V_TetMetric.cpp File Reference
#include "moab/verdict.h"
#include "verdict_defines.hpp"
#include "VerdictVector.hpp"
#include "V_GaussIntegration.hpp"
#include <memory.h>
+ Include dependency graph for V_TetMetric.cpp:
Defines
#define VERDICT_EXPORTS
Functions
C_FUNC_DEF void v_set_tet_size (double size)
 Sets average size (volume) of tet, needed for v_tet_relative_size(...)
int get_weight (VerdictVector &w1, VerdictVector &w2, VerdictVector &w3)
C_FUNC_DEF double v_tet_edge_ratio (int, double coordinates[][3])
 Calculates tet edge ratio metric.
C_FUNC_DEF double v_tet_scaled_jacobian (int, double coordinates[][3])
 Calculates tet scaled jacobian.
C_FUNC_DEF double v_tet_radius_ratio (int, double coordinates[][3])
 Calculates tet radius ratio metric.
C_FUNC_DEF double v_tet_aspect_beta (int, double coordinates[][3])
 Calculates the radius ratio metric of a positively oriented tet.
C_FUNC_DEF double v_tet_aspect_ratio (int, double coordinates[][3])
 Calculates tet aspect ratio metric.
C_FUNC_DEF double v_tet_aspect_gamma (int, double coordinates[][3])
 Calculates tet aspect gamma metric.
C_FUNC_DEF double v_tet_aspect_frobenius (int, double coordinates[][3])
 Calculates tet aspect frobenius metric.
C_FUNC_DEF double v_tet_minimum_angle (int, double coordinates[][3])
 Calculates tet minimum dihedral angle.
C_FUNC_DEF double v_tet_collapse_ratio (int, double coordinates[][3])
 Calculates tet collapse ratio metric.
C_FUNC_DEF double v_tet_volume (int, double coordinates[][3])
 Calculates tet volume.
C_FUNC_DEF double v_tet_condition (int, double coordinates[][3])
 Calculates tet condition metric.
C_FUNC_DEF double v_tet_jacobian (int, double coordinates[][3])
 Calculates tet jacobian.
C_FUNC_DEF double v_tet_shape (int, double coordinates[][3])
 Calculates tet shape metric.
C_FUNC_DEF double v_tet_relative_size_squared (int, double coordinates[][3])
 Calculates tet relative size metric.
C_FUNC_DEF double v_tet_shape_and_size (int num_nodes, double coordinates[][3])
 Calculates tet shape-size metric.
C_FUNC_DEF double v_tet_distortion (int num_nodes, double coordinates[][3])
 Calculates tet distortion metric.
C_FUNC_DEF void v_tet_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, TetMetricVals *metric_vals)
 Calculates quality metrics for tetrahedral elements.
Variables
double verdict_tet_size = 0
 the average volume of a tet
Define Documentation
Definition at line 23 of file V_TetMetric.cpp.
Function Documentation
int get_weight ( VerdictVector w1,
VerdictVector w2,
VerdictVector w3
get the weights based on the average size of a tet
Definition at line 46 of file V_TetMetric.cpp.
References determinant(), VerdictVector::set(), and verdict_tet_size.
    static const double rt3       = sqrt( 3.0 );
    static const double root_of_2 = sqrt( 2.0 );
    w1.set( 1, 0, 0 );
    w2.set( 0.5, 0.5 * rt3, 0 );
    w3.set( 0.5, rt3 / 6.0, root_of_2 / rt3 );
    double scale = pow( 6. * verdict_tet_size / determinant( w1, w2, w3 ), 0.3333333333333 );
    w1 *= scale;
    w2 *= scale;
    w3 *= scale;
    return 1;
C_FUNC_DEF void v_set_tet_size ( double  size)
set the average volume of a tet
Definition at line 37 of file V_TetMetric.cpp.
References size, and verdict_tet_size.
Referenced by moab::VerdictWrapper::set_size().
C_FUNC_DEF double v_tet_aspect_beta ( int  ,
The radius ratio of a positively-oriented tet, a.k.a. "aspect beta"
NB (P. Pebay 04/16/07): CR / (3.0 * IR) where CR is the circumsphere radius and IR is the inscribed sphere radius if the element has positive orientation. Note that this metric is similar to the radius ratio of a tet, except that it returns VERDICT_DBL_MAX if the element has negative orientation.
Definition at line 265 of file V_TetMetric.cpp.
References length(), VerdictVector::length(), length_squared(), VerdictVector::length_squared(), VerdictVector::set(), v_tet_volume(), VERDICT_DBL_MAX, VERDICT_DBL_MIN, and VERDICT_MIN.
Referenced by moab::VerdictWrapper::quality_measure().
    // Determine side vectors
    VerdictVector side[6];
    side[0].set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
                 coordinates[1][2] - coordinates[0][2] );
    side[1].set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
                 coordinates[2][2] - coordinates[1][2] );
    side[2].set( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1],
                 coordinates[0][2] - coordinates[2][2] );
    side[3].set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
                 coordinates[3][2] - coordinates[0][2] );
    side[4].set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
                 coordinates[3][2] - coordinates[1][2] );
    side[5].set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
                 coordinates[3][2] - coordinates[2][2] );
    VerdictVector numerator = side[3].length_squared() * ( side[2] * side[0] ) +
                              side[2].length_squared() * ( side[3] * side[0] ) +
                              side[0].length_squared() * ( side[3] * side[2] );
    double area_sum;
    area_sum = ( ( side[2] * side[0] ).length() + ( side[3] * side[0] ).length() + ( side[4] * side[1] ).length() +
                 ( side[3] * side[2] ).length() ) *
               0.5;
    double volume = v_tet_volume( 4, coordinates );
    if( volume < VERDICT_DBL_MIN )
        return (double)VERDICT_DBL_MAX;
    else
        double radius_ratio;
        radius_ratio = numerator.length() * area_sum / ( 108 * volume * volume );
        return (double)VERDICT_MIN( radius_ratio, VERDICT_DBL_MAX );
C_FUNC_DEF double v_tet_aspect_frobenius ( int  ,
The aspect frobenius of a tet
NB (P. Pebay 01/22/07): Frobenius condition number when the reference element is regular
Definition at line 426 of file V_TetMetric.cpp.
References VerdictVector::get_xyz(), VerdictVector::set(), VERDICT_DBL_MAX, VERDICT_DBL_MIN, VERDICT_MAX, and VERDICT_MIN.
Referenced by moab::VerdictWrapper::quality_measure(), and v_tet_quality().
    static const double normal_exp = 1. / 3.;
    VerdictVector ab, ac, ad;
    ab.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
    ac.set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1],
            coordinates[2][2] - coordinates[0][2] );
    ad.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
    double denominator = ab % ( ac * ad );
    denominator *= denominator;
    denominator *= 2.;
    denominator = 3. * pow( denominator, normal_exp );
    if( denominator < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX;
    double u[3];
    ab.get_xyz( u );
    double v[3];
    ac.get_xyz( v );
    double w[3];
    ad.get_xyz( w );
    double numerator = u[0] * u[0] + u[1] * u[1] + u[2] * u[2];
    numerator += v[0] * v[0] + v[1] * v[1] + v[2] * v[2];
    numerator += w[0] * w[0] + w[1] * w[1] + w[2] * w[2];
    numerator *= 1.5;
    numerator -= v[0] * u[0] + v[1] * u[1] + v[2] * u[2];
    numerator -= w[0] * u[0] + w[1] * u[1] + w[2] * u[2];
    numerator -= w[0] * v[0] + w[1] * v[1] + w[2] * v[2];
    double aspect_frobenius = numerator / denominator;
    if( aspect_frobenius > 0 ) return (double)VERDICT_MIN( aspect_frobenius, VERDICT_DBL_MAX );
    return (double)VERDICT_MAX( aspect_frobenius, -VERDICT_DBL_MAX );
C_FUNC_DEF double v_tet_aspect_gamma ( int  ,
the aspect gamma of a tet
srms^3 / (8.48528137423857*V) where srms = sqrt(sum(Si^2)/6), where Si is the edge length
Definition at line 381 of file V_TetMetric.cpp.
References VerdictVector::length_squared(), VerdictVector::set(), v_tet_volume(), VERDICT_DBL_MAX, and VERDICT_DBL_MIN.
    VerdictVector side0, side1, side2, side3, side4, side5;
    side0.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
    side1.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
    side2.set( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1],
    side3.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
    side4.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
    side5.set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
    double volume = fabs( v_tet_volume( 4, coordinates ) );
    else
        double srms = sqrt( ( side0.length_squared() + side1.length_squared() + side2.length_squared() +
                              side3.length_squared() + side4.length_squared() + side5.length_squared() ) /
                            6.0 );
        double aspect_ratio_gamma = pow( srms, 3 ) / ( 8.48528137423857 * volume );
        return (double)aspect_ratio_gamma;
C_FUNC_DEF double v_tet_aspect_ratio ( int  ,
The aspect ratio of a tet
NB (P. Pebay 01/22/07): Hmax / (2 sqrt(6) r) where Hmax and r respectively denote the greatest edge length and the inradius of the tetrahedron
Definition at line 318 of file V_TetMetric.cpp.
References VerdictVector::length(), VerdictVector::length_squared(), VerdictVector::set(), VERDICT_DBL_MAX, VERDICT_DBL_MIN, VERDICT_MAX, and VERDICT_MIN.
    static const double normal_coeff = sqrt( 6. ) / 12.;
    VerdictVector ab, bc, ac, ad, bd, cd;
    double detTet = ab % ( ac * ad );
    if( detTet < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX;
    bc.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
    bd.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
    cd.set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
    double ab2 = ab.length_squared();
    double bc2 = bc.length_squared();
    double ac2 = ac.length_squared();
    double ad2 = ad.length_squared();
    double bd2 = bd.length_squared();
    double cd2 = cd.length_squared();
    double A  = ab2 > bc2 ? ab2 : bc2;
    double B  = ac2 > ad2 ? ac2 : ad2;
    double C  = bd2 > cd2 ? bd2 : cd2;
    double D  = A > B ? A : B;
    double hm = D > C ? sqrt( D ) : sqrt( C );
    bd = ab * bc;
    A  = bd.length();
    bd = ab * ad;
    B  = bd.length();
    bd = ac * ad;
    C  = bd.length();
    bd = bc * cd;
    D  = bd.length();
    double aspect_ratio;
    aspect_ratio = normal_coeff * hm * ( A + B + C + D ) / fabs( detTet );
    if( aspect_ratio > 0 ) return (double)VERDICT_MIN( aspect_ratio, VERDICT_DBL_MAX );
    return (double)VERDICT_MAX( aspect_ratio, -VERDICT_DBL_MAX );
C_FUNC_DEF double v_tet_collapse_ratio ( int  ,
The collapse ratio of a tet
Definition at line 526 of file V_TetMetric.cpp.
References VerdictVector::length(), VerdictVector::set(), VERDICT_DBL_MAX, VERDICT_DBL_MIN, VERDICT_MAX, and VERDICT_MIN.
    VerdictVector e01, e02, e03, e12, e13, e23;
    e01.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
    e02.set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1],
    e03.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
    e12.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
    e13.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
    e23.set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
    double l[6];
    l[0] = e01.length();
    l[1] = e02.length();
    l[2] = e03.length();
    l[3] = e12.length();
    l[4] = e13.length();
    l[5] = e23.length();
    // Find longest edge for each bounding triangle of tetrahedron
    double l012 = l[4] > l[0] ? l[4] : l[0];
    l012        = l[1] > l012 ? l[1] : l012;
    double l031 = l[0] > l[2] ? l[0] : l[2];
    l031        = l[3] > l031 ? l[3] : l031;
    double l023 = l[2] > l[1] ? l[2] : l[1];
    l023        = l[5] > l023 ? l[5] : l023;
    double l132 = l[4] > l[3] ? l[4] : l[3];
    l132        = l[5] > l132 ? l[5] : l132;
    // Compute collapse ratio for each vertex/triangle pair
    VerdictVector N;
    double h, magN;
    double cr;
    double crMin;
    N     = e01 * e02;
    magN  = N.length();
    h     = ( e03 % N ) / magN;  // height of vertex 3 above 0-1-2
    crMin = h / l012;            // ratio of height to longest edge of 0-1-2
    N    = e03 * e01;
    magN = N.length();
    h    = ( e02 % N ) / magN;  // height of vertex 2 above 0-3-1
    cr   = h / l031;            // ratio of height to longest edge of 0-3-1
    if( cr < crMin ) crMin = cr;
    N    = e02 * e03;
    magN = N.length();
    h    = ( e01 % N ) / magN;  // height of vertex 1 above 0-2-3
    cr   = h / l023;            // ratio of height to longest edge of 0-2-3
    N    = e12 * e13;
    magN = N.length();
    h    = ( e01 % N ) / magN;  // height of vertex 0 above 1-3-2
    cr   = h / l132;            // ratio of height to longest edge of 1-3-2
    if( crMin < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX;
    if( crMin > 0 ) return (double)VERDICT_MIN( crMin, VERDICT_DBL_MAX );
    return (double)VERDICT_MAX( crMin, -VERDICT_DBL_MAX );
C_FUNC_DEF double v_tet_condition ( int  ,
the condition of a tet
condition number of the jacobian matrix at any corner
Definition at line 629 of file V_TetMetric.cpp.
References VerdictVector::set(), VERDICT_DBL_MAX, and VERDICT_DBL_MIN.
    double condition, term1, term2, det;
    double rt6 = sqrt( 6.0 );
    VerdictVector side0, side2, side3;
    VerdictVector c_1, c_2, c_3;
    c_1 = side0;
    c_2 = ( -2 * side2 - side0 ) / rt3;
    c_3 = ( 3 * side3 + side2 - side0 ) / rt6;
    term1 = c_1 % c_1 + c_2 % c_2 + c_3 % c_3;
    term2 = ( c_1 * c_2 ) % ( c_1 * c_2 ) + ( c_2 * c_3 ) % ( c_2 * c_3 ) + ( c_1 * c_3 ) % ( c_1 * c_3 );
    det   = c_1 % ( c_2 * c_3 );
    if( det <= VERDICT_DBL_MIN )
        return VERDICT_DBL_MAX;
    else
        condition = sqrt( term1 * term2 ) / ( 3.0 * det );
    return (double)condition;
C_FUNC_DEF double v_tet_distortion ( int  num_nodes,
the distortion of a tet
Definition at line 765 of file V_TetMetric.cpp.
References GaussIntegration::calculate_derivative_at_nodes_3d_tet(), GaussIntegration::calculate_shape_function_3d_tet(), GaussIntegration::get_shape_func(), GaussIntegration::initialize(), maxNumberNodes, maxTotalNumberGaussPoints, VerdictVector::set(), and VERDICT_DBL_MAX.
    double distortion          = VERDICT_DBL_MAX;
    int number_of_gauss_points = 0;
    if( num_nodes == 4 )
        // for linear tet, the distortion is always 1 because
        // straight edge tets are the target shape for tet
        return 1.0;
    else if( num_nodes == 10 )
        // use four integration points for quadratic tet
        number_of_gauss_points = 4;
    int number_dims                  = 3;
    int total_number_of_gauss_points = number_of_gauss_points;
    // use is_tri=1 to indicate this is for tet in 3D
    int is_tri = 1;
    double shape_function[maxTotalNumberGaussPoints][maxNumberNodes];
    double dndy1[maxTotalNumberGaussPoints][maxNumberNodes];
    double dndy2[maxTotalNumberGaussPoints][maxNumberNodes];
    double dndy3[maxTotalNumberGaussPoints][maxNumberNodes];
    double weight[maxTotalNumberGaussPoints];
    // create an object of GaussIntegration for tet
    GaussIntegration::initialize( number_of_gauss_points, num_nodes, number_dims, is_tri );
    GaussIntegration::calculate_shape_function_3d_tet();
    GaussIntegration::get_shape_func( shape_function[0], dndy1[0], dndy2[0], dndy3[0], weight );
    // vector xxi is the derivative vector of coordinates w.r.t local xi coordinate in the
    // computation space
    // vector xet is the derivative vector of coordinates w.r.t local et coordinate in the
    // vector xze is the derivative vector of coordinates w.r.t local ze coordinate in the
    VerdictVector xxi, xet, xze, xin;
    double jacobian, minimum_jacobian;
    double element_volume = 0.0;
    minimum_jacobian      = VERDICT_DBL_MAX;
    // calculate element volume
    int ife, ja;
    for( ife = 0; ife < total_number_of_gauss_points; ife++ )
        xxi.set( 0.0, 0.0, 0.0 );
        xet.set( 0.0, 0.0, 0.0 );
        xze.set( 0.0, 0.0, 0.0 );
        for( ja = 0; ja < num_nodes; ja++ )
            xin.set( coordinates[ja][0], coordinates[ja][1], coordinates[ja][2] );
            xxi += dndy1[ife][ja] * xin;
            xet += dndy2[ife][ja] * xin;
            xze += dndy3[ife][ja] * xin;
        // determinant
        jacobian = xxi % ( xet * xze );
        if( minimum_jacobian > jacobian ) minimum_jacobian = jacobian;
        element_volume += weight[ife] * jacobian;
    }  // element_volume is 6 times the actual volume
    // loop through all nodes
    double dndy1_at_node[maxNumberNodes][maxNumberNodes];
    double dndy2_at_node[maxNumberNodes][maxNumberNodes];
    double dndy3_at_node[maxNumberNodes][maxNumberNodes];
    GaussIntegration::calculate_derivative_at_nodes_3d_tet( dndy1_at_node, dndy2_at_node, dndy3_at_node );
    int node_id;
    for( node_id = 0; node_id < num_nodes; node_id++ )
            xxi += dndy1_at_node[node_id][ja] * xin;
            xet += dndy2_at_node[node_id][ja] * xin;
            xze += dndy3_at_node[node_id][ja] * xin;
    distortion = minimum_jacobian / element_volume;
    return (double)distortion;
C_FUNC_DEF double v_tet_edge_ratio ( int  ,
the edge ratio of a tet
NB (P. Pebay 01/22/07): Hmax / Hmin where Hmax and Hmin are respectively the maximum and the minimum edge lengths
Definition at line 71 of file V_TetMetric.cpp.
References VerdictVector::length_squared(), VerdictVector::set(), VERDICT_DBL_MAX, VERDICT_DBL_MIN, VERDICT_MAX, and VERDICT_MIN.
    VerdictVector a, b, c, d, e, f;
    a.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
    b.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
    c.set( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1],
    e.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
    f.set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
    double a2 = a.length_squared();
    double b2 = b.length_squared();
    double c2 = c.length_squared();
    double d2 = d.length_squared();
    double e2 = e.length_squared();
    double f2 = f.length_squared();
    double m2, M2, mab, mcd, mef, Mab, Mcd, Mef;
    if( a2 < b2 )
        mab = a2;
        Mab = b2;
    else  // b2 <= a2
        mab = b2;
        Mab = a2;
    if( c2 < d2 )
        mcd = c2;
        Mcd = d2;
    else  // d2 <= c2
        mcd = d2;
        Mcd = c2;
    if( e2 < f2 )
        mef = e2;
        Mef = f2;
    else  // f2 <= e2
        mef = f2;
        Mef = e2;
    m2 = mab < mcd ? mab : mcd;
    m2 = m2 < mef ? m2 : mef;
    if( m2 < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX;
    M2 = Mab > Mcd ? Mab : Mcd;
    M2 = M2 > Mef ? M2 : Mef;
    double edge_ratio = sqrt( M2 / m2 );
    if( edge_ratio > 0 ) return (double)VERDICT_MIN( edge_ratio, VERDICT_DBL_MAX );
    return (double)VERDICT_MAX( edge_ratio, -VERDICT_DBL_MAX );
C_FUNC_DEF double v_tet_jacobian ( int  ,
the jacobian of a tet
TODO
Definition at line 670 of file V_TetMetric.cpp.
References VerdictVector::set().
    return (double)( side3 % ( side2 * side0 ) );
C_FUNC_DEF double v_tet_minimum_angle ( int  ,
The minimum angle of a tet
NB (P. Pebay 01/22/07): minimum nonoriented dihedral angle
Definition at line 475 of file V_TetMetric.cpp.
    static const double normal_coeff = 180. * .3183098861837906715377675267450287;
    VerdictVector ab, bc, ad, cd;
    VerdictVector abc = ab * bc;
    double nabc       = abc.length();
    VerdictVector abd = ab * ad;
    double nabd       = abd.length();
    VerdictVector acd = ad * cd;
    double nacd       = acd.length();
    VerdictVector bcd = bc * cd;
    double nbcd       = bcd.length();
    double alpha   = acos( ( abc % abd ) / ( nabc * nabd ) );
    double beta    = acos( ( abc % acd ) / ( nabc * nacd ) );
    double gamma   = acos( ( abc % bcd ) / ( nabc * nbcd ) );
    double delta   = acos( ( abd % acd ) / ( nabd * nacd ) );
    double epsilon = acos( ( abd % bcd ) / ( nabd * nbcd ) );
    double zeta    = acos( ( acd % bcd ) / ( nacd * nbcd ) );
    alpha = alpha < beta ? alpha : beta;
    alpha = alpha < gamma ? alpha : gamma;
    alpha = alpha < delta ? alpha : delta;
    alpha = alpha < epsilon ? alpha : epsilon;
    alpha = alpha < zeta ? alpha : zeta;
    alpha *= normal_coeff;
    if( alpha < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX;
    if( alpha > 0 ) return (double)VERDICT_MIN( alpha, VERDICT_DBL_MAX );
    return (double)VERDICT_MAX( alpha, -VERDICT_DBL_MAX );
C_FUNC_DEF void v_tet_quality ( int  num_nodes,
TetMetricVals metric_vals
the quality metrics of a tet
Definition at line 862 of file V_TetMetric.cpp.
References TetMetricVals::aspect_beta, TetMetricVals::aspect_frobenius, TetMetricVals::aspect_gamma, TetMetricVals::aspect_ratio, TetMetricVals::collapse_ratio, TetMetricVals::condition, TetMetricVals::distortion, get_weight(), TetMetricVals::jacobian, length(), VerdictVector::length(), length_squared(), VerdictVector::length_squared(), TetMetricVals::minimum_angle, TetMetricVals::radius_ratio, TetMetricVals::relative_size_squared, TetMetricVals::scaled_jacobian, VerdictVector::set(), TetMetricVals::shape, TetMetricVals::shape_and_size, V_TET_ASPECT_BETA, V_TET_ASPECT_FROBENIUS, v_tet_aspect_frobenius(), V_TET_ASPECT_GAMMA, V_TET_ASPECT_RATIO, v_tet_aspect_ratio(), V_TET_COLLAPSE_RATIO, v_tet_collapse_ratio(), V_TET_CONDITION, V_TET_DISTORTION, v_tet_distortion(), V_TET_JACOBIAN, V_TET_MINIMUM_ANGLE, v_tet_minimum_angle(), V_TET_RADIUS_RATIO, v_tet_radius_ratio(), V_TET_RELATIVE_SIZE_SQUARED, V_TET_SCALED_JACOBIAN, V_TET_SHAPE, V_TET_SHAPE_AND_SIZE, V_TET_VOLUME, VERDICT_DBL_MAX, VERDICT_DBL_MIN, VERDICT_MAX, VERDICT_MIN, and TetMetricVals::volume.
Referenced by moab::VerdictWrapper::all_quality_measures().
    memset( metric_vals, 0, sizeof( TetMetricVals ) );
      node numbers and edge numbers below
               3
               +            edge 0 is node 0 to 1
              +|+           edge 1 is node 1 to 2
            3/ | \5         edge 2 is node 0 to 2
            / 4|  \         edge 3 is node 0 to 3
          0 - -|- + 2       edge 4 is node 1 to 3
            \  |  +         edge 5 is node 2 to 3
            0\ | /1
              +|/           edge 2 is behind edge 4
               1
    // lets start with making the vectors
    VerdictVector edges[6];
    edges[0].set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
    edges[1].set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
    edges[2].set( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1],
    edges[3].set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
    edges[4].set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
    edges[5].set( coordinates[3][0] - coordinates[2][0], coordinates[3][1] - coordinates[2][1],
    // common numbers
    // calculate the jacobian
    static const int do_jacobian = V_TET_JACOBIAN | V_TET_VOLUME | V_TET_ASPECT_BETA | V_TET_ASPECT_GAMMA |
                                   V_TET_SHAPE | V_TET_RELATIVE_SIZE_SQUARED | V_TET_SHAPE_AND_SIZE |
                                   V_TET_SCALED_JACOBIAN | V_TET_CONDITION;
    if( metrics_request_flag & do_jacobian )
        metric_vals->jacobian = (double)( edges[3] % ( edges[2] * edges[0] ) );
    // calculate the volume
    if( metrics_request_flag & V_TET_VOLUME )
        metric_vals->volume = (double)( metric_vals->jacobian / 6.0 );
    // calculate aspect ratio
    if( metrics_request_flag & V_TET_ASPECT_BETA )
        double surface_area = ( ( edges[2] * edges[0] ).length() + ( edges[3] * edges[0] ).length() +
                                ( edges[4] * edges[1] ).length() + ( edges[3] * edges[2] ).length() ) *
                              0.5;
        VerdictVector numerator = edges[3].length_squared() * ( edges[2] * edges[0] ) +
                                  edges[2].length_squared() * ( edges[3] * edges[0] ) +
                                  edges[0].length_squared() * ( edges[3] * edges[2] );
        double volume = metric_vals->jacobian / 6.0;
            metric_vals->aspect_beta = (double)( VERDICT_DBL_MAX );
        else
            metric_vals->aspect_beta = (double)( numerator.length() * surface_area / ( 108 * volume * volume ) );
    // calculate the aspect gamma
    if( metrics_request_flag & V_TET_ASPECT_GAMMA )
        double volume = fabs( metric_vals->jacobian / 6.0 );
        if( fabs( volume ) < VERDICT_DBL_MIN )
            metric_vals->aspect_gamma = VERDICT_DBL_MAX;
        else
            double srms = sqrt( ( edges[0].length_squared() + edges[1].length_squared() + edges[2].length_squared() +
                                  edges[3].length_squared() + edges[4].length_squared() + edges[5].length_squared() ) /
                                6.0 );
            // cube the srms
            srms *= ( srms * srms );
            metric_vals->aspect_gamma = (double)( srms / ( 8.48528137423857 * volume ) );
    // calculate the shape of the tet
    if( metrics_request_flag & ( V_TET_SHAPE | V_TET_SHAPE_AND_SIZE ) )
        // if the jacobian is non-positive, the shape is 0
        if( metric_vals->jacobian < VERDICT_DBL_MIN )
            metric_vals->shape = (double)0.0;
        else
            static const double two_thirds = 2.0 / 3.0;
            double num                     = 3.0 * pow( root_of_2 * metric_vals->jacobian, two_thirds );
            double den                     = 1.5 * ( edges[0] % edges[0] + edges[2] % edges[2] + edges[3] % edges[3] ) -
                         ( edges[0] % -edges[2] + -edges[2] % edges[3] + edges[3] % edges[0] );
            if( den < VERDICT_DBL_MIN )
            else
                metric_vals->shape = (double)VERDICT_MAX( num / den, 0 );
    // calculate the relative size of the tet
    if( metrics_request_flag & ( V_TET_RELATIVE_SIZE_SQUARED | V_TET_SHAPE_AND_SIZE ) )
        VerdictVector w1, w2, w3;
        get_weight( w1, w2, w3 );
        double avg_vol = ( w1 % ( w2 * w3 ) ) / 6;
        if( avg_vol < VERDICT_DBL_MIN )
            metric_vals->relative_size_squared = 0.0;
        else
            double tmp = metric_vals->jacobian / ( 6 * avg_vol );
            if( tmp < VERDICT_DBL_MIN )
            else
                tmp *= tmp;
                metric_vals->relative_size_squared = (double)VERDICT_MIN( tmp, 1 / tmp );
    // calculate the shape and size
    if( metrics_request_flag & V_TET_SHAPE_AND_SIZE )
        metric_vals->shape_and_size = (double)( metric_vals->shape * metric_vals->relative_size_squared );
    // calculate the scaled jacobian
    if( metrics_request_flag & V_TET_SCALED_JACOBIAN )
        // find out which node the normalized jacobian can be calculated at
        // and it will be the smaller than at other nodes
        double length_squared[4] = { edges[0].length_squared() * edges[2].length_squared() * edges[3].length_squared(),
                                     edges[0].length_squared() * edges[1].length_squared() * edges[4].length_squared(),
                                     edges[1].length_squared() * edges[2].length_squared() * edges[5].length_squared(),
                                     edges[3].length_squared() * edges[4].length_squared() *
                                         edges[5].length_squared() };
        int which_node = 0;
        if( length_squared[1] > length_squared[which_node] ) which_node = 1;
        if( length_squared[2] > length_squared[which_node] ) which_node = 2;
        if( length_squared[3] > length_squared[which_node] ) which_node = 3;
        // find the scaled jacobian at this node
        double length_product = sqrt( length_squared[which_node] );
        if( length_product < fabs( metric_vals->jacobian ) ) length_product = fabs( metric_vals->jacobian );
        if( length_product < VERDICT_DBL_MIN )
            metric_vals->scaled_jacobian = (double)VERDICT_DBL_MAX;
        else
            metric_vals->scaled_jacobian = (double)( root_of_2 * metric_vals->jacobian / length_product );
    // calculate the condition number
    if( metrics_request_flag & V_TET_CONDITION )
        static const double root_of_3 = sqrt( 3.0 );
        static const double root_of_6 = sqrt( 6.0 );
        c_1 = edges[0];
        c_2 = ( -2 * edges[2] - edges[0] ) / root_of_3;
        c_3 = ( 3 * edges[3] + edges[2] - edges[0] ) / root_of_6;
        double term1 = c_1 % c_1 + c_2 % c_2 + c_3 % c_3;
        double term2 = ( c_1 * c_2 ) % ( c_1 * c_2 ) + ( c_2 * c_3 ) % ( c_2 * c_3 ) + ( c_3 * c_1 ) % ( c_3 * c_1 );
        double det = c_1 % ( c_2 * c_3 );
            metric_vals->condition = (double)VERDICT_DBL_MAX;
        else
            metric_vals->condition = (double)( sqrt( term1 * term2 ) / ( 3.0 * det ) );
    // calculate the distortion
    if( metrics_request_flag & V_TET_DISTORTION )
        metric_vals->distortion = v_tet_distortion( num_nodes, coordinates );
    // check for overflow
        if( metric_vals->aspect_beta > 0 )
            metric_vals->aspect_beta = (double)VERDICT_MIN( metric_vals->aspect_beta, VERDICT_DBL_MAX );
        metric_vals->aspect_beta = (double)VERDICT_MAX( metric_vals->aspect_beta, -VERDICT_DBL_MAX );
        if( metric_vals->aspect_gamma > 0 )
            metric_vals->aspect_gamma = (double)VERDICT_MIN( metric_vals->aspect_gamma, VERDICT_DBL_MAX );
        metric_vals->aspect_gamma = (double)VERDICT_MAX( metric_vals->aspect_gamma, -VERDICT_DBL_MAX );
        if( metric_vals->volume > 0 ) metric_vals->volume = (double)VERDICT_MIN( metric_vals->volume, VERDICT_DBL_MAX );
        metric_vals->volume = (double)VERDICT_MAX( metric_vals->volume, -VERDICT_DBL_MAX );
        if( metric_vals->condition > 0 )
            metric_vals->condition = (double)VERDICT_MIN( metric_vals->condition, VERDICT_DBL_MAX );
        metric_vals->condition = (double)VERDICT_MAX( metric_vals->condition, -VERDICT_DBL_MAX );
    if( metrics_request_flag & V_TET_JACOBIAN )
        if( metric_vals->jacobian > 0 )
            metric_vals->jacobian = (double)VERDICT_MIN( metric_vals->jacobian, VERDICT_DBL_MAX );
        metric_vals->jacobian = (double)VERDICT_MAX( metric_vals->jacobian, -VERDICT_DBL_MAX );
        if( metric_vals->scaled_jacobian > 0 )
            metric_vals->scaled_jacobian = (double)VERDICT_MIN( metric_vals->scaled_jacobian, VERDICT_DBL_MAX );
        metric_vals->scaled_jacobian = (double)VERDICT_MAX( metric_vals->scaled_jacobian, -VERDICT_DBL_MAX );
    if( metrics_request_flag & V_TET_SHAPE )
        if( metric_vals->shape > 0 ) metric_vals->shape = (double)VERDICT_MIN( metric_vals->shape, VERDICT_DBL_MAX );
        metric_vals->shape = (double)VERDICT_MAX( metric_vals->shape, -VERDICT_DBL_MAX );
    if( metrics_request_flag & V_TET_RELATIVE_SIZE_SQUARED )
        if( metric_vals->relative_size_squared > 0 )
                (double)VERDICT_MIN( metric_vals->relative_size_squared, VERDICT_DBL_MAX );
            (double)VERDICT_MAX( metric_vals->relative_size_squared, -VERDICT_DBL_MAX );
        if( metric_vals->shape_and_size > 0 )
            metric_vals->shape_and_size = (double)VERDICT_MIN( metric_vals->shape_and_size, VERDICT_DBL_MAX );
        metric_vals->shape_and_size = (double)VERDICT_MAX( metric_vals->shape_and_size, -VERDICT_DBL_MAX );
        if( metric_vals->distortion > 0 )
            metric_vals->distortion = (double)VERDICT_MIN( metric_vals->distortion, VERDICT_DBL_MAX );
        metric_vals->distortion = (double)VERDICT_MAX( metric_vals->distortion, -VERDICT_DBL_MAX );
    if( metrics_request_flag & V_TET_ASPECT_RATIO ) metric_vals->aspect_ratio = v_tet_aspect_ratio( 4, coordinates );
    if( metrics_request_flag & V_TET_ASPECT_FROBENIUS )
        metric_vals->aspect_frobenius = v_tet_aspect_frobenius( 4, coordinates );
    if( metrics_request_flag & V_TET_MINIMUM_ANGLE ) metric_vals->minimum_angle = v_tet_minimum_angle( 4, coordinates );
    if( metrics_request_flag & V_TET_COLLAPSE_RATIO )
        metric_vals->collapse_ratio = v_tet_collapse_ratio( 4, coordinates );
    if( metrics_request_flag & V_TET_RADIUS_RATIO ) metric_vals->radius_ratio = v_tet_radius_ratio( 4, coordinates );
C_FUNC_DEF double v_tet_radius_ratio ( int  ,
The radius ratio of a tet
NB (P. Pebay 04/16/07): CR / (3.0 * IR) where CR is the circumsphere radius and IR is the inscribed sphere radius. Note that this metric is similar to the aspect beta of a tet, except that it does not return VERDICT_DBL_MAX if the element has negative orientation.
Definition at line 209 of file V_TetMetric.cpp.
    double area_sum;
               0.5;
    else
C_FUNC_DEF double v_tet_relative_size_squared ( int  ,
the relative size of a tet
Min(J,1/J), where J is the determinant of the weighted Jacobian matrix
Definition at line 727 of file V_TetMetric.cpp.
References get_weight(), size, v_tet_volume(), and VERDICT_DBL_MIN.
Referenced by moab::VerdictWrapper::quality_measure(), and v_tet_shape_and_size().
    double size;
    double avg_volume = ( w1 % ( w2 * w3 ) ) / 6.0;
    if( avg_volume < VERDICT_DBL_MIN )
        return 0.0;
    else
        size = volume / avg_volume;
        if( size <= VERDICT_DBL_MIN ) return 0.0;
        if( size > 1 ) size = (double)( 1 ) / size;
    return (double)( size * size );
C_FUNC_DEF double v_tet_scaled_jacobian ( int  ,
the scaled jacobian of a tet
minimum of the jacobian divided by the lengths of 3 edge vectors
Definition at line 153 of file V_TetMetric.cpp.
References length_squared(), VerdictVector::length_squared(), VerdictVector::set(), VERDICT_DBL_MAX, and VERDICT_DBL_MIN.
    double jacobi;
    jacobi = side3 % ( side2 * side0 );
    // products of lengths squared of each edge attached to a node.
    double length_squared[4] = { side0.length_squared() * side2.length_squared() * side3.length_squared(),
                                 side0.length_squared() * side1.length_squared() * side4.length_squared(),
                                 side1.length_squared() * side2.length_squared() * side5.length_squared(),
                                 side3.length_squared() * side4.length_squared() * side5.length_squared() };
    int which_node           = 0;
    if( length_product < fabs( jacobi ) ) length_product = fabs( jacobi );
    if( length_product < VERDICT_DBL_MIN ) return (double)VERDICT_DBL_MAX;
    return (double)( root_of_2 * jacobi / length_product );
C_FUNC_DEF double v_tet_shape ( int  ,
the shape of a tet
3/ condition number of weighted jacobian matrix
Definition at line 691 of file V_TetMetric.cpp.
References VerdictVector::set(), VERDICT_DBL_MIN, and VERDICT_MAX.
    VerdictVector edge0, edge2, edge3;
    edge0.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
    edge2.set( coordinates[0][0] - coordinates[2][0], coordinates[0][1] - coordinates[2][1],
    edge3.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
    double jacobian = edge3 % ( edge2 * edge0 );
    if( jacobian < VERDICT_DBL_MIN )
        return (double)0.0;
    double num = 3 * pow( root_of_2 * jacobian, two_thirds );
    double den =
        1.5 * ( edge0 % edge0 + edge2 % edge2 + edge3 % edge3 ) - ( edge0 % -edge2 + -edge2 % edge3 + edge3 % edge0 );
    if( den < VERDICT_DBL_MIN ) return (double)0.0;
    return (double)VERDICT_MAX( num / den, 0 );
C_FUNC_DEF double v_tet_shape_and_size ( int  num_nodes,
the shape and size of a tet
Product of the shape and relative size
Definition at line 752 of file V_TetMetric.cpp.
References size, v_tet_relative_size_squared(), and v_tet_shape().
    double shape, size;
    shape = v_tet_shape( num_nodes, coordinates );
    size  = v_tet_relative_size_squared( num_nodes, coordinates );
    return (double)( shape * size );
C_FUNC_DEF double v_tet_volume ( int  ,
the volume of a tet
1/6 * jacobian at a corner node
Definition at line 606 of file V_TetMetric.cpp.
Referenced by moab::VerdictWrapper::quality_measure(), v_tet_aspect_beta(), v_tet_aspect_gamma(), v_tet_radius_ratio(), and v_tet_relative_size_squared().
    return (double)( ( side3 % ( side2 * side0 ) ) / 6.0 );
Variable Documentation
Definition at line 32 of file V_TetMetric.cpp.
Referenced by get_weight(), and v_set_tet_size().
