MOAB: Mesh Oriented datABase
(version 5.4.1)
Classes | |
class | GetOffsets |
struct | ExpectedSize |
Defines | |
#define | OFFSET(A) ( (char*)( &( A ) ) - (char*)this ) |
Functions | |
void | test_valid_struct () |
void | test_inline () |
void | test_non_inline () |
void | test_resize_ii () |
void | test_resize_in () |
void | test_resize_ni () |
void | test_resize_nn () |
int | main () |
#define OFFSET | ( | A | ) | ( (char*)( &( A ) ) - (char*)this ) |
Definition at line 36 of file VarLenTagTest.cpp.
Referenced by ScalarAddMetricTest< OFFSET >::evaluate(), GetOffsets::pointer_array_offset(), GetOffsets::pointer_size_offset(), and moab::ReadTemplate::read_elements().
int main | ( | ) |
Definition at line 16 of file VarLenTagTest.cpp.
References RUN_TEST, test_inline(), test_non_inline(), test_resize_ii(), test_resize_in(), test_resize_ni(), test_resize_nn(), and test_valid_struct().
{ int count = 0; count += RUN_TEST( test_valid_struct ); if( count ) { std::cerr << "ABORTING VarLenTag TEST" << std::endl << "Structure is not valid" << std::endl; return count; } count += RUN_TEST( test_inline ); count += RUN_TEST( test_non_inline ); count += RUN_TEST( test_resize_ii ); count += RUN_TEST( test_resize_in ); count += RUN_TEST( test_resize_ni ); count += RUN_TEST( test_resize_nn ); return count; }
void test_inline | ( | ) |
Definition at line 76 of file VarLenTagTest.cpp.
References CHECK_EQUAL, and moab::VarLenTag::data().
Referenced by main().
{ VarLenTag tag( sizeof( void* ) ); CHECK_EQUAL( (unsigned char*)&tag, tag.data() ); }
void test_non_inline | ( | ) |
Definition at line 82 of file VarLenTagTest.cpp.
References CHECK, and moab::VarLenTag::data().
void test_resize_ii | ( | ) |
Definition at line 88 of file VarLenTagTest.cpp.
References CHECK_EQUAL, moab::VarLenTag::data(), and moab::VarLenTag::resize().
{ VarLenTag tag( 1 ); tag.data()[0] = 'X'; unsigned char* ptr = tag.resize( 3 ); CHECK_EQUAL( tag.data(), ptr ); CHECK_EQUAL( (unsigned char*)&tag, tag.data() ); CHECK_EQUAL( tag.data()[0], 'X' ); }
void test_resize_in | ( | ) |
Definition at line 98 of file VarLenTagTest.cpp.
References CHECK, CHECK_EQUAL, moab::VarLenTag::data(), and moab::VarLenTag::resize().
{ VarLenTag tag( sizeof( void* ) ); memcpy( tag.data(), "ABCDEFGHIJKLMNOPQRST", sizeof( void* ) ); unsigned char* ptr = tag.resize( 2 * sizeof( void* ) ); CHECK_EQUAL( tag.data(), ptr ); CHECK( (unsigned char*)&tag != tag.data() ); CHECK( !memcmp( tag.data(), "ABCDEFGHIJKLMNOPQRST", sizeof( void* ) ) ); }
void test_resize_ni | ( | ) |
Definition at line 108 of file VarLenTagTest.cpp.
{ VarLenTag tag( 2 * sizeof( void* ) ); memcpy( tag.data(), "12345678901234567890", sizeof( void* ) ); unsigned char* ptr = tag.resize( sizeof( void* ) ); CHECK_EQUAL( tag.data(), ptr ); CHECK_EQUAL( (unsigned char*)&tag, tag.data() ); CHECK( !memcmp( tag.data(), "12345678901234567890", sizeof( void* ) ) ); }
void test_resize_nn | ( | ) |
Definition at line 118 of file VarLenTagTest.cpp.
{ VarLenTag tag( 2 * sizeof( void* ) ); memcpy( tag.data(), "TSRQPONMLKJIHGFEDCBA", 2 * sizeof( void* ) ); unsigned char* ptr = tag.resize( 4 * sizeof( void* ) ); CHECK_EQUAL( tag.data(), ptr ); CHECK( (unsigned char*)&tag != tag.data() ); CHECK( !memcmp( tag.data(), "TSRQPONMLKJIHGFEDCBA", sizeof( void* ) ) ); }
void test_valid_struct | ( | ) |
Definition at line 65 of file VarLenTagTest.cpp.
References CHECK_EQUAL, GetOffsets::pointer_array_offset(), GetOffsets::pointer_size_offset(), and u.
{ GetOffsets off; CHECK_EQUAL( 0u, off.pointer_array_offset() ); #ifdef VAR_LEN_TAG_ELIDE_DATA CHECK_EQUAL( 0u, off.inline_array_offset() ); CHECK_EQUAL( off.pointer_size_offset(), off.inline_size_offset() ); #endif CHECK_EQUAL( sizeof( ExpectedSize ), sizeof( VarLenTag ) ); }
