VtkUtil.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #include "moab/VtkUtil.hpp"
00017
00018 namespace moab
00019 {
00020
00021 const char* VtkUtil::vtkTypeNames[] = {
00022     "unsigned_char",  // MB_TYPE_OPAQUE
00023     "int",            // MB_TYPE_INTEGER
00024     "double",         // MB_TYPE_DOUBLE
00025     "bit",            // MB_TYPE_BIT
00026     "unsigned_long",  // MB_TYPE_HANDLE
00027 };
00028
00029 /*
00030 const unsigned VtkUtil::typeSizes[] = {
00031  1,                      // MB_TYPE_OPAQUE
00032  sizeof(int),            // MB_TYPE_INTEGER
00033  sizeof(double),         // MB_TYPE_DOUBLE
00034  1,                      // MB_TYPE_BIT
00035  sizeof(EntityHandle), // MB_TYPE_HANDLE
00036 };
00037 */
00038
00039 // Define node ordering for those types for which
00040 // the VTK and MOAB ordering doesn't match.  The values
00041 // contained in the array are MOAB connectivity indices,
00042 // and the values used to index the arrays are VTK
00043 // connectivity indices.
00044 const unsigned pixel[] = { 0, 1, 3, 2 };
00045 const unsigned voxel[] = { 0, 1, 3, 2, 4, 5, 7, 6 };
00046 const unsigned wedge[] = { 0,  2,  1,                                       // bottom corners
00047                            3,  5,  4,                                       // top corners
00048                            8,  7,  6,                                       // bottom edges
00049                            14, 13, 12,                                      // top edges
00050                            9,  11, 10,                                      // lateral edges
00051                            17, 16, 15 };                                    // quadrilateral faces
00052 const unsigned qhex[]  = { 0,  1,  2,  3,                                   // corners (same)
00053                           4,  5,  6,  7,  8,  9,  10, 11,                  // mid-edge (top before lateral)
00054                           16, 17, 18, 19, 12, 13, 14, 15, 23, 21, 20, 22,  // mid-face (mixed up) & mid-region (same)
00055                           24, 25, 26 };
00056
00057 // List of VtkElemType structs, indexed by the VTK type number.
00058 const VtkElemType VtkUtil::vtkElemTypes[] = {
00059     { 0, 0, MBMAXTYPE, 0, 0 },
00060     { "vertex", 1, MBVERTEX, 1, 0 },
00061     { "polyvertex", 2, MBMAXTYPE, 0, 0 },
00062     { "line", 3, MBEDGE, 2, 0 },
00063     { "polyline", 4, MBMAXTYPE, 0, 0 },
00064     { "triangle", 5, MBTRI, 3, 0 },
00065     { "triangle strip", 6, MBMAXTYPE, 0, 0 },
00066     { "polygon", 7, MBPOLYGON, 0, 0 },
00067     { "pixel", 8, MBQUAD, 4, pixel },
00068     { "quadrilateral", 9, MBQUAD, 4, 0 },
00069     { "tetrahedron", 10, MBTET, 4, 0 },
00070     { "voxel", 11, MBHEX, 8, voxel },
00071     { "hexahedron", 12, MBHEX, 8, 0 },
00072     { "wedge", 13, MBPRISM, 6, wedge },
00073     { "pyramid", 14, MBPYRAMID, 5, 0 },
00074     { "pentagonal prism", 15, MBMAXTYPE, 10, 0 },  // not supported
00075     { "hexagonal prism", 16, MBMAXTYPE, 12, 0 },   // not supported
00076     { 0, 17, MBMAXTYPE, 0, 0 },
00077     { 0, 18, MBMAXTYPE, 0, 0 },
00078     { 0, 19, MBMAXTYPE, 0, 0 },
00079     { 0, 20, MBMAXTYPE, 0, 0 },
00080     { "quadratic edge", 21, MBEDGE, 3, 0 },
00081     { "quadratic tri", 22, MBTRI, 6, 0 },
00082     { "quadratic quad", 23, MBQUAD, 8, 0 },
00083     { "quadratic tet", 24, MBTET, 10, 0 },
00084     { "quadratic hex", 25, MBHEX, 20, qhex },
00085     { "quadratic wedge", 26, MBPRISM, 15, wedge },
00086     { "quadratic pyramid", 27, MBPYRAMID, 13, 0 },
00087     { "bi-quadratic quad", 28, MBQUAD, 9, 0 },
00088     { "tri-quadratic hex", 29, MBHEX, 27, qhex },
00089     { "quadratic-linear quad", 30, MBMAXTYPE, 6, 0 },        // not supported
00090     { "quadratic-linear wedge", 31, MBMAXTYPE, 12, wedge },  // not supported
00091     { "bi-quadratic wedge", 32, MBMAXTYPE, 18, wedge },      // not supported
00092     { "bi-quadratic hex", 33, MBMAXTYPE, 24, qhex },         // not supported
00093     { "bi-quadratic triangle", 34, MBMAXTYPE, 0, 0 },
00094     { "cubic line", 35, MBMAXTYPE, 0, 0 },  // VTK_CUBIC_LINE not supported
00095     { 0, 36, MBMAXTYPE, 0, 0 },
00096     { 0, 37, MBMAXTYPE, 0, 0 },
00097     { 0, 38, MBMAXTYPE, 0, 0 },
00098     { 0, 39, MBMAXTYPE, 0, 0 },
00099     { 0, 40, MBMAXTYPE, 0, 0 },
00100     { "convex point set", 41, MBMAXTYPE, 0, 0 },  //  VTK_CONVEX_POINT_SET = 41, not supported
00101     { "polyhedron", 42, MBPOLYHEDRON, 0, 0 }      //
00102 };
00103
00104 const unsigned VtkUtil::numVtkElemType = sizeof( VtkUtil::vtkElemTypes ) / sizeof( VtkUtil::vtkElemTypes[0] );
00105
00106 // Define an array, indexed by EntityType containing the corresponding
00107 // VTK element type numbers for the linear, quadratic (mid-edge),
00108 // and full (mid-face & mid-region node) elements.
00109 // Zero is used to indicate an invalid type (not supported by VTK.)  The
00110 // VTK element type number may be used as an index into vtkElemTypes[].
00111 const int mb_to_vtk_type[][3] = { { 1, 0, 0 },     // MBVERTEX
00112                                   { 3, 21, 0 },    // MBEDGE
00113                                   { 5, 22, 0 },    // MBTRI
00114                                   { 9, 23, 28 },   // MBQUAD
00115                                   { 7, 0, 0 },     // MBPOLYGON
00116                                   { 10, 24, 0 },   // MBTET
00117                                   { 14, 27, 0 },   // MBPYRAMID
00118                                   { 13, 26, 0 },   // MBWEDGE
00119                                   { 0, 0, 0 },     // MBKNIFE
00120                                   { 12, 25, 29 },  // MBHEX
00121                                   { 42, 0, 0 },    // MBPOLYHEDRON
00122                                   { 0, 0, 0 },     // MBENTITYSET
00123                                   { 0, 0, 0 } };   // MBMAXTYPE
00124
00125 const VtkElemType* VtkUtil::get_vtk_type( EntityType type, unsigned num_nodes )
00126 {
00127     const int i = mb_to_vtk_type[type][0];  // Index for linear type
00128     const int j = mb_to_vtk_type[type][1];  // Index for quadratic type
00129     const int k = mb_to_vtk_type[type][2];  // Index for full quadratic type
00130     if( i )  // If element type is supported at all (if not linear then not quadratic either)
00131     {
00132         // If the linear type is requested (all polygons are linear
00133         // irrespective of the number of nodes), return that.
00134         if( type == MBPOLYGON || type == MBPOLYHEDRON || vtkElemTypes[i].num_nodes == num_nodes )
00135             return vtkElemTypes + i;
00136         // Otherwise if there is a quadratic type and the number of
00137         // nodes specified corresponds to the quadratic type, return that.
00138         else if( j && vtkElemTypes[j].num_nodes == num_nodes )
00139             return vtkElemTypes + j;
00140         // Otherwise if there is a full quadratic type and the number of
00141         // nodes specified corresponds to the quadratic type, return that.
00142         else if( k && vtkElemTypes[k].num_nodes == num_nodes )
00143             return vtkElemTypes + k;
00144     }
00145
00146     return 0;
00147 }
00148
00149 }  // namespace moab
