Types.hpp File Reference
+ Include dependency graph for Types.hpp:
+ This graph shows which files directly or indirectly include this file:
Variables
 MB_SUCCESS = 0
 MB_INDEX_OUT_OF_RANGE = 1
 MB_TYPE_OUT_OF_RANGE = 2
 MB_MEMORY_ALLOCATION_FAILED = 3
 MB_ENTITY_NOT_FOUND = 4
 MB_MULTIPLE_ENTITIES_FOUND = 5
 MB_TAG_NOT_FOUND = 6
 MB_FILE_DOES_NOT_EXIST = 7
 MB_FILE_WRITE_ERROR = 8
 MB_NOT_IMPLEMENTED = 9
 MB_ALREADY_ALLOCATED = 10
 MB_VARIABLE_DATA_LENGTH = 11
 MB_INVALID_SIZE = 12
 MB_UNSUPPORTED_OPERATION = 13
 MB_UNHANDLED_OPTION = 14
 MB_STRUCTURED_MESH = 15
 MB_TAG_BIT = 0
 MB_TAG_SPARSE = 1 << 0
 MB_TAG_DENSE = 1 << 1
 MB_TAG_MESH = 1 << 2
 MB_TAG_BYTES = 1 << 3
 MB_TAG_VARLEN = 1 << 4
 MB_TAG_CREAT = 1 << 5
 MB_TAG_EXCL = 1 << 6
 MB_TAG_STORE = 1 << 7
 MB_TAG_ANY = 1 << 8
 MB_TAG_NOOPQ = 1 << 9
 MB_TYPE_OPAQUE = 0
 MB_TYPE_INTEGER = 1
 MB_TYPE_DOUBLE = 2
 MB_TYPE_BIT = 3
 MB_TYPE_HANDLE = 4
 MESHSET_TRACK_OWNER = 0x1
 MESHSET_SET = 0x2
 SENSE_INVALID = -2
 SENSE_REVERSE = -1
 SENSE_BOTH = 0
Types and names
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. Types used in the MOAB interface
enum  Constants { MB_VARIABLE_LENGTH = -1 }
typedef struct TagInfo * Tag
enum MOAB_EXPORT ErrorCode
enum MOAB_EXPORT TagType
enum MOAB_EXPORT DataType
enum MOAB_EXPORT EntitySetProperty
enum MOAB_EXPORT SenseType
Typedef Documentation
typedef struct TagInfo* Tag
Misc. integer constants, declared in enum for portability
Examples:
ComputeTriDual.cpp.
Definition at line 110 of file Types.hpp.
Enumeration Type Documentation
enum Constants
Enumerator:
MB_VARIABLE_LENGTH
Length value for variable-length tags
Definition at line 63 of file Types.hpp.
    MB_VARIABLE_LENGTH = -1 /**< Length value for variable-length tags */
Variable Documentation
Specify data type for tags.
Definition at line 87 of file Types.hpp.
    MB_TYPE_OPAQUE   = 0, /**< byte array */
    MB_TYPE_INTEGER  = 1, /**< native 'int' type */
    MB_TYPE_DOUBLE   = 2, /**< native 'double' type */
    MB_TYPE_BIT      = 3, /**< mandatory type for tags with MB_TAG_BIT storage */
    MB_TYPE_HANDLE   = 4, /**< EntityHandle */
    MB_MAX_DATA_TYPE = MB_TYPE_HANDLE
Meshset options: properties for meshset creation. Values are bit flags that may be combined with a bitwise OR (|)
Definition at line 116 of file Types.hpp.
    MESHSET_TRACK_OWNER = 0x1, /**< create entity to meshset adjacencies */
    MESHSET_SET         = 0x2, /**< set contents are unique */
    MESHSET_ORDERED     = 0x4  /**< order of set contents is preserved */
MOAB error codes
Examples:
addPCdata.cpp, ComputeTriDual.cpp, copyPartition.cpp, CrystalRouterExample.cpp, DeformMeshRemap.cpp, DirectAccessNoHoles.cpp, DirectAccessWithHoles.cpp, ErrorHandlingSimulation.cpp, ExtractLand.cpp, ExtrudePoly.cpp, GenLargeMesh.cpp, GetEntities.cpp, HelloMOAB.cpp, HelloParMOAB.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, LoadPartial.cpp, QuadTriConv.cpp, ReadPartFile.cpp, ReadWriteTest.cpp, ReduceExchangeTags.cpp, SetsNTags.cpp, StructuredMeshSimple.cpp, TestErrorHandling.cpp, TestErrorHandlingPar.cpp, TestExodusII.cpp, and VisTags.cpp.
Definition at line 37 of file Types.hpp.
Referenced by moab::GeomTopoTool::A_is_in_B(), moab::AdaptiveKDTree::AdaptiveKDTree(), moab::AEntityFactory::add_adjacency(), moab::Skinner::add_adjacency(), moab::HalfFacetRep::add_cells_of_single_component(), add_dead_elems_to_impl_compl(), moab::SpatialLocator::add_elems(), moab::ReadABAQUS::add_entity_set(), add_field_value(), moab::GeomTopoTool::add_geo_set(), moab::DualTool::add_graphics_point(), moab::ParallelComm::add_pcomm(), moab::ScdBox::add_vbox(), moab::ParallelComm::add_verts(), moab::Core::adjacencies_iterate(), moab::VerdictWrapper::all_quality_measures(), moab::ReadVtk::allocate_elements(), moab::SequenceManager::allocate_mesh_set(), moab::ReadVtk::allocate_vertices(), moab::HalfFacetRep::another_halfedge(), moab::WriteHDF5Parallel::append_serial_tag_data(), moab::Coupler::apply_group_norm_factor(), moab::TempestOnlineMap::ApplyWeights(), moab::area_coordinates(), moab::IntxAreaUtils::area_on_sphere(), moab::IntxAreaUtils::area_spherical_element(), moab::WriteSTL::ascii_write_triangles(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ParallelComm::assign_entities_part(), moab::ParallelComm::assign_global_ids(), moab::ScdInterface::assign_global_ids(), moab::ReadUtil::assign_ids(), moab::ReadNASTRAN::assign_ids(), moab::WriteUtil::assign_ids(), moab::TempestRemapper::assign_vertex_element_IDs(), moab::DualTool::atomic_pillow(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::HiReconstruction::average_vertex_normal(), moab::HiReconstruction::average_vertex_tangent(), moab::ReadMCNP5::average_with_existing_tally(), ZoltanPartitioner::balance_mesh(), moab::AdaptiveKDTree::best_subdivision_plane(), moab::AdaptiveKDTree::best_subdivision_snap_plane(), moab::AdaptiveKDTree::best_vertex_median_plane(), moab::AdaptiveKDTree::best_vertex_sample_plane(), moab::WriteSTL::binary_write_triangles(), moab::GeomQueryTool::boundary_case(), moab::FBEngine::boundary_mesh_edges_on_face(), moab::FBEngine::boundary_nodes_on_face(), moab::OrientedBoxTreeTool::box(), moab::ScdInterface::box_dims_tag(), moab::box_from_axes(), moab::ScdInterface::box_periodic_tag(), moab::ScdInterface::box_set_tag(), moab::FBEngine::BreakTriangle2(), moab::MeshGeneration::BrickInstance(), moab::ParallelComm::broadcast_entities(), moab::BVHTree::bruteforce_find(), SphereDecomp::build_hexes(), moab::ReadRTT::build_moab(), build_new_surface(), moab::RangeSetIterator::build_pair_vec(), moab::OrientedBoxTreeTool::build_sets(), moab::ParallelComm::build_sharedhps_list(), SphereDecomp::build_sphere_mesh(), moab::AdaptiveKDTree::build_tree(), moab::BVHTree::build_tree(), moab::OrientedBoxTreeTool::build_tree(), moab::AxisBox::calculate(), moab::BSPTreeIter::calculate_polyhedron(), moab::Util::centroid(), moab::FBEngine::chain_able_edge(), moab::FBEngine::chain_edges(), moab::FBEngine::chain_two_edges(), moab::DualTool::check_1d_loop_edge(), moab::Core::check_adjacencies(), moab::ParallelComm::check_all_shared_handles(), moab::ParallelComm::check_clean_iface(), moab::DualTool::check_dual_adjs(), moab::DualTool::check_dual_equiv_edges(), moab::GeomTopoTool::check_edge_sense_tags(), moab::AEntityFactory::check_equiv_entities(), moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperGCRM::check_existing_mesh(), moab::NCHelperMPAS::check_existing_mesh(), moab::ScdNCHelper::check_existing_mesh(), moab::GeomTopoTool::check_face_sense_tag(), moab::GeomTopoTool::check_geom_tag(), moab::GeomTopoTool::check_gid_tag(), moab::ParallelComm::check_global_ids(), check_handle_tag_type(), moab::check_int_tag(), moab::ParallelComm::check_local_shared(), moab::HalfFacetRep::check_mixed_entity_type(), moab::GeomTopoTool::check_model(), moab::ParallelComm::check_my_shared_handles(), moab::ParallelComm::check_sent_ents(), moab::WriteHDF5Parallel::check_serial_tag_data(), moab::check_tag_type(), moab::SequenceManager::check_valid_entities(), moab::Skinner::classify_2d_boundary(), moab::ParallelComm::clean_shared_tags(), cleanup_after_intersection(), moab::MeshSet::clear_all(), moab::MeshTag::clear_data(), moab::BitTag::clear_data(), moab::VarLenSparseTag::clear_data(), moab::SparseTag::clear_data(), moab::DenseTag::clear_data(), moab::Core::clear_meshset(), moab::GeomQueryTool::closest_to_location(), moab::OrientedBoxTreeTool::closest_to_location(), moab::closest_to_triangles(), moab::AdaptiveKDTree::closest_triangle(), moab::HalfFacetRep::collect_and_compare(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteHelper::collect_variable_data(), moab::MeshTopoUtil::common_entity(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), compute_area(), moab::HiReconstruction::compute_average_vertex_normals_surf(), moab::HiReconstruction::compute_average_vertex_tangents_curve(), moab::SmoothCurve::compute_control_points_on_boundary_edges(), compute_dual_mesh(), moab::OrientedBox::compute_from_2d_cells(), moab::OrientedBox::compute_from_vertices(), moab::SmoothFace::compute_internal_control_points_on_facets(), moab::FBEngine::compute_intersection_points(), compute_lagrange_mesh_on_sphere(), SphereDecomp::compute_nodes(), compute_normals(), moab::ParCommGraph::compute_partition(), moab::ScdInterface::compute_partition(), moab::TreeStats::compute_stats(), moab::SmoothFace::compute_tangents_for_each_edge(), moab::SmoothCurve::compute_tangents_for_each_edge(), compute_tracer_case1(), compute_velocity_case1(), moab::TempestRemapper::ComputeGlobalLocalMaps(), moab::Intx2MeshInPlane::computeIntersectionBetweenTgtAndSrc(), moab::IntxRllCssphere::computeIntersectionBetweenTgtAndSrc(), moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc(), moab::TempestOnlineMap::ComputeMetrics(), moab::TempestRemapper::ComputeOverlapMesh(), moab::Core::connect_iterate(), moab::Coupler::constant_interp(), moab::MeshTopoUtil::construct_aentities(), moab::ScdInterface::construct_box(), moab::ReadCCMIO::construct_cells(), moab::DualTool::construct_dual(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_hyperplanes(), moab::DualTool::construct_dual_vertex(), moab::DualTool::construct_dual_vertices(), moab::BVHTree::construct_element_vec(), moab::DualTool::construct_hex_dual(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::construct_hm_3D(), moab::NestedRefine::construct_hm_entities(), moab::DualTool::construct_hp_parent_child(), moab::DualTool::construct_new_hyperplane(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_obb_trees(), moab::GeomTopoTool::construct_vertex_ranges(), moab::TempestRemapper::ConstructCoveringSet(), moab::DamselUtil::container_to_range(), moab::HigherOrderFactory::convert(), moab::MeshSet::convert(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::HigherOrderFactory::convert_sequence(), moab::TempestRemapper::convert_tempest_mesh_private(), moab::SpectralMeshTool::convert_to_coarse(), moab::BVHTree::convert_tree(), moab::TempestRemapper::ConvertMeshToTempest(), moab::Core::coords_iterate(), moab::NestedRefine::copy_vertices_from_prev_level(), moab::ParallelComm::correct_thin_ghost_layers(), moab::WriteHDF5::count_adjacencies(), count_owned(), moab::WriteHDF5::count_set_size(), moab::NestedRefine::count_subentities(), moab::HalfFacetRep::count_subentities(), moab::OrientedBox::covariance_data_from_tris(), moab::MeshSet::create_adjacencies(), moab::WriteHDF5Parallel::create_adjacency_tables(), moab::ScdInterface::create_box_set(), moab::ReadCCMIO::create_cell_from_faces(), create_coarse_mesh(), moab::NCHelper::create_conventional_tags(), moab::ReadCGM::create_curve_facets(), moab::WriteHDF5Parallel::create_dataset(), moab::NCHelper::create_dummy_variables(), moab::SequenceManager::create_element(), moab::Core::create_element(), moab::WriteHDF5Parallel::create_element_tables(), moab::ReadIDEAS::create_elements(), moab::ReadCGNS::create_elements(), moab::ReadGmsh::create_elements(), moab::ReadMCNP5::create_elements(), moab::SequenceManager::create_entity_sequence(), moab::ReadUtil::create_entity_sets(), moab::ReadCGM::create_entity_sets(), moab::AEntityFactory::create_explicit_adjs(), create_fine_mesh(), moab::ReadUtil::create_gather_set(), moab::NCHelperMPAS::create_gather_set_cells(), moab::NCHelperGCRM::create_gather_set_edges(), moab::NCHelperMPAS::create_gather_set_edges(), moab::NCHelperGCRM::create_gather_set_vertices(), moab::NCHelperMPAS::create_gather_set_vertices(), moab::ReadRTT::create_group(), moab::ReadCGM::create_group_entsets(), moab::NestedRefine::create_hm_storage_single_level(), moab::ParallelComm::create_iface_pc_links(), moab::ReadABAQUS::create_instance_of_part(), create_int_ents(), moab::ParallelComm::create_interface_sets(), create_lagr_mesh(), moab::NCHelperMPAS::create_local_cells(), moab::NCHelperGCRM::create_local_edges(), moab::NCHelperMPAS::create_local_edges(), moab::NCHelperGCRM::create_local_vertices(), moab::NCHelperMPAS::create_local_vertices(), moab::ReadNASTRAN::create_materials(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::ScdNCHelper::create_mesh(), create_mesh(), create_mesh_no_holes(), moab::SequenceManager::create_mesh_set(), create_mesh_with_holes(), moab::SequenceManager::create_meshset_sequence(), moab::WriteHDF5Parallel::create_meshset_tables(), moab::ReadOBJ::create_new_face(), moab::FBEngine::create_new_gedge(), moab::ReadOBJ::create_new_group(), moab::ReadOBJ::create_new_object(), moab::ReadOBJ::create_new_vertex(), moab::WriteHDF5Parallel::create_node_table(), moab::NCHelperGCRM::create_padded_gather_set_cells(), moab::NCHelperMPAS::create_padded_gather_set_cells(), moab::NCHelperGCRM::create_padded_local_cells(), moab::NCHelperMPAS::create_padded_local_cells(), moab::ParallelComm::create_part(), moab::ReadParallel::create_partition_sets(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::Tree::create_root(), moab::SequenceManager::create_scd_sequence(), moab::ScdInterface::create_scd_sequence(), moab::Core::create_scd_sequence(), moab::Core::create_set_iterator(), moab::ReadCGNS::create_sets(), moab::ReadGmsh::create_sets(), moab::ReadTemplate::create_sets(), moab::Skinner::create_side(), moab::ReadNCDF::create_sideset_element(), IntxUtilsCSLAM::create_span_quads(), moab::SpectralMeshTool::create_spectral_elems(), moab::ReadCGM::create_surface_facets(), moab::SequenceManager::create_sweep_sequence(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::RefinerTagManager::create_tag_internal(), moab::WriteHDF5Parallel::create_tag_tables(), moab::ReadMCNP5::create_tags(), moab::ReadCGM::create_topology(), moab::BSPTree::create_tree(), moab::ReadOBJ::create_tri_faces(), moab::Coupler::create_tuples(), moab::AEntityFactory::create_vert_elem_adjacencies(), moab::SequenceManager::create_vertex(), moab::ReadIDEAS::create_vertices(), moab::ReadCGM::create_vertices(), moab::ReadMCNP5::create_vertices(), moab::Core::create_vertices(), moab::FBEngine::create_volume_with_direction(), moab::FBEngine::createEntSet(), moab::FBEngine::createTag(), moab::Intx2Mesh::createTags(), CreateTempestMesh(), moab::DataCoupler::DataCoupler(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::Skinner::deinitialize(), moab::GeomTopoTool::delete_all_obb_trees(), moab::DualTool::delete_dual_entities(), moab::SequenceManager::delete_entities(), moab::Core::delete_entities(), moab::ParallelComm::delete_entities(), moab::Core::delete_mesh(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::FBEngine::delete_smooth_tags(), moab::BSPTree::delete_tree(), moab::OrientedBoxTreeTool::delete_tree(), moab::Tree::delete_tree_sets(), moab::DualTool::delete_whole_dual(), moab::ParallelComm::destroy_part(), moab::HalfFacetRep::determine_border_vertices(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_incident_halffaces(), moab::HalfFacetRep::determine_incident_halfverts(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), moab::Intx2Mesh::DetermineOrderedNeighbors(), moab::GeomTopoTool::dimension(), moab::BVHTree::distance_search(), moab::AdaptiveKDTree::distance_search(), moab::FBEngine::divide_triangle(), moab::Coupler::do_normalization(), do_test_mode(), moab::BSPTreeIter::down(), moab::BSPTreeBoxIter::down(), moab::DualTool::dualCurve_tag(), moab::DualTool::dualEntity_tag(), moab::DualTool::dualGraphicsPoint_tag(), moab::DualTool::dualSurface_tag(), moab::DualTool::DualTool(), moab::GeomTopoTool::duplicate_model(), moab::GQT_IntRegCtxt::edge_node_piercing_intersect(), moab::Skinner::edge_reversed(), moab::IntxUtils::enforce_convexity(), moab::GeomTopoTool::entity_by_id(), moab::Skinner::entity_deletable(), moab::MeshTopoUtil::equivalent_entities(), moab::TypeSequenceManager::erase(), moab::ParallelComm::estimate_ents_buffer_size(), moab::NestedRefine::estimate_hm_storage(), moab::ParallelComm::estimate_sets_buffer_size(), moab::SmoothFace::eval_bezier_patch(), moab::SmoothFace::eval_bezier_patch_normal(), moab::LinearTet::evaluate_reverse(), moab::LinearTri::evaluate_reverse(), moab::EvalSet::evaluate_reverse(), moab::SmoothFace::evaluate_smooth_edge(), moab::SmoothCurve::evaluate_smooth_edge(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_ghost_cells(), moab::NestedRefine::exchange_ghosts(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_owned_meshs(), moab::ParallelComm::exchange_tags(), DeformMeshRemap::execute(), McnpData::extract_tally_data(), moab::DualTool::extraDualEntity_tag(), moab::ReadSmf::face(), moab::DualTool::face_open_collapse(), moab::Skinner::face_reversed(), moab::DualTool::face_shrink(), moab::SmoothFace::facet_area_coordinate(), FBiGeom_destroyTag(), FBiGeom_getArrAdj(), FBiGeom_getEgEvalXYZ(), FBiGeom_getEgFcSense(), FBiGeom_getEgVtxSense(), FBiGeom_getEnt2ndAdj(), FBiGeom_getEntAdj(), FBiGeom_getEntBoundBox(), FBiGeom_getEntClosestPt(), FBiGeom_getEntities(), FBiGeom_getEntNrmlSense(), FBiGeom_getEntNrmlXYZ(), FBiGeom_getEntSets(), FBiGeom_getEntTgntU(), FBiGeom_getEntType(), FBiGeom_getEntURange(), FBiGeom_getEntUtoXYZ(), FBiGeom_getFcEvalXYZ(), FBiGeom_getNumEntSets(), FBiGeom_getNumOfType(), FBiGeom_getPntRayIntsct(), FBiGeom_getRootSet(), FBiGeom_getVtxCoord(), FBiGeom_isEntAdj(), FBiGeom_load(), FBiGeom_measure(), moab::HalfFacetRep::fid_from_halfacet(), fill_coord_on_edges(), moab::ParallelComm::filter_pstatus(), moab::Tree::find_all_trees(), moab::ScdInterface::find_boxes(), moab::AdaptiveKDTree::find_close_triangle(), moab::ElemEvaluator::find_containing_entity(), moab::SmoothFace::find_edges_orientations(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), moab::ParallelComm::find_existing_entity(), moab::Skinner::find_geometric_skin(), moab::GeomTopoTool::find_geomsets(), moab::Skinner::find_inferred_edges(), moab::Skinner::find_match(), moab::HalfFacetRep::find_matching_halfedge(), moab::HalfFacetRep::find_matching_halfface(), moab::HalfFacetRep::find_matching_implicit_edge_in_cell(), moab::MergeMesh::find_merged_to(), DeformMeshRemap::find_other_sets(), moab::BVHTree::find_point(), moab::ReadHDF5::find_sets_containing(), moab::NestedRefine::find_shortest_diagonal_octahedron(), moab::Skinner::find_skin(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_scd(), moab::Skinner::find_skin_vertices(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::HalfFacetRep::find_total_edges_2d(), moab::HalfFacetRep::find_total_edges_faces_3d(), moab::FBEngine::find_vertex_set_for_node(), moab::GeomQueryTool::find_volume(), moab::GeomQueryTool::find_volume_slow(), moab::Intx2Mesh::FindMaxEdges(), moab::Intx2Mesh::FindMaxEdgesInSet(), moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), moab::IntxUtils::fix_degenerate_quads(), fix_surface_senses(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_addl_ents(), moab::DualTool::foc_get_ents(), moab::DualTool::foc_get_stars(), moab::ParCommGraph::form_mesh_from_tuples(), moab::ParCommGraph::form_tuples_to_migrate_mesh(), moab::DualTool::fs_check_quad_sense(), moab::DualTool::fs_get_quad_loops(), moab::DualTool::fs_get_quads(), moab::DualTool::fsr_get_fourth_quad(), FunctionA(), FunctionB(), moab::WriteHDF5::gather_all_mesh(), moab::ParallelComm::gather_data(), moab::WriteUtil::gather_entities(), moab::HalfFacetRep::gather_halfedges(), moab::WriteHDF5Parallel::gather_interface_meshes(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteCCMIO::gather_matset_info(), moab::WriteVtk::gather_mesh(), moab::WriteHDF5::gather_mesh_info(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::WriteCCMIO::gather_neuset_info(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadUtil::gather_related_ents(), gather_set_stats(), gather_tag_counts(), moab::WriteHDF5::gather_tags(), moab::NestedRefine::generate_hm(), moab::GeomTopoTool::generate_implicit_complement(), moab::NestedRefine::generate_mesh_hierarchy(), moab::ReadRTT::generate_parent_child_links(), moab::ReadRTT::generate_topology(), moab::TempestRemapper::GenerateCSMeshMetadata(), moab::TempestRemapper::GenerateMeshMetadata(), moab::TempestOnlineMap::GenerateRemappingWeights(), moab::GeomTopoTool::geometrize_surface_set(), moab::GeomTopoTool::GeomTopoTool(), moab::ScdBox::get_adj_edge_or_face(), moab::NestedRefine::get_adjacencies(), moab::HalfFacetRep::get_adjacencies(), moab::AEntityFactory::get_adjacencies(), moab::WriteUtil::get_adjacencies(), moab::Core::get_adjacencies(), moab::WriteHDF5::get_adjacencies(), moab::get_adjacencies_intersection(), moab::get_adjacencies_union(), moab::AEntityFactory::get_adjacency_ptr(), get_adjacent_elems(), moab::ParallelComm::get_all_pcomm(), moab::VarLenDenseTag::get_array(), moab::DenseTag::get_array_private(), moab::AEntityFactory::get_associated_meshsets(), moab::MeshTopoUtil::get_average_position(), get_barycenters(), get_boundary_entities(), moab::GeomTopoTool::get_bounding_coords(), moab::Tree::get_box_tag(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::WriteCGNS::get_cell_entities(), moab::DualTool::get_cell_points(), moab::Core::get_child_meshsets(), moab::OrientedBoxTreeTool::get_close_tris(), moab::ParallelComm::get_comm_procs(), moab::WriteCGNS::get_conn_table(), moab::NestedRefine::get_connectivity(), moab::SweptElementSeq::get_connectivity(), moab::StructuredElementSeq::get_connectivity(), moab::Core::get_connectivity(), moab::Core::get_connectivity_by_type(), moab::Core::get_contained_meshsets(), moab::ReadDamsel::get_contents(), moab::NestedRefine::get_coordinates(), moab::Core::get_coords(), moab::DenseTag::get_data(), moab::VarLenDenseTag::get_data(), moab::VarLenSparseTag::get_data(), moab::SparseTag::get_data(), moab::ReadCCMIO::get_dbl_option(), get_degree_seq(), get_departure_grid(), moab::MeshSetSequence::get_dimension(), moab::HalfFacetRep::get_down_adjacencies(), moab::HalfFacetRep::get_down_adjacencies_2d(), moab::HalfFacetRep::get_down_adjacencies_edg_3d(), moab::HalfFacetRep::get_down_adjacencies_face_3d(), moab::AEntityFactory::get_down_adjacency_elements(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::DualTool::get_dual_entities(), moab::DualTool::get_dual_entity(), moab::DualTool::get_dual_hyperplane(), moab::DualTool::get_dual_hyperplanes(), moab::WriteCGNS::get_edge_entities(), moab::AEntityFactory::get_element(), moab::ReadUtil::get_element_connect(), moab::WriteUtil::get_element_connect(), moab::AEntityFactory::get_elements(), moab::ReadABAQUS::get_elements_by_id(), moab::MeshSetSequence::get_entities(), moab::Tqdcfr::get_entities(), moab::Core::get_entities_by_dimension(), moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), moab::BitTag::get_entities_with_bits(), moab::WriteUtil::get_entity_list_pointers(), moab::EvalSet::get_eval_set(), moab::DualTool::get_extra_dual_entity(), moab::HalfFacetRep::get_face_edges(), moab::WriteCGNS::get_face_entities(), moab::ReadUtil::get_gather_set(), moab::ParallelComm::get_ghosted_entities(), moab::WriteCCMIO::get_gids(), moab::Coupler::get_gl_points_on_elements(), get_gnomonic_plane(), moab::DualTool::get_graphics_points(), moab::Coupler::get_group_integ_vals(), get_group_names(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::HalfFacetRep::get_half_facet_in_comp(), moab::ParallelComm::get_iface_entities(), get_imesh_mesh(), moab::AdaptiveKDTree::get_info(), moab::FileOptions::get_int_option(), moab::ReadCCMIO::get_int_option(), moab::ParallelComm::get_interface_procs(), moab::ParallelData::get_interface_sets(), moab::ParallelComm::get_interface_sets(), get_intersection_weights(), moab::FileOptions::get_ints_option(), moab::AdaptiveKDTree::get_last_iterator(), get_linear_reconstruction(), moab::ParallelComm::get_local_handles(), moab::NestedRefine::get_local_vid(), moab::MeshTopoUtil::get_manifold(), moab::Coupler::get_matching_entities(), get_max_volume(), moab::AEntityFactory::get_memory_use(), moab::Tqdcfr::get_mesh_entities(), moab::Tqdcfr::get_names(), moab::HalfFacetRep::get_neighbor_adjacencies(), moab::HalfFacetRep::get_neighbor_adjacencies_2d(), moab::ScdInterface::get_neighbor_alljkbal(), moab::ScdInterface::get_neighbor_alljorkori(), moab::ScdInterface::get_neighbor_sqij(), moab::ScdInterface::get_neighbor_sqijk(), moab::ScdInterface::get_neighbor_sqjk(), moab::AdaptiveKDTreeIter::get_neighbors(), moab::BSPTreeBoxIter::get_neighbors(), moab::WriteTemplate::get_neuset_elems(), moab::WriteSLAC::get_neuset_elems(), moab::WriteCCMIO::get_neuset_elems(), moab::ReorderTool::get_new_handles(), moab::RangeSetIterator::get_next_arr(), moab::VectorSetIterator::get_next_arr(), moab::ReadUtil::get_node_coords(), moab::WriteUtil::get_node_coords(), moab::ReadABAQUS::get_nodes_by_id(), moab::FBEngine::get_nodes_from_edge(), moab::GeomQueryTool::get_normal(), moab::SmoothFace::get_normals_for_vertices(), moab::HiReconstruction::get_normals_surf(), moab::FileOptions::get_null_option(), moab::WriteHDF5::get_num_sparse_tagged_entities(), moab::Core::get_number_entities_by_dimension(), moab::Core::get_number_entities_by_handle(), moab::Core::get_number_entities_by_type(), moab::Core::get_number_entities_by_type_and_tag(), moab::GeomTopoTool::get_obb(), moab::DualTool::get_opposite_verts(), moab::FileOptions::get_option(), moab::ReadUtil::get_ordered_vertices(), moab::SharedSetData::get_owner(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_owning_part(), moab::ScdBox::get_params(), moab::MeshSetSequence::get_parent_child_meshsets(), moab::Core::get_parent_meshsets(), moab::ParallelComm::get_part_entities(), moab::ParallelComm::get_part_neighbor_ids(), moab::ParallelData::get_partition_sets(), moab::ParallelComm::get_pcomm(), moab::AEntityFactory::get_polyhedron_vertices(), moab::ParallelComm::get_proc_nvecs(), moab::ParallelComm::get_pstatus(), moab::ParallelComm::get_pstatus_entities(), moab::DualTool::get_radial_dverts(), moab::FileOptions::get_real_option(), moab::FileOptions::get_reals_option(), moab::ParallelComm::get_remote_handles(), moab::ReorderTool::get_reordered_handles(), moab::GeomTopoTool::get_sense(), moab::GeomTopoTool::get_senses(), moab::ParallelComm::get_sent_ents(), moab::ReadSms::get_set(), moab::ReadABAQUS::get_set_by_name(), moab::ReadABAQUS::get_set_elements(), moab::ReadABAQUS::get_set_elements_by_name(), moab::WriteCGNS::get_set_entities(), moab::WriteHDF5::get_set_info(), moab::ReadABAQUS::get_set_nodes(), moab::ParallelComm::get_shared_entities(), moab::ScdInterface::get_shared_vertices(), moab::ParallelComm::get_sharing_data(), moab::ParallelComm::get_sharing_parts(), moab::SharedSetData::get_sharing_procs(), moab::WriteNCDF::get_sideset_elems(), get_signed_volume(), moab::AdaptiveKDTree::get_split_plane(), moab::FileOptions::get_str_option(), moab::ReadCCMIO::get_str_option(), moab::FileOptions::get_strs_option(), moab::ReadHDF5::get_subset_ids(), moab::GeomTopoTool::get_surface_senses(), moab::ReadABAQUS::get_tag(), moab::WriteHDF5::get_tag_data_length(), moab::WriteUtil::get_tag_list(), moab::ParallelComm::get_tag_send_list(), moab::WriteHDF5::get_tag_size(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), moab::get_tagged(), moab::HiReconstruction::get_tangents_curve(), moab::FileOptions::get_toggle_option(), moab::BSPTree::get_tree_end_iterator(), moab::AdaptiveKDTree::get_tree_iterator(), moab::BSPTree::get_tree_iterator(), moab::WriteSTL::get_triangle_data(), moab::WriteSTL::get_triangles(), moab::MeshSetSequence::get_type(), moab::HalfFacetRep::get_up_adjacencies(), moab::HalfFacetRep::get_up_adjacencies_2d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d_comp(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::get_up_adjacencies_vert_2d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), moab::AEntityFactory::get_up_adjacency_elements(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::WriteNCDF::get_valid_sides(), moab::ReadNC::get_variables(), get_vartag_data(), moab::FBEngine::get_vert_edges(), moab::Core::get_vertex_coordinates(), moab::WriteCGNS::get_vertex_entities(), moab::AEntityFactory::get_vertices(), moab::Core::get_vertices(), moab::AEntityFactory::get_zero_to_n_elements(), moab::FBEngine::getAdjacentEntities(), moab::FBEngine::getEgFcSense(), moab::FBEngine::getEgVtxSense(), moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntClosestPt(), moab::FBEngine::getEntities(), moab::FBEngine::getEntNrmlXYZ(), moab::ParallelMergeMesh::GetGlobalBox(), moab::TempestRemapper::GetIMasks(), moab::FBEngine::getNumEntSets(), moab::FBEngine::getNumOfType(), moab::TempestRemapper::GetOverlapAugmentedEntities(), moab::FBEngine::getPntRayIntsct(), moab::FBEngine::getVtxCoord(), moab::ScdInterface::global_box_dims_tag(), moab::IntxUtils::global_gnomonic_projection(), moab::GeomTopoTool::global_id(), moab::DualTool::globalId_tag(), moab::FBEngine::gsubtract(), moab::Core::handle_from_id(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), hcFilter(), hex_containing_point(), moab::Core::high_order_node(), moab::HiReconstruction::hiproj_walf_around_vertex(), moab::HiReconstruction::hiproj_walf_in_element(), moab::HiReconstruction::HiReconstruction(), iMesh_addEntArrToSet(), iMesh_addEntSet(), iMesh_addPrntChld(), iMesh_connectIterate(), iMesh_coordsIterate(), iMesh_createEnt(), iMesh_createEntArr(), iMesh_createEntSet(), iMesh_createStructuredMesh(), iMesh_createTagWithOptions(), iMesh_createVtxArr(), iMesh_deleteEntArr(), iMesh_destroyEntSet(), iMesh_destroyTag(), iMesh_getAllEntSetTags(), iMesh_getAllIfaceTags(), iMesh_getAllTags(), iMesh_getArrData(), iMesh_getChldn(), iMesh_getEntArr2ndAdj(), iMesh_getEntArrAdj(), iMesh_getEntitiesRec(), iMesh_getEntsByTagsRec(), iMesh_getEntSetData(), iMesh_getEntSets(), iMesh_getEntSetsByTagsRec(), iMesh_getNumChld(), iMesh_getNumEntSets(), iMesh_getNumOfTopoRec(), iMesh_getNumOfTypeRec(), iMesh_getNumPrnt(), iMesh_getPrnts(), iMesh_getTagHandle(), iMesh_getTagName(), iMesh_getTagSizeBytes(), iMesh_getTagSizeValues(), iMesh_getTagType(), iMesh_getVtxArrCoords(), iMesh_initEntArrIterRec(), iMesh_intersect(), iMesh_isChildOf(), iMesh_isList(), iMesh_load(), iMesh_newMesh(), iMesh_resetEntArrIter(), iMesh_rmvArrTag(), iMesh_rmvEntArrFromSet(), iMesh_rmvEntSet(), iMesh_rmvEntSetTag(), iMesh_rmvPrntChld(), iMesh_save(), iMesh_setArrData(), iMesh_setEntSetData(), iMesh_setGeometricDimension(), iMesh_setVtxArrCoords(), iMesh_stepEntArrIter(), iMesh_subtract(), iMesh_tagIterate(), iMesh_unite(), iMeshP_assignGlobalIds(), iMeshP_createGhostEntsAll(), iMeshP_createPart(), iMeshP_createPartitionAll(), iMeshP_destroyPart(), iMeshP_destroyPartitionAll(), iMeshP_exchEntArrToPartsAll(), iMeshP_getAdjEntities(), iMeshP_getCopies(), iMeshP_getCopyOnPart(), iMeshP_getCopyParts(), iMeshP_getEntOwnerPartArr(), iMeshP_getEntStatusArr(), iMeshP_getNumCopies(), iMeshP_getNumGlobalParts(), iMeshP_getNumOfTopoAll(), iMeshP_getNumOfTypeAll(), iMeshP_getNumPartBdryEnts(), iMeshP_getNumPartitions(), iMeshP_getNumPartNborsArr(), iMeshP_getOwnerCopy(), iMeshP_getPartBdryEnts(), iMeshP_getPartHandlesFromPartsIdsArr(), iMeshP_getPartIdsFromPartHandlesArr(), iMeshP_getPartitions(), iMeshP_getPartNborsArr(), iMeshP_getRankOfPartArr(), iMeshP_initEntArrIter(), iMeshP_initPartBdryEntArrIter(), iMeshP_isEntOwnerArr(), iMeshP_loadAll(), iMeshP_pushTags(), iMeshP_pushTagsEnt(), iMeshP_syncMeshAll(), iMeshP_syncPartitionAll(), iMOAB_CreateElements(), iMOAB_CreateVertices(), iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_DuplicateAppMesh(), iMOAB_GetBlockElementConnectivities(), iMOAB_GetBlockID(), iMOAB_GetBlockInfo(), iMOAB_GetDoubleTagStorage(), iMOAB_GetElementConnectivity(), iMOAB_GetElementID(), iMOAB_GetElementOwnership(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_GetNeighborElements(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleElementsInfo(), iMOAB_GetVisibleVerticesCoordinates(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_ReduceTagsMax(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorage(), iMOAB_SetDoubleTagStorageWithGid(), iMOAB_SetIntTagStorage(), iMOAB_SynchronizeTags(), iMOAB_UpdateMeshInfo(), iMOAB_WriteLocalMesh(), iMOAB_WriteMesh(), ZoltanPartitioner::include_closure(), moab::FBEngine::Init(), moab::RangeSeqIntersectIter::init(), moab::ReadHDF5::init(), moab::AdaptiveKDTree::init(), moab::WriteHDF5::init(), moab::SmoothFace::init_bezier_edge(), moab::HalfFacetRep::init_curve(), moab::SmoothFace::init_facet_control_points(), moab::SmoothFace::init_gradient(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::HalfFacetRep::init_surface(), moab::WriteDamsel::init_tag_info(), moab::BSPTree::init_tags(), moab::HalfFacetRep::init_volume(), moab::NestedRefine::initialize(), moab::HiReconstruction::initialize(), moab::TempestRemapper::initialize(), moab::HalfFacetRep::initialize(), moab::GeomQueryTool::initialize(), moab::Skinner::initialize(), moab::LloydSmoother::initialize(), moab::gs_data::initialize(), moab::BSPTreeBoxIter::initialize(), initialize_area_and_tracer(), moab::WriteNCDF::initialize_exodus_file(), moab::WriteHDF5::initialize_mesh(), moab::Coupler::initialize_spectral_elements(), initialize_tree(), moab::Coupler::initialize_tree(), moab::FBEngine::initializeSmoothing(), moab::MeshSet::insert_entity_ranges(), moab::MeshSet::insert_entity_vector(), moab::GeomTopoTool::insert_in_tree(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::ElemEvaluator::integrate(), moab::LinearQuad::integrateFcn(), moab::LinearHex::integrateFcn(), moab::Coupler::interp_field(), moab::DataCoupler::interpolate(), moab::Coupler::interpolate(), moab::Tqdcfr::interpret_acis_records(), moab::MeshSet::intersect(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::BSPTreeIter::intersect_ray(), SetIntersectIter< Container >::intersect_with_set(), intersection_at_level(), moab::DualTool::is_blind(), moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_edge_on_boundary(), moab::NestedRefine::is_face_on_boundary(), moab::ParallelComm::is_iface_proc(), moab::GeomTopoTool::is_owned_set(), moab::BSPTreeIter::is_sibling(), moab::AdaptiveKDTreeIter::is_sibling(), moab::Core::is_valid(), moab::NestedRefine::is_vertex_on_boundary(), moab::DualTool::isDualCell_tag(), moab::FBEngine::isEntAdj(), moab::OrientedBoxTreeTool::join_trees(), laplacianFilter(), TriCounter::leaf(), TriStats::leaf(), moab::RayIntersectSets::leaf(), moab::BSPTree::leaf_containing_point(), moab::DualTool::list_entities(), moab::Core::list_entities(), moab::ParallelComm::list_entities(), moab::Core::list_entity(), list_formats(), moab::ReadSms::load_file(), moab::ReadCGNS::load_file(), moab::ReadIDEAS::load_file(), moab::ReadTemplate::load_file(), moab::ReadParallel::load_file(), moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), moab::ReadCCMIO::load_file(), moab::ReadDamsel::load_file(), moab::ReadTetGen::load_file(), moab::ReadSmf::load_file(), moab::ReadNASTRAN::load_file(), moab::ReadMCNP5::load_file(), moab::ReadCGM::load_file(), moab::ReadHDF5::load_file(), moab::ReadSTL::load_file(), moab::ReadNC::load_file(), moab::ReadNCDF::load_file(), moab::Core::load_file(), moab::ReadRTT::load_file(), moab::ReadOBJ::load_file(), moab::Tqdcfr::load_file(), moab::ReadABAQUS::load_file(), moab::ReadSms::load_file_impl(), moab::ReadHDF5::load_file_impl(), moab::ReadHDF5::load_file_partial(), moab::ReadCCMIO::load_matset_data(), moab::ReadCCMIO::load_metadata(), moab::ReadCCMIO::load_neuset_data(), moab::ReadMCNP5::load_one_file(), moab::Remapper::LoadNativeMesh(), moab::WriteGMV::local_write_mesh(), moab::SpatialLocator::locate_points(), moab::Coupler::locate_points(), main(), make_atomic_pillow(), make_chord_push(), make_face_shrink(), moab::ReadCCMIO::make_faces(), moab::OrientedBox::make_hex(), moab::AdaptiveKDTree::make_tag(), make_triple_chord_push(), make_tris_from_quad(), make_tris_from_quads(), manufacture_lagrange_mesh_on_sphere(), moab::WriteDamsel::map_dense_tags(), moab::WriteDamsel::map_sparse_tags(), moab::HalfFacetRep::mark_halfedges(), moab::FileOptions::match_option(), moab::FBEngine::measure(), measure(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), moab::ParallelMergeMesh::merge(), moab::AEntityFactory::merge_adjust_adjacencies(), moab::MergeMesh::merge_all(), merge_duplicate_vertices(), moab::MergeMesh::merge_entities(), moab::Core::merge_entities(), moab::MergeMesh::merge_higher_dimensions(), merge_input_surfs(), moab::TypeSequenceManager::merge_internal(), moab::AdaptiveKDTree::merge_leaf(), moab::BSPTree::merge_leaf(), moab::MergeMesh::merge_using_integer_tag(), min_edge_length(), moab::ReadSmf::mload(), moab::ReadSmf::mmult(), moab::SmoothFace::move_to_surface(), smoab::Interface::name(), moab::Coupler::nat_param(), moab::NestedRefine::NestedRefine(), moab::DualTool::next_loop_vertex(), moab::GeomTopoTool::next_vol(), moab::Util::normal(), moab::SmoothFace::normal_at(), moab::Coupler::normalize_mesh(), moab::Coupler::normalize_subset(), moab::TypeSequenceManager::notify_appended(), moab::AEntityFactory::notify_change_connectivity(), moab::AEntityFactory::notify_create_entity(), moab::AEntityFactory::notify_delete_entity(), moab::TypeSequenceManager::notify_prepended(), moab::Core::num_child_meshsets(), moab::MeshSetSequence::num_children(), moab::Core::num_contained_meshsets(), moab::MeshSetSequence::num_contained_sets(), moab::MeshSetSequence::num_dimension(), moab::MeshSetSequence::num_entities(), moab::Core::num_parent_meshsets(), moab::MeshSetSequence::num_parents(), moab::DenseTag::num_tagged_entities(), moab::VarLenDenseTag::num_tagged_entities(), moab::MeshSetSequence::num_type(), obbstat_write(), obbvis_create(), moab::HiReconstruction::obtain_nring_ngbvs(), moab::ReadTetGen::open_file(), moab::BSPTreePlaneIter::operator++(), moab::MeshTopoUtil::opposite_entity(), moab::DualTool::order_chord(), orient_faces_outward(), moab::OrientedBoxTreeTool::OrientedBoxTreeTool(), moab::GeomTopoTool::other_entity(), moab::ParallelComm::pack_buffer(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::WriteHDF5Parallel::pack_set(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_shared_handles(), moab::ParallelComm::pack_tag(), moab::ParallelComm::pack_tags(), moab::ParallelComm::packed_tag_size(), moab::WriteHDF5Parallel::parallel_create_file(), moab::Tqdcfr::parse_acis_attribs(), moab::ReadTetGen::parse_attr_list(), moab::Tree::parse_common_options(), moab::ReadSmf::parse_doubles(), moab::ReadSmf::parse_line(), moab::ReadSmf::parse_mat(), moab::BVHTree::parse_options(), moab::AdaptiveKDTree::parse_options(), moab::ReadDamsel::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), parse_tag_create(), parse_tag_spec(), moab::ScdInterface::part_method_tag(), ZoltanPartitioner::partition_inferred_mesh(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), ZoltanPartitioner::partition_owned_cells(), moab::ParallelComm::partition_tag(), moab::ParallelComm::pcomm_tag(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::MergeMesh::perform_merge(), moab::LloydSmoother::perform_smooth(), moab::ParallelMergeMesh::PerformMerge(), moab::GeomQueryTool::point_in_box(), moab::GeomQueryTool::point_in_volume(), moab::GeomQueryTool::point_in_volume_slow(), moab::AdaptiveKDTree::point_search(), moab::BVHTree::point_search(), moab::GeomQueryTool::poly_solid_angle(), moab::HiReconstruction::polyfit3d_walf_curve_vertex(), moab::HiReconstruction::polyfit3d_walf_surf_vertex(), moab::MeshSetSequence::pop_back(), moab::MeshSetSequence::pop_front(), moab::ParallelMergeMesh::PopulateMySkinEnts(), moab::ParallelMergeMesh::PopulateMyTup(), moab::SmoothCurve::position_from_u(), moab::IntxAreaUtils::positive_orientation(), moab::OrientedBoxTreeTool::preorder_traverse(), moab::AdaptiveKDTree::print(), moab::OrientedBoxTreeTool::print(), moab::DualTool::print_cell(), moab::TreeNodePrinter::print_contents(), moab::TreeNodePrinter::print_counts(), moab::Core::print_database(), moab::Core::print_entity_tags(), moab::TreeNodePrinter::print_geometry(), print_memory_stats(), print_vertex_fields(), moab::WriteNC::process_conventional_tags(), moab::ReadDamsel::process_ent_info(), moab::ReadDamsel::process_entity_tags(), process_partition_file(), moab::Tqdcfr::process_sideset_10(), moab::Tqdcfr::process_sideset_11(), moab::ReadDamsel::process_tags(), moab::SmoothFace::project_to_facet(), moab::SmoothFace::project_to_facet_plane(), moab::SmoothFace::project_to_facets_main(), moab::SmoothFace::project_to_patch(), moab::ParallelComm::pstatus_tag(), moab::MeshSetSequence::push_back(), moab::MeshSetSequence::push_front(), moab::Tqdcfr::put_into_set(), moab::putElementField(), moab::putSpectralElementField(), quads_to_tris(), moab::VerdictWrapper::quality_measure(), moab::Interface::query_interface(), moab::range_to_id_list_templ(), moab::RangeSetIterator::RangeSetIterator(), moab::GeomQueryTool::ray_fire(), moab::OrientedBoxTreeTool::ray_intersect_sets(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::OrientedBoxTreeTool::ray_intersect_triangles(), moab::SmoothFace::ray_intersection_correct(), moab::ReadHDF5VarLen::read(), moab::ReadHDF5::read_adjacencies(), moab::ReadCCMIO::read_all_faces(), moab::ReadABAQUS::read_assembly(), moab::Tqdcfr::read_block(), moab::ReadCCMIO::read_cells(), moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5::read_dense_tag(), moab::ReadTetGen::read_elem_file(), moab::ReadNASTRAN::read_element(), moab::ReadABAQUS::read_element_list(), moab::ReadABAQUS::read_element_set(), moab::ReadTemplate::read_elements(), moab::Tqdcfr::read_elements(), moab::ReadHDF5::read_elems(), moab::ReadCCMIO::read_faces(), DeformMeshRemap::read_file(), moab::ReadCCMIO::read_gids_and_types(), moab::ReadNCDF::read_global_ids(), moab::Tqdcfr::read_group(), moab::ReadNC::read_header(), moab::ReadRTT::read_header(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::ReadABAQUS::read_instance(), moab::ReadTetGen::read_line(), McnpData::read_mcnpfile(), moab::ReadMCNP5::read_mesh_planes(), moab::ReadNASTRAN::read_node(), moab::ReadHDF5::read_node_adj_elems(), moab::ReadTetGen::read_node_file(), moab::ReadABAQUS::read_node_list(), moab::ReadABAQUS::read_node_set(), moab::ReadHDF5::read_nodes(), moab::Tqdcfr::read_nodes(), moab::Tqdcfr::read_nodeset(), moab::ReadABAQUS::read_part(), moab::ReadHDF5::read_poly(), moab::ReadCCMIO::read_processor(), moab::ScdNCHelper::read_scd_variables_to_nonset(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_sets(), moab::Tqdcfr::read_sideset(), moab::ReadNCDF::read_sidesets(), moab::ReadABAQUS::read_solid_section(), moab::ReadHDF5::read_sparse_tag(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag(), moab::ReadHDF5::read_tag_values(), moab::ReadNCDF::read_tag_values(), moab::ReadMCNP5::read_tally_header(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperMPAS::read_ucd_variables_to_nonset(), moab::NCHelperGCRM::read_ucd_variables_to_nonset(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::ReadHDF5::read_var_len_tag(), moab::ScdNCHelper::read_variables(), moab::UcdNCHelper::read_variables(), moab::NCHelper::read_variables_to_set(), moab::NCHelper::read_variables_to_set_allocate(), moab::ReadTemplate::read_vertices(), moab::ReadVtk::read_vertices(), moab::ReadCCMIO::read_vertices(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), moab::ReadNCDF::ReadNCDF(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), ReadTriangleOutput(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), moab::MeshSetSequence::recursive_get_sets(), moab::OrientedBoxTreeTool::recursive_stats(), moab::ParallelComm::recv_entities(), moab::ParallelComm::recv_messages(), moab::ParallelComm::recv_remote_handle_messages(), moab::FBEngine::redistribute_boundary_edges_to_faces(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::reduce_void(), moab::GQT_IntRegCtxt::register_intersection(), moab::DenseTag::release_all_data(), moab::VarLenDenseTag::release_all_data(), moab::AEntityFactory::remove_adjacency(), moab::Skinner::remove_adjacency(), moab::AEntityFactory::remove_all_adjacencies(), moab::VarLenDenseTag::remove_data(), moab::VarLenSparseTag::remove_data(), moab::SparseTag::remove_data(), moab::IntxUtils::remove_duplicate_vertices(), remove_empty_cgm_surfs_and_vols(), moab::ParallelComm::remove_entities_part(), moab::MeshSet::remove_entity_ranges(), moab::MeshSet::remove_entity_vector(), moab::IntxUtils::remove_padded_vertices(), moab::ParallelComm::remove_pcomm(), moab::GeomTopoTool::remove_root(), moab::ReorderTool::reorder_entities(), moab::NestedRefine::reorder_indices(), moab::ReorderTool::reorder_tag_data(), moab::MeshSet::replace_entities(), replace_faceted_cgm_surfs(), replace_surface(), MBIter< Container >::reset(), PartBoundaryIter::reset(), SetIntersectIter< Container >::reset(), moab::GeomTopoTool::resize_rootSets(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_obb_index(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), SphereDecomp::retrieve_subdiv_verts(), moab::DualTool::rev_atomic_pillow(), moab::DualTool::rev_face_shrink(), moab::ReadSmf::rot(), run_local_smoother(), moab::ReadSmf::scale(), moab::IntxUtils::ScaleToRadius(), moab::ParallelComm::scatter_entities(), moab::ScdBox::ScdBox(), moab::ReadHDF5::search_tag_values(), moab::ParallelComm::send_buffer(), moab::ParallelComm::send_entities(), moab::ParCommGraph::send_graph(), moab::ParCommGraph::send_graph_partition(), moab::ParCommGraph::send_mesh_parts(), moab::ParallelComm::send_recv_entities(), moab::ParCommGraph::send_tag_values(), moab::FBEngine::separate(), moab::GeomTopoTool::separate_by_dimension(), moab::WriteHDF5::serial_create_file(), moab::Core::serial_load_file(), moab::Core::serial_read_tag(), moab::AEntityFactory::set_adjacency_ptr(), moab::Core::set_connectivity(), moab::Core::set_coords(), moab::BitTag::set_data(), moab::DenseTag::set_data(), moab::MeshTag::set_data(), moab::SparseTag::set_data(), moab::VarLenSparseTag::set_data(), moab::VarLenDenseTag::set_data(), moab::FBEngine::set_default_neumann_tags(), set_density(), set_departure_points_position(), moab::ElemEvaluator::set_ent_handle(), moab::ElemEvaluator::set_eval_set(), moab::MeshSet::set_flags(), moab::ReadMCNP5::set_header_tags(), set_intersection_query(), moab::Error::set_last_error(), moab::FBEngine::set_neumann_tags(), moab::ReadCGM::set_options(), moab::SharedSetData::set_owner(), moab::ParallelComm::set_partitioning(), moab::ParallelComm::set_pstatus_entities(), moab::GeomTopoTool::set_root_set(), moab::GeomTopoTool::set_sense(), moab::GeomTopoTool::set_senses(), moab::ParallelComm::set_sharing_data(), moab::SharedSetData::set_sharing_procs(), moab::AdaptiveKDTree::set_split_plane(), moab::GeomTopoTool::set_surface_senses(), moab::ReadRTT::set_surface_senses(), moab::ElemEvaluator::set_tag(), moab::ElemEvaluator::set_tag_handle(), moab::WriteCGNS::set_tag_values(), moab::ReadMCNP5::set_tally_tags(), moab::ReadHDF5::set_up_read(), moab::TempestOnlineMap::SetDOFmapAssociation(), moab::TempestOnlineMap::SetDOFmapTags(), moab::ParallelComm::settle_intersection_points(), moab::ReadRTT::setup_group_data(), moab::GeomTopoTool::setup_implicit_complement(), moab::Intx2MeshInPlane::setup_tgt_cell(), moab::IntxRllCssphere::setup_tgt_cell(), moab::Intx2MeshOnSphere::setup_tgt_cell(), moab::ParallelComm::sharedh_tag(), moab::ParallelComm::sharedhs_tag(), moab::ParallelComm::sharedp_tag(), moab::ParallelComm::sharedps_tag(), moab::SharedSetData::SharedSetData(), moab::BSPTreeIter::sibling_is_forward(), moab::AdaptiveKDTreeIter::sibling_is_forward(), moab::AdaptiveKDTreeIter::sibling_side(), moab::BSPTreeBoxIter::sibling_side(), moab::Core::side_element(), moab::Core::side_number(), moab::Skinner::skin_box(), moab::FBEngine::smooth_new_intx_points(), moab::SpatialLocator::SpatialLocator(), moab::SpectralMeshTool::spectral_order_tag(), moab::SpectralMeshTool::spectral_vertices_tag(), moab::AdaptiveKDTree::sphere_intersect_triangles(), moab::OrientedBoxTreeTool::sphere_intersect_triangles(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_boundary(), moab::split_box(), moab::FBEngine::split_edge_at_mesh_node(), moab::MeshTopoUtil::split_entities_manifold(), moab::MeshTopoUtil::split_entity_nonmanifold(), moab::FBEngine::split_internal_edge(), moab::AdaptiveKDTree::split_leaf(), moab::BSPTree::split_leaf(), moab::DualTool::split_pair_nonmanifold(), moab::ReadOBJ::split_quad(), moab::FBEngine::split_quads(), moab::FBEngine::split_surface(), moab::FBEngine::split_surface_with_direction(), moab::MeshTopoUtil::star_entities(), moab::MeshTopoUtil::star_entities_nonmanifold(), moab::MeshTopoUtil::star_next_entity(), moab::OrientedBoxTreeTool::stats(), moab::RangeSeqIntersectIter::step(), moab::BSPTreeIter::step(), moab::BSPTreeBoxIter::step(), moab::AdaptiveKDTreeIter::step(), moab::BSPTreeIter::step_to_first_leaf(), moab::AdaptiveKDTreeIter::step_to_first_leaf(), moab::BSPTreeBoxIter::step_to_first_leaf(), moab::ReadCGM::store_curve_senses(), moab::ReadVtk::store_file_ids(), moab::ReadHDF5::store_file_ids(), moab::ReadCGM::store_group_content(), moab::ReadCGM::store_groups(), moab::ReadHDF5::store_sets_file_ids(), moab::ReadCGM::store_surface_senses(), moab::NestedRefine::subdivide_cells(), SphereDecomp::subdivide_tet(), moab::NestedRefine::subdivide_tets(), summarize_cell_volume_change(), moab::Core::tag_delete(), tag_depth(), moab::HigherOrderFactory::tag_for_deletion(), moab::Core::tag_get_by_ptr(), moab::ParallelComm::tag_iface_entities(), moab::DenseTag::tag_iterate(), moab::SparseTag::tag_iterate(), moab::Core::tag_iterate(), moab::ScdInterface::tag_shared_vertices(), moab::ParallelComm::tag_shared_verts(), tag_storage_string(), tag_type_string(), moab::ParallelMergeMesh::TagSharedElements(), test_existinterface(), test_intx_in_parallel_elem_based(), test_linear_reconstruction(), moab::Coupler::test_local_box(), test_spectral_hex(), test_spectral_quad(), moab::GeomQueryTool::test_volume_boundary(), TestErrorHandling_1(), TestErrorHandling_2(), TestErrorHandling_3(), TestErrorHandling_4(), TestErrorHandlingPar_1(), TestErrorHandlingPar_2(), TestMeshRefiner(), moab::Tqdcfr::Tqdcfr(), moab::ReadSmf::trans(), moab::WriteCCMIO::transform_coords(), moab::TreeStats::traverse(), moab::DualTool::traverse_hyperplane(), moab::TreeNodePrinter::TreeNodePrinter(), TriStats::TriStats(), moab::SmoothCurve::u_from_position(), moab::ParallelComm::unpack_buffer(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::unpack_remote_handles(), moab::ParallelComm::unpack_sets(), moab::ParallelComm::unpack_tags(), moab::BSPTreeBoxIter::up(), moab::BoundBox::update(), moab::ReadNCDF::update(), moab::NestedRefine::update_ahf_1D(), moab::ReadHDF5::update_connectivity(), update_density(), moab::HalfFacetRep::update_entity_ranges(), moab::NestedRefine::update_global_ahf(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), moab::NestedRefine::update_local_ahf(), moab::GQT_IntRegCtxt::update_orient(), moab::ParallelComm::update_remote_data(), moab::ParallelComm::update_remote_data_old(), moab::ReorderTool::update_set_contents(), moab::NestedRefine::update_special_tags(), moab::NCHelper::update_time_tag_vals(), update_tracer(), moab::Intx2MeshOnSphere::update_tracer_data(), update_tracer_test(), moab::NestedRefine::update_tracking_verts(), moab::WriteHDF5::vector_to_id_list(), moab::ReadSmf::vertex(), moab::HiReconstruction::vertex_get_incident_elements(), moab::NestedRefine::vertex_to_entities_down(), moab::NestedRefine::vertex_to_entities_up(), TriCounter::visit(), moab::RayIntersector::visit(), moab::RayIntersectSets::visit(), moab::TreeNodePrinter::visit(), moab::BSPTreeIter::volume(), moab::ReadVtk::vtk_create_structured_elems(), moab::ReadVtk::vtk_read_field_attrib(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_polygons(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), moab::ReadVtk::vtk_read_tag_data(), moab::ReadVtk::vtk_read_unstructured_grid(), moab::FBEngine::weave_lateral_face_from_edges(), moab::WriteHDF5::write_adjacencies(), MetisPartitioner::write_aggregationtag_partition(), DeformMeshRemap::write_and_save(), moab::WriteNCDF::write_BCs(), moab::WriteVtk::write_bit_tag(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteCGNS::write_coord_cgns(), moab::WriteCCMIO::write_dbl_option(), moab::WriteHDF5::write_dense_tag(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteHDF5::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteCCMIO::write_external_faces(), moab::WriteSmf::write_file(), moab::WriteVtk::write_file(), moab::WriteGmsh::write_file(), moab::WriteSTL::write_file(), moab::WriteGMV::write_file(), moab::WriteAns::write_file(), moab::WriteHDF5::write_file(), moab::WriteDamsel::write_file(), moab::WriteCCMIO::write_file(), moab::WriteCGNS::write_file(), moab::WriteNC::write_file(), moab::Core::write_file(), moab::WriteHDF5::write_file_impl(), moab::WriteCCMIO::write_int_option(), moab::WriteTemplate::write_matsets(), moab::WriteSLAC::write_matsets(), moab::WriteVtk::write_nodes(), moab::WriteTemplate::write_nodes(), moab::WriteSLAC::write_nodes(), moab::WriteCCMIO::write_nodes(), moab::WriteNCDF::write_nodes(), moab::WriteHDF5::write_nodes(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteCCMIO::write_problem_description(), moab::WriteHDF5::write_set_data(), moab::WriteDamsel::write_sets(), moab::WriteHDF5::write_sets(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), moab::WriteCCMIO::write_str_option(), moab::WriteDamsel::write_subrange(), moab::WriteVtk::write_tag(), moab::WriteHDF5::write_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteVtk::write_tags(), DeformMeshRemap::write_to_coords(), moab::WriteHDF5::write_var_len_data(), moab::WriteHDF5::write_var_len_indices(), moab::WriteHDF5::write_var_len_tag(), moab::WriteDamsel::write_vertices(), moab::WriteDamsel::WriteDamsel(), moab::TempestOnlineMap::WriteHDF5MapFile(), moab::TempestOnlineMap::WriteParallelMap(), moab::TempestOnlineMap::WriteSCRIPMapFile(), moab::BSPTree::~BSPTree(), moab::LloydSmoother::~LloydSmoother(), moab::OrientedBoxTreeTool::~OrientedBoxTreeTool(), and moab::Tqdcfr::~Tqdcfr().
Definition at line 43 of file Types.hpp.
Referenced by moab::Core::add_child_meshset(), moab::Core::add_child_meshsets(), moab::Core::add_entities(), moab::Core::add_parent_child(), moab::Core::add_parent_meshset(), moab::Core::add_parent_meshsets(), moab::Core::adjacencies_iterate(), moab::AdaptiveKDTree::build_tree(), moab::TypeSequenceManager::check_valid_handles(), moab::Core::clear_meshset(), moab::Core::connect_iterate(), moab::Core::coords_iterate(), moab::ReadGmsh::create_sets(), moab::WriteHDF5::create_tag(), moab::BSPTreeIter::down(), moab::BSPTreeBoxIter::down(), moab::ent_not_found(), moab::TypeSequenceManager::erase(), error_code_test(), moab::TypeSequenceManager::find(), moab::AdaptiveKDTree::find_close_triangle(), moab::Skinner::find_geometric_skin(), moab::RangeSeqIntersectIter::find_invalid_range(), moab::MergeMesh::find_merged_to(), moab::GeomQueryTool::find_volume(), moab::GeomQueryTool::find_volume_slow(), moab::WriteVtk::gather_mesh(), moab::WriteUtil::gather_nodes_from_elements(), moab::Core::get_child_meshsets(), moab::Core::get_connectivity(), moab::Core::get_contained_meshsets(), moab::Core::get_coords(), moab::ReadUtil::get_gather_set(), moab::GeomTopoTool::get_implicit_complement(), moab::GeomQueryTool::RayHistory::get_last_intersection(), moab::Core::get_meshset_options(), moab::BSPTreeBoxIter::get_neighbors(), moab::FileOptions::get_option(), moab::Core::get_parent_meshsets(), moab::BSPTreeIter::get_parent_split_plane(), moab::AdaptiveKDTreeIter::get_parent_split_plane(), moab::ParallelComm::get_part_handle(), moab::GeomTopoTool::get_sense(), moab::ReadHDF5::get_subset_ids(), moab::FileOptions::get_toggle_option(), moab::FileOptions::get_unseen_option(), iMesh_addPrntChld(), iMesh_getChldn(), iMesh_getNumChld(), iMesh_getNumPrnt(), iMesh_getPrnts(), iMesh_isChildOf(), iMesh_rmvPrntChld(), moab::BSPTreeBoxIter::initialize(), moab::Core::intersect_meshset(), moab::ReadParallel::load_file(), moab::Core::load_file(), moab::ReadHDF5::load_file_partial(), moab::Core::merge_entities(), moab::Coupler::nat_param(), moab::AEntityFactory::notify_delete_entity(), moab::Core::num_child_meshsets(), moab::Core::num_contained_meshsets(), moab::Core::num_parent_meshsets(), moab::ReadTetGen::open_file(), moab::AdaptiveKDTree::parse_options(), moab::ReadDamsel::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), parse_tag_create(), moab::AdaptiveKDTree::point_search(), moab::range_to_id_list_templ(), moab::ReadHDF5::read_poly(), moab::Core::remove_child_meshset(), moab::Core::remove_entities(), moab::HigherOrderFactory::remove_ho_nodes(), moab::Core::remove_parent_child(), moab::Core::remove_parent_meshset(), moab::OrientedBoxTreeTool::remove_root(), moab::TypeSequenceManager::remove_sequence(), moab::MeshSet::replace_entities(), moab::Core::replace_entities(), moab::Core::set_connectivity(), moab::Core::set_meshset_options(), moab::ReadHDF5::set_up_read(), moab::AdaptiveKDTreeIter::sibling_side(), moab::BSPTreeBoxIter::sibling_side(), moab::Core::side_element(), moab::Core::side_number(), skin_tris(), moab::BSPTreeIter::step(), moab::BSPTreeBoxIter::step(), moab::AdaptiveKDTreeIter::step(), moab::Core::subtract_meshset(), moab::Core::tag_get_default_value(), moab::Core::unite_meshset(), moab::BSPTreeIter::up(), moab::BSPTreeBoxIter::up(), moab::WriteGmsh::write_file(), moab::WriteSTL::write_file(), moab::WriteHDF5::write_file(), moab::WriteDamsel::write_file(), and moab::Core::write_file().
Examples:
ErrorHandlingSimulation.cpp.
Definition at line 48 of file Types.hpp.
Referenced by moab::VerdictWrapper::all_quality_measures(), moab::NCWriteHelper::collect_variable_data(), moab::HigherOrderFactory::convert(), moab::SpectralMeshTool::convert_to_fine(), moab::ReadIDEAS::create_elements(), moab::ReadMCNP5::create_elements(), moab::ReadNASTRAN::determine_entity_type(), FunctionC(), moab::SweptElementSeq::get_connectivity(), moab::EvalSet::get_eval_set(), moab::Tree::get_info(), moab::ScdBox::get_params(), moab::WriteUtil::get_poly_connect(), moab::WriteUtil::get_poly_connect_size(), moab::FBEngine::getEgEvalXYZ(), moab::FBEngine::getEntNrmlSense(), moab::FBEngine::getFcEvalXYZ(), iMesh_newMesh(), iMeshP_getPartsArrOnRank(), MetisPartitioner::include_closure(), moab::NestedRefine::initialize(), moab::QuadraticHex::integrateFcn(), moab::ReadCGNS::load_file(), moab::ReadParallel::load_file(), moab::QuadraticHex::normalFcn(), moab::AEntityFactory::notify_change_connectivity(), moab::WriteHDF5::parallel_create_file(), moab::ReadDamsel::parse_options(), moab::VerdictWrapper::quality_measure(), moab::ReadNASTRAN::read_node(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::ReadSms::read_tag_values(), moab::ReadCGNS::read_tag_values(), moab::ReadTemplate::read_tag_values(), moab::ReadIDEAS::read_tag_values(), moab::ReadVtk::read_tag_values(), moab::ReadGmsh::read_tag_values(), moab::ReadTetGen::read_tag_values(), moab::ReadSmf::read_tag_values(), moab::ReadMCNP5::read_tag_values(), moab::ReadNASTRAN::read_tag_values(), moab::ReadCGM::read_tag_values(), moab::ReadSTL::read_tag_values(), moab::ReadOBJ::read_tag_values(), moab::ReadRTT::read_tag_values(), moab::Tqdcfr::read_tag_values(), moab::ReadABAQUS::read_tag_values(), moab::HigherOrderFactory::remove_ho_nodes(), moab::SweptElementSeq::set_connectivity(), moab::ReadHDF5::set_up_read(), moab::Core::side_number(), moab::TupleList::sort(), moab::ReadNASTRAN::tokenize_line(), moab::ReadMCNP5::transform_point_to_cartesian(), moab::ReadNCDF::update(), moab::NestedRefine::update_global_ahf(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::NCWriteHOMME::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), and moab::NCWriteHelper::write_set_variables().
Examples:
ComputeTriDual.cpp, DeformMeshRemap.cpp, DirectAccessNoHoles.cpp, DirectAccessWithHoles.cpp, ErrorHandlingSimulation.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, LoadPartial.cpp, ReduceExchangeTags.cpp, TestErrorHandling.cpp, TestErrorHandlingPar.cpp, and VisTags.cpp.
Definition at line 39 of file Types.hpp.
Referenced by moab::AdaptiveKDTree::AdaptiveKDTree(), moab::AEntityFactory::add_adjacency(), moab::Skinner::add_adjacency(), moab::ScdInterface::add_box(), moab::HalfFacetRep::add_cells_of_single_component(), moab::Core::add_child_meshset(), moab::Core::add_child_meshsets(), add_dead_elems_to_impl_compl(), moab::RefinerTagManager::add_element_tag(), moab::ReadABAQUS::add_entity_set(), add_field_value(), moab::GeomTopoTool::add_geo_set(), moab::DualTool::add_graphics_point(), moab::HigherOrderFactory::add_mid_edge_nodes(), moab::HigherOrderFactory::add_mid_face_nodes(), moab::HigherOrderFactory::add_mid_volume_nodes(), moab::Core::add_parent_child(), moab::Core::add_parent_meshset(), moab::Core::add_parent_meshsets(), moab::ParallelComm::add_pcomm(), DeformMeshRemap::add_set_no(), moab::RefinerTagManager::add_vertex_tag(), moab::ParallelComm::add_verts(), moab::SweptElementData::add_vsequence(), moab::ScdElementData::add_vsequence(), moab::Core::adjacencies_iterate(), moab::VerdictWrapper::all_quality_measures(), moab::ReadVtk::allocate_elements(), moab::SequenceManager::allocate_mesh_set(), moab::ReadVtk::allocate_vertices(), moab::ReadSmf::annotation(), moab::HalfFacetRep::another_halfedge(), moab::EntitySequence::append_entities(), moab::WriteHDF5Parallel::append_serial_tag_data(), moab::Coupler::apply_group_norm_factor(), moab::TempestOnlineMap::ApplyWeights(), moab::area_coordinates(), moab::IntxAreaUtils::area_on_sphere(), moab::ReadSTL::ascii_read_triangles(), moab::WriteSTL::ascii_write_triangles(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ParallelComm::assign_entities_part(), moab::ParallelComm::assign_global_ids(), moab::ScdInterface::assign_global_ids(), moab::ReadUtil::assign_ids(), moab::ReadNASTRAN::assign_ids(), moab::WriteUtil::assign_ids(), moab::WriteHDF5::assign_ids(), moab::TempestRemapper::assign_vertex_element_IDs(), moab::DualTool::atomic_pillow(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::ReadMCNP5::average_tally_values(), moab::ReadMCNP5::average_with_existing_tally(), ZoltanPartitioner::balance_mesh(), moab::ReadSmf::begin(), moab::AdaptiveKDTree::best_subdivision_plane(), moab::AdaptiveKDTree::best_subdivision_snap_plane(), moab::AdaptiveKDTree::best_vertex_median_plane(), moab::AdaptiveKDTree::best_vertex_sample_plane(), moab::ReadSTL::binary_read_triangles(), moab::WriteSTL::binary_write_triangles(), moab::GeomQueryTool::boundary_case(), moab::FBEngine::boundary_mesh_edges_on_face(), moab::FBEngine::boundary_nodes_on_face(), moab::ScdInterface::box_dims_tag(), moab::box_from_axes(), moab::ScdInterface::box_periodic_tag(), moab::ScdInterface::box_set_tag(), moab::FBEngine::BreakTriangle2(), moab::MeshGeneration::BrickInstance(), moab::ParallelComm::broadcast_entities(), moab::BVHTree::bruteforce_find(), SphereDecomp::build_hexes(), moab::ReadRTT::build_moab(), build_new_surface(), moab::RangeSetIterator::build_pair_vec(), moab::OrientedBoxTreeTool::build_sets(), moab::ParallelComm::build_sharedhps_list(), moab::AdaptiveKDTree::build_tree(), moab::BVHTree::build_tree(), moab::OrientedBoxTreeTool::build_tree(), moab::AxisBox::calculate(), moab::BSPTreeIter::calculate_polyhedron(), moab::ReadCCMIO::ccmio_to_moab_type(), moab::FBEngine::chain_able_edge(), moab::FBEngine::chain_edges(), moab::FBEngine::chain_two_edges(), check(), moab::DualTool::check_1d_loop_edge(), moab::Core::check_adjacencies(), moab::ParallelComm::check_all_shared_handles(), moab::ParallelComm::check_clean_iface(), moab::WriteUtil::check_doesnt_exist(), moab::DualTool::check_dual_adjs(), moab::DualTool::check_dual_equiv_edges(), moab::GeomTopoTool::check_edge_sense_tags(), moab::AEntityFactory::check_equiv_entities(), moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperGCRM::check_existing_mesh(), moab::NCHelperMPAS::check_existing_mesh(), moab::ScdNCHelper::check_existing_mesh(), moab::GeomTopoTool::check_face_sense_tag(), moab::GeomTopoTool::check_geom_tag(), moab::GeomTopoTool::check_gid_tag(), moab::ParallelComm::check_global_ids(), check_handle_tag_type(), moab::check_int_tag(), moab::ReadSmf::check_length(), moab::ParallelComm::check_local_shared(), moab::TypeSequenceManager::check_merge_next(), moab::TypeSequenceManager::check_merge_prev(), moab::GeomTopoTool::check_model(), moab::ParallelComm::check_my_shared_handles(), moab::ParallelComm::check_sent_ents(), moab::WriteHDF5Parallel::check_serial_tag_data(), moab::check_tag_type(), moab::SequenceManager::check_valid_entities(), moab::TypeSequenceManager::check_valid_handles(), moab::NestedRefine::child_to_parent(), chkerr(), moab::Skinner::classify_2d_boundary(), moab::ParallelComm::clean_shared_tags(), moab::ReadHDF5::clean_up_read(), moab::TempestRemapper::clear(), moab::MeshSet::clear(), moab::MeshTag::clear_data(), moab::BitTag::clear_data(), moab::VarLenSparseTag::clear_data(), moab::SparseTag::clear_data(), moab::DenseTag::clear_data(), moab::Core::clear_meshset(), moab::WriteCCMIO::close_and_compress(), moab::GeomQueryTool::closest_to_location(), moab::OrientedBoxTreeTool::closest_to_location(), moab::closest_to_triangles(), moab::AdaptiveKDTree::closest_triangle(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteHOMME::collect_variable_data(), moab::NCWriteMPAS::collect_variable_data(), moab::NCWriteHelper::collect_variable_data(), moab::ScdNCWriteHelper::collect_variable_data(), moab::ParallelComm::collective_sync_partition(), moab::MeshTopoUtil::common_entity(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), compute_area(), moab::HiReconstruction::compute_average_vertex_normals_surf(), moab::HiReconstruction::compute_average_vertex_tangents_curve(), moab::SmoothCurve::compute_control_points_on_boundary_edges(), moab::SmoothFace::compute_control_points_on_edges(), moab::NestedRefine::compute_coordinates(), moab::AdaptiveKDTree::compute_depth(), compute_dual_mesh(), moab::OrientedBox::compute_from_2d_cells(), moab::OrientedBox::compute_from_covariance_data(), moab::OrientedBox::compute_from_vertices(), moab::SmoothFace::compute_internal_control_points_on_facets(), moab::FBEngine::compute_intersection_points(), SphereDecomp::compute_nodes(), compute_normals(), moab::ParCommGraph::compute_partition(), moab::ScdInterface::compute_partition(), moab::ScdInterface::compute_partition_alljkbal(), moab::ScdInterface::compute_partition_alljorkori(), moab::ScdInterface::compute_partition_sqij(), moab::ScdInterface::compute_partition_sqijk(), moab::ScdInterface::compute_partition_sqjk(), moab::SmoothFace::compute_tangents_for_each_edge(), moab::SmoothCurve::compute_tangents_for_each_edge(), moab::ParCommGraph::compute_trivial_partition(), compute_velocity_case1(), moab::TempestRemapper::ComputeGlobalLocalMaps(), moab::Intx2MeshInPlane::computeIntersectionBetweenTgtAndSrc(), moab::IntxRllCssphere::computeIntersectionBetweenTgtAndSrc(), moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc(), moab::TempestOnlineMap::ComputeMetrics(), moab::TempestRemapper::ComputeOverlapMesh(), moab::Core::connect_iterate(), moab::Coupler::consolidate_tuples(), moab::Coupler::constant_interp(), moab::MeshTopoUtil::construct_aentities(), moab::ScdInterface::construct_box(), moab::ReadCCMIO::construct_cells(), moab::DualTool::construct_dual(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_hyperplanes(), moab::DualTool::construct_dual_vertex(), moab::DualTool::construct_dual_vertices(), moab::BVHTree::construct_element_vec(), moab::DualTool::construct_hex_dual(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::construct_hm_3D(), moab::NestedRefine::construct_hm_entities(), moab::DualTool::construct_hp_parent_child(), moab::DualTool::construct_new_hyperplane(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_vertex_ranges(), moab::DamselUtil::container_to_range(), moab::HigherOrderFactory::convert(), moab::MeshSet::convert(), moab::ReadHDF5::convert_id_to_handle(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::ReadHDF5::convert_range_to_handle(), moab::HigherOrderFactory::convert_sequence(), moab::TempestRemapper::convert_tempest_mesh_private(), moab::SpectralMeshTool::convert_to_coarse(), moab::BVHTree::convert_tree(), moab::Core::coords_iterate(), moab::RefinerTagManager::copy_gid(), moab::HigherOrderFactory::copy_nodes(), moab::NestedRefine::copy_vertices_from_prev_level(), moab::Core::Core(), moab::ParallelComm::correct_thin_ghost_layers(), moab::WriteHDF5::count_adjacencies(), count_owned(), moab::WriteHDF5::count_set_size(), moab::NestedRefine::count_subentities(), moab::HalfFacetRep::count_subentities(), moab::OrientedBox::covariance_data_from_tris(), moab::MeshSet::create_adjacencies(), moab::WriteHDF5Parallel::create_adjacency_tables(), moab::NCHelper::create_attrib_string(), moab::ScdInterface::create_box_set(), moab::WriteCCMIO::create_ccmio_structure(), moab::ReadCCMIO::create_cell_from_faces(), moab::NCHelper::create_conventional_tags(), moab::ReadCGM::create_curve_facets(), moab::WriteHDF5Parallel::create_dataset(), moab::NCHelper::create_dummy_variables(), moab::WriteHDF5::create_elem_table(), moab::SequenceManager::create_element(), moab::EntitySource::create_element(), moab::Core::create_element(), moab::WriteHDF5Parallel::create_element_tables(), moab::ReadIDEAS::create_elements(), moab::ReadCGNS::create_elements(), moab::ReadGmsh::create_elements(), moab::ReadMCNP5::create_elements(), moab::SequenceManager::create_entity_sequence(), moab::ReadUtil::create_entity_sets(), moab::ReadCGM::create_entity_sets(), moab::AEntityFactory::create_explicit_adjs(), moab::ReadUtil::create_gather_set(), moab::NCHelperMPAS::create_gather_set_cells(), moab::NCHelperGCRM::create_gather_set_edges(), moab::NCHelperMPAS::create_gather_set_edges(), moab::NCHelperGCRM::create_gather_set_vertices(), moab::NCHelperMPAS::create_gather_set_vertices(), moab::ReadGmsh::create_geometric_topology(), moab::ReadRTT::create_group(), moab::ReadCGM::create_group_entsets(), moab::NestedRefine::create_hm_storage_single_level(), moab::ParallelComm::create_iface_pc_links(), moab::ReadABAQUS::create_instance_of_part(), create_int_ents(), moab::ParallelComm::create_interface_sets(), create_lagr_mesh(), moab::NCHelperMPAS::create_local_cells(), moab::NCHelperGCRM::create_local_edges(), moab::NCHelperMPAS::create_local_edges(), moab::NCHelperGCRM::create_local_vertices(), moab::NCHelperMPAS::create_local_vertices(), moab::ReadNASTRAN::create_materials(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::ScdNCHelper::create_mesh(), create_mesh_no_holes(), moab::SequenceManager::create_mesh_set(), create_mesh_with_holes(), moab::SequenceManager::create_meshset_sequence(), moab::WriteHDF5Parallel::create_meshset_tables(), moab::WriteHDF5Parallel::create_node_table(), moab::NCHelperGCRM::create_padded_gather_set_cells(), moab::NCHelperMPAS::create_padded_gather_set_cells(), moab::NCHelperGCRM::create_padded_local_cells(), moab::NCHelperMPAS::create_padded_local_cells(), moab::ParallelComm::create_part(), moab::ReadParallel::create_partition_sets(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::Tree::create_root(), moab::SequenceManager::create_scd_sequence(), moab::ScdInterface::create_scd_sequence(), moab::Core::create_set_iterator(), moab::WriteHDF5::create_set_meta(), moab::WriteHDF5::create_set_tables(), moab::ReadCGNS::create_sets(), moab::ReadGmsh::create_sets(), moab::ReadTemplate::create_sets(), moab::Skinner::create_side(), moab::ReadNCDF::create_sideset_element(), IntxUtilsCSLAM::create_span_quads(), moab::SpectralMeshTool::create_spectral_elems(), moab::ReadNCDF::create_ss_elements(), moab::ReadCGM::create_surface_facets(), moab::SequenceManager::create_sweep_sequence(), moab::BitTag::create_tag(), moab::DenseTag::create_tag(), moab::VarLenDenseTag::create_tag(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::WriteHDF5Parallel::create_tag_tables(), moab::ReadMCNP5::create_tags(), moab::ReadCGM::create_topology(), moab::BSPTree::create_tree(), moab::Coupler::create_tuples(), moab::AEntityFactory::create_vert_elem_adjacencies(), moab::SequenceManager::create_vertex(), moab::ReadIDEAS::create_vertices(), moab::ReadCGM::create_vertices(), moab::ReadMCNP5::create_vertices(), moab::Core::create_vertices(), moab::FBEngine::create_volume_with_direction(), moab::FBEngine::createTag(), moab::Intx2Mesh::createTags(), CreateTempestMesh(), moab::DataCoupler::DataCoupler(), moab::ReadSmf::dec(), moab::VectorSetIterator::decrement(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::HalfFacetRep::deinitialize(), moab::Skinner::deinitialize(), moab::GeomTopoTool::delete_all_obb_trees(), moab::SequenceManager::delete_entities(), moab::Core::delete_entities(), moab::ParallelComm::delete_entities(), moab::Core::delete_mesh(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::BSPTree::delete_tree(), moab::OrientedBoxTreeTool::delete_tree(), moab::Tree::delete_tree_sets(), moab::DualTool::delete_whole_dual(), moab::ParallelComm::destroy_part(), moab::HalfFacetRep::determine_border_vertices(), moab::ReadNASTRAN::determine_entity_type(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_incident_halffaces(), moab::HalfFacetRep::determine_incident_halfverts(), moab::ReadNASTRAN::determine_line_format(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), moab::Intx2Mesh::DetermineOrderedNeighbors(), moab::GeomTopoTool::dimension(), moab::BVHTree::distance_search(), moab::AdaptiveKDTree::distance_search(), moab::FBEngine::divide_triangle(), do_test_mode(), dot_children(), dot_nodes(), dot_write_id_nodes(), moab::BSPTreeIter::down(), moab::BSPTreeBoxIter::down(), moab::DualTool::dualCurve_tag(), moab::DualTool::dualEntity_tag(), moab::DualTool::dualGraphicsPoint_tag(), moab::DualTool::dualSurface_tag(), moab::DualTool::DualTool(), moab::ParCommGraph::dump_comm_information(), moab::GeomTopoTool::duplicate_model(), moab::Skinner::edge_reversed(), moab::IntxUtils::EdgeIntersections2(), moab::IntxUtils::EdgeIntxRllCs(), moab::Matrix3::eigen_decomposition(), moab::ScdBox::elem_seq(), moab::ReadSmf::end(), moab::IntxUtils::enforce_convexity(), moab::GeomTopoTool::entity_by_id(), moab::Skinner::entity_deletable(), moab::MeshTopoUtil::equivalent_entities(), moab::TypeSequenceManager::erase(), error_code_test(), moab::NestedRefine::estimate_hm_storage(), moab::SmoothFace::eval_bezier_patch(), moab::SmoothFace::eval_bezier_patch_normal(), moab::QuadraticHex::evalFcn(), moab::LinearHex::evalFcn(), moab::LinearQuad::evalFcn(), moab::LinearTri::evalFcn(), moab::LinearTet::evalFcn(), moab::LinearTet::evaluate_reverse(), moab::LinearTri::evaluate_reverse(), moab::EvalSet::evaluate_reverse(), moab::SmoothFace::evaluate_smooth_edge(), moab::SmoothCurve::evaluate_smooth_edge(), moab::ParallelComm::exchange_all_shared_handles(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_ghost_cells(), moab::NestedRefine::exchange_ghosts(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_owned_meshs(), moab::ParallelComm::exchange_tags(), DeformMeshRemap::execute(), McnpData::extract_tally_data(), moab::DualTool::extraDualEntity_tag(), moab::ReadSmf::f_color(), moab::ReadSmf::face(), moab::BSPTreeBoxIter::face_corners(), moab::DualTool::face_open_collapse(), moab::Skinner::face_reversed(), moab::DualTool::face_shrink(), moab::SmoothFace::facet_area_coordinate(), FBiGeom_getEntSets(), FBiGeom_getNumEntSets(), FBiGeom_isError(), moab::TempestOnlineMap::fill_col_ids(), fill_coord_on_edges(), moab::TempestOnlineMap::fill_row_ids(), moab::ParallelComm::filter_pstatus(), moab::TypeSequenceManager::find(), moab::Tree::find_all_trees(), moab::ScdInterface::find_boxes(), moab::AdaptiveKDTree::find_close_triangle(), moab::ElemEvaluator::find_containing_entity(), moab::SmoothFace::find_edges_orientations(), moab::MeshTag::find_entities_with_value(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), moab::VarLenSparseTag::find_entities_with_value(), moab::SparseTag::find_entities_with_value(), moab::ParallelComm::find_existing_entity(), moab::Skinner::find_geometric_skin(), moab::GeomTopoTool::find_geomsets(), moab::Skinner::find_inferred_edges(), moab::ReadHDF5::find_int_tag(), moab::Skinner::find_match(), moab::HalfFacetRep::find_matching_halfedge(), moab::MergeMesh::find_merged_to(), moab::SplitVertices< _n >::find_or_create(), DeformMeshRemap::find_other_sets(), moab::BVHTree::find_point(), moab::ReadHDF5::find_sets_containing(), moab::NestedRefine::find_shortest_diagonal_octahedron(), moab::ReadNCDF::find_side_element_type(), moab::Skinner::find_skin(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_scd(), moab::Skinner::find_skin_vertices(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::HalfFacetRep::find_total_edges_faces_3d(), moab::FBEngine::find_vertex_set_for_node(), moab::GeomQueryTool::find_volume(), moab::GeomQueryTool::find_volume_slow(), moab::Intx2Mesh::FindMaxEdges(), moab::Intx2Mesh::FindMaxEdgesInSet(), moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), moab::IntxUtils::fix_degenerate_quads(), fix_surface_senses(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_addl_ents(), moab::DualTool::foc_get_ents(), moab::DualTool::foc_get_stars(), moab::ParCommGraph::form_mesh_from_tuples(), moab::ParCommGraph::form_tuples_to_migrate_mesh(), moab::DualTool::fs_check_quad_sense(), moab::DualTool::fs_get_quad_loops(), moab::DualTool::fs_get_quads(), moab::DualTool::fsr_get_fourth_quad(), FunctionA(), FunctionB(), FunctionC(), moab::WriteHDF5::gather_all_mesh(), moab::ParallelComm::gather_data(), moab::WriteUtil::gather_entities(), moab::HalfFacetRep::gather_halfedges(), moab::WriteHDF5Parallel::gather_interface_meshes(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteCCMIO::gather_matset_info(), moab::WriteVtk::gather_mesh(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::WriteCCMIO::gather_neuset_info(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadUtil::gather_related_ents(), gather_set_stats(), gather_tag_counts(), moab::WriteHDF5::gather_tags(), moab::NestedRefine::generate_hm(), moab::GeomTopoTool::generate_implicit_complement(), moab::NestedRefine::generate_mesh_hierarchy(), moab::ReadRTT::generate_parent_child_links(), moab::ReadRTT::generate_topology(), moab::TempestRemapper::GenerateCSMeshMetadata(), moab::TempestRemapper::GenerateMeshMetadata(), moab::TempestOnlineMap::GenerateRemappingWeights(), moab::GeomTopoTool::geometrize_surface_set(), moab::GeomTopoTool::GeomTopoTool(), moab::BoundBox::get(), moab::TupleList::get(), moab::ScdBox::get_adj_edge_or_face(), moab::NestedRefine::get_adjacencies(), moab::HalfFacetRep::get_adjacencies(), moab::AEntityFactory::get_adjacencies(), moab::WriteUtil::get_adjacencies(), moab::Core::get_adjacencies(), moab::WriteHDF5::get_adjacencies(), moab::get_adjacencies_intersection(), moab::get_adjacencies_union(), moab::AEntityFactory::get_adjacency_ptr(), get_adjacent_elems(), moab::ParallelComm::get_all_pcomm(), moab::VarLenDenseTag::get_array(), moab::DenseTag::get_array_private(), moab::AEntityFactory::get_associated_meshsets(), moab::ReadNC::get_attributes(), moab::MeshTopoUtil::get_average_position(), get_barycenters(), get_boundary_entities(), moab::BVHTree::get_bounding_box(), moab::Tree::get_bounding_box(), moab::GeomTopoTool::get_bounding_coords(), moab::BSPTreeBoxIter::get_box_corners(), moab::Tree::get_box_tag(), moab::ScdInterface::get_boxes(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::WriteCGNS::get_cgns_type(), moab::Core::get_child_meshsets(), moab::MeshSetSequence::get_children(), moab::OrientedBoxTreeTool::get_close_tris(), moab::ParallelComm::get_comm_procs(), moab::RefinerTagManager::get_common_processes(), moab::WriteCGNS::get_conn_table(), moab::PolyElementSeq::get_connectivity(), moab::UnstructuredElemSeq::get_connectivity(), moab::NestedRefine::get_connectivity(), moab::SweptElementSeq::get_connectivity(), moab::Core::get_connectivity(), moab::StructuredElementSeq::get_connectivity(), moab::Core::get_connectivity_by_type(), moab::Core::get_contained_meshsets(), moab::ReadDamsel::get_contents(), moab::VertexSequence::get_coordinate_arrays(), moab::ScdBox::get_coordinate_arrays(), moab::VertexSequence::get_coordinates(), moab::NestedRefine::get_coordinates(), moab::VertexSequence::get_coordinates_ref(), moab::Core::get_coords(), moab::MeshTag::get_data(), moab::BitTag::get_data(), moab::DenseTag::get_data(), moab::VarLenDenseTag::get_data(), moab::VarLenSparseTag::get_data(), moab::SparseTag::get_data(), moab::VarLenSparseTag::get_data_ptr(), moab::SparseTag::get_data_ptr(), moab::ReadCCMIO::get_dbl_option(), get_degree_seq(), moab::MeshSetSequence::get_dimension(), moab::Core::get_dimension(), moab::ReadNC::get_dimensions(), moab::HalfFacetRep::get_down_adjacencies(), moab::HalfFacetRep::get_down_adjacencies_2d(), moab::HalfFacetRep::get_down_adjacencies_edg_3d(), moab::HalfFacetRep::get_down_adjacencies_face_3d(), moab::AEntityFactory::get_down_adjacency_elements(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::DualTool::get_dual_entities(), moab::DualTool::get_dual_entity(), moab::DualTool::get_dual_hyperplane(), moab::DualTool::get_dual_hyperplanes(), moab::AEntityFactory::get_element(), moab::ReadUtil::get_element_connect(), moab::WriteUtil::get_element_connect(), moab::AEntityFactory::get_elements(), moab::ReadABAQUS::get_elements_by_id(), moab::MeshSetSequence::get_entities(), moab::MeshSet::get_entities(), moab::Tqdcfr::get_entities(), moab::MeshSet::get_entities_by_dimension(), moab::Core::get_entities_by_dimension(), moab::Core::get_entities_by_handle(), moab::MeshSet::get_entities_by_type(), moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), moab::BitTag::get_entities_with_bits(), moab::WriteUtil::get_entity_list_pointers(), moab::HalfFacetRep::get_entity_ranges(), moab::EvalSet::get_eval_set(), moab::DualTool::get_extra_dual_entity(), moab::HalfFacetRep::get_face_edges(), get_file_options(), moab::point_locator::io::get_file_options(), moab::ReadUtil::get_gather_set(), moab::ParallelComm::get_ghosted_entities(), moab::WriteCCMIO::get_gids(), moab::Coupler::get_gl_points_on_elements(), moab::ParallelComm::get_global_part_count(), get_gnomonic_plane(), moab::DualTool::get_graphics_points(), moab::Coupler::get_group_integ_vals(), get_group_names(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::HalfFacetRep::get_half_facet_in_comp(), moab::ReadRTT::get_header_data(), moab::ParallelComm::get_iface_entities(), moab::GeomTopoTool::get_implicit_complement(), moab::HalfFacetRep::get_incident_map(), moab::ScdInterface::get_indices(), moab::AdaptiveKDTree::get_info(), moab::FileOptions::get_int_option(), moab::ReadCCMIO::get_int_option(), moab::ParallelComm::get_interface_procs(), moab::ParallelData::get_interface_sets(), moab::ParallelComm::get_interface_sets(), get_intersection_weights(), moab::FileOptions::get_ints_option(), moab::Error::get_last_error(), moab::Core::get_last_error(), moab::GeomQueryTool::RayHistory::get_last_intersection(), moab::AdaptiveKDTree::get_last_iterator(), moab::NestedRefine::get_lid_inci_child(), get_linear_reconstruction(), moab::SharedSetData::get_local_handle(), moab::ParallelComm::get_local_handles(), moab::NestedRefine::get_local_vid(), moab::MeshTopoUtil::get_manifold(), get_max_volume(), moab::AEntityFactory::get_memory_use(), moab::BitTag::get_memory_use(), moab::MeshTag::get_memory_use(), moab::DenseTag::get_memory_use(), moab::VarLenDenseTag::get_memory_use(), moab::VarLenSparseTag::get_memory_use(), moab::SparseTag::get_memory_use(), moab::Tqdcfr::get_mesh_entities(), moab::ReadMCNP5::get_mesh_plane(), moab::get_mesh_set(), moab::Core::get_meshset_options(), moab::Tqdcfr::get_names(), moab::ScdInterface::get_neighbor(), moab::HalfFacetRep::get_neighbor_adjacencies(), moab::HalfFacetRep::get_neighbor_adjacencies_1d(), moab::HalfFacetRep::get_neighbor_adjacencies_2d(), moab::HalfFacetRep::get_neighbor_adjacencies_3d(), moab::ScdInterface::get_neighbor_alljkbal(), moab::ScdInterface::get_neighbor_alljorkori(), moab::ScdInterface::get_neighbor_sqij(), moab::ScdInterface::get_neighbor_sqijk(), moab::ScdInterface::get_neighbor_sqjk(), moab::AdaptiveKDTreeIter::get_neighbors(), moab::BSPTreeBoxIter::get_neighbors(), moab::ReorderTool::get_new_handles(), moab::RangeSetIterator::get_next_arr(), moab::VectorSetIterator::get_next_arr(), moab::RangeSetIterator::get_next_by_dimension(), moab::RangeSetIterator::get_next_by_type(), moab::ReadUtil::get_node_coords(), moab::WriteUtil::get_node_coords(), moab::ReadABAQUS::get_nodes_by_id(), moab::FBEngine::get_nodes_from_edge(), moab::MeshSet::get_non_set_entities(), moab::GeomQueryTool::get_normal(), moab::HiReconstruction::get_normals_surf(), moab::FileOptions::get_null_option(), moab::Core::get_number_entities_by_dimension(), moab::Core::get_number_entities_by_handle(), moab::Core::get_number_entities_by_type(), moab::NestedRefine::get_octahedron_corner_coords(), moab::DualTool::get_opposite_verts(), moab::FileOptions::get_option(), moab::ReadUtil::get_ordered_vertices(), moab::SharedSetData::get_owner(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_owning_part(), moab::SharedSetData::get_owning_procs(), moab::ScdVertexData::get_params(), moab::SweptVertexData::get_params(), moab::SweptElementData::get_params(), moab::ScdElementData::get_params(), moab::ScdBox::get_params(), moab::SweptElementData::get_params_connectivity(), moab::ScdElementData::get_params_connectivity(), moab::MeshSetSequence::get_parent_child_meshsets(), moab::Core::get_parent_meshsets(), moab::MeshSetSequence::get_parents(), moab::ParallelComm::get_part_entities(), moab::ParallelComm::get_part_handle(), moab::ParallelComm::get_part_id(), moab::ParallelComm::get_part_neighbor_ids(), moab::ParallelComm::get_part_owner(), moab::ReadHDF5::get_partition(), moab::ParallelData::get_partition_sets(), moab::ParallelComm::get_pcomm(), moab::AEntityFactory::get_polyhedron_vertices(), moab::ParallelComm::get_proc_nvecs(), moab::ReadCCMIO::get_processors(), moab::ParallelComm::get_pstatus_entities(), moab::DualTool::get_radial_dverts(), moab::ReadNASTRAN::get_real(), moab::FileOptions::get_real_option(), moab::FileOptions::get_reals_option(), moab::Tqdcfr::get_ref_entities(), moab::ParallelComm::get_remote_handles(), moab::ReorderTool::get_reordered_handles(), moab::GeomTopoTool::get_root(), moab::GeomTopoTool::get_sense(), moab::GeomTopoTool::get_senses(), moab::ParallelComm::get_sent_ents(), moab::ReadSms::get_set(), moab::ReadABAQUS::get_set_by_name(), moab::ReadHDF5::get_set_contents(), moab::ReadABAQUS::get_set_elements(), moab::ReadABAQUS::get_set_elements_by_name(), moab::WriteCGNS::get_set_entities(), moab::WriteHDF5::get_set_info(), moab::Core::get_set_iterators(), moab::ReadABAQUS::get_set_nodes(), DeformMeshRemap::get_set_nos(), moab::WriteCCMIO::get_sets(), moab::ParallelComm::get_shared_entities(), moab::ParallelComm::get_shared_proc_tags(), moab::SharedSetData::get_shared_sets(), moab::ScdInterface::get_shared_vertices(), moab::ParallelComm::get_sharing_data(), moab::ParallelComm::get_sharing_parts(), moab::SharedSetData::get_sharing_procs(), moab::HalfFacetRep::get_sibling_map(), get_signed_volume(), moab::WriteHDF5::get_sparse_tagged_entities(), moab::AdaptiveKDTree::get_split_plane(), moab::ReadCCMIO::get_state(), moab::FileOptions::get_str_option(), moab::ReadCCMIO::get_str_option(), moab::FileOptions::get_strs_option(), moab::ReadHDF5::get_subset_ids(), moab::GeomTopoTool::get_surface_senses(), moab::ReadABAQUS::get_tag(), moab::WriteHDF5::get_tag_data_length(), moab::WriteUtil::get_tag_list(), moab::ParallelComm::get_tag_send_list(), moab::WriteHDF5::get_tag_size(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), moab::get_tagged(), moab::MeshTag::get_tagged_entities(), moab::BitTag::get_tagged_entities(), moab::DenseTag::get_tagged_entities(), moab::VarLenSparseTag::get_tagged_entities(), moab::SparseTag::get_tagged_entities(), moab::ReadHDF5::get_tagged_entities(), moab::ReadMCNP5::get_tally_particle(), moab::HiReconstruction::get_tangents_curve(), moab::FileOptions::get_toggle_option(), moab::BSPTree::get_tree_end_iterator(), moab::AdaptiveKDTree::get_tree_iterator(), moab::BSPTree::get_tree_iterator(), moab::WriteSTL::get_triangle_data(), moab::WriteSTL::get_triangles(), moab::MeshSetSequence::get_type(), moab::FileOptions::get_unseen_option(), moab::HalfFacetRep::get_up_adjacencies(), moab::HalfFacetRep::get_up_adjacencies_1d(), moab::HalfFacetRep::get_up_adjacencies_2d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d_comp(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::get_up_adjacencies_vert_2d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), moab::AEntityFactory::get_up_adjacency_elements(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::WriteNCDF::get_valid_sides(), moab::ReadNC::get_variables(), get_vartag_data(), moab::FBEngine::get_vert_edges(), moab::Core::get_vertex_coordinates(), moab::NestedRefine::get_vertex_duplicates(), moab::Core::get_vertices(), moab::AEntityFactory::get_zero_to_n_elements(), moab::FBEngine::getAdjacentEntities(), moab::FBEngine::getEgFcSense(), moab::FBEngine::getEgVtxSense(), moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntClosestPt(), moab::FBEngine::getEntities(), moab::FBEngine::getEntNrmlXYZ(), moab::FBEngine::getEntTgntU(), moab::FBEngine::getEntType(), moab::FBEngine::getEntURange(), moab::FBEngine::getEntUtoXYZ(), moab::ParallelMergeMesh::GetGlobalBox(), moab::TempestRemapper::GetIMasks(), moab::FBEngine::getNumOfType(), moab::TempestRemapper::GetOverlapAugmentedEntities(), moab::FBEngine::getPntRayIntsct(), moab::FBEngine::getRootSet(), moab::FBEngine::getVtxCoord(), moab::ScdInterface::global_box_dims_tag(), moab::IntxUtils::global_gnomonic_projection(), moab::GeomTopoTool::global_id(), moab::DualTool::globalId_tag(), moab::IntxUtils::gnomonic_projection(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), hcFilter(), moab::Core::high_order_node(), moab::HiReconstruction::HiReconstruction(), iMesh_createEnt(), iMesh_createEntArr(), iMesh_createTagWithOptions(), iMesh_destroyTag(), iMesh_getArrData(), iMesh_getEntArr2ndAdj(), iMesh_getEntArrAdj(), iMesh_getEntitiesRec(), iMesh_getEntsByTagsRec(), iMesh_getNumOfTopoRec(), iMesh_getNumOfTypeRec(), iMesh_getTagHandle(), iMesh_initEntArrIterRec(), iMesh_intersect(), iMesh_isError(), iMesh_newMesh(), iMesh_setVtxArrCoords(), iMesh_subtract(), iMesh_unite(), iMeshP_getEntOwnerPartArr(), iMeshP_getNumOfTopoAll(), iMeshP_getNumOfTypeAll(), iMeshP_getRankOfPartArr(), iMeshP_initEntArrIter(), iMeshP_initPartBdryEntArrIter(), iMOAB_CreateElements(), iMOAB_CreateVertices(), iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_DuplicateAppMesh(), iMOAB_Finalize(), iMOAB_GetBlockElementConnectivities(), iMOAB_GetBlockID(), iMOAB_GetBlockInfo(), iMOAB_GetDoubleTagStorage(), iMOAB_GetElementConnectivity(), iMOAB_GetElementID(), iMOAB_GetElementOwnership(), iMOAB_GetGlobalInfo(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_GetNeighborElements(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleElementsInfo(), iMOAB_GetVisibleVerticesCoordinates(), iMOAB_Initialize(), iMOAB_ReadHeaderInfo(), iMOAB_ReduceTagsMax(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorage(), iMOAB_SetDoubleTagStorageWithGid(), iMOAB_SetGlobalInfo(), iMOAB_SetIntTagStorage(), iMOAB_SynchronizeTags(), iMOAB_UpdateMeshInfo(), iMOAB_WriteLocalMesh(), iMOAB_WriteMesh(), moab::ReadSmf::inc(), ZoltanPartitioner::include_closure(), moab::FBEngine::Init(), moab::ReadDamsel::init(), moab::ReadHDF5::init(), moab::AdaptiveKDTree::init(), moab::WriteHDF5::init(), moab::SmoothFace::init_bezier_edge(), moab::HalfFacetRep::init_curve(), moab::SmoothFace::init_edge_control_points(), moab::SmoothFace::init_facet_control_points(), moab::NCWriteHelper::init_file(), moab::SmoothFace::init_gradient(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::HalfFacetRep::init_surface(), moab::WriteDamsel::init_tag_info(), moab::BSPTree::init_tags(), moab::HalfFacetRep::init_volume(), moab::LinearTet::initFcn(), moab::LinearTri::initFcn(), moab::NestedRefine::initialize(), moab::TempestRemapper::initialize(), moab::HalfFacetRep::initialize(), moab::GeomQueryTool::initialize(), moab::Skinner::initialize(), moab::LloydSmoother::initialize(), moab::gs_data::initialize(), moab::BSPTreeIter::initialize(), moab::BSPTreeBoxIter::initialize(), moab::Core::initialize(), moab::WriteNCDF::initialize_exodus_file(), moab::WriteTemplate::initialize_file(), moab::WriteSLAC::initialize_file(), moab::WriteHDF5::initialize_mesh(), moab::Coupler::initialize_spectral_elements(), initialize_tree(), moab::Coupler::initialize_tree(), moab::FBEngine::initializeSmoothing(), moab::ReadHDF5::insert_in_id_map(), moab::GeomTopoTool::insert_in_tree(), moab::TypeSequenceManager::insert_sequence(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::ElemEvaluator::integrate(), integrate_scalar_field_test(), moab::LinearHex::integrateFcn(), moab::LinearTet::integrateFcn(), moab::LinearTri::integrateFcn(), moab::LinearQuad::integrateFcn(), moab::Coupler::interp_field(), moab::DataCoupler::interpolate(), moab::Coupler::interpolate(), moab::Tqdcfr::interpret_acis_records(), moab::MeshSet::intersect(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::IntxUtils::intersect_great_circle_arc_with_clat_arc(), moab::IntxUtils::intersect_great_circle_arcs(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::BSPTreeIter::intersect_ray(), SetIntersectIter< Container >::intersect_with_set(), moab::DualTool::is_blind(), moab::TypeSequenceManager::is_free_handle(), moab::ParallelComm::is_iface_proc(), moab::GeomTopoTool::is_owned_set(), moab::BSPTreeIter::is_sibling(), moab::AdaptiveKDTreeIter::is_sibling(), moab::DenseTag::is_tagged(), moab::VarLenDenseTag::is_tagged(), moab::Core::is_valid(), moab::DualTool::isDualCell_tag(), moab::FBEngine::isEntAdj(), moab::QuadraticHex::jacobianFcn(), moab::LinearHex::jacobianFcn(), moab::LinearQuad::jacobianFcn(), moab::LinearTri::jacobianFcn(), moab::LinearTet::jacobianFcn(), moab::OrientedBoxTreeTool::join_trees(), laplacianFilter(), moab::RayIntersector::leaf(), moab::RayIntersectSets::leaf(), moab::TreeLayoutPrinter::leaf(), moab::TreeNodePrinter::leaf(), moab::BSPTree::leaf_containing_point(), moab::TempestOnlineMap::LinearRemapNN_MOAB(), moab::DualTool::list_entities(), moab::Core::list_entities(), moab::ParallelComm::list_entities(), moab::Core::list_entity(), list_formats(), moab::ReadCGNS::load_file(), moab::ReadTemplate::load_file(), moab::ReadIDEAS::load_file(), moab::ReadParallel::load_file(), moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), moab::ReadDamsel::load_file(), moab::ReadTetGen::load_file(), moab::ReadSmf::load_file(), moab::ReadNASTRAN::load_file(), moab::ReadMCNP5::load_file(), moab::ReadCGM::load_file(), moab::ReadHDF5::load_file(), moab::ReadSTL::load_file(), moab::ReadNC::load_file(), moab::ReadNCDF::load_file(), moab::Core::load_file(), moab::ReadRTT::load_file(), moab::ReadOBJ::load_file(), moab::Tqdcfr::load_file(), moab::ReadABAQUS::load_file(), moab::ReadSms::load_file_impl(), moab::ReadHDF5::load_file_impl(), moab::ReadHDF5::load_file_partial(), moab::ReadCCMIO::load_matset_data(), moab::ReadCCMIO::load_metadata(), moab::ReadCCMIO::load_neuset_data(), moab::ReadMCNP5::load_one_file(), moab::TempestRemapper::load_tempest_mesh_private(), moab::Remapper::LoadNativeMesh(), moab::WriteGMV::local_write_mesh(), moab::SpatialLocator::locate_points(), moab::Coupler::locate_points(), main(), make_atomic_pillow(), make_chord_push(), make_face_shrink(), moab::ReadCCMIO::make_faces(), moab::WriteSTL::make_header(), moab::OrientedBox::make_hex(), moab::AdaptiveKDTree::make_tag(), make_triple_chord_push(), make_tris_from_quad(), make_tris_from_quads(), manufacture_lagrange_mesh_on_sphere(), moab::WriteDamsel::map_dense_tags(), moab::WriteDamsel::map_sparse_tags(), moab::MeshOutputFunctor::map_vertex(), moab::HalfFacetRep::mark_halfedges(), moab::FileOptions::match_option(), moab::FBEngine::measure(), measure(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), moab::EntitySequence::merge(), moab::AEntityFactory::merge_adjust_adjacencies(), moab::MergeMesh::merge_all(), merge_duplicate_vertices(), moab::MergeMesh::merge_entities(), moab::Core::merge_entities(), moab::MergeMesh::merge_higher_dimensions(), merge_input_surfs(), moab::TypeSequenceManager::merge_internal(), moab::AdaptiveKDTree::merge_leaf(), moab::BSPTree::merge_leaf(), moab::MergeMesh::merge_using_integer_tag(), min_edge_length(), moab::ReadSmf::mload(), moab::ReadSmf::mmult(), moab::SmoothFace::move_to_surface(), smoab::Interface::name(), moab::Coupler::nat_param(), moab::WriteHDF5Parallel::negotiate_type_list(), moab::NestedRefine::NestedRefine(), moab::DualTool::next_loop_vertex(), moab::GeomTopoTool::next_vol(), moab::SmoothFace::normal_at(), moab::LinearTet::normalFcn(), moab::LinearTri::normalFcn(), moab::LinearHex::normalFcn(), moab::LinearQuad::normalFcn(), moab::AEntityFactory::notify_change_connectivity(), moab::AEntityFactory::notify_create_entity(), moab::AEntityFactory::notify_delete_entity(), moab::Core::num_child_meshsets(), moab::MeshSetSequence::num_children(), moab::Core::num_contained_meshsets(), moab::MeshSetSequence::num_contained_sets(), moab::MeshSetSequence::num_dimension(), moab::MeshSetSequence::num_entities(), moab::Core::num_parent_meshsets(), moab::MeshSetSequence::num_parents(), moab::MeshTag::num_tagged_entities(), moab::BitTag::num_tagged_entities(), moab::VarLenSparseTag::num_tagged_entities(), moab::SparseTag::num_tagged_entities(), moab::MeshSetSequence::num_type(), obbstat_write(), moab::WriteCCMIO::open_file(), moab::ReadTetGen::open_file(), moab::WriteTemplate::open_file(), moab::WriteSLAC::open_file(), moab::WriteNCDF::open_file(), moab::WriteHDF5Parallel::NoopDescCreator::operator()(), moab::BSPTreePlaneIter::operator++(), moab::MeshTopoUtil::opposite_entity(), moab::DualTool::order_chord(), orient_faces_outward(), moab::OrientedBoxTreeTool::OrientedBoxTreeTool(), moab::GeomTopoTool::other_entity(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::ParallelComm::pack_range_map(), moab::ParCommGraph::pack_receivers_graph(), moab::ParallelComm::pack_remote_handles(), moab::WriteHDF5Parallel::pack_set(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_shared_handles(), moab::ParallelComm::pack_tag(), moab::ParallelComm::pack_tags(), moab::ParallelComm::packed_tag_size(), moab::WriteHDF5Parallel::parallel_create_file(), moab::NestedRefine::parent_to_child(), moab::Tqdcfr::parse_acis_attribs(), moab::ReadTetGen::parse_attr_list(), moab::Tree::parse_common_options(), moab::ReadSmf::parse_doubles(), moab::ReadSmf::parse_line(), moab::ReadSmf::parse_mat(), moab::BVHTree::parse_options(), moab::AdaptiveKDTree::parse_options(), moab::ReadDamsel::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), parse_tag_create(), parse_tag_spec(), moab::ScdInterface::part_method_tag(), ZoltanPartitioner::partition_inferred_mesh(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), ZoltanPartitioner::partition_owned_cells(), moab::ParallelComm::partition_tag(), moab::ParallelMergeMesh::PartitionGlobalBox(), moab::ParallelComm::pcomm_tag(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::MergeMesh::perform_merge(), moab::LloydSmoother::perform_smooth(), moab::ParallelMergeMesh::PerformMerge(), moab::plane_cut_box(), moab::plane_uncut_box(), moab::GeomQueryTool::point_in_volume(), moab::GeomQueryTool::point_in_volume_slow(), moab::AdaptiveKDTree::point_search(), moab::BVHTree::point_search(), moab::GeomQueryTool::poly_solid_angle(), moab::MeshSetSequence::pop_back(), moab::EntitySequence::pop_back(), moab::MeshSetSequence::pop_front(), moab::EntitySequence::pop_front(), moab::ParallelMergeMesh::PopulateMyMatches(), moab::ParallelMergeMesh::PopulateMySkinEnts(), moab::ParallelMergeMesh::PopulateMyTup(), moab::SmoothCurve::position_from_u(), moab::IntxAreaUtils::positive_orientation(), moab::ParallelComm::post_irecv(), moab::OrientedBoxTreeTool::preorder_traverse(), moab::EntitySequence::prepend_entities(), moab::BVHTree::print(), moab::AdaptiveKDTree::print(), moab::OrientedBoxTreeTool::print(), moab::ParallelComm::print_buffer(), moab::DualTool::print_cell(), moab::TreeNodePrinter::print_contents(), moab::TreeNodePrinter::print_counts(), moab::Core::print_database(), moab::Core::print_entity_tags(), print_error(), moab::TreeNodePrinter::print_geometry(), print_memory_stats(), moab::BVHTree::print_nodes(), moab::WriteHDF5Parallel::print_shared_sets(), moab::HalfFacetRep::print_tags(), moab::print_type_sets(), print_vertex_fields(), moab::WriteNC::process_concatenated_attribute(), moab::WriteNC::process_conventional_tags(), moab::ReadDamsel::process_ent_info(), moab::ReadDamsel::process_entity_tags(), moab::ReadCGNS::process_options(), moab::ReadTemplate::process_options(), moab::Tqdcfr::process_record(), moab::Tqdcfr::process_sideset_10(), moab::Tqdcfr::process_sideset_11(), moab::ReadDamsel::process_tags(), moab::SmoothFace::project_to_facet_plane(), moab::SmoothFace::project_to_facets(), moab::SmoothFace::project_to_facets_main(), moab::SmoothFace::project_to_patch(), moab::ParallelComm::pstatus_tag(), moab::MeshSetSequence::push_back(), moab::MeshSetSequence::push_front(), moab::Tqdcfr::put_into_set(), moab::putElementField(), moab::putSpectralElementField(), quads_to_tris(), moab::VerdictWrapper::quality_measure(), moab::Core::query_interface_type(), moab::range_to_blocked_list_templ(), moab::range_to_id_list_templ(), moab::range_tool< pair_iter_t >::ranged_insert_entities(), moab::range_tool< pair_iter_t >::ranged_remove_entities(), moab::RangeSetIterator::RangeSetIterator(), moab::GeomQueryTool::ray_fire(), moab::OrientedBoxTreeTool::ray_intersect_sets(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::OrientedBoxTreeTool::ray_intersect_triangles(), moab::SmoothFace::ray_intersection_correct(), moab::ReadHDF5VarLen::read(), moab::Tqdcfr::read_acis_records(), moab::ReadHDF5::read_adjacencies(), moab::ReadHDF5::read_all_set_meta(), moab::ReadABAQUS::read_assembly(), moab::Tqdcfr::read_block(), moab::ReadNCDF::read_block_headers(), moab::ReadCCMIO::read_cells(), moab::ReadRTT::read_cells(), moab::NCHelper::read_coordinate(), moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5::read_dense_tag(), moab::ReadTetGen::read_elem_file(), moab::ReadNASTRAN::read_element(), moab::ReadABAQUS::read_element_list(), moab::ReadABAQUS::read_element_set(), moab::ReadMCNP5::read_element_values_and_errors(), moab::ReadTemplate::read_elements(), moab::ReadNCDF::read_elements(), moab::Tqdcfr::read_elements(), moab::ReadHDF5::read_elems(), moab::ReadNCDF::read_exodus_header(), moab::ReadNCDF::read_face_blocks_headers(), moab::ReadCCMIO::read_faces(), moab::ReadRTT::read_facets(), DeformMeshRemap::read_file(), moab::ReadMCNP5::read_file_header(), moab::Tqdcfr::read_file_header(), moab::ReadCCMIO::read_gids_and_types(), moab::ReadNCDF::read_global_ids(), moab::Tqdcfr::read_group(), moab::ReadNC::read_header(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::ReadABAQUS::read_heading(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::ReadABAQUS::read_instance(), moab::ReadTetGen::read_line(), McnpData::read_mcnpfile(), moab::Tqdcfr::read_md_string(), moab::ReadMCNP5::read_mesh_planes(), moab::Tqdcfr::read_meta_data(), moab::Tqdcfr::ModelEntry::read_metadata_info(), moab::Tqdcfr::read_model_entries(), moab::ReadNASTRAN::read_node(), moab::ReadHDF5::read_node_adj_elems(), moab::ReadTetGen::read_node_file(), moab::ReadABAQUS::read_node_list(), moab::ReadABAQUS::read_node_set(), moab::ReadNCDF::read_nodes(), moab::ReadHDF5::read_nodes(), moab::Tqdcfr::read_nodes(), moab::ReadRTT::read_nodes(), moab::Tqdcfr::read_nodeset(), moab::ReadNCDF::read_nodesets(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadSms::read_parallel_info(), moab::ReadABAQUS::read_part(), moab::ReadHDF5::read_poly(), moab::ReadNCDF::read_polyhedra_faces(), moab::ReadHDF5::read_qa(), moab::ReadNCDF::read_qa_information(), moab::ReadNCDF::read_qa_records(), moab::ReadNCDF::read_qa_string(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_sets(), moab::ReadRTT::read_sides(), moab::Tqdcfr::read_sideset(), moab::ReadNCDF::read_sidesets(), moab::ReadABAQUS::read_solid_section(), moab::ReadHDF5::read_sparse_tag(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag(), moab::ReadHDF5::read_tag_values(), moab::ReadNCDF::read_tag_values(), moab::ReadHDF5::read_tag_values_all(), moab::ReadHDF5::read_tag_values_partial(), moab::ReadMCNP5::read_tally_header(), moab::ReadRTT::read_tets(), moab::ReadCCMIO::read_topology_types(), moab::ReadHDF5::read_var_len_tag(), moab::ScdNCHelper::read_variables(), moab::UcdNCHelper::read_variables(), moab::NCHelper::read_variables_setup(), moab::NCHelper::read_variables_to_set_allocate(), moab::ReadVtk::read_vertices(), moab::ReadCCMIO::read_vertices(), moab::ReadNCDF::ReadNCDF(), moab::TempestOnlineMap::ReadParallelMap(), ReadTriangleOutput(), moab::ParCommGraph::receive_comm_graph(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), moab::MeshSetSequence::recursive_get_sets(), moab::OrientedBoxTreeTool::recursive_stats(), moab::ParallelComm::recv_buffer(), moab::ParallelComm::recv_entities(), moab::ParallelComm::recv_messages(), moab::ParallelComm::recv_remote_handle_messages(), moab::FBEngine::redistribute_boundary_edges_to_faces(), moab::ParallelComm::reduce(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::reduce_void(), moab::MeshRefiner::refine(), moab::SimplexTemplateRefiner::refine_entity(), moab::ReaderWriterSet::register_factory(), moab::FindVolumeIntRegCtxt::register_intersection(), moab::GQT_IntRegCtxt::register_intersection(), moab::OrientedBoxTreeTool::IntRegCtxt::register_intersection(), moab::MeshTag::release_all_data(), moab::BitTag::release_all_data(), moab::DenseTag::release_all_data(), moab::VarLenDenseTag::release_all_data(), moab::VarLenSparseTag::release_all_data(), moab::SparseTag::release_all_data(), moab::Core::release_interface_type(), moab::ParCommGraph::release_send_buffers(), moab::SequenceManager::release_tag_array(), moab::MeshSet::remove_adjacencies(), moab::AEntityFactory::remove_adjacency(), moab::Skinner::remove_adjacency(), moab::AEntityFactory::remove_all_adjacencies(), moab::ScdInterface::remove_box(), moab::Core::remove_child_meshset(), moab::MeshTag::remove_data(), moab::BitTag::remove_data(), moab::VarLenDenseTag::remove_data(), moab::VarLenSparseTag::remove_data(), moab::SparseTag::remove_data(), moab::IntxUtils::remove_duplicate_vertices(), remove_empty_cgm_surfs_and_vols(), moab::ParallelComm::remove_entities_part(), moab::HigherOrderFactory::remove_ho_nodes(), moab::IntxUtils::remove_padded_vertices(), moab::Core::remove_parent_child(), moab::Core::remove_parent_meshset(), moab::ParallelComm::remove_pcomm(), moab::GeomTopoTool::remove_root(), moab::OrientedBoxTreeTool::remove_root(), moab::TypeSequenceManager::remove_sequence(), moab::Core::remove_set_iterator(), DeformMeshRemap::remove_set_no(), remove_var_len_tags(), moab::ReorderTool::reorder_entities(), moab::NestedRefine::reorder_indices(), moab::ReorderTool::reorder_tag_data(), ZoltanPartitioner::repartition(), moab::MeshSet::replace_entities(), replace_faceted_cgm_surfs(), replace_surface(), moab::BitTag::reserve(), moab::SequenceManager::reserve_tag_array(), moab::RangeSetIterator::reset(), MBIter< Container >::reset(), moab::VectorSetIterator::reset(), SetIntersectIter< Container >::reset(), moab::Tqdcfr::reset_record(), moab::TupleList::resize(), moab::HalfFacetRep::resize_hf_maps(), moab::GeomTopoTool::resize_rootSets(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_obb_index(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), SphereDecomp::retrieve_subdiv_verts(), moab::DualTool::rev_atomic_pillow(), moab::DualTool::rev_face_shrink(), moab::IntxUtils::reverse_gnomonic_projection(), moab::ReadSmf::rot(), moab::ReadSmf::scale(), moab::IntxUtils::ScaleToRadius(), moab::ParallelComm::scatter_entities(), moab::ScdBox::ScdBox(), moab::ReadHDF5::search_tag_values(), moab::ParallelComm::send_buffer(), moab::ParallelComm::send_entities(), moab::ParCommGraph::send_graph(), moab::ParCommGraph::send_graph_partition(), moab::ParCommGraph::send_mesh_parts(), moab::ParallelComm::send_recv_entities(), moab::ParCommGraph::send_tag_values(), moab::FBEngine::separate(), moab::GeomTopoTool::separate_by_dimension(), moab::WriteHDF5::serial_create_file(), moab::Core::serial_load_file(), moab::Core::serial_read_tag(), moab::BSPTreePoly::set(), moab::ReadSmf::set(), moab::AEntityFactory::set_adjacency_ptr(), moab::TempestOnlineMap::set_col_dc_dofs(), moab::UnstructuredElemSeq::set_connectivity(), moab::Core::set_connectivity(), moab::VertexSequence::set_coordinates(), moab::Core::set_coords(), moab::MeshTag::set_data(), moab::BitTag::set_data(), moab::DenseTag::set_data(), moab::VarLenSparseTag::set_data(), moab::SparseTag::set_data(), moab::VarLenDenseTag::set_data(), moab::FBEngine::set_default_neumann_tags(), set_density(), set_departure_points_position(), moab::Core::set_dimension(), moab::DualTool::set_dual_surface_or_curve(), moab::ElemEvaluator::set_ent_handle(), moab::ElemEvaluator::set_eval_set(), moab::MeshSet::set_flags(), moab::ReadMCNP5::set_header_tags(), moab::HalfFacetRep::set_incident_map(), moab::Error::set_last_error(), moab::FBEngine::set_neumann_tags(), moab::ReadCGM::set_options(), moab::SharedSetData::set_owner(), moab::ParallelComm::set_partitioning(), moab::ParallelComm::set_pstatus_entities(), moab::GeomTopoTool::set_root_set(), moab::TempestOnlineMap::set_row_dc_dofs(), moab::GeomTopoTool::set_sense(), moab::GeomTopoTool::set_senses(), moab::SharedSetData::set_sharing_procs(), moab::HalfFacetRep::set_sibling_map(), moab::VerdictWrapper::set_size(), moab::AdaptiveKDTree::set_split_plane(), moab::ParCommGraph::set_split_ranges(), moab::GeomTopoTool::set_surface_senses(), moab::ReadRTT::set_surface_senses(), moab::ElemEvaluator::set_tag(), moab::ElemEvaluator::set_tag_handle(), moab::WriteCGNS::set_tag_values(), moab::ReadMCNP5::set_tally_tags(), moab::ReadHDF5::set_up_read(), moab::TempestOnlineMap::SetDOFmapAssociation(), moab::TempestOnlineMap::SetDOFmapTags(), moab::ParallelComm::settle_intersection_points(), moab::ParCommGraph::settle_send_graph(), moab::GeomTopoTool::setup_implicit_complement(), moab::Intx2MeshInPlane::setup_tgt_cell(), moab::IntxRllCssphere::setup_tgt_cell(), moab::ParallelComm::sharedh_tag(), moab::ParallelComm::sharedhs_tag(), moab::ParallelComm::sharedp_tag(), moab::ParallelComm::sharedps_tag(), moab::SharedSetData::SharedSetData(), moab::BSPTreeIter::sibling_is_forward(), moab::AdaptiveKDTreeIter::sibling_is_forward(), moab::AdaptiveKDTreeIter::sibling_side(), moab::BSPTreeBoxIter::sibling_side(), moab::Core::side_element(), moab::Core::side_number(), moab::Skinner::skin_box(), skin_tris(), moab::ReadIDEAS::skip_header(), moab::FBEngine::smooth_new_intx_points(), moab::TupleList::sort(), moab::ParallelMergeMesh::SortMyMatches(), moab::SpatialLocator::SpatialLocator(), moab::SpectralMeshTool::spectral_order_tag(), moab::SpectralMeshTool::spectral_vertices_tag(), moab::AdaptiveKDTree::sphere_intersect_triangles(), moab::OrientedBoxTreeTool::sphere_intersect_triangles(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::split_box(), moab::FBEngine::split_edge_at_mesh_node(), moab::MeshTopoUtil::split_entities_manifold(), moab::FBEngine::split_internal_edge(), moab::AdaptiveKDTree::split_leaf(), moab::BSPTree::split_leaf(), moab::ParCommGraph::split_owned_range(), moab::DualTool::split_pair_nonmanifold(), moab::FBEngine::split_quads(), moab::split_sets(), moab::FBEngine::split_surface(), moab::FBEngine::split_surface_with_direction(), moab::MeshTopoUtil::star_entities(), moab::MeshTopoUtil::star_entities_nonmanifold(), moab::MeshTopoUtil::star_next_entity(), moab::ExoIIUtil::static_get_element_type(), moab::OrientedBoxTreeTool::stats(), moab::BSPTreeIter::step(), moab::BSPTreeBoxIter::step(), moab::AdaptiveKDTreeIter::step(), step_iterator(), moab::BSPTreeIter::step_to_first_leaf(), moab::AdaptiveKDTreeIter::step_to_first_leaf(), moab::BSPTreeBoxIter::step_to_first_leaf(), moab::ReadCGM::store_curve_senses(), moab::ReadVtk::store_file_ids(), moab::ReadHDF5::store_file_ids(), moab::ReadCGM::store_group_content(), moab::ReadCGM::store_groups(), moab::ReadHDF5::store_sets_file_ids(), moab::ReadCGM::store_surface_senses(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), summarize_cell_volume_change(), moab::Core::tag_delete(), moab::Core::tag_get_bytes(), moab::Core::tag_get_data_type(), moab::Core::tag_get_default_value(), moab::Core::tag_get_handle(), moab::Core::tag_get_length(), moab::Core::tag_get_name(), moab::Core::tag_get_tags(), moab::Core::tag_get_tags_on_entity(), moab::Core::tag_get_type(), moab::ParallelComm::tag_iface_entities(), moab::MeshTag::tag_iterate(), moab::DenseTag::tag_iterate(), moab::SparseTag::tag_iterate(), moab::Core::tag_iterate(), moab::ScdInterface::tag_shared_vertices(), moab::ParallelComm::tag_shared_verts(), tag_storage_string(), tag_type_string(), moab::ParallelMergeMesh::TagSharedElements(), test_existinterface(), test_linear_reconstruction(), moab::Coupler::test_local_box(), test_spectral_hex(), test_spectral_quad(), moab::GeomQueryTool::test_volume_boundary(), TestErrorHandling_1(), TestErrorHandling_2(), TestErrorHandling_3(), TestErrorHandling_4(), TestErrorHandlingPar_1(), TestErrorHandlingPar_2(), TestMeshRefiner(), moab::ReadNASTRAN::tokenize_line(), moab::ReadSmf::trans(), moab::WriteCCMIO::transform_coords(), moab::ReadMCNP5::transform_point_to_cartesian(), moab::TreeStats::traverse(), moab::DualTool::traverse_hyperplane(), moab::TreeNodePrinter::TreeNodePrinter(), moab::SmoothCurve::u_from_position(), moab::ParallelComm::unpack_buffer(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::unpack_remote_handles(), moab::WriteHDF5Parallel::unpack_set(), moab::ParallelComm::unpack_sets(), moab::ParallelComm::unpack_tags(), moab::BSPTreeIter::up(), moab::BSPTreeBoxIter::up(), moab::BoundBox::update(), moab::ReadNCDF::update(), moab::ReadUtil::update_adjacencies(), moab::NestedRefine::update_ahf_1D(), moab::ReadHDF5::update_connectivity(), update_density(), moab::HalfFacetRep::update_entity_ranges(), moab::RangeSeqIntersectIter::update_entity_sequence(), moab::NestedRefine::update_global_ahf(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), moab::NestedRefine::update_local_ahf(), moab::GQT_IntRegCtxt::update_orient(), moab::OrientedBoxTreeTool::IntRegCtxt::update_orient(), moab::ParallelComm::update_remote_data(), moab::ParallelComm::update_remote_data_old(), moab::ReorderTool::update_set_contents(), moab::NestedRefine::update_special_tags(), moab::NCHelper::update_time_tag_vals(), moab::Intx2MeshOnSphere::update_tracer_data(), moab::NestedRefine::update_tracking_verts(), moab::ReadSmf::v_color(), moab::ReadSmf::v_normal(), moab::TagInfo::validate_lengths(), moab::range_tool< pair_iter_t >::vector_insert_entities(), moab::vector_insert_vector(), moab::vector_remove_range(), moab::vector_remove_ranges(), moab::vector_remove_vector(), moab::WriteHDF5::vector_to_id_list(), moab::ScdBox::vert_dat(), moab::ReadSmf::vertex(), moab::NestedRefine::vertex_to_entities_down(), moab::NestedRefine::vertex_to_entities_up(), TriStats::visit(), moab::RayIntersector::visit(), moab::RayIntersectSets::visit(), moab::TreeLayoutPrinter::visit(), moab::TreeNodePrinter::visit(), moab::BSPTreeIter::volume(), moab::ReadVtk::vtk_create_structured_elems(), moab::ReadVtk::vtk_read_field(), moab::ReadVtk::vtk_read_field_attrib(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_polygons(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), moab::ReadVtk::vtk_read_tag_data(), moab::ReadVtk::vtk_read_unstructured_grid(), moab::FBEngine::weave_lateral_face_from_edges(), moab::WriteHDF5::write_adjacencies(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteNCDF::write_BCs(), moab::WriteVtk::write_bit_tag(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteCGNS::write_coord_cgns(), moab::WriteCCMIO::write_dbl_option(), moab::WriteHDF5::write_dense_tag(), moab::WriteNCDF::write_element_order_map(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteHDF5::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteNCDF::write_exodus_integer_variable(), moab::WriteCCMIO::write_external_faces(), moab::WriteSmf::write_file(), moab::WriteVtk::write_file(), moab::WriteGmsh::write_file(), moab::WriteSTL::write_file(), moab::WriteGMV::write_file(), moab::WriteAns::write_file(), moab::WriteHDF5::write_file(), moab::WriteTemplate::write_file(), moab::WriteSLAC::write_file(), moab::WriteDamsel::write_file(), moab::WriteCCMIO::write_file(), moab::WriteCGNS::write_file(), moab::WriteNC::write_file(), moab::WriteNCDF::write_file(), moab::Core::write_file(), moab::WriteHDF5::write_file_impl(), moab::WriteHDF5::write_finished(), moab::WriteNCDF::write_global_element_order_map(), moab::WriteNCDF::write_global_node_order_map(), moab::WriteVtk::write_header(), moab::WriteNCDF::write_header(), moab::WriteCCMIO::write_int_option(), moab::WriteTemplate::write_matsets(), moab::WriteSLAC::write_matsets(), moab::WriteVtk::write_nodes(), moab::WriteTemplate::write_nodes(), moab::WriteSLAC::write_nodes(), moab::WriteCCMIO::write_nodes(), moab::WriteNCDF::write_nodes(), moab::WriteHDF5::write_nodes(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteCCMIO::write_problem_description(), moab::WriteCCMIO::write_processor(), moab::WriteHDF5::write_qa(), moab::WriteNCDF::write_qa_records(), moab::WriteNCDF::write_qa_string(), moab::WriteHDF5::write_set_data(), moab::NCWriteHelper::write_set_variables(), moab::WriteDamsel::write_sets(), moab::WriteHDF5::write_sets(), moab::WriteCCMIO::write_solution_data(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), moab::WriteCCMIO::write_str_option(), moab::WriteDamsel::write_subrange(), moab::WriteVtk::write_tag(), moab::WriteHDF5::write_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteVtk::write_tags(), DeformMeshRemap::write_to_coords(), moab::NCWriteHelper::write_values(), moab::WriteHDF5::write_var_len_data(), moab::WriteHDF5::write_var_len_indices(), moab::WriteHDF5::write_var_len_tag(), moab::WriteDamsel::write_vertices(), moab::TempestOnlineMap::WriteHDF5MapFile(), moab::TempestOnlineMap::WriteSCRIPMapFile(), moab::TempestRemapper::WriteTempestIntersectionMesh(), moab::HigherOrderFactory::zero_nodes(), moab::BSPTree::~BSPTree(), moab::OrientedBoxTreeTool::~OrientedBoxTreeTool(), and moab::Tqdcfr::~Tqdcfr().
MB_TAG_CREAT = 1 << 5
Create tag if it does not already exist
Examples:
addPCdata.cpp, DeformMeshRemap.cpp, DirectAccessNoHoles.cpp, DirectAccessWithHoles.cpp, ExtractLand.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, ReduceExchangeTags.cpp, TestErrorHandling.cpp, and VisTags.cpp.
Definition at line 77 of file Types.hpp.
Referenced by add_field_value(), moab::Coupler::apply_group_norm_factor(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ScdInterface::box_dims_tag(), moab::ScdInterface::box_periodic_tag(), moab::ScdInterface::box_set_tag(), moab::MeshGeneration::BrickInstance(), moab::ReadRTT::build_moab(), moab::GeomTopoTool::check_edge_sense_tags(), moab::GeomTopoTool::check_face_sense_tag(), moab::GeomTopoTool::check_geom_tag(), moab::GeomTopoTool::check_gid_tag(), moab::WriteHDF5Parallel::check_serial_tag_data(), moab::Skinner::classify_2d_boundary(), compute_lagrange_mesh_on_sphere(), moab::SmoothFace::compute_tangents_for_each_edge(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::HigherOrderFactory::convert_sequence(), moab::TempestRemapper::convert_tempest_mesh_private(), create_coarse_mesh(), moab::NCHelper::create_conventional_tags(), moab::NCHelper::create_dummy_variables(), moab::ReadIDEAS::create_elements(), create_fine_mesh(), moab::ReadUtil::create_gather_set(), moab::ReadCGM::create_group_entsets(), moab::ParallelComm::create_iface_pc_links(), create_lagr_mesh(), moab::ReadNASTRAN::create_materials(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::ReadParallel::create_partition_sets(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::ReadCGNS::create_sets(), moab::ReadGmsh::create_sets(), IntxUtilsCSLAM::create_span_quads(), moab::ReadHDF5::create_tag(), moab::ReadMCNP5::create_tags(), moab::Intx2Mesh::createTags(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::Intx2Mesh::DetermineOrderedNeighbors(), moab::Core::dirichletBC_tag(), do_test_mode(), moab::DualTool::DualTool(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::Skinner::find_geometric_skin(), moab::Skinner::find_inferred_edges(), moab::Skinner::find_skin_vertices(), moab::ParCommGraph::form_mesh_from_tuples(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::TempestRemapper::GenerateMeshMetadata(), moab::TempestOnlineMap::GenerateRemappingWeights(), moab::Core::geom_dimension_tag(), moab::GeomTopoTool::GeomTopoTool(), moab::Tree::get_box_tag(), moab::ReadCCMIO::get_dbl_option(), moab::Coupler::get_group_integ_vals(), get_imesh_mesh(), moab::ReadCCMIO::get_int_option(), moab::Tqdcfr::get_names(), moab::ParallelComm::get_pcomm(), moab::ReadCCMIO::get_str_option(), moab::AxisBox::get_tag(), moab::AffineXform::get_tag(), moab::ReadABAQUS::get_tag(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), moab::TempestRemapper::GetIMasks(), moab::FBEngine::getNumOfType(), moab::ScdInterface::global_box_dims_tag(), moab::Core::globalId_tag(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), iMeshP_createPartitionAll(), iMOAB_DefineTagStorage(), ZoltanPartitioner::include_closure(), moab::SmoothFace::init_gradient(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::BSPTree::init_tags(), moab::Skinner::initialize(), moab::LloydSmoother::initialize(), initialize_area_and_tracer(), McnpData::initialize_tags(), moab::FBEngine::initializeSmoothing(), moab::Tqdcfr::interpret_acis_records(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::ReadParallel::load_file(), moab::ReadNC::load_file(), moab::ReadSms::load_file_impl(), moab::ReadCCMIO::load_metadata(), main(), moab::AdaptiveKDTree::make_tag(), moab::Core::material_tag(), moab::Core::neumannBC_tag(), obbvis_create(), moab::ParallelComm::pack_sets(), moab::Tqdcfr::parse_acis_attribs(), moab::ReadTetGen::parse_attr_list(), parse_tag_create(), moab::ScdInterface::part_method_tag(), moab::ParallelComm::partition_tag(), moab::ParallelComm::pcomm_tag(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), process_partition_file(), moab::Tqdcfr::process_sideset_10(), moab::Tqdcfr::process_sideset_11(), moab::ReadDamsel::process_tags(), moab::ParallelComm::pstatus_tag(), moab::Tqdcfr::put_into_set(), moab::putElementField(), moab::putSpectralElementField(), moab::putVertexField(), quads_to_tris(), moab::Tqdcfr::read_block(), moab::ReadTetGen::read_elem_file(), moab::Tqdcfr::read_group(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::Tqdcfr::read_nodes(), moab::Tqdcfr::read_nodeset(), moab::Tqdcfr::read_sideset(), moab::ReadNCDF::read_sidesets(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), moab::ReadNCDF::ReadNCDF(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::ParCommGraph::receive_mesh(), moab::ParallelComm::resolve_shared_ents(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::FBEngine::separate(), moab::ParallelComm::set_partitioning(), moab::GeomTopoTool::setup_implicit_complement(), moab::ParallelComm::sharedh_tag(), moab::ParallelComm::sharedhs_tag(), moab::ParallelComm::sharedp_tag(), moab::ParallelComm::sharedps_tag(), moab::SharedSetData::SharedSetData(), moab::SpectralMeshTool::spectral_order_tag(), moab::SpectralMeshTool::spectral_vertices_tag(), moab::ReadHDF5::store_sets_file_ids(), moab::Core::tag_get_handle(), moab::OrientedBox::tag_handle(), TestErrorHandling_4(), moab::Tqdcfr::Tqdcfr(), moab::DualTool::traverse_hyperplane(), moab::ParallelComm::unpack_sets(), moab::ParallelComm::unpack_tags(), update_tracer(), update_tracer_test(), moab::ReadVtk::vtk_read_tag_data(), MetisPartitioner::write_aggregationtag_partition(), DeformMeshRemap::write_and_save(), moab::WriteCCMIO::write_cells_and_faces(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteAns::WriteAns(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteDamsel::WriteDamsel(), moab::WriteGMV::WriteGMV(), moab::TempestOnlineMap::WriteHDF5MapFile(), moab::WriteNCDF::WriteNCDF(), moab::WriteSLAC::WriteSLAC(), and moab::WriteTemplate::WriteTemplate().
MB_TAG_DENSE = 1 << 1
Storage optimized for tags on most entities of a type
Examples:
Definition at line 73 of file Types.hpp.
Referenced by add_field_value(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::MeshGeneration::BrickInstance(), SphereDecomp::build_sphere_mesh(), moab::GeomTopoTool::check_geom_tag(), moab::GeomTopoTool::check_gid_tag(), moab::Skinner::classify_2d_boundary(), compute_lagrange_mesh_on_sphere(), moab::SmoothFace::compute_tangents_for_each_edge(), compute_tracer_case1(), moab::TempestRemapper::convert_tempest_mesh_private(), moab::ReadIDEAS::create_elements(), create_fine_mesh(), moab::ParallelComm::create_iface_pc_links(), create_lagr_mesh(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), IntxUtilsCSLAM::create_span_quads(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::WriteHDF5Parallel::create_tag_tables(), moab::ReadMCNP5::create_tags(), moab::Intx2Mesh::createTags(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::Intx2Mesh::DetermineOrderedNeighbors(), moab::DualTool::DualTool(), moab::IntxUtils::enforce_convexity(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParCommGraph::form_mesh_from_tuples(), moab::WriteSLAC::gather_interior_exterior(), moab::TempestRemapper::GenerateMeshMetadata(), moab::TempestOnlineMap::GenerateRemappingWeights(), get_departure_grid(), get_imesh_mesh(), get_intersection_weights(), moab::DenseTag::get_storage_type(), moab::VarLenDenseTag::get_storage_type(), moab::AxisBox::get_tag(), moab::AffineXform::get_tag(), moab::NCHelper::get_tag_to_nonset(), moab::TempestRemapper::GetIMasks(), moab::Core::globalId_tag(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), iMesh_createTagWithOptions(), iMOAB_DefineTagStorage(), moab::AdaptiveKDTree::init(), moab::SmoothFace::init_gradient(), moab::WriteDamsel::init_tag_info(), moab::BSPTree::init_tags(), moab::Skinner::initialize(), moab::LloydSmoother::initialize(), initialize_area_and_tracer(), McnpData::initialize_tags(), moab::FBEngine::initializeSmoothing(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::Core::list_entity(), moab::ReadParallel::load_file(), moab::ReadSms::load_file_impl(), main(), moab::WriteDamsel::map_dense_tags(), moab::MergeMesh::merge_all(), moab::MergeMesh::merge_entities(), moab::MergeMesh::merge_using_integer_tag(), obbvis_create(), moab::ReadTetGen::parse_attr_list(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::ReadDamsel::process_tags(), moab::ParallelComm::pstatus_tag(), moab::putElementField(), moab::putSpectralElementField(), moab::putVertexField(), quads_to_tris(), moab::ReadABAQUS::ReadABAQUS(), smoab::DataSetConverter::readDenseTags(), moab::ParCommGraph::receive_mesh(), moab::ParallelComm::resolve_shared_ents(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::FBEngine::separate(), moab::WriteHDF5::serial_create_file(), moab::ParallelComm::sharedh_tag(), moab::ParallelComm::sharedp_tag(), moab::SpectralMeshTool::spectral_order_tag(), moab::SpectralMeshTool::spectral_vertices_tag(), moab::ReadHDF5::store_sets_file_ids(), moab::Core::tag_get_handle(), moab::OrientedBox::tag_handle(), tag_storage_string(), TestErrorHandling_4(), update_density(), update_tracer(), moab::Intx2MeshOnSphere::update_tracer_data(), update_tracer_test(), moab::ReadVtk::vtk_read_tag_data(), DeformMeshRemap::write_and_save(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteDamsel::WriteDamsel(), and moab::WriteSLAC::WriteSLAC().
MB_TAG_MESH = 1 << 2
Storage for tags on no entities, only the root set/whole mesh.
Definition at line 74 of file Types.hpp.
Referenced by moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::MeshTag::get_storage_type(), iMesh_createTagWithOptions(), moab::AdaptiveKDTree::init(), and moab::Core::tag_get_handle().
MB_TAG_NOOPQ = 1 << 9
Do not accept MB_TYPE_OPAQUE as a match for any type.
Definition at line 81 of file Types.hpp.
Referenced by moab::Core::tag_get_handle().
Definition at line 45 of file Types.hpp.
Referenced by moab::ParallelComm::add_pcomm(), moab::ScdInterface::box_dims_tag(), moab::ScdInterface::box_periodic_tag(), moab::ScdInterface::box_set_tag(), moab::ParallelComm::check_sent_ents(), moab::ParallelComm::clean_shared_tags(), moab::MeshTag::clear_data(), moab::DualTool::construct_dual_hyperplanes(), moab::ReadABAQUS::create_instance_of_part(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::Core::delete_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::FBEngine::delete_smooth_tags(), moab::DualTool::delete_whole_dual(), moab::IntxUtils::enforce_convexity(), error_code_test(), moab::ParallelComm::exchange_tags(), moab::ReadHDF5::find_int_tag(), moab::WriteCCMIO::gather_neuset_info(), moab::ParallelComm::get_all_pcomm(), moab::MeshTag::get_data(), moab::SparseTag::get_data(), moab::VarLenSparseTag::get_data_ptr(), moab::DualTool::get_dual_entity(), moab::DualTool::get_dual_hyperplane(), moab::Core::get_entities_by_type_and_tag(), moab::DualTool::get_extra_dual_entity(), get_group_names(), moab::Tqdcfr::get_mesh_entities(), moab::ParallelData::get_partition_sets(), moab::ParallelComm::get_pcomm(), moab::GeomTopoTool::get_sense(), moab::ReadABAQUS::get_set_by_name(), moab::WriteUtil::get_tag_list(), moab::WriteHDF5::get_tag_size(), moab::ScdInterface::global_box_dims_tag(), iMesh_destroyTag(), iMesh_getArrData(), iMesh_rmvArrTag(), iMesh_rmvEntSetTag(), moab::ReadParallel::load_file(), moab::Remapper::LoadNativeMesh(), main(), moab::not_found(), moab::not_root_set(), moab::ParallelComm::pack_sets(), moab::Tqdcfr::parse_acis_attribs(), parse_tag_spec(), moab::ScdInterface::part_method_tag(), moab::WriteNC::process_conventional_tags(), moab::ReadNCDF::read_tag_values(), moab::ParallelComm::reduce_tags(), moab::SequenceManager::release_tag_array(), moab::MeshTag::remove_data(), moab::VarLenSparseTag::remove_data(), moab::SparseTag::remove_data(), moab::GeomTopoTool::restore_obb_index(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::MeshTag::set_data(), moab::GeomTopoTool::set_sense(), moab::TempestOnlineMap::SetDOFmapTags(), moab::Core::tag_delete(), moab::Core::tag_get_bytes(), moab::Core::tag_get_data_type(), moab::Core::tag_get_default_value(), moab::Core::tag_get_handle(), moab::Core::tag_get_length(), moab::Core::tag_get_name(), moab::WriteCCMIO::transform_coords(), moab::Intx2MeshOnSphere::update_tracer_data(), moab::WriteTemplate::write_nodes(), moab::WriteSLAC::write_nodes(), and moab::WriteNCDF::write_nodes().
MB_TAG_SPARSE = 1 << 0
Storage optimized for tags on a few entities
Definition at line 72 of file Types.hpp.
Referenced by moab::Coupler::apply_group_norm_factor(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ScdInterface::box_dims_tag(), moab::ScdInterface::box_periodic_tag(), moab::ScdInterface::box_set_tag(), moab::MeshGeneration::BrickInstance(), moab::ReadRTT::build_moab(), moab::GeomTopoTool::check_edge_sense_tags(), moab::GeomTopoTool::check_face_sense_tag(), moab::Tqdcfr::convert_nodesets_sidesets(), create_coarse_mesh(), moab::NCHelper::create_conventional_tags(), moab::NCHelper::create_dummy_variables(), create_fine_mesh(), moab::ReadUtil::create_gather_set(), moab::ReadCGM::create_group_entsets(), moab::ReadNASTRAN::create_materials(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::ReadParallel::create_partition_sets(), moab::ReadCGNS::create_sets(), moab::ReadGmsh::create_sets(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::ReadMCNP5::create_tags(), moab::FBEngine::createTag(), moab::Core::dirichletBC_tag(), do_test_mode(), moab::DualTool::DualTool(), moab::Skinner::find_geometric_skin(), moab::Core::geom_dimension_tag(), moab::GeomTopoTool::GeomTopoTool(), moab::Tree::get_box_tag(), moab::ReadCCMIO::get_dbl_option(), moab::ReadUtil::get_gather_set(), moab::Coupler::get_group_integ_vals(), moab::ReadCCMIO::get_int_option(), moab::Tqdcfr::get_names(), moab::ParallelComm::get_pcomm(), moab::VarLenSparseTag::get_storage_type(), moab::SparseTag::get_storage_type(), moab::ReadCCMIO::get_str_option(), moab::NCHelper::get_tag_to_set(), moab::FBEngine::getNumOfType(), moab::ScdInterface::global_box_dims_tag(), iMesh_createTagWithOptions(), iMeshP_createPartitionAll(), iMOAB_DefineTagStorage(), ZoltanPartitioner::include_closure(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::WriteDamsel::init_tag_info(), moab::BSPTree::init_tags(), moab::Tqdcfr::interpret_acis_records(), moab::ReadParallel::load_file(), moab::ReadNC::load_file(), moab::ReadSms::load_file_impl(), moab::ReadCCMIO::load_metadata(), main(), moab::WriteDamsel::map_sparse_tags(), moab::Core::material_tag(), moab::Core::neumannBC_tag(), moab::ParallelComm::pack_sets(), moab::Tqdcfr::parse_acis_attribs(), parse_tag_create(), moab::ScdInterface::part_method_tag(), moab::ParallelComm::partition_tag(), moab::ParallelComm::pcomm_tag(), moab::Core::print(), moab::Core::print_entity_tags(), moab::WriteNC::process_conventional_tags(), process_partition_file(), moab::Tqdcfr::process_sideset_10(), moab::Tqdcfr::process_sideset_11(), moab::Tqdcfr::put_into_set(), moab::Tqdcfr::read_block(), moab::ReadTetGen::read_elem_file(), moab::Tqdcfr::read_group(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::Tqdcfr::read_nodes(), moab::Tqdcfr::read_nodeset(), moab::Tqdcfr::read_sideset(), moab::ReadNCDF::read_sidesets(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), moab::ReadNCDF::ReadNCDF(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::ParallelComm::set_partitioning(), moab::GeomTopoTool::setup_implicit_complement(), moab::ParallelComm::sharedhs_tag(), moab::ParallelComm::sharedps_tag(), moab::SharedSetData::SharedSetData(), moab::Core::tag_get_handle(), tag_storage_string(), moab::Tqdcfr::Tqdcfr(), moab::ParallelComm::unpack_sets(), MetisPartitioner::write_aggregationtag_partition(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteAns::WriteAns(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteGMV::WriteGMV(), moab::TempestOnlineMap::WriteHDF5MapFile(), moab::WriteNCDF::WriteNCDF(), moab::WriteSLAC::WriteSLAC(), and moab::WriteTemplate::WriteTemplate().
MB_TAG_STORE = 1 << 7
Fail if tag exists and has different storage type
Definition at line 79 of file Types.hpp.
native 'double' type
Examples:
addPCdata.cpp, DeformMeshRemap.cpp, DirectAccessNoHoles.cpp, DirectAccessWithHoles.cpp, ExtractLand.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, ReduceExchangeTags.cpp, and VisTags.cpp.
Definition at line 91 of file Types.hpp.
Referenced by add_field_value(), moab::Coupler::apply_group_norm_factor(), SphereDecomp::build_sphere_mesh(), moab::SmoothCurve::compute_control_points_on_boundary_edges(), compute_lagrange_mesh_on_sphere(), moab::SmoothFace::compute_tangents_for_each_edge(), moab::SmoothCurve::compute_tangents_for_each_edge(), moab::NCHelperDomain::create_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), IntxUtilsCSLAM::create_span_quads(), moab::ReadHDF5::create_tag(), moab::ReadMCNP5::create_tags(), moab::Coupler::create_tuples(), moab::FBEngine::createTag(), moab::serial_tag_data::def_val_bytes(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::FBEngine::delete_smooth_tags(), do_test_mode(), moab::DualTool::DualTool(), moab::SmoothCurve::evaluate_smooth_edge(), moab::find_map_values_equal(), moab::find_map_varlen_values_equal(), moab::find_tag_values_equal(), moab::find_tag_varlen_values_equal(), moab::TempestOnlineMap::GenerateRemappingWeights(), moab::Tree::get_box_tag(), moab::ReadCCMIO::get_dbl_option(), moab::Coupler::get_group_integ_vals(), get_imesh_mesh(), moab::Coupler::get_matching_entities(), moab::AxisBox::get_tag(), moab::AffineXform::get_tag(), moab::WriteHDF5::get_tag_size(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), iMOAB_DefineTagStorage(), iMOAB_GetDoubleTagStorage(), iMOAB_SetDoubleTagStorage(), iMOAB_SetDoubleTagStorageWithGid(), moab::AdaptiveKDTree::init(), moab::SmoothFace::init_gradient(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::WriteDamsel::init_tag_info(), moab::BSPTree::init_tags(), initialize_area_and_tracer(), moab::Coupler::initialize_spectral_elements(), McnpData::initialize_tags(), moab::FBEngine::initializeSmoothing(), moab::Coupler::interpolate(), moab::ReadSms::load_file_impl(), main(), moab::Coupler::normalize_subset(), moab::SimplexTemplateTagAssigner::operator()(), moab::ReadTetGen::parse_attr_list(), parse_tag_create(), parse_values(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::ParallelComm::print_buffer(), moab::Core::print_entity_tags(), moab::putElementField(), moab::putSpectralElementField(), moab::putVertexField(), moab::Tqdcfr::read_block(), moab::Tqdcfr::read_sideset(), moab::ReadCGM::ReadCGM(), smoab::DataSetConverter::readDenseTags(), moab::ReadNCDF::ReadNCDF(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::reduce_void(), moab::ReorderTool::reorder_tag_data(), moab::OrientedBox::tag_handle(), tag_type_string(), test_spectral_hex(), moab::WriteCCMIO::transform_coords(), moab::SmoothCurve::u_from_position(), moab::NCHelper::update_time_tag_vals(), update_tracer(), update_tracer_test(), moab::ReadVtk::vtk_read_tag_data(), DeformMeshRemap::write_and_save(), moab::WriteCCMIO::write_dbl_option(), moab::WriteTemplate::write_nodes(), moab::WriteSLAC::write_nodes(), moab::WriteNCDF::write_nodes(), moab::WriteVtk::write_tag(), moab::WriteDamsel::WriteDamsel(), moab::TempestOnlineMap::WriteHDF5MapFile(), and moab::WriteNCDF::WriteNCDF().
EntityHandle
Definition at line 93 of file Types.hpp.
Referenced by SphereDecomp::build_sphere_mesh(), moab::GeomTopoTool::check_edge_sense_tags(), moab::GeomTopoTool::check_face_sense_tag(), check_handle_tag_type(), compute_tracer_case1(), create_fine_mesh(), moab::ParallelComm::create_iface_pc_links(), create_lagr_mesh(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::FBEngine::createTag(), moab::Intx2Mesh::createTags(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::serial_tag_data::def_val_bytes(), moab::Intx2Mesh::DetermineOrderedNeighbors(), moab::DualTool::DualTool(), moab::IntxUtils::enforce_convexity(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::find_map_values_equal(), moab::find_map_varlen_values_equal(), moab::find_tag_values_equal(), moab::find_tag_varlen_values_equal(), moab::GeomTopoTool::GeomTopoTool(), get_departure_grid(), moab::DualTool::get_dual_hyperplanes(), moab::WriteHDF5::get_tag_size(), moab::ReorderTool::handle_order_from_int_tag(), iMesh_getTagType(), iMOAB_DefineTagStorage(), moab::Intx2Mesh::intersect_meshes_kdtree(), main(), moab::MergeMesh::merge_all(), moab::MergeMesh::merge_entities(), moab::MergeMesh::merge_using_integer_tag(), parse_tag_create(), parse_values(), moab::ParallelComm::print_buffer(), moab::Core::print_entity_tags(), moab::ReadHDF5::read_dense_tag(), moab::ReadHDF5::read_sparse_tag(), moab::ReadHDF5::read_var_len_tag(), moab::ReadABAQUS::ReadABAQUS(), moab::ReorderTool::reorder_entities(), moab::ReorderTool::reorder_tag_data(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::ParallelComm::sharedh_tag(), moab::ParallelComm::sharedhs_tag(), moab::SpectralMeshTool::spectral_vertices_tag(), tag_type_string(), moab::ParallelComm::unpack_tags(), update_density(), moab::Intx2MeshOnSphere::update_tracer_data(), moab::WriteVtk::write_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteVtk::write_tags(), and moab::WriteHDF5::write_var_len_tag().
native 'int' type
Examples:
addPCdata.cpp, DirectAccessNoHoles.cpp, DirectAccessWithHoles.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, ReduceExchangeTags.cpp, SetsNTags.cpp, TestErrorHandling.cpp, and TestExodusII.cpp.
Definition at line 90 of file Types.hpp.
Referenced by moab::GeomTopoTool::add_geo_set(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::DualTool::atomic_pillow(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::ScdInterface::box_dims_tag(), moab::ScdInterface::box_periodic_tag(), moab::MeshGeneration::BrickInstance(), moab::ReadRTT::build_moab(), moab::GeomTopoTool::check_edge_sense_tags(), moab::NCHelperMPAS::check_existing_mesh(), moab::GeomTopoTool::check_geom_tag(), moab::GeomTopoTool::check_gid_tag(), moab::check_int_tag(), moab::Skinner::classify_2d_boundary(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteHelper::collect_variable_data(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::TempestRemapper::convert_tempest_mesh_private(), create_coarse_mesh(), moab::NCHelper::create_conventional_tags(), moab::NCHelper::create_dummy_variables(), moab::ReadIDEAS::create_elements(), create_fine_mesh(), moab::ReadUtil::create_gather_set(), moab::ReadNASTRAN::create_materials(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::ReadParallel::create_partition_sets(), moab::ReadCGNS::create_sets(), moab::ReadGmsh::create_sets(), IntxUtilsCSLAM::create_span_quads(), moab::ReadHDF5::create_tag(), moab::ReadMCNP5::create_tags(), moab::FBEngine::create_volume_with_direction(), moab::FBEngine::createTag(), moab::Intx2Mesh::createTags(), smoab::Tag::dataType(), moab::serial_tag_data::def_val_bytes(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::dimension(), moab::Core::dirichletBC_tag(), do_test_mode(), moab::DualTool::DualTool(), moab::GeomTopoTool::duplicate_model(), moab::IntxUtils::enforce_convexity(), FBiGeom_getEntSets(), FBiGeom_getNumEntSets(), moab::Skinner::find_geometric_skin(), moab::GeomTopoTool::find_geomsets(), moab::find_map_values_equal(), moab::find_map_varlen_values_equal(), moab::find_tag_values_equal(), moab::find_tag_varlen_values_equal(), moab::FBEngine::find_vertex_set_for_node(), moab::ParCommGraph::form_mesh_from_tuples(), moab::WriteSLAC::gather_interior_exterior(), moab::TempestRemapper::GenerateMeshMetadata(), moab::Core::geom_dimension_tag(), moab::GeomTopoTool::GeomTopoTool(), moab::ReadUtil::get_gather_set(), get_imesh_mesh(), moab::ReadCCMIO::get_int_option(), moab::ParallelData::get_interface_sets(), get_intersection_weights(), moab::WriteTemplate::get_neuset_elems(), moab::WriteSLAC::get_neuset_elems(), moab::WriteCCMIO::get_neuset_elems(), moab::ParallelData::get_partition_sets(), moab::ParallelComm::get_pcomm(), moab::WriteNCDF::get_sideset_elems(), moab::WriteHDF5::get_tag_size(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), moab::TempestRemapper::GetIMasks(), moab::FBEngine::getNumOfType(), moab::ScdInterface::global_box_dims_tag(), moab::Core::globalId_tag(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), iMeshP_createPartitionAll(), iMOAB_DefineTagStorage(), iMOAB_GetIntTagStorage(), iMOAB_Initialize(), iMOAB_SetIntTagStorage(), ZoltanPartitioner::include_closure(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::WriteDamsel::init_tag_info(), moab::Coupler::initialize_spectral_elements(), moab::FBEngine::initializeSmoothing(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::ReadParallel::load_file(), moab::ReadNC::load_file(), moab::ReadSms::load_file_impl(), main(), moab::Core::material_tag(), moab::MergeMesh::merge_using_integer_tag(), moab::Core::neumannBC_tag(), obbvis_create(), moab::ParallelComm::pack_sets(), parse_tag_create(), parse_values(), moab::ScdInterface::part_method_tag(), moab::ParallelComm::partition_tag(), moab::ParallelComm::print_buffer(), moab::Core::print_entity_tags(), moab::WriteHDF5Parallel::print_shared_sets(), moab::print_type_sets(), moab::WriteNC::process_conventional_tags(), process_partition_file(), moab::Tqdcfr::process_sideset_10(), moab::Tqdcfr::process_sideset_11(), quads_to_tris(), moab::ReadTetGen::read_elem_file(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::read_nodes(), moab::ReadNCDF::read_sidesets(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), smoab::DataSetConverter::readDenseTags(), moab::ReadNCDF::ReadNCDF(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::ParCommGraph::receive_mesh(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::reduce_void(), moab::ReorderTool::reorder_tag_data(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), run_local_smoother(), moab::FBEngine::separate(), moab::FBEngine::set_default_neumann_tags(), moab::FBEngine::set_neumann_tags(), moab::ParallelComm::set_partitioning(), moab::TempestOnlineMap::SetDOFmapTags(), moab::ParallelComm::sharedp_tag(), moab::ParallelComm::sharedps_tag(), moab::SpectralMeshTool::spectral_order_tag(), tag_type_string(), test_spectral_hex(), TestErrorHandling_4(), moab::Tqdcfr::Tqdcfr(), moab::TreeNodePrinter::TreeNodePrinter(), moab::ParallelComm::unpack_sets(), update_density(), moab::NestedRefine::update_special_tags(), moab::ReadVtk::vtk_read_tag_data(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteGmsh::write_file(), moab::WriteCCMIO::write_int_option(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteVtk::write_tag(), moab::WriteAns::WriteAns(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteDamsel::WriteDamsel(), moab::WriteGMV::WriteGMV(), moab::TempestOnlineMap::WriteHDF5MapFile(), moab::WriteNCDF::WriteNCDF(), moab::WriteSLAC::WriteSLAC(), and moab::WriteTemplate::WriteTemplate().
byte array
Definition at line 89 of file Types.hpp.
Referenced by moab::ScdInterface::box_set_tag(), moab::MeshGeneration::BrickInstance(), moab::check_int_tag(), moab::NCHelper::create_conventional_tags(), moab::ReadCGM::create_group_entsets(), moab::ReadHDF5::create_tag(), moab::ReadMCNP5::create_tags(), moab::FBEngine::createTag(), moab::serial_tag_data::def_val_bytes(), moab::DualTool::DualTool(), moab::ParallelComm::exchange_tags(), moab::GeomTopoTool::GeomTopoTool(), moab::Tqdcfr::get_names(), moab::ReadCCMIO::get_str_option(), moab::WriteHDF5::get_tag_size(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), iMesh_getTagHandle(), moab::AdaptiveKDTree::init(), moab::Skinner::initialize(), moab::LloydSmoother::initialize(), moab::Tqdcfr::interpret_acis_records(), moab::ReadParallel::load_file(), moab::ReadCCMIO::load_metadata(), main(), smoab::Interface::name(), moab::ParallelComm::pack_tag(), moab::Tqdcfr::parse_acis_attribs(), parse_tag_create(), parse_tag_spec(), parse_values(), moab::ParallelComm::pcomm_tag(), moab::ParallelComm::print_buffer(), moab::Core::print_entity_tags(), moab::WriteNC::process_conventional_tags(), moab::ReadDamsel::process_tags(), moab::ParallelComm::pstatus_tag(), moab::Tqdcfr::put_into_set(), moab::Tqdcfr::read_group(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::Tqdcfr::read_nodeset(), moab::Tqdcfr::read_sideset(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), moab::ReadNCDF::ReadNCDF(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::ParallelComm::reduce_tags(), moab::ReorderTool::reorder_tag_data(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::setup_implicit_complement(), moab::SharedSetData::SharedSetData(), moab::ReadHDF5::store_sets_file_ids(), moab::Core::tag_get_handle(), tag_type_string(), moab::Tqdcfr::Tqdcfr(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteCCMIO::write_problem_description(), moab::WriteCCMIO::write_str_option(), moab::WriteVtk::write_tag(), moab::WriteCCMIO::WriteCCMIO(), and moab::WriteNCDF::WriteNCDF().
Examples:
ErrorHandlingSimulation.cpp.
Definition at line 41 of file Types.hpp.
Referenced by moab::Core::adjacencies_iterate(), moab::OrientedBoxTreeTool::build(), check_handle_tag_type(), moab::check_int_tag(), moab::check_tag_type(), moab::Core::connect_iterate(), moab::HigherOrderFactory::convert(), moab::HigherOrderFactory::convert_sequence(), moab::SequenceManager::create_element(), moab::SequenceManager::create_entity_sequence(), moab::SequenceManager::create_scd_sequence(), moab::ScdInterface::create_scd_sequence(), moab::SequenceManager::create_sweep_sequence(), error_code_test(), moab::DualTool::face_open_collapse(), moab::DualTool::face_shrink(), moab::Skinner::find_skin_vertices(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::DualTool::foc_get_ents(), FunctionC(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::Core::get_connectivity(), moab::Core::get_coords(), moab::BitTag::get_data(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::AEntityFactory::get_elements(), moab::WriteUtil::get_entity_list_pointers(), moab::FileOptions::get_int_option(), moab::FileOptions::get_ints_option(), moab::FileOptions::get_null_option(), moab::Core::get_number_entities_by_type(), moab::FileOptions::get_real_option(), moab::FileOptions::get_reals_option(), moab::FileOptions::get_str_option(), moab::FileOptions::get_strs_option(), moab::WriteUtil::get_tag_list(), moab::FileOptions::get_toggle_option(), moab::FBEngine::getEntClosestPt(), moab::ReorderTool::handle_order_from_sets_and_adj(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::OrientedBoxTreeTool::join_trees(), moab::ReadParallel::load_file(), moab::ReadTetGen::load_file(), moab::Core::merge_entities(), moab::ParallelComm::pack_tag(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), moab::ReadHDF5::read_elems(), moab::ParallelComm::reduce(), moab::ReorderTool::reorder_tag_data(), moab::DualTool::rev_face_shrink(), moab::Core::set_connectivity(), moab::Core::set_coords(), moab::BitTag::set_data(), moab::ReadHDF5::set_up_read(), moab::Core::tag_get_handle(), moab::BitTag::tag_iterate(), moab::ReadNCDF::update(), moab::RangeSeqIntersectIter::update_entity_sequence(), moab::WriteSTL::write_file(), and moab::Core::write_file().
MESHSET_SET = 0x2
set contents are unique
Examples:
ComputeTriDual.cpp, DeformMeshRemap.cpp, ExtractLand.cpp, GenLargeMesh.cpp, LaplacianSmoother.cpp, ReadPartFile.cpp, ReadWriteTest.cpp, and ReduceExchangeTags.cpp.
Definition at line 119 of file Types.hpp.
Referenced by moab::ReadABAQUS::add_entity_set(), MetisPartitioner::assemble_taggedents_graph(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::MeshGeneration::BrickInstance(), moab::ReadRTT::build_moab(), SphereDecomp::build_sphere_mesh(), moab::ParallelComm::check_clean_iface(), moab::DualTool::construct_new_hyperplane(), moab::TempestRemapper::ConstructCoveringSet(), moab::ScdInterface::create_box_set(), moab::ReadIDEAS::create_elements(), moab::ReadCGM::create_entity_sets(), moab::ReadUtil::create_gather_set(), moab::ReadRTT::create_group(), moab::ReadCGM::create_group_entsets(), moab::NestedRefine::create_hm_storage_single_level(), moab::ParallelComm::create_interface_sets(), moab::ReadNASTRAN::create_materials(), create_mesh(), moab::FBEngine::create_new_gedge(), moab::ReadOBJ::create_new_group(), moab::ReadOBJ::create_new_object(), moab::ParallelComm::create_part(), moab::Core::create_set_iterator(), moab::ReadCGNS::create_sets(), moab::ReadGmsh::create_sets(), moab::ReadTemplate::create_sets(), IntxUtilsCSLAM::create_span_quads(), moab::FBEngine::create_volume_with_direction(), moab::FBEngine::createEntSet(), moab::GeomTopoTool::duplicate_model(), moab::ParallelComm::estimate_sets_buffer_size(), DeformMeshRemap::execute(), moab::GeomTopoTool::generate_implicit_complement(), moab::ReadRTT::generate_topology(), moab::GeomTopoTool::geometrize_surface_set(), moab::Core::get_meshset_options(), moab::ReadSms::get_set(), moab::IntxUtils::global_gnomonic_projection(), iMesh_createEntSet(), iMesh_intersect(), iMesh_subtract(), iMesh_unite(), iMeshP_createPartitionAll(), iMeshP_loadAll(), iMOAB_CreateElements(), iMOAB_RegisterApplication(), moab::TempestRemapper::initialize(), moab::ReadParallel::load_file(), moab::ReadNC::load_file(), moab::ReadOBJ::load_file(), moab::ReadABAQUS::load_file(), moab::ReadMCNP5::load_one_file(), main(), manufacture_lagrange_mesh_on_sphere(), ZoltanPartitioner::partition_inferred_mesh(), process_partition_file(), moab::ReadTetGen::read_elem_file(), moab::ReadNCDF::read_elements(), moab::ReadCCMIO::read_faces(), moab::ReadCCMIO::read_gids_and_types(), moab::ReadNCDF::read_sidesets(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), moab::FBEngine::separate(), moab::MeshSet::set(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_edge_at_mesh_node(), moab::FBEngine::split_surface(), summarize_cell_volume_change(), test_intx_in_parallel_elem_based(), TestMeshRefiner(), update_tracer(), moab::FBEngine::weave_lateral_face_from_edges(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteNCDF::write_file(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), and moab::WriteDamsel::write_sets().
both senses valid
Definition at line 127 of file Types.hpp.
Referenced by moab::GeomTopoTool::set_sense().
default, invalid, not defined
Definition at line 125 of file Types.hpp.
Misc. integer constants, declared in enum for portability
Definition at line 123 of file Types.hpp.
    SENSE_INVALID = -2, /**< default, invalid, not defined */
    SENSE_REVERSE = -1, /**< reversed */
    SENSE_BOTH    = 0,  /**< both senses valid  */
    SENSE_FORWARD = 1   /**< forward  */
Specify storage type for tags. See MOAB users guide for more information.
Definition at line 69 of file Types.hpp.
Referenced by moab::RefinerTagManager::add_element_tag(), moab::RefinerTagManager::add_vertex_tag(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ReadHDF5::create_tag(), moab::WriteHDF5::create_tag(), moab::RefinerTagManager::create_tag_internal(), moab::WriteHDF5Parallel::create_tag_tables(), moab::FBEngine::createTag(), iMesh_createTagWithOptions(), iMOAB_DefineTagStorage(), moab::ParallelComm::pack_tag(), moab::Core::print_entity_tags(), smoab::DataSetConverter::readDenseTags(), moab::WriteHDF5::serial_create_file(), moab::Core::tag_get_handle(), and tag_storage_string().
    MB_TAG_BIT    = 0,      /**< Tag size specified in bits, tag value is 8 bits or less */
    MB_TAG_SPARSE = 1 << 0, /**< Storage optimized for tags on a few entities */
    MB_TAG_DENSE  = 1 << 1, /**< Storage optimized for tags on most entities of a type */
    MB_TAG_MESH   = 1 << 2, /**< Storage for tags on no entities, only the root set/whole mesh. */
    MB_TAG_BYTES  = 1 << 3, /**< Size is in number of bytes rather than number of values of \c DataType */
    MB_TAG_VARLEN = 1 << 4, /**< Create variable-length tag */
    MB_TAG_CREAT  = 1 << 5, /**< Create tag if it does not already exist */
    MB_TAG_EXCL   = 1 << 6, /**< Fail if TAG_CREATE and tag already exists */
    MB_TAG_STORE  = 1 << 7, /**< Fail if tag exists and has different storage type */
    MB_TAG_ANY    = 1 << 8, /**< Do not fail if size, type, or default value do not match. */
    MB_TAG_NOOPQ  = 1 << 9, /**< Do not accept MB_TYPE_OPAQUE as a match for any type. */
    MB_TAG_DFTOK  = 1 << 10 /**< Do not fail for mismatched default values */
    /**<  MB_TAG_CNVRT = 1<<11,  Convert storage type if it does not match */
