VerdictVector.cpp File Reference
#include "moab/verdict.h"
#include <cmath>
#include "VerdictVector.hpp"
#include <cfloat>
+ Include dependency graph for VerdictVector.cpp:
Defines
#define VERDICT_EXPORTS
Functions
VerdictVector interpolate (const double param, const VerdictVector &v1, const VerdictVector &v2)
VerdictVector vectorRotate (const double angle, const VerdictVector &normalAxis, const VerdictVector &referenceAxis)
Variables
const double TWO_VERDICT_PI = 2.0 * VERDICT_PI
Define Documentation
Definition at line 23 of file VerdictVector.cpp.
Function Documentation
VerdictVector interpolate ( const double  param,
const VerdictVector v1,
const VerdictVector v2
Definition at line 98 of file VerdictVector.cpp.
    VerdictVector temp = ( 1.0 - param ) * v1;
    temp += param * v2;
    return temp;
VerdictVector vectorRotate ( const double  angle,
const VerdictVector normalAxis,
const VerdictVector referenceAxis
Definition at line 225 of file VerdictVector.cpp.
References VerdictVector::normalize().
    // A new coordinate system is created with the xy plane corresponding
    // to the plane normal to the normal axis, and the x axis corresponding to
    // the projection of the reference axis onto the normal plane.  The normal
    // plane is the tangent plane at the root point.  A unit vector is
    // constructed along the local x axis and then rotated by the given
    // ccw angle to form the new point.  The new point, then is a unit
    // distance from the global origin in the tangent plane.
    double x, y;
    // project a unit distance from root along reference axis
    VerdictVector yAxis = normalAxis * referenceAxis;
    VerdictVector xAxis = yAxis * normalAxis;
    yAxis.normalize();
    xAxis.normalize();
    x = cos( angle );
    y = sin( angle );
    xAxis *= x;
    yAxis *= y;
    return VerdictVector( xAxis + yAxis );
Variable Documentation
