TargetReadWriteTest.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retian certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file TargetReadWriteTest.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "TargetWriter.hpp"
00034 #include "TargetReader.hpp"
00035 #include "WeightReader.hpp"
00036 #include "MeshImpl.hpp"
00037 #include "PatchData.hpp"
00038 #include "Settings.hpp"
00039 #include "ElemSampleQM.hpp"
00040
00041 #include "cppunit/extensions/HelperMacros.h"
00042 #include "UnitUtil.hpp"
00043
00044 #include <iostream>
00045
00046 using namespace MBMesquite;
00047
00048 class TargetReadWriteTest : public CppUnit::TestFixture
00049 {
00050   private:
00051     CPPUNIT_TEST_SUITE( TargetReadWriteTest );
00052     CPPUNIT_TEST( read_write_3D_targets );
00053     CPPUNIT_TEST( read_write_2D_targets );
00054     CPPUNIT_TEST( read_write_surface_targets );
00055     CPPUNIT_TEST( read_write_weights );
00056     CPPUNIT_TEST_SUITE_END();
00057
00058     MeshImpl myMesh;    // mesh data
00059     PatchData myPatch;  // global patch for mesh data
00060     Settings linearMaps;
00061
00062   public:
00063     void setUp();
00064     void tearDown();
00065     void read_write_3D_targets();
00066     void read_write_2D_targets();
00067     void read_write_surface_targets();
00068     void read_write_weights();
00069 };
00070
00071 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TargetReadWriteTest, "TargetReadWriteTest" );
00072 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TargetReadWriteTest, "Unit" );
00073
00074 static const char vtk_file_data[] = "# vtk DataFile Version 2.0\n"
00075                                     "Mesquite Mesh\n"
00076                                     "ASCII\n"
00077                                     "DATASET UNSTRUCTURED_GRID\n"
00078                                     "POINTS 11 float\n"
00079                                     "-1 -1 -1\n"
00080                                     " 1 -1 -1\n"
00081                                     " 1  1 -1\n"
00082                                     "-1  1 -1\n"
00083                                     "-1 -1  1\n"
00084                                     " 1 -1  1\n"
00085                                     " 1  1  1\n"
00086                                     "-1  1  1\n"
00087                                     " 0  0  2\n"
00088                                     "-2  0  2\n"
00089                                     "-2  0 -1\n"
00090                                     "CELLS 6 36\n"
00091                                     "3 0 1 10\n"
00092                                     "4 0 1 2 3\n"
00093                                     "4 4 5 8 9\n"
00094                                     "5 4 5 6 7 8\n"
00095                                     "6 4 5 9 1 0 10\n"
00096                                     "8 0 1 2 3 4 5 6 7\n"
00097                                     "CELL_TYPES 6\n"
00098                                     "5 9 10 14 13 12\n"
00099                                     "\n";
00100
00101 void TargetReadWriteTest::setUp()
00102 {
00103     // create input file
00104     const char filename[] = "target_reader_test.vtk";
00105     FILE* file            = fopen( filename, "w" );
00106     CPPUNIT_ASSERT( file );
00107     int rval = fputs( vtk_file_data, file );
00108     fclose( file );
00109     CPPUNIT_ASSERT( rval != EOF );
00110
00111     // read input file
00112     MsqError err;
00113     myMesh.read_vtk( filename, err );
00114     remove( filename );
00115     if( err ) std::cout << err << std::endl;
00116     CPPUNIT_ASSERT( !err );
00117
00118     // Construct global patch
00119     std::vector< Mesh::ElementHandle > elems;
00120     std::vector< Mesh::VertexHandle > verts;
00121     myMesh.get_all_elements( elems, err );
00122     CPPUNIT_ASSERT( !err );
00123     myMesh.get_all_vertices( verts, err );
00124     CPPUNIT_ASSERT( !err );
00125     myPatch.set_mesh( &myMesh );
00126     myPatch.attach_settings( &linearMaps );
00127     myPatch.set_mesh_entities( elems, verts, err );
00128     CPPUNIT_ASSERT( !err );
00129 }
00130
00131 void TargetReadWriteTest::tearDown()
00132 {
00133     myMesh.clear();
00134 }
00135
00136 class FakeTargetCalc : public TargetCalculator, public WeightCalculator
00137 {
00138     bool surfOrient;
00139
00140   public:
00141     FakeTargetCalc( bool surface_orient = true ) : surfOrient( surface_orient ) {}
00142
00143     ~FakeTargetCalc() {}
00144
00145     bool get_3D_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 3, 3 >& W_out, MsqError& err );
00146
00147     bool get_2D_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 2, 2 >& W_out, MsqError& err );
00148
00149     bool get_surface_target( PatchData& pd, size_t element, Sample sample, MsqMatrix< 3, 2 >& W_out, MsqError& err );
00150
00151     double get_weight( PatchData& pd, size_t element, Sample sample, MsqError& err );
00152
00153     bool have_surface_orient() const
00154     {
00155         return surfOrient;
00156     }
00157
00158     unsigned long make_value( Mesh::ElementHandle elem, Sample sample, unsigned idx );
00159 };
00160
00161 bool FakeTargetCalc::get_3D_target( PatchData& pd, size_t elem, Sample sample, MsqMatrix< 3, 3 >& W_out, MsqError& )
00162 {
00163     CPPUNIT_ASSERT_EQUAL( 3u, TopologyInfo::dimension( pd.element_by_index( elem ).get_element_type() ) );
00164     unsigned i, j;
00165     for( i = 0; i < 3; ++i )
00166     {
00167         for( j = 0; j < i; ++j )
00168             W_out( i, j ) = 0.0;
00169         for( j = i; j < 3; ++j )
00170             W_out( i, j ) = make_value( pd.get_element_handles_array()[elem], sample, 3 * i + j + 1 );
00171     }
00172     return true;
00173 }
00174
00175 bool FakeTargetCalc::get_surface_target( PatchData& pd,
00176                                          size_t elem,
00177                                          Sample sample,
00178                                          MsqMatrix< 3, 2 >& W_out,
00179                                          MsqError& )
00180 {
00181     CPPUNIT_ASSERT_EQUAL( 2u, TopologyInfo::dimension( pd.element_by_index( elem ).get_element_type() ) );
00182     for( unsigned i = 0; i < 3; ++i )
00183         for( unsigned j = 0; j < 2; ++j )
00184             W_out( i, j ) = make_value( pd.get_element_handles_array()[elem], sample, 2 * i + j );
00185     return true;
00186 }
00187
00188 bool FakeTargetCalc::get_2D_target( PatchData& pd, size_t elem, Sample sample, MsqMatrix< 2, 2 >& W_out, MsqError& )
00189 {
00190     CPPUNIT_ASSERT_EQUAL( 2u, TopologyInfo::dimension( pd.element_by_index( elem ).get_element_type() ) );
00191     for( unsigned i = 0; i < 2; ++i )
00192         for( unsigned j = 0; j < 2; ++j )
00193             W_out( i, j ) = make_value( pd.get_element_handles_array()[elem], sample, ( 2 - i ) * ( 2 - j ) );
00194     return true;
00195 }
00196
00197 double FakeTargetCalc::get_weight( PatchData& pd, size_t elem, Sample sample, MsqError& )
00198 {
00199     return make_value( pd.get_element_handles_array()[elem], sample, 0 );
00200 }
00201
00202 unsigned long FakeTargetCalc::make_value( Mesh::ElementHandle elem, Sample sample, unsigned idx )
00203 {
00204     const unsigned index_bits = 4;
00205     CPPUNIT_ASSERT( idx < ( 1 << index_bits ) );
00206     unsigned long result = (unsigned long)elem;
00207     result               = ( result << Sample::SIDE_DIMENSION_BITS ) | sample.dimension;
00208     result               = ( result << Sample::SIDE_NUMBER_BITS ) | sample.number;
00209     result               = ( result << index_bits ) | idx;
00210     return result;
00211 }
00212
00213 void TargetReadWriteTest::read_write_3D_targets()
00214 {
00215     const bool oriented = true;  // doesn't matter which value for 3D
00216
00217     MsqPrintError err( std::cout );
00218     FakeTargetCalc tc( oriented );
00219
00220     // Write the targets
00221     TargetWriter writer( &tc );
00222     MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &myMesh, 0 );
00223     writer.loop_over_mesh( &mesh_and_domain, &linearMaps, err );
00224     CPPUNIT_ASSERT( !err );
00225
00226     // Compare all target matrices
00227     bool checked_something = false;  // make sure mesh actually contains volume elements
00228     TargetReader reader( oriented );
00229     for( size_t i = 0; i < myPatch.num_elements(); ++i )
00230     {
00231         const unsigned d = TopologyInfo::dimension( myPatch.element_by_index( i ).get_element_type() );
00232         if( d != 3 ) continue;
00233
00234         checked_something = true;
00235         std::vector< Sample > samples;
00236         myPatch.get_samples( i, samples, err );
00237         ASSERT_NO_ERROR( err );
00238         for( size_t j = 0; j < samples.size(); ++j )
00239         {
00240             MsqMatrix< 3, 3 > expected, read;
00241             tc.get_3D_target( myPatch, i, samples[j], expected, err );
00242             CPPUNIT_ASSERT( !err );
00243             reader.get_3D_target( myPatch, i, samples[j], read, err );
00244             CPPUNIT_ASSERT( !err );
00245             ASSERT_MATRICES_EQUAL( expected, read, 1e-12 );
00246         }
00247     }
00248
00249     CPPUNIT_ASSERT( checked_something );
00250 }
00251
00252 void TargetReadWriteTest::read_write_surface_targets()
00253 {
00254     const bool oriented = true;
00255
00256     MsqPrintError err( std::cout );
00257     FakeTargetCalc tc( oriented );
00258
00259     // Write the targets
00260     TargetWriter writer( &tc );
00261     MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &myMesh, 0 );
00262     writer.loop_over_mesh( &mesh_and_domain, &linearMaps, err );
00263     CPPUNIT_ASSERT( !err );
00264
00265     // Compare all target matrices
00266     bool checked_something = false;  // make sure mesh actually contains surface elements
00267     TargetReader reader( oriented );
00268     for( size_t i = 0; i < myPatch.num_elements(); ++i )
00269     {
00270         const unsigned d = TopologyInfo::dimension( myPatch.element_by_index( i ).get_element_type() );
00271         if( d != 2 ) continue;
00272
00273         checked_something = true;
00274         std::vector< Sample > samples;
00275         myPatch.get_samples( i, samples, err );
00276         ASSERT_NO_ERROR( err );
00277         for( size_t j = 0; j < samples.size(); ++j )
00278         {
00279             MsqMatrix< 3, 2 > expected, read;
00280             tc.get_surface_target( myPatch, i, samples[j], expected, err );
00281             CPPUNIT_ASSERT( !err );
00282             reader.get_surface_target( myPatch, i, samples[j], read, err );
00283             CPPUNIT_ASSERT( !err );
00284             ASSERT_MATRICES_EQUAL( expected, read, 1e-6 );
00285         }
00286     }
00287
00288     CPPUNIT_ASSERT( checked_something );
00289 }
00290
00291 void TargetReadWriteTest::read_write_2D_targets()
00292 {
00293     const bool oriented = false;
00294
00295     MsqPrintError err( std::cout );
00296     FakeTargetCalc tc( oriented );
00297
00298     // Write the targets
00299     TargetWriter writer( &tc );
00300     MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &myMesh, 0 );
00301     writer.loop_over_mesh( &mesh_and_domain, &linearMaps, err );
00302     CPPUNIT_ASSERT( !err );
00303
00304     // Compare all target matrices
00305     bool checked_something = false;  // make sure mesh actually contains surface elements
00306     TargetReader reader( oriented );
00307     for( size_t i = 0; i < myPatch.num_elements(); ++i )
00308     {
00309         const unsigned d = TopologyInfo::dimension( myPatch.element_by_index( i ).get_element_type() );
00310         if( d != 2 ) continue;
00311
00312         checked_something = true;
00313         std::vector< Sample > samples;
00314         myPatch.get_samples( i, samples, err );
00315         ASSERT_NO_ERROR( err );
00316         for( size_t j = 0; j < samples.size(); ++j )
00317         {
00318             MsqMatrix< 2, 2 > expected, read;
00319             tc.get_2D_target( myPatch, i, samples[j], expected, err );
00320             CPPUNIT_ASSERT( !err );
00321             reader.get_2D_target( myPatch, i, samples[j], read, err );
00322             CPPUNIT_ASSERT( !err );
00323             ASSERT_MATRICES_EQUAL( expected, read, 1e-6 );
00324         }
00325     }
00326
00327     CPPUNIT_ASSERT( checked_something );
00328 }
00329
00330 void TargetReadWriteTest::read_write_weights()
00331 {
00332     MsqPrintError err( std::cout );
00333     FakeTargetCalc tc;
00334
00335     // Write the targets
00336     TargetWriter writer( 0, &tc );
00337     MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &myMesh, 0 );
00338     writer.loop_over_mesh( &mesh_and_domain, &linearMaps, err );
00339     CPPUNIT_ASSERT( !err );
00340
00341     // Compare all target matrices
00342     WeightReader reader;
00343     for( size_t i = 0; i < myPatch.num_elements(); ++i )
00344     {
00345         std::vector< Sample > samples;
00346         myPatch.get_samples( i, samples, err );
00347         ASSERT_NO_ERROR( err );
00348         for( size_t j = 0; j < samples.size(); ++j )
00349         {
00350             double expected = tc.get_weight( myPatch, i, samples[j], err );
00351             CPPUNIT_ASSERT( !err );
00352             double read = reader.get_weight( myPatch, i, samples[j], err );
00353             CPPUNIT_ASSERT( !err );
00354             CPPUNIT_ASSERT_DOUBLES_EQUAL( expected, read, 1e-12 );
00355         }
00356     }
00357 }
