WriteCCMIO.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 //-------------------------------------------------------------------------
00017 // Filename      : WriteCCMIO.hpp
00018 //
00019 // Purpose       : ExodusII writer
00020 //
00021 // Special Notes : Lots of code taken from verde implementation
00022 //
00023 // Creator       : Corey Ernst
00024 //
00025 // Date          : 8/02
00026 //
00027 // Owner         : Corey Ernst
00028 //-------------------------------------------------------------------------
00029
00030 #ifndef WRITECCMIO_HPP
00031 #define WRITECCMIO_HPP
00032
00033 #ifndef IS_BUILDING_MB
00034 #error "WriteCCMIO.hpp isn't supposed to be included into an application"
00035 #endif
00036
00037 #include <vector>
00038 #include <string>
00039
00040 #include "moab/Forward.hpp"
00041 #include "moab/Range.hpp"
00042 #include "moab/ExoIIInterface.hpp"
00043 #include "moab/WriterIface.hpp"
00044 #include "ccmio.h"
00045
00046 namespace moab
00047 {
00048
00049 class WriteUtilIface;
00050
00051 class WriteCCMIO : public WriterIface
00052 {
00053
00054   public:
00055     //! Constructor
00056     WriteCCMIO( Interface* impl );
00057
00058     //! Destructor
00059     virtual ~WriteCCMIO();
00060
00061     static WriterIface* factory( Interface* );
00062
00063     //! writes out a file
00064     ErrorCode write_file( const char* file_name,
00065                           const bool overwrite,
00066                           const FileOptions& opts,
00067                           const EntityHandle* output_list,
00068                           const int num_sets,
00069                           const std::vector< std::string >& qa_list,
00070                           const Tag* tag_list  = NULL,
00071                           int num_tags         = 0,
00072                           int export_dimension = 3 );
00073
00074   protected:
00075     //! number of dimensions in this file
00076     // int number_dimensions();
00077
00078     //! open a file for writing
00079     ErrorCode open_file( const char* filename, bool overwrite, CCMIOID& rootID );
00080
00081     //! contains the general information about a mesh
00082     class MeshInfo
00083     {
00084       public:
00085         unsigned int num_dim;
00086         unsigned int num_nodes;
00087         unsigned int num_elements;
00088         unsigned int num_matsets;
00089         unsigned int num_dirsets;
00090         unsigned int num_neusets;
00091         Range nodes;
00092
00093         MeshInfo()
00094             : num_dim( 0 ), num_nodes( 0 ), num_elements( 0 ), num_matsets( 0 ), num_dirsets( 0 ), num_neusets( 0 )
00095         {
00096         }
00097     };
00098
00099     // material set information
00100     class MaterialSetData
00101     {
00102       public:
00103         Range elems;               // elements in material set
00104         EntityHandle setHandle;    // handle of the material set
00105         EntityType entityType;     // entity type of these elements
00106         int verts_per_element;     // number of vertices in each element
00107         int matsetId;              // id of this matset, from MATERIAL_SET tag
00108         int materialId;            // materialid, if any (from CCMIO)
00109         std::string setName;       // name for this matset, if any
00110         std::string materialType;  // material type for this matset, if any
00111
00112         MaterialSetData()
00113             : setHandle( 0 ), entityType( MBMAXTYPE ), verts_per_element( 0 ), matsetId( -1 ), materialId( -1 )
00114
00115         {
00116         }
00117     };
00118
00119     // neumann set information
00120     class NeumannSetData
00121     {
00122       public:
00123         Range elems;             // elements in neumann set
00124         EntityHandle setHandle;  // handle of the neumann set
00125         EntityType entityType;   // entity type of these elements
00126         int verts_per_element;   // number of vertices in each element
00127         int neusetId;            // id of this matset, from NEUMANN_SET tag
00128         std::string setName;     // name for this neuset, if any
00129
00130         NeumannSetData() : setHandle( 0 ), entityType( MBMAXTYPE ), verts_per_element( 0 ), neusetId( -1 ) {}
00131     };
00132
00133   private:
00134     //! interface instance
00135     Interface* mbImpl;
00136     WriteUtilIface* mWriteIface;
00137
00138     //! file name
00139     std::string fileName;
00140
00141     //! Meshset Handle for the mesh that is currently being read
00142     EntityHandle mCurrentMeshHandle;
00143
00144     //! Cached tags for reading.  Note that all these tags are defined when the
00145     //! core is initialized.
00146     Tag mMaterialSetTag;
00147     Tag mDirichletSetTag;
00148     Tag mNeumannSetTag;
00149     Tag mPartitionSetTag;
00150     Tag mHasMidNodesTag;
00151     Tag mGlobalIdTag;
00152     Tag mNameTag, mMaterialIdTag, mMaterialTypeTag;
00153     Tag mRadiationTag, mPorosityIdTag, mSpinIdTag, mGroupIdTag, mColorIdxTag, mProcessorIdTag, mLightMaterialTag,
00154         mFreeSurfaceMaterialTag;
00155     Tag mThicknessTag, mProstarRegionNumberTag, mBoundaryTypeTag, mCreatingProgramTag;
00156
00157     Tag mEntityMark;  // used to say whether an entity will be exported
00158
00159     int mDimension;  // dimension of entities being exported
00160
00161     bool mWholeMesh;  // if true, whole mesh is being output
00162
00163     //! gathers elements in each matset, and all the vertices used by them;
00164     //! marks the vertices with the mEntityMark bit flag
00165     ErrorCode gather_matset_info( std::vector< EntityHandle >& matsets,
00166                                   std::vector< MaterialSetData >& matset_data,
00167                                   Range& all_verts );
00168
00169     //! gathers elements in each neuset
00170     ErrorCode gather_neuset_info( std::vector< EntityHandle >& neusets, std::vector< NeumannSetData >& neuset_data );
00171
00172     ErrorCode close_and_compress( const char* filename, CCMIOID rootID );
00173
00174     ErrorCode initialize_file( MeshInfo& mesh_info );
00175
00176     //! write vertices to file
00177     ErrorCode write_nodes( CCMIOID rootID, const Range& nodes, const int dimension, CCMIOID& verticesID );
00178
00179     //! write cells and internal/boundary faces, using vgids and verts input
00180     ErrorCode write_cells_and_faces( CCMIOID rootID,
00181                                      std::vector< WriteCCMIO::MaterialSetData >& matset_data,
00182                                      std::vector< WriteCCMIO::NeumannSetData >& neuset_data,
00183                                      Range& verts,
00184                                      CCMIOID& topologyID );
00185
00186     //! write external faces, including connectivity and connected cells
00187     ErrorCode write_external_faces( CCMIOID rootID, CCMIOID topologyID, int set_num, Range& facets );
00188
00189     // get global ids for these entities; allocates gids and passes back,
00190     // caller is responsible for deleting
00191     ErrorCode get_gids( const Range& ents, int*& gids, int& minid, int& maxid );
00192
00193     ErrorCode write_meshes( MeshInfo& mesh_info,
00194                             std::vector< MaterialSetData >& matset_data,
00195                             std::vector< NeumannSetData >& neuset_data,
00196                             Range& verts,
00197                             const int* vgids );
00198
00199     ErrorCode get_valid_sides( Range& elems, const int sense, WriteCCMIO::NeumannSetData& neuset_data );
00200
00201     void reset_matset( std::vector< MaterialSetData >& matset_info );
00202
00203     ErrorCode get_neuset_elems( EntityHandle neuset, int current_sense, Range& forward_elems, Range& reverse_elems );
00204
00205     ErrorCode transform_coords( const int dimension, const int num_nodes, double* coords );
00206
00207     ErrorCode write_problem_description( CCMIOID rootID,
00208                                          CCMIOID stateID,
00209                                          CCMIOID& problemID,
00210                                          CCMIOID processorID,
00211                                          std::vector< MaterialSetData >& matset_data,
00212                                          std::vector< NeumannSetData >& neuset_data );
00213
00214     // get the material, dirichlet, neumann, and partition sets to be written,
00215     // either from input sets or in the whole mesh
00216     ErrorCode get_sets( const EntityHandle* ent_handles,
00217                         int num_sets,
00218                         std::vector< EntityHandle >& matsets,
00219                         std::vector< EntityHandle >& dirsets,
00220                         std::vector< EntityHandle >& neusets,
00221                         std::vector< EntityHandle >& partsets );
00222
00223     //! create state and processor nodes
00224     ErrorCode create_ccmio_structure( CCMIOID rootID, CCMIOID& stateID, CCMIOID& processorID );
00225
00226     //! write solution (tag) data
00227     ErrorCode write_solution_data();
00228
00229     //! finalize processor
00230     ErrorCode write_processor( CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID );
00231
00232     //! convert MOAB to CCMIO type
00233     int moab_to_ccmio_type( EntityType etype, int has_mid_nodes[] );
00234
00235     ErrorCode write_int_option( const char* opt_name, EntityHandle seth, Tag& tag, CCMIOID& node );
00236
00237     ErrorCode write_dbl_option( const char* opt_name, EntityHandle seth, Tag& tag, CCMIOID& node );
00238
00239     ErrorCode write_str_option( const char* opt_name,
00240                                 EntityHandle seth,
00241                                 Tag& tag,
00242                                 CCMIOID& node,
00243                                 const char* other_name = NULL );
00244 };
00245
00246 }  // namespace moab
00247
00248 #endif
