TagIterateF.F
00001 c TagIterate: Get a pointer to tag memory and interact directly with that
00002 c
00003 c This program shows how to get a pointer to tag memory and assign it to
00004 c a fortran array, allowing an application to bypass the API and/or share
00005 c memory with MOAB.
00006
00007 c Usage: TagIterate <mesh_filename>
00008
00009       program tag_iterate
00010 #include "iMesh_f.h"
00011
00012 c declarations
00013       iMesh_Instance mesh
00014       iBase_EntityHandle root_set
00015       iBase_EntityArrIterator iter
00016       iBase_TagHandle tagh
00017       IBASE_HANDLE_T rpents, ents, rpdata
00018       real*8 tag_data
00019       pointer (rpdata, tag_data(0:*))
00020       pointer (rpents, ents(0:*))
00021       pointer (ipoffsets, ioffsets(0,*))
00022       integer ierr, ents_alloc, ents_size, num_regions, atend, count
00023
00024 c create the Mesh instance
00025       call iMesh_newMesh("MOAB", mesh, ierr)
00026
00027 c get the root set
00028       call iMesh_getRootSet(%VAL(mesh), root_set, ierr)
00029
00030 c load the mesh
00031       call iMesh_load(%VAL(mesh), %VAL(root_set), "125hex.vtk", "",ierr)
00032
00033 c get the number of regions
00034       call iMesh_getNumOfType(%VAL(mesh), %VAL(root_set),
00035      1 %VAL(iBase_REGION), num_regions, ierr)
00036
00037 c get an iterator over regions
00038       call iMesh_initEntArrIter(%VAL(mesh), %VAL(root_set),
00039      1 %VAL(iBase_REGION), %VAL(iMesh_ALL_TOPOLOGIES),%VAL(num_regions),
00040      1 %VAL(0), iter, ierr)
00041
00042 c create a tag to put on the regions
00043       call iMesh_createTagWithOptions(%VAL(mesh), "dumtag",
00044      1 "moab:TAG_STORAGE_TYPE=DENSE moab:TAG_DEFAULT_VALUE=0.0",
00045      1 %VAL(1), %VAL(iBase_DOUBLE), tagh, ierr)
00046
00047 c iterate over tag memory
00048  10   call iMesh_tagIterate(%VAL(mesh), %VAL(tagh), %VAL(iter),
00049      1     rpdata, count, ierr)
00050
00051 c step the iterator over count entities
00052       call iMesh_stepEntArrIter(%VAL(mesh), %VAL(iter), %VAL(count),
00053      1     atend, ierr)
00054
00055       if (atend .eq. 0) go to 10
00056
00057
00058       call iMesh_dtor(%VAL(mesh), ierr)
00059
00060       end
