DIM >& T, double& result, MsqMatrix< DIM, DIM >& deriv_wrt_T ) 00059 { 00060 double tau = det( T ); 00061 if( tau < mGamma ) 00062 { 00063 double d = mGamma - tau; 00064 result = d * d * d; 00065 deriv_wrt_T = -3 * d * d * transpose_adj( T ); 00066 } 00067 else 00068 { 00069 result = 0.0; 00070 deriv_wrt_T = MsqMatrix< DIM, DIM >( 0.0 ); 00071 } 00072 return true; 00073 } 00074 00075 template < unsigned DIM > 00076 inline bool TUntangleBeta::hess( const MsqMatrix< DIM, DIM >& T, 00077 double& result, 00078 MsqMatrix< DIM, DIM >& deriv_wrt_T, 00079 MsqMatrix< DIM, DIM >* second_wrt_T ) 00080 { 00081 double tau = det( T ); 00082 if( tau < mGamma ) 00083 { 00084 const MsqMatrix< DIM, DIM > adjt = transpose_adj( T ); 00085 double d = mGamma - tau; 00086 result = d * d * d; 00087 deriv_wrt_T = -3 * d * d * adjt; 00088 set_scaled_outer_product( second_wrt_T, 6 * d, adjt ); 00089 pluseq_scaled_2nd_deriv_of_det( second_wrt_T, -3 * d * d, T ); 00090 } 00091 else 00092 { 00093 result = 0.0; 00094 deriv_wrt_T = MsqMatrix< DIM, DIM >( 0.0 ); 00095 set_scaled_I( second_wrt_T, 0.0 ); // zero everything 00096 } 00097 return true; 00098 } 00099 00100 TMP_T_TEMPL_IMPL_COMMON( TUntangleBeta ) 00101 00102 } // namespace MBMesquite
