MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <thread>
#include <set>
#include "TypeSequenceManager.hpp"
#include "EntitySequence.hpp"
#include "SequenceData.hpp"
#include "TestUtil.hpp"
#include "moab/Error.hpp"
void call_find | ( | TypeSequenceManager * | seqman, |
const std::set< int > & | removed, | ||
int | num_orig_entities, | ||
int & | n_failures | ||
Definition at line 1051 of file TestTypeSequenceManager.cpp.
References CHECK_EQUAL, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::find(), and MB_SUCCESS.
Referenced by test_threaded_access().
{ ErrorCode rval = MB_SUCCESS; const EntitySequence* seq; int n_queries = 10000; for( int i = 0; i < n_queries; i++ ) { long unsigned idx = ( (double)rand() / RAND_MAX * num_orig_entities ) + 1; // do not check for entities we've removed if( removed.count( idx ) != 0 ) continue; // search for this entity in the sequence manager rval = seqman->find( idx, seq ); CHECK_EQUAL( MB_SUCCESS, rval ); // check that the returned sequence actually contains this entity // (this is where threaded access used to fail) if( idx < seq->start_handle() || idx > seq->end_handle() ) { n_failures += 1; } } }
ErrorCode insert_seq | ( | TypeSequenceManager & | seqman, |
EntityHandle | start_handle, | ||
EntityID | count, | ||
SequenceData * | data, | ||
bool | del_data = false |
Definition at line 151 of file TestTypeSequenceManager.cpp.
References CHECK, moab::EntitySequence::end_handle(), ErrorCode, moab::TypeSequenceManager::insert_sequence(), MB_SUCCESS, and moab::EntitySequence::start_handle().
Referenced by make_basic_sequence(), regression_svn1952(), regression_svn1958(), regression_svn1960(), test_insert_sequence_merge(), test_insert_sequence_nomerge(), test_is_free_handle(), test_replace_subsequence(), and test_threaded_access().
{ EntitySequence* seq = new DumSeq( start_handle, count, data ); ErrorCode rval = seqman.insert_sequence( seq ); if( MB_SUCCESS != rval ) { delete seq; if( del_data ) delete data; } else { CHECK( start_handle >= seq->start_handle() ); CHECK( start_handle + count - 1 <= seq->end_handle() ); } return rval; }
int main | ( | ) |
Definition at line 61 of file TestTypeSequenceManager.cpp.
References error_count, regression_svn1952(), regression_svn1958(), regression_svn1960(), RUN_TEST, test_basic(), test_erase(), test_find(), test_find_free_handle(), test_find_free_sequence(), test_get_entities(), test_insert_sequence_merge(), test_insert_sequence_nomerge(), test_is_free_sequence(), test_lower_bound(), test_multi_thread_access(), test_remove_sequence(), test_replace_subsequence(), test_single_thread_access(), and test_upper_bound().
{ if( RUN_TEST( test_basic ) ) { printf( "BASIC USE TEST FAILED\nCANNOT TEST FURTHER\n" ); return 1; } int error_count = 0; error_count += RUN_TEST( test_lower_bound ); error_count += RUN_TEST( test_upper_bound ); error_count += RUN_TEST( test_find ); error_count += RUN_TEST( test_get_entities ); error_count += RUN_TEST( test_insert_sequence_merge ); error_count += RUN_TEST( test_insert_sequence_nomerge ); error_count += RUN_TEST( test_remove_sequence ); error_count += RUN_TEST( test_replace_subsequence ); error_count += RUN_TEST( test_erase ); error_count += RUN_TEST( test_find_free_handle ); error_count += RUN_TEST( test_find_free_sequence ); error_count += RUN_TEST( test_is_free_sequence ); #ifndef MOAB_FORCE_32_BIT_HANDLES error_count += RUN_TEST( test_single_thread_access ); error_count += RUN_TEST( test_multi_thread_access ); #endif error_count += RUN_TEST( regression_svn1952 ); error_count += RUN_TEST( regression_svn1958 ); error_count += RUN_TEST( regression_svn1960 ); if( !error_count ) printf( "ALL TESTS PASSED\n" ); else printf( "%d TESTS FAILED\n", error_count ); return error_count; }
void make_basic_sequence | ( | TypeSequenceManager & | seq | ) |
Definition at line 145 of file TestTypeSequenceManager.cpp.
Referenced by test_basic(), test_erase(), test_find(), test_find_free_handle(), test_find_free_sequence(), test_get_entities(), test_insert_sequence_merge(), test_is_free_sequence(), test_lower_bound(), test_remove_sequence(), and test_upper_bound().
{ EntitySequence *s, *t, *u; make_basic_sequence( seqman, s, t, u ); }
void make_basic_sequence | ( | TypeSequenceManager & | seq, |
EntitySequence *& | seq3to7, | ||
EntitySequence *& | seq100to111, | ||
EntitySequence *& | seq1001 | ||
Definition at line 172 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::EntitySequence::data(), moab::TypeSequenceManager::empty(), moab::TypeSequenceManager::end(), moab::EntitySequence::end_handle(), moab::TypeSequenceManager::get_number_entities(), insert_seq(), moab::EntitySequence::size(), and moab::EntitySequence::start_handle().
{ CHECK( seqman.empty() ); CHECK_EQUAL( (EntityID)0, seqman.get_number_entities() ); SequenceData* data = new SequenceData( 0, 1, 22000 );CHECK_ERR( insert_seq( seqman, 3, 5, data ) );CHECK_ERR( insert_seq( seqman, 100, 12, data ) );CHECK_ERR( insert_seq( seqman, 1001, 1, data ) ); CHECK( !seqman.empty() ); CHECK_EQUAL( (EntityID)18, seqman.get_number_entities() ); TypeSequenceManager::iterator iter = seqman.begin(); CHECK( iter != seqman.end() ); seq1 = *iter; CHECK_EQUAL( (EntityHandle)3, seq1->start_handle() ); CHECK_EQUAL( (EntityHandle)7, seq1->end_handle() ); CHECK_EQUAL( data, seq1->data() ); CHECK_EQUAL( (EntityID)5, seq1->size() ); ++iter; CHECK( iter != seqman.end() ); seq2 = *iter; CHECK_EQUAL( (EntityHandle)100, seq2->start_handle() ); CHECK_EQUAL( (EntityHandle)111, seq2->end_handle() ); CHECK_EQUAL( data, seq2->data() ); CHECK_EQUAL( (EntityID)12, seq2->size() ); ++iter; seq3 = *iter; CHECK( iter != seqman.end() ); CHECK_EQUAL( (EntityHandle)1001, seq3->start_handle() ); CHECK_EQUAL( (EntityHandle)1001, seq3->end_handle() ); CHECK_EQUAL( data, seq3->data() ); CHECK_EQUAL( (EntityID)1, seq3->size() ); ++iter; CHECK( iter == seqman.end() ); }
void regression_svn1952 | ( | ) |
Definition at line 1149 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_ERR, moab::TypeSequenceManager::find_free_sequence(), and insert_seq().
Referenced by main().
{ const EntityHandle last_handle = 50000; TypeSequenceManager seqman; SequenceData* data = new SequenceData( 0, 41673, last_handle );CHECK_ERR( insert_seq( seqman, 41686, 1000, data, true ) ); SequenceData* result_data; EntityID result_size; EntityHandle result_handle; result_handle = seqman.find_free_sequence( 1686, 4000, 2 * last_handle, result_data, result_size ); CHECK( result_handle > last_handle || result_handle + result_size <= 41673 ); CHECK( result_handle + result_size <= 2 * last_handle ); }
void regression_svn1958 | ( | ) |
Definition at line 1174 of file TestTypeSequenceManager.cpp.
{ const int data_size = 100; const EntityHandle data_start = 100; const EntityHandle data_end = data_start + data_size - 1; const int seq_offset = 2; TypeSequenceManager seqman; SequenceData* data = new SequenceData( 0, data_start, data_end );CHECK_ERR( insert_seq( seqman, data_start + seq_offset, data_size - seq_offset, data, true ) ); SequenceData* result_data; EntityID result_size; EntityHandle result_handle; result_handle = seqman.find_free_sequence( data_start - 1, 1, 100000, result_data, result_size ); CHECK( result_handle > data_end || result_handle + result_size <= data_start ); }
void regression_svn1960 | ( | ) |
Definition at line 1198 of file TestTypeSequenceManager.cpp.
{ const int data_size = 6000; const EntityHandle data_start = 4000; const EntityHandle data_end = data_start + data_size - 1; const int seq_offset = 1000; TypeSequenceManager seqman; SequenceData* data = new SequenceData( 0, data_start, data_end );CHECK_ERR( insert_seq( seqman, data_start + seq_offset, data_size - seq_offset, data, true ) ); SequenceData* result_data; EntityID result_size; EntityHandle result_handle; result_handle = seqman.find_free_sequence( data_start - 2, 1, 100000, result_data, result_size ); CHECK( result_handle + result_size <= data_start ); }
bool seqman_equal | ( | const EntityHandle | pair_array[][2], |
unsigned | num_pairs, | ||
const TypeSequenceManager & | seqman | ||
Definition at line 336 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), moab::EntitySequence::data(), moab::TypeSequenceManager::end(), moab::SequenceData::end_handle(), moab::EntitySequence::end_handle(), moab::ID_FROM_HANDLE(), moab::SequenceData::start_handle(), and moab::EntitySequence::start_handle().
Referenced by test_erase(), test_get_entities(), test_insert_sequence_merge(), test_insert_sequence_nomerge(), test_remove_sequence(), and test_replace_subsequence().
{ unsigned i; TypeSequenceManager::const_iterator j = seqman.begin(); EntitySequence* seq = 0; for( i = 0; i < num_pairs; ++i, ++j ) { if( j == seqman.end() ) break; if( seq && seq->end_handle() >= ( *j )->start_handle() ) { printf( "Sequence [%lu,%lu] overlaps sequence [%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( seq->start_handle() ), (unsigned long)ID_FROM_HANDLE( seq->end_handle() ), (unsigned long)ID_FROM_HANDLE( ( *j )->start_handle() ), (unsigned long)ID_FROM_HANDLE( ( *j )->end_handle() ) ); return false; } if( seq && seq->data() != ( *j )->data() && seq->data()->end_handle() >= ( *j )->data()->start_handle() ) { printf( "SequenceData [%lu,%lu] overlaps SequenceData [%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( seq->data()->start_handle() ), (unsigned long)ID_FROM_HANDLE( seq->data()->end_handle() ), (unsigned long)ID_FROM_HANDLE( ( *j )->data()->start_handle() ), (unsigned long)ID_FROM_HANDLE( ( *j )->data()->end_handle() ) ); return false; } seq = *j; if( seq->start_handle() > seq->end_handle() ) { printf( "Inverted sequence [%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( seq->start_handle() ), (unsigned long)ID_FROM_HANDLE( seq->end_handle() ) ); return false; } if( pair_array[i][0] != seq->start_handle() || pair_array[i][1] != seq->end_handle() ) break; if( seq->data()->start_handle() > seq->start_handle() || seq->data()->end_handle() < seq->end_handle() ) { printf( "Sequence [%lu,%lu] has data [%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( seq->start_handle() ), (unsigned long)ID_FROM_HANDLE( seq->end_handle() ), (unsigned long)ID_FROM_HANDLE( seq->data()->start_handle() ), (unsigned long)ID_FROM_HANDLE( seq->data()->end_handle() ) ); return false; } } if( i == num_pairs && j == seqman.end() ) return true; if( i < num_pairs ) printf( "Sequence Mismatch: Expected: [%lu,%lu], got ", (unsigned long)ID_FROM_HANDLE( pair_array[i][0] ), (unsigned long)ID_FROM_HANDLE( pair_array[i][1] ) ); else printf( "Sequence Mismatch: Expected END, got " ); if( j == seqman.end() ) printf( "END.\n" ); else printf( "[%lu,%lu]\n", (unsigned long)ID_FROM_HANDLE( ( *j )->start_handle() ), (unsigned long)ID_FROM_HANDLE( ( *j )->end_handle() ) ); return false; }
void test_basic | ( | ) |
Definition at line 213 of file TestTypeSequenceManager.cpp.
References make_basic_sequence().
{ TypeSequenceManager seqman; make_basic_sequence( seqman ); }
void test_erase | ( | ) |
Definition at line 693 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::empty(), moab::TypeSequenceManager::erase(), make_basic_sequence(), MB_ENTITY_NOT_FOUND, and seqman_equal().
{ TypeSequenceManager seqman; make_basic_sequence( seqman ); Error eh; // verify initial state EntityHandle exp1[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 } }; CHECK( seqman_equal( exp1, 3, seqman ) ); // try erasing invalid handles at start of existing sequence CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.erase( &eh, 1000, 1001 ) ); // try erasing invalid entities at end of existing sequence CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.erase( &eh, 3, 8 ) ); // verify initial state CHECK( seqman_equal( exp1, 3, seqman ) ); // erase from front of sequence CHECK_ERR( seqman.erase( &eh, 3, 6 ) ); EntityHandle exp2[][2] = { { 7, 7 }, { 100, 111 }, { 1001, 1001 } }; CHECK( seqman_equal( exp2, 3, seqman ) ); // erase from end of sequence CHECK_ERR( seqman.erase( &eh, 110, 111 ) ); EntityHandle exp3[][2] = { { 7, 7 }, { 100, 109 }, { 1001, 1001 } }; CHECK( seqman_equal( exp3, 3, seqman ) ); // erase from middle of sequence CHECK_ERR( seqman.erase( &eh, 105, 107 ) ); EntityHandle exp4[][2] = { { 7, 7 }, { 100, 104 }, { 108, 109 }, { 1001, 1001 } }; CHECK( seqman_equal( exp4, 4, seqman ) ); // erase sequence CHECK_ERR( seqman.erase( &eh, 7, 7 ) ); EntityHandle exp5[][2] = { { 100, 104 }, { 108, 109 }, { 1001, 1001 } }; CHECK( seqman_equal( exp5, 3, seqman ) ); // erase sequence CHECK_ERR( seqman.erase( &eh, 108, 109 ) ); EntityHandle exp6[][2] = { { 100, 104 }, { 1001, 1001 } }; CHECK( seqman_equal( exp6, 2, seqman ) ); // erase sequence CHECK_ERR( seqman.erase( &eh, 100, 104 ) ); EntityHandle exp7[][2] = { { 1001, 1001 } }; CHECK( seqman_equal( exp7, 1, seqman ) ); // erase sequence CHECK_ERR( seqman.erase( &eh, 1001, 1001 ) ); CHECK( seqman.empty() ); }
void test_find | ( | ) |
Definition at line 297 of file TestTypeSequenceManager.cpp.
References CHECK_EQUAL, moab::TypeSequenceManager::find(), and make_basic_sequence().
{ TypeSequenceManager seqman; EntitySequence *seq1, // 3 to 7 *seq2, // 100 to 111 *seq3, // 1001 *seq; make_basic_sequence( seqman, seq1, seq2, seq3 ); seq = seqman.find( 2 ); CHECK_EQUAL( NULL, seq ); seq = seqman.find( 3 ); CHECK_EQUAL( seq1, seq ); seq = seqman.find( 4 ); CHECK_EQUAL( seq1, seq ); seq = seqman.find( 7 ); CHECK_EQUAL( seq1, seq ); seq = seqman.find( 8 ); CHECK_EQUAL( NULL, seq ); seq = seqman.find( 99 ); CHECK_EQUAL( NULL, seq ); seq = seqman.find( 100 ); CHECK_EQUAL( seq2, seq ); seq = seqman.find( 110 ); CHECK_EQUAL( seq2, seq ); seq = seqman.find( 111 ); CHECK_EQUAL( seq2, seq ); seq = seqman.find( 112 ); CHECK_EQUAL( NULL, seq ); seq = seqman.find( 1000 ); CHECK_EQUAL( NULL, seq ); seq = seqman.find( 1001 ); CHECK_EQUAL( seq3, seq ); seq = seqman.find( 1002 ); CHECK_EQUAL( NULL, seq ); }
void test_find_free_handle | ( | ) |
Definition at line 745 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::end(), moab::TypeSequenceManager::find_free_handle(), make_basic_sequence(), and MB_END_ID.
{ bool append; TypeSequenceManager::iterator seq; TypeSequenceManager seqman; make_basic_sequence( seqman ); // { [3,7], [100,111], [1001] } seq = seqman.find_free_handle( 0, MB_END_ID, append ); CHECK( seq != seqman.end() ); // expect the first available handle (2). CHECK_EQUAL( (EntityHandle)3, ( *seq )->start_handle() ); CHECK_EQUAL( (EntityHandle)7, ( *seq )->end_handle() ); CHECK( !append ); // Expect end() if no adjacent sequence seq = seqman.find_free_handle( 9, 98, append ); CHECK( seq == seqman.end() ); // Try a limited handle range seq = seqman.find_free_handle( 8, 99, append ); CHECK( seq != seqman.end() ); // expect the first available handle (8). CHECK_EQUAL( (EntityHandle)3, ( *seq )->start_handle() ); CHECK_EQUAL( (EntityHandle)7, ( *seq )->end_handle() ); CHECK( append ); // Try an unambigious case (above tests have multiple // possible answers, were we assume the first available // handle). seq = seqman.find_free_handle( 8, 98, append ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)3, ( *seq )->start_handle() ); CHECK_EQUAL( (EntityHandle)7, ( *seq )->end_handle() ); CHECK( append ); // Try an unambigious case (above tests have multiple // possible answers, were we assume the first available // handle). seq = seqman.find_free_handle( 9, 99, append ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)100, ( *seq )->start_handle() ); CHECK_EQUAL( (EntityHandle)111, ( *seq )->end_handle() ); CHECK( !append ); // Try a case where the expected result handle // is in the middle of the input range. seq = seqman.find_free_handle( 900, 1100, append ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)1001, ( *seq )->start_handle() ); CHECK_EQUAL( (EntityHandle)1001, ( *seq )->end_handle() ); // Expect first available handle CHECK( !append ); }
void test_find_free_sequence | ( | ) |
Definition at line 799 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, moab::TypeSequenceManager::find_free_sequence(), make_basic_sequence(), and MB_END_ID.
{ EntityHandle start; SequenceData* data = 0; EntityID data_size = 0; TypeSequenceManager seqman; make_basic_sequence( seqman ); // { [3,7], [100,111], [1001] } SequenceData* expdata = ( *seqman.begin() )->data(); start = seqman.find_free_sequence( 2, 1, 3, data, data_size ); CHECK_EQUAL( expdata, data ); CHECK_EQUAL( (EntityHandle)1, start ); start = seqman.find_free_sequence( 3, 1, 7, data, data_size ); CHECK_EQUAL( (EntityHandle)0, start ); CHECK_EQUAL( NULL, data ); start = seqman.find_free_sequence( 30, 1, 120, data, data_size ); CHECK_EQUAL( expdata, data ); CHECK( start == 8 || start == 70 ); start = seqman.find_free_sequence( 10, 92, 999, data, data_size ); CHECK_EQUAL( expdata, data ); CHECK_EQUAL( (EntityHandle)112, start ); start = seqman.find_free_sequence( 100, 1, 600, data, data_size ); CHECK_EQUAL( expdata, data ); CHECK_EQUAL( (EntityHandle)112, start ); start = seqman.find_free_sequence( 1000, 1, MB_END_ID, data, data_size ); CHECK_EQUAL( expdata, data ); CHECK_EQUAL( (EntityHandle)1002, start ); start = seqman.find_free_sequence( 980, 1, 1800, data, data_size ); CHECK_EQUAL( (EntityHandle)0, start ); CHECK_EQUAL( NULL, data ); }
void test_get_entities | ( | ) |
Definition at line 402 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::empty(), entities, moab::TypeSequenceManager::get_entities(), moab::TypeSequenceManager::get_number_entities(), make_basic_sequence(), and seqman_equal().
{ TypeSequenceManager seqman; make_basic_sequence( seqman ); CHECK( !seqman.empty() ); CHECK_EQUAL( (EntityID)18, seqman.get_number_entities() ); Range entities; seqman.get_entities( entities ); CHECK_EQUAL( (size_t)18, entities.size() ); EntityHandle pairs[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 } }; CHECK( seqman_equal( pairs, 3, seqman ) ); }
void test_insert_sequence_merge | ( | ) |
Definition at line 418 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, insert_seq(), make_basic_sequence(), MB_ALREADY_ALLOCATED, and seqman_equal().
{ TypeSequenceManager seqman; make_basic_sequence( seqman ); SequenceData* data = ( *seqman.begin() )->data(); // append a sequence CHECK_ERR( insert_seq( seqman, 1003, 1, data ) ); EntityHandle exp1[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 }, { 1003, 1003 } }; CHECK( seqman_equal( exp1, 4, seqman ) ); // prepend a sequence CHECK_ERR( insert_seq( seqman, 1, 1, data ) ); EntityHandle exp2[][2] = { { 1, 1 }, { 3, 7 }, { 100, 111 }, { 1001, 1001 }, { 1003, 1003 } }; CHECK( seqman_equal( exp2, 5, seqman ) ); // insert sequence in middle CHECK_ERR( insert_seq( seqman, 150, 11, data ) ); EntityHandle exp3[][2] = { { 1, 1 }, { 3, 7 }, { 100, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } }; CHECK( seqman_equal( exp3, 6, seqman ) ); // merge sequence with predecessor CHECK_ERR( insert_seq( seqman, 8, 13, data ) ); EntityHandle exp4[][2] = { { 1, 1 }, { 3, 20 }, { 100, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } }; CHECK( seqman_equal( exp4, 6, seqman ) ); // merge sequence with following one CHECK_ERR( insert_seq( seqman, 87, 13, data ) ); EntityHandle exp5[][2] = { { 1, 1 }, { 3, 20 }, { 87, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } }; CHECK( seqman_equal( exp5, 6, seqman ) ); // merge sequence with two adjacent ones CHECK_ERR( insert_seq( seqman, 2, 1, data ) ); EntityHandle exp6[][2] = { { 1, 20 }, { 87, 111 }, { 150, 160 }, { 1001, 1001 }, { 1003, 1003 } }; CHECK( seqman_equal( exp6, 5, seqman ) ); // try to insert a sequence that overlaps on the end CHECK_EQUAL( MB_ALREADY_ALLOCATED, insert_seq( seqman, 900, 1001, data ) ); // try to insert a sequence that overlaps at the start CHECK_EQUAL( MB_ALREADY_ALLOCATED, insert_seq( seqman, 111, 140, data ) ); }
void test_insert_sequence_nomerge | ( | ) |
Definition at line 461 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::empty(), ErrorCode, insert_seq(), moab::TypeSequenceManager::insert_sequence(), MB_ALREADY_ALLOCATED, MB_SUCCESS, and seqman_equal().
{ TypeSequenceManager seqman; // make sure inserting a sequence w/out a SequenceData fails CHECK_EQUAL( MB_FAILURE, insert_seq( seqman, 1, 5, NULL ) ); CHECK( seqman.empty() ); // Now set up a TypeSequenceManager for testing // Insert an EntitySequence for which the corresponding SequenceData // is exactly the same size. SequenceData* data1 = new SequenceData( 0, 3, 7 ); DumSeq* seq = new DumSeq( data1 ); ErrorCode rval = seqman.insert_sequence( seq );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { delete seq; delete data1; return; } // Insert an EntitySequence with additional room on both ends of // the SequenceData SequenceData* data2 = new SequenceData( 0, 100, 999 ); seq = new DumSeq( 200, 100, data2 ); rval = seqman.insert_sequence( seq );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { delete seq; delete data2; return; } // Insert another EntitySequence sharing the previous SequenceData seq = new DumSeq( 400, 100, data2 ); rval = seqman.insert_sequence( seq );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { delete seq; return; } // Setup complete, begin tests // Test inserting sequence that appends an existing sequence // but overlaps underling SequenceData boundary SequenceData* data = new SequenceData( 0, 999, 1000 ); seq = new DumSeq( data ); rval = seqman.insert_sequence( seq ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, rval ); delete seq; delete data; // Test inserting sequence that prepends an existing sequence // but overlaps underling SequenceData boundary data = new SequenceData( 0, 50, 199 ); seq = new DumSeq( data ); rval = seqman.insert_sequence( seq ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, rval ); delete seq; delete data; // Test fits within existing, but has different SequenceData data = new SequenceData( 0, 500, 599 ); seq = new DumSeq( data ); rval = seqman.insert_sequence( seq ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, rval ); delete seq; delete data; // Make sure we're starting out with what we expect EntityHandle exp1[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 } }; CHECK( seqman_equal( exp1, 3, seqman ) ); // Test fits within existing, and has same data CHECK_ERR( insert_seq( seqman, 600, 100, data2 ) ); EntityHandle exp2[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 }, { 600, 699 } }; CHECK( seqman_equal( exp2, 4, seqman ) ); // Test is entirely outside existing data CHECK_ERR( insert_seq( seqman, 2000, 2, new SequenceData( 0, 2000, 2001 ), true ) ); EntityHandle exp3[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 }, { 600, 699 }, { 2000, 2001 } }; CHECK( seqman_equal( exp3, 5, seqman ) ); // Test abutts end of existing data CHECK_ERR( insert_seq( seqman, 1000, 6, new SequenceData( 0, 1000, 1005 ), true ) ); EntityHandle exp4[][2] = { { 3, 7 }, { 200, 299 }, { 400, 499 }, { 600, 699 }, { 1000, 1005 }, { 2000, 2001 } }; CHECK( seqman_equal( exp4, 6, seqman ) ); // Test abutts beginning of existing data CHECK_ERR( insert_seq( seqman, 50, 50, new SequenceData( 0, 50, 99 ), true ) ); EntityHandle exp5[][2] = { { 3, 7 }, { 50, 99 }, { 200, 299 }, { 400, 499 }, { 600, 699 }, { 1000, 1005 }, { 2000, 2001 } }; CHECK( seqman_equal( exp5, 7, seqman ) ); }
void test_is_free_handle | ( | ) |
Definition at line 861 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::end(), ErrorCode, moab::GeomUtil::first(), insert_seq(), moab::TypeSequenceManager::is_free_handle(), MB_ALREADY_ALLOCATED, MB_END_ID, and MB_SUCCESS.
{ // Construct a TypeSequenceManager with the following data: // EntitySequence: |[1,500]| |[601,1000]| |[2500,2599]| |[2800,2999]| // SequenceData: | [1,1000] | | [2001,3000] | ErrorCode rval; TypeSequenceManager seqman; SequenceData* data1 = new SequenceData( 0, 1, 1000 ); SequenceData* data2 = new SequenceData( 0, 2001, 3000 ); rval = insert_seq( seqman, 1, 500, data1, true );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { // data1 has been deleted by insert_seq call above return; } rval = insert_seq( seqman, 601, 400, data1, false );CHECK_ERR( rval ); rval = insert_seq( seqman, 2500, 100, data2, true );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { // data2 has been deleted by insert_seq call above return; } rval = insert_seq( seqman, 2800, 200, data2, false );CHECK_ERR( rval ); // Begin tests TypeSequenceManager::iterator seq; SequenceData* data; EntityHandle first, last; // Test handle in use CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 1, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 300, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 500, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 601, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2500, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2599, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2800, seq, data, first, last ) ); CHECK_EQUAL( MB_ALREADY_ALLOCATED, seqman.is_free_handle( 2999, seq, data, first, last ) ); // Test prepend to sequence seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 600, seq, data, first, last ) ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)601, ( *seq )->start_handle() ); CHECK_EQUAL( data1, data ); CHECK_EQUAL( (EntityHandle)600, first ); CHECK_EQUAL( (EntityHandle)600, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 2499, seq, data, first, last ) ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)2500, ( *seq )->start_handle() ); CHECK_EQUAL( data2, data ); CHECK_EQUAL( (EntityHandle)2499, first ); CHECK_EQUAL( (EntityHandle)2499, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 2799, seq, data, first, last ) ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)2800, ( *seq )->start_handle() ); CHECK_EQUAL( data2, data ); CHECK_EQUAL( (EntityHandle)2799, first ); CHECK_EQUAL( (EntityHandle)2799, last ); // Test append to sequence seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 501, seq, data, first, last ) ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)1, ( *seq )->start_handle() ); CHECK_EQUAL( data1, data ); CHECK_EQUAL( (EntityHandle)501, first ); CHECK_EQUAL( (EntityHandle)501, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 2600, seq, data, first, last ) ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)2500, ( *seq )->start_handle() ); CHECK_EQUAL( data2, data ); CHECK_EQUAL( (EntityHandle)2600, first ); CHECK_EQUAL( (EntityHandle)2600, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 3000, seq, data, first, last ) ); CHECK( seq != seqman.end() ); CHECK_EQUAL( (EntityHandle)2800, ( *seq )->start_handle() ); CHECK_EQUAL( data2, data ); CHECK_EQUAL( (EntityHandle)3000, first ); CHECK_EQUAL( (EntityHandle)3000, last ); // Test new sequence in existing SequenceData seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 502, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( data1, data ); CHECK_EQUAL( (EntityHandle)501, first ); CHECK_EQUAL( (EntityHandle)600, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 599, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( data1, data ); CHECK_EQUAL( (EntityHandle)501, first ); CHECK_EQUAL( (EntityHandle)600, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 2001, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( data2, data ); CHECK_EQUAL( (EntityHandle)2001, first ); CHECK_EQUAL( (EntityHandle)2499, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 2498, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( data2, data ); CHECK_EQUAL( (EntityHandle)2001, first ); CHECK_EQUAL( (EntityHandle)2499, last ); // Test new SequenceData seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 1001, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( (SequenceData*)0, data ); CHECK_EQUAL( (EntityHandle)1001, first ); CHECK_EQUAL( (EntityHandle)2000, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 1500, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( (SequenceData*)0, data ); CHECK_EQUAL( (EntityHandle)1001, first ); CHECK_EQUAL( (EntityHandle)2000, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 2000, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( (SequenceData*)0, data ); CHECK_EQUAL( (EntityHandle)1001, first ); CHECK_EQUAL( (EntityHandle)2000, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 3001, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( (SequenceData*)0, data ); CHECK_EQUAL( (EntityHandle)3001, first ); CHECK_EQUAL( (EntityHandle)MB_END_ID, last ); seq = seqman.end(); data = 0; first = last = 0; CHECK( seqman.is_free_handle( 10000, seq, data, first, last ) ); CHECK( seqman.end() == seq ); CHECK_EQUAL( (SequenceData*)0, data ); CHECK_EQUAL( (EntityHandle)3001, first ); CHECK_EQUAL( (EntityHandle)MB_END_ID, last ); }
void test_is_free_sequence | ( | ) |
Definition at line 837 of file TestTypeSequenceManager.cpp.
References moab::TypeSequenceManager::begin(), CHECK, CHECK_EQUAL, moab::TypeSequenceManager::is_free_sequence(), and make_basic_sequence().
{ SequenceData* data = 0; TypeSequenceManager seqman; make_basic_sequence( seqman ); // { [3,7], [100,111], [1001] } SequenceData* expdata = ( *seqman.begin() )->data(); CHECK( !seqman.is_free_sequence( 1, 3, data ) ); CHECK( seqman.is_free_sequence( 1, 2, data ) ); CHECK_EQUAL( expdata, data ); CHECK( !seqman.is_free_sequence( 7, 93, data ) ); CHECK( !seqman.is_free_sequence( 8, 93, data ) ); CHECK( seqman.is_free_sequence( 8, 92, data ) ); CHECK_EQUAL( expdata, data ); CHECK( !seqman.is_free_sequence( 111, 890, data ) ); CHECK( !seqman.is_free_sequence( 112, 890, data ) ); CHECK( seqman.is_free_sequence( 112, 879, data ) ); CHECK_EQUAL( expdata, data ); CHECK( seqman.is_free_sequence( 1002, 1, data ) ); CHECK_EQUAL( expdata, data ); CHECK( seqman.is_free_sequence( 2000, 20000, data ) ); CHECK_EQUAL( expdata, data ); }
void test_lower_bound | ( | ) |
Definition at line 219 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::end(), moab::TypeSequenceManager::lower_bound(), and make_basic_sequence().
{ TypeSequenceManager::const_iterator i; TypeSequenceManager seqman; EntitySequence *seq1, // 3 to 7 *seq2, // 100 to 111 *seq3; // 1001 make_basic_sequence( seqman, seq1, seq2, seq3 ); i = seqman.lower_bound( 2 ); CHECK_EQUAL( seq1, *i ); i = seqman.lower_bound( 3 ); CHECK_EQUAL( seq1, *i ); i = seqman.lower_bound( 4 ); CHECK_EQUAL( seq1, *i ); i = seqman.lower_bound( 7 ); CHECK_EQUAL( seq1, *i ); i = seqman.lower_bound( 8 ); CHECK_EQUAL( seq2, *i ); i = seqman.lower_bound( 99 ); CHECK_EQUAL( seq2, *i ); i = seqman.lower_bound( 100 ); CHECK_EQUAL( seq2, *i ); i = seqman.lower_bound( 110 ); CHECK_EQUAL( seq2, *i ); i = seqman.lower_bound( 111 ); CHECK_EQUAL( seq2, *i ); i = seqman.lower_bound( 112 ); CHECK_EQUAL( seq3, *i ); i = seqman.lower_bound( 1000 ); CHECK_EQUAL( seq3, *i ); i = seqman.lower_bound( 1001 ); CHECK_EQUAL( seq3, *i ); i = seqman.lower_bound( 1002 ); CHECK( i == seqman.end() ); }
void test_multi_thread_access | ( | ) |
Definition at line 1124 of file TestTypeSequenceManager.cpp.
References test_threaded_access().
{ test_threaded_access( 2 ); }
void test_remove_sequence | ( | ) |
Definition at line 558 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::EntitySequence::data(), make_basic_sequence(), MB_ENTITY_NOT_FOUND, moab::TypeSequenceManager::remove_sequence(), and seqman_equal().
{ TypeSequenceManager seqman; EntitySequence *seq1, // 3 to 7 *seq2, // 100 to 111 *seq3; // 1001 make_basic_sequence( seqman, seq1, seq2, seq3 ); // test removing something that hasn't been inserted bool last; DumSeq junk( 3, 5, NULL ); CHECK_EQUAL( MB_ENTITY_NOT_FOUND, seqman.remove_sequence( &junk, last ) ); EntityHandle exp1[][2] = { { 3, 7 }, { 100, 111 }, { 1001, 1001 } }; CHECK( seqman_equal( exp1, 3, seqman ) ); // remove the middle sequence CHECK_ERR( seqman.remove_sequence( seq2, last ) ); CHECK( !last ); delete seq2; // remove the first sequence CHECK_ERR( seqman.remove_sequence( seq1, last ) ); CHECK( !last ); delete seq1; // remove the last sequence CHECK_ERR( seqman.remove_sequence( seq3, last ) ); CHECK( last ); SequenceData* data = seq3->data(); delete seq3; delete data; }
void test_replace_subsequence | ( | ) |
Definition at line 591 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, ErrorCode, insert_seq(), MB_SUCCESS, moab::TypeSequenceManager::replace_subsequence(), and seqman_equal().
{ ErrorCode rval; TypeSequenceManager seqman; // create an initial set SequenceData* data1 = new SequenceData( 0, 51, 950 ); rval = insert_seq( seqman, 101, 100, data1, true );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { // data1 has been deleted by insert_seq call above return; } rval = insert_seq( seqman, 301, 300, data1 );CHECK_ERR( rval ); rval = insert_seq( seqman, 701, 100, data1 );CHECK_ERR( rval ); // try a sequence that is outside all existing data SequenceData* data = new SequenceData( 0, 10, 20 ); DumSeq* seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 ); CHECK_EQUAL( MB_FAILURE, rval ); delete seq; delete data; // try a sequence that overlaps the start of the data data = new SequenceData( 0, 40, 60 ); seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 ); CHECK_EQUAL( MB_FAILURE, rval ); delete seq; delete data; // try a sequence that is within the data but not within any sequence data = new SequenceData( 0, 60, 70 ); seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 ); CHECK_EQUAL( MB_FAILURE, rval ); delete seq; delete data; // try a sequence that overlaps an existing sequence data = new SequenceData( 0, 60, 101 ); seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 ); CHECK_EQUAL( MB_FAILURE, rval ); delete seq; delete data; // try a sequence that should work, but with a SequenceData that // overlaps an existing sequence data = new SequenceData( 0, 150, 200 ); seq = new DumSeq( 190, 200, data ); rval = seqman.replace_subsequence( seq, 0, 0 ); CHECK_EQUAL( MB_FAILURE, rval ); delete seq; delete data; // check that we're starting with what we expect EntityHandle exp1[][2] = { { 101, 200 }, { 301, 600 }, { 701, 800 } }; CHECK( seqman_equal( exp1, 3, seqman ) ); // split at start of sequence data = new SequenceData( 0, 101, 105 ); seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { delete seq; delete data; return; } EntityHandle exp2[][2] = { { 101, 105 }, { 106, 200 }, { 301, 600 }, { 701, 800 } }; CHECK( seqman_equal( exp2, 4, seqman ) ); // split at end of sequence data = new SequenceData( 0, 750, 800 ); seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { delete seq; delete data; return; } EntityHandle exp3[][2] = { { 101, 105 }, { 106, 200 }, { 301, 600 }, { 701, 749 }, { 750, 800 } }; CHECK( seqman_equal( exp3, 5, seqman ) ); // split at middle of sequence data = new SequenceData( 0, 400, 499 ); seq = new DumSeq( data ); rval = seqman.replace_subsequence( seq, 0, 0 );CHECK_ERR( rval ); if( MB_SUCCESS != rval ) { delete seq; delete data; return; } EntityHandle exp4[][2] = { { 101, 105 }, { 106, 200 }, { 301, 399 }, { 400, 499 }, { 500, 600 }, { 701, 749 }, { 750, 800 } }; CHECK( seqman_equal( exp4, 7, seqman ) ); }
void test_single_thread_access | ( | ) |
Definition at line 1119 of file TestTypeSequenceManager.cpp.
{ test_threaded_access( 1 ); }
void test_threaded_access | ( | int | n_threads | ) |
Definition at line 1075 of file TestTypeSequenceManager.cpp.
References call_find(), CHECK_EQUAL, CHECK_ERR, moab::TypeSequenceManager::erase(), and insert_seq().
Referenced by test_multi_thread_access(), and test_single_thread_access().
{ TypeSequenceManager seqman; std::set< int > removed_indices; // create a sequence from start to end EntityHandle start = 1, end = 200000; int i_end = end; SequenceData* data = new SequenceData( 0, start, end );CHECK_ERR( insert_seq( seqman, start, end, data ) ); // erase one hundred random entities from the sequence // to ensure a lot of switching of TypeSequenceManager::lastReferenced Error e; for( int i = 0; i < 100; i++ ) { int idx = ( (double)rand() / RAND_MAX * i_end ) + 1; removed_indices.insert( idx ); seqman.erase( &e, idx ); } // create a set of quereies per thread std::vector< std::thread > threads; std::vector< int > failures( n_threads, 0 ); for( int i = 0; i < n_threads; i++ ) { threads.push_back( std::thread( call_find, &seqman, removed_indices, i_end, std::ref< int >( failures[i] ) ) ); } // wait for threads to finish for( size_t i = 0; i < threads.size(); i++ ) { threads[i].join(); } int n_failures = 0; for( size_t i = 0; i < failures.size(); i++ ) n_failures += failures[i]; if( n_failures > 0 ) { std::cout << n_failures << " invalid sequences found." << std::endl; } CHECK_EQUAL( 0, n_failures ); }
void test_upper_bound | ( | ) |
Definition at line 259 of file TestTypeSequenceManager.cpp.
References CHECK, CHECK_EQUAL, moab::TypeSequenceManager::end(), make_basic_sequence(), and moab::TypeSequenceManager::upper_bound().
{ TypeSequenceManager::const_iterator i; TypeSequenceManager seqman; EntitySequence *seq1, // 3 to 7 *seq2, // 100 to 111 *seq3; // 1001 make_basic_sequence( seqman, seq1, seq2, seq3 ); i = seqman.upper_bound( 2 ); CHECK_EQUAL( seq1, *i ); i = seqman.upper_bound( 3 ); CHECK_EQUAL( seq2, *i ); i = seqman.upper_bound( 4 ); CHECK_EQUAL( seq2, *i ); i = seqman.upper_bound( 7 ); CHECK_EQUAL( seq2, *i ); i = seqman.upper_bound( 8 ); CHECK_EQUAL( seq2, *i ); i = seqman.upper_bound( 99 ); CHECK_EQUAL( seq2, *i ); i = seqman.upper_bound( 100 ); CHECK_EQUAL( seq3, *i ); i = seqman.upper_bound( 110 ); CHECK_EQUAL( seq3, *i ); i = seqman.upper_bound( 111 ); CHECK_EQUAL( seq3, *i ); i = seqman.upper_bound( 112 ); CHECK_EQUAL( seq3, *i ); i = seqman.upper_bound( 1000 ); CHECK_EQUAL( seq3, *i ); i = seqman.upper_bound( 1001 ); CHECK( i == seqman.end() ); }
