UsageTable.h
00001 #ifndef __smoab_detail_UsageTable_h
00002 #define __smoab_detail_UsageTable_h
00003
00004 #include <set>
00005 #include <vector>
00006
00007 namespace smoab
00008 {
00009 namespace detail
00010 {
00011
00012     namespace internal
00013     {
00014
00015         struct KeyType
00016         {
00017             moab::EntityHandle Handle;
00018             int ParentId;
00019
00020             KeyType( const moab::EntityHandle& h, int p ) : Handle( h ), ParentId( p ) {}
00021
00022             bool operator<( const KeyType& other ) const
00023             {
00024                 return ( ( this->Handle < other.Handle ) ||
00025                          ( ( this->Handle < other.Handle ) && ( this->ParentId < other.ParentId ) ) );
00026             }
00027         };
00028
00029         class key_inserter
00030         {
00031
00032           protected:
00033             Range* container;
00034
00035           public:
00036             //constructor
00037             explicit key_inserter( Range& x ) : container( &x ) {}
00038             key_inserter& operator=( const KeyType& value )
00039             {
00040                 container->insert( value.Handle );
00041                 return *this;
00042             }
00043
00044             key_inserter& operator*()
00045             {
00046                 return *this;
00047             }
00048             key_inserter& operator++()
00049             {
00050                 return *this;
00051             }
00052             key_inserter& operator++( int )
00053             {
00054                 return *this;
00055             }
00056
00057             typedef moab::EntityHandle value_type;
00058             typedef moab::EntityID difference_type;
00059             typedef std::output_iterator_tag iterator_category;
00060             typedef moab::EntityHandle* pointer;
00061             typedef moab::EntityHandle& reference;
00062         };
00063
00064     }  // namespace internal
00065
00066     //will store a collection of entities that are used only once with a given
00067     //owner id
00068     class UsageTable
00069     {
00070       public:
00071         void incrementUsage( const std::vector< smoab::EntityHandle >& entities, const std::vector< int >& usageId );
00072
00073         smoab::Range multipleUsage() const;
00074         smoab::Range singleUsage() const;
00075
00076       private:
00077         std::vector< smoab::EntityHandle > MultipleUsageIds;
00078         std::set< internal::KeyType > SingleUsageIds;
00079     };
00080
00081     //----------------------------------------------------------------------------
00082     void UsageTable::incrementUsage( const std::vector< smoab::EntityHandle >& entities,
00083                                      const std::vector< int >& usageId )
00084     {
00085         typedef std::vector< smoab::EntityHandle >::const_iterator iterator;
00086         typedef std::vector< int >::const_iterator uiterator;
00087
00088         uiterator usage = usageId.begin();
00089         for( iterator i = entities.begin(); i != entities.end(); ++i, ++usage )
00090         {
00091             internal::KeyType key( *i, *usage );
00092             if( this->SingleUsageIds.find( key ) != this->SingleUsageIds.end() )
00093             {
00094                 this->SingleUsageIds.erase( key );
00095                 this->MultipleUsageIds.push_back( *i );
00096             }
00097             else
00098             {
00099                 this->SingleUsageIds.insert( key );
00100             }
00101         }
00102     }
00103
00104     //----------------------------------------------------------------------------
00105     smoab::Range UsageTable::multipleUsage() const
00106     {
00107         smoab::Range multiples;
00108         std::copy( this->MultipleUsageIds.rbegin(), this->MultipleUsageIds.rend(), moab::range_inserter( multiples ) );
00109         return multiples;
00110     }
00111
00112     //----------------------------------------------------------------------------
00113     smoab::Range UsageTable::singleUsage() const
00114     {
00115         smoab::Range single;
00116         std::copy( this->SingleUsageIds.rbegin(), this->SingleUsageIds.rend(), internal::key_inserter( single ) );
00117         return single;
00118     }
00119
00120 }  // namespace detail
00121 }  // namespace smoab
00122 #endif
