WriteDamsel.cpp
00001 /* WriteDamsel.cpp
00002  * The Damsel library provides mesh-aware parallel I/O; see
00003  * http://cucis.ece.northwestern.edu/projects/DAMSEL/ for details, though for now that site is
00004  * restricted to project participants.  Damsel uses a data model that's very similar to that used in
00005  * MOAB and ITAPS.  It uses the same basic data model concepts of entities, sets, tags, and
00006  * interface. In theory, we should be able to completely save/restore to/from Damsel any data that
00007  * can be saved/restored to/from our native HDF5-based reader/writer.
00008  *
00009  * Mapping between MOAB-Damsel data models
00010  * =======================================
00011  * Basic data model entities, MOAB <--> Damsel:
00012  *        Entity <--> Entity
00013  *     EntitySet <--> Collection
00014  *           Tag <--> Tag
00015  * API/data strutures:
00016  *          Range (n1) <--> Sequence container
00017  *         std::vector <--> Vector container
00018  *          Range (n2) <--> Tree container
00019  *
00020  * n1: single contiguous subrange
00021  * n2: multiple subranges
00022  *
00023  * Conventions
00024  * ===========
00025  * There are parts of MOAB data structures that need to be stored to Damsel that aren't represented
00026  * in the Damsel data model, e.g. dense vs. sparse storage type, set tracking flags.
00027  * - We need to store these as tags in Damsel.
00028  * - Since Damsel tags need to have a MOAB counterpart, we have to create those as tag data in MOAB
00029  * too (duplicating the data in the data structures, bummer).
00030  * - Because we may want to use these tags for multiple Damsel writes/models, we create the
00031  * MOAB-side tags in the WriteDamsel constructor, not in the init_tags function that's called for
00032  * every write
00033  * - Conventional tags have names prefixed with mbdmsl_ to avoid name conflicts with other MOAB
00034  * tags. Here we list the conventional tags used by MOAB's Damsel reader/writer.
00035  *
00036  * Tag name                   Tag char's (storage type, data type, length, def val)       Values,
00037  * used for what
00038  * --------                   -----------------------------------------------------
00039  * -------------------- mbdmsl_XCOORDS             dense; double[1]; 0.0 MOAB vertex x coordinate
00040  * mbdmsl_YCOORDS             dense; double[1]; 0.0                                       MOAB
00041  * vertex y coordinate mbdmsl_ZCOORDS             dense; double[1]; 0.0 MOAB vertex z coordinate
00042  * mbdmsl_COLL_FLAGS          sparse; char; 1; 0x0                                        bit 0:
00043  * 0=set-type, 1=vector-type 1: 1=tracking, 0=not tracking mbdmsl_PARENTS      sparse; handle; var;
00044  * (list of parent sets) mbdmsl_CHILDS       sparse; handle; var; (list of child sets)
00045  *
00046  *
00047  *
00048  */
00049
00050 #include "WriteDamsel.hpp"
00051
00052 #include "DamselUtil.hpp"
00053 #include "damsel.h"
00054 #include <cassert>
00055 #include "moab/Interface.hpp"
00056 #include "moab/Core.hpp"
00057 #include "moab/Range.hpp"
00058 #include "moab/Error.hpp"
00059 #include "moab/WriteUtilIface.hpp"
00060 #include "MBTagConventions.hpp"
00061 #include "EntitySequence.hpp"
00062 #include "Internals.hpp"
00063 #include "DenseTag.hpp"
00064 #include "SparseTag.hpp"
00065
00066 namespace moab
00067 {
00068
00069 WriterIface* WriteDamsel::factory( Interface* iface )
00070 {
00071     return new WriteDamsel( iface );
00072 }
00073
00074 WriteDamsel::WriteDamsel( Interface* impl )
00075     : mbImpl( impl ), mWriteIface( NULL ), sequenceManager( NULL ), dU(), DAMSEL_FLAGS( DAMSEL_IS_TRACKING )
00076 {
00077     assert( impl != NULL );
00078
00079     impl->query_interface( mWriteIface );
00080     assert( mWriteIface );
00081
00082     sequenceManager = dynamic_cast< Core* >( impl )->sequence_manager();
00083     assert( sequenceManager );
00084
00085     ErrorCode rval =
00086         mbImpl->tag_get_handle( "mbdmsl_XCOORDS", 1, MB_TYPE_DOUBLE, dU.xcoordsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_XCOORDS" );
00087     dU.xcoordsTag.tagType = MB_TAG_ANY;
00088     dU.tagMap.push_back( dU.xcoordsTag );
00089     rval =
00090         mbImpl->tag_get_handle( "mbdmsl_YCOORDS", 1, MB_TYPE_DOUBLE, dU.ycoordsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_YCOORDS" );
00091     dU.ycoordsTag.tagType = MB_TAG_ANY;
00092     dU.tagMap.push_back( dU.ycoordsTag );
00093
00094     rval =
00095         mbImpl->tag_get_handle( "mbdmsl_ZCOORDS", 1, MB_TYPE_DOUBLE, dU.zcoordsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_ZCOORDS" );
00096     dU.zcoordsTag.tagType = MB_TAG_ANY;
00097     dU.tagMap.push_back( dU.zcoordsTag );
00098
00099     rval = mbImpl->tag_get_handle( "mbdmsl_COLL_FLAGS", 1, MB_TYPE_INTEGER, dU.collFlagsTag.mTagh,
00100                                    MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_CONT( rval, "Failed to create_tag mbdmsl_COLL_FLAGS" );
00101     dU.collFlagsTag.tagType = MB_TAG_ANY;
00102     dU.tagMap.push_back( dU.collFlagsTag );
00103
00104     /*
00105       rval = mbImpl->tag_get_handle("mbdmsl_PARENTS", 1, MB_TYPE_HANDLE,
00106                                    dU.parentsTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT |
00107       MB_TAG_VARLEN);MB_CHK_SET_ERR_CONT(rval, "Failed to create_tag mbdmsl_PARENTS");
00108       dU.parentsTag.tagType = MB_TAG_DENSE;
00109       dU.tagMap.push_back(dU.parentsTag);
00110
00111       rval = mbImpl->tag_get_handle("mbdmsl_CHILDREN", 1, MB_TYPE_HANDLE,
00112                                    dU.childrenTag.mTagh, MB_TAG_DENSE | MB_TAG_CREAT |
00113       MB_TAG_VARLEN);MB_CHK_SET_ERR_CONT(rval, "Failed to create_tag mbdmsl_CHILDREN");
00114       dU.childrenTag.tagType = MB_TAG_DENSE;
00115       dU.tagMap.push_back(dU.childrenTag);
00116     */
00117
00118     dU.moabHandleType = ( sizeof( EntityHandle ) == 64 ? DAMSEL_HANDLE_TYPE_HANDLE64 : DAMSEL_HANDLE_TYPE_HANDLE32 );
00119 }
00120
00121 WriteDamsel::~WriteDamsel()
00122 {
00123     if( mWriteIface ) mbImpl->release_interface( mWriteIface );
00124 }
00125
00126 ErrorCode WriteDamsel::write_file( const char* file_name,
00127                                    const bool /* overwrite */,
00128                                    const FileOptions& opts,
00129                                    const EntityHandle* meshset_list,
00130                                    const int num_sets,
00131                                    const std::vector< std::string >& /* qa_records */,
00132                                    const Tag* /* tag_list */,
00133                                    int /* num_tags */,
00134                                    int /* requested_output_dimension */ )
00135 {
00136     // Gather all entities into one big range
00137     Range all_ents;
00138     ErrorCode rval;
00139     damsel_err_t err;
00140
00141     dU.dmslLib = DMSLlib_init();
00142
00143     // Create a damsel model
00144     dU.dmslModel =
00145         DMSLmodel_create( sizeof( EntityHandle ) == 8 ? DAMSEL_HANDLE_TYPE_HANDLE64 : DAMSEL_HANDLE_TYPE_HANDLE32 );
00146
00147     // Attach to a file, since we need it for creating containers
00148     MPI_Comm comm = MPI_COMM_WORLD;
00149     unlink( file_name );
00150     err = DMSLmodel_attach( dU.dmslModel, file_name, comm, NULL );
00151     CHK_DMSL_ERR( err, "DMSLmodel_attach failed" );
00152
00153     rval = mWriteIface->gather_entities( all_ents, meshset_list, num_sets );MB_CHK_SET_ERR( rval, "Gather entities failed in WriteDamsel" );
00154
00155     if( all_ents.empty() ) return MB_SUCCESS;
00156
00157     // Create damsel tags for MOAB dense, sparse, and conventional tags
00158     rval = init_tag_info();MB_CHK_ERR( rval );
00159
00160     // Iterate through the groups of contiguous sequences of handles
00161     RangeSeqIntersectIter rsi( sequenceManager );
00162     rval = rsi.init( all_ents.begin(), all_ents.end() );
00163
00164     while( MB_SUCCESS == rval )
00165     {
00166         // Write subrange of things to damsel: map handles, map entity definition data
00167         // (connectivity/coords/set contents), map dense tags
00168         rval = write_subrange( rsi );MB_CHK_SET_ERR( rval, "Failed to write subrange" );
00169
00170         rval = rsi.step();
00171         while( MB_ENTITY_NOT_FOUND == rval )
00172             rval = rsi.step();
00173     }
00174
00175     // Write sparse tags
00176     rval = map_sparse_tags();MB_CHK_SET_ERR( rval, "Failed to write sparse tags" );
00177
00178     // damsel_request_t request;
00179     // err = DMSLmodel_transfer_async(dU.dmslModel, DAMSEL_TRANSFER_TYPE_WRITE, &request);
00180     err = DMSLmodel_transfer_sync( dU.dmslModel, DAMSEL_TRANSFER_TYPE_WRITE );
00181     CHK_DMSL_ERR( err, "DMSLmodel_transfer_asynch failed" );
00182
00183     // damsel_status_t status;
00184     // err = DMSLmodel_wait(request, &status);CHK_DMSL_ERR(err, "DMSLmodel_wait failed");
00185
00186     DMSLmodel_close( dU.dmslModel );
00187
00188     DMSLlib_finalize( dU.dmslLib );
00189
00190     // We should be done
00191     return MB_SUCCESS;
00192 }
00193
00194 ErrorCode WriteDamsel::init_tag_info()
00195 {
00196     // Initialize allTags and tagIndices
00197     std::vector< Tag > tmp_mtags;
00198     ErrorCode rval = mbImpl->tag_get_tags( tmp_mtags );MB_CHK_SET_ERR( rval, "Failed to get all tag handles." );
00199     int dum_size;
00200     damsel_err_t err;
00201
00202     // Define damsel tag handles for all dense/sparse tags
00203     for( std::vector< Tag >::iterator vit = tmp_mtags.begin(); vit != tmp_mtags.end(); ++vit )
00204     {
00205         if( ( ( *vit )->get_storage_type() != MB_TAG_DENSE && ( *vit )->get_storage_type() != MB_TAG_SPARSE ) ||
00206             mbImpl->tag_get_length( *vit, dum_size ) == MB_VARIABLE_DATA_LENGTH || dum_size != 1 )
00207         {
00208             std::cerr << "Warning: tag " << ( *vit )->get_name()
00209                       << "is not of type dense or sparse, and is not currently supported by the "
00210                          "damsel writer."
00211                       << std::endl;
00212             continue;
00213         }
00214
00215         std::vector< DamselUtil::tinfo >::iterator vit2 =
00216             std::find_if( dU.tagMap.begin(), dU.tagMap.end(), DamselUtil::MtagP< DamselUtil::tinfo >( *vit ) );
00217
00218         if( vit2 != dU.tagMap.end() && ( *vit2 ).tagType == MB_TAG_ANY )
00219             // Conventional tag - skip
00220             continue;
00221
00222         else if( vit2 == dU.tagMap.end() )
00223         {
00224             // Create a damsel counterpart for this tag
00225             Tag thandle = *vit;
00226             err         = DMSLtag_define( dU.dmslModel, (damsel_handle_ptr)&thandle,
00227                                           DamselUtil::mtod_data_type[( *vit )->get_data_type()], ( *vit )->get_name().c_str() );
00228             CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" );
00229             dU.tagMap.push_back( DamselUtil::tinfo( thandle, 0, ( *vit )->get_storage_type() ) );
00230         }
00231         else
00232         {
00233             // Assert there's a corresponding moab tag handle
00234             assert( ( *vit2 ).mTagh );
00235         }
00236     }
00237
00238     // Do the same for conventional tags:
00239     // XCOORDS
00240     err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.xcoordsTag.mTagh ),
00241                           DamselUtil::mtod_data_type[MB_TYPE_DOUBLE], dU.xcoordsTag.mTagh->get_name().c_str() );
00242     dU.tagMap.push_back( dU.xcoordsTag );
00243     CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" );
00244
00245     // YCOORDS
00246     err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.ycoordsTag.mTagh ),
00247                           DamselUtil::mtod_data_type[MB_TYPE_DOUBLE], dU.ycoordsTag.mTagh->get_name().c_str() );
00248     dU.tagMap.push_back( dU.ycoordsTag );
00249     CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" );
00250
00251     // ZCOORDS
00252     err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.zcoordsTag.mTagh ),
00253                           DamselUtil::mtod_data_type[MB_TYPE_DOUBLE], dU.zcoordsTag.mTagh->get_name().c_str() );
00254     dU.tagMap.push_back( dU.zcoordsTag );
00255     CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" );
00256
00257     // COLL_FLAGS
00258     err = DMSLtag_define( dU.dmslModel, ( damsel_handle_ptr ) & ( dU.collFlagsTag.mTagh ),
00259                           DamselUtil::mtod_data_type[MB_TYPE_INTEGER], dU.collFlagsTag.mTagh->get_name().c_str() );
00260     dU.tagMap.push_back( dU.collFlagsTag );
00261     CHK_DMSL_ERR( err, "Failure to get Damsel tag for MOAB tag" );
00262
00263     /*
00264       SKIP PARENTS/CHILDREN FOR NOW, UNTIL WE HAVE VAR LENGTH TAGS IN DAMSEL
00265
00266       // PARENTS
00267       dU.parentsTagPair.second = DMSLtag_define(dU.dmslModel,
00268       (damsel_handle_ptr)&(dU.collFlagsTagPair.first),
00269                                                DamselUtil::mtod_data_type[(dU.collFlagsTagPair.first)->get_data_type()],
00270                                                (dU.parentsTagPair.first)->get_name().c_str());
00271       if (DAMSEL_TAG_INVALID == dtag)
00272         MB_SET_ERR(MB_FAILURE, "Failure to get Damsel tag for MOAB tag " <<
00273       (dU.parentsTagPair.first)->get_name());
00274
00275       // CHILDREN
00276       dU.childrenTagPair.second = DMSLtag_define(dU.dmslModel,
00277       (damsel_handle_ptr)&(dU.collFlagsTagPair.first),
00278                                                DamselUtil::mtod_data_type[(dU.collFlagsTagPair.first)->get_data_type()],
00279                                                (dU.childrenTagPair.first)->get_name().c_str());
00280       if (DAMSEL_TAG_INVALID == dtag)
00281         MB_SET_ERR(MB_FAILURE, "Failure to get Damsel tag for MOAB tag " <<
00282       (dU.childrenTagPair.first)->get_name());
00283     */
00284
00285     // Map the tag handles in one big call
00286     int num_tags = dU.tagMap.size();
00287     std::vector< Tag > moab_taghs;
00288     moab_taghs.reserve( num_tags );
00289     for( std::vector< DamselUtil::tinfo >::iterator vit = dU.tagMap.begin(); vit != dU.tagMap.end(); ++vit )
00290     {
00291         moab_taghs.push_back( ( *vit ).mTagh );
00292     }
00293
00294     damsel_container mtags =
00295         DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle_ptr)&moab_taghs[0], moab_taghs.size() );
00296     std::cerr << "MOAB: created model container: mtags = " << mtags << std::endl;
00297
00298     err = DMSLmodel_map_handles_inventing_file_handles( mtags );
00299     CHK_DMSL_ERR( err, "Failed to map tag handles" );
00300
00301     err = DMSLcontainer_release( mtags );
00302     CHK_DMSL_ERR( err, "Problem releasing tag handle container" );
00303
00304     return MB_SUCCESS;
00305 }
00306
00307 ErrorCode WriteDamsel::write_vertices( RangeSeqIntersectIter& rsi )
00308 {
00309     // Write the vertices; these vertices will be in the same sequence and will be contiguous,
00310     // guaranteed
00311     EntityHandle start_vert = rsi.get_start_handle(), end_vert = rsi.get_end_handle();
00312
00313     // Create a damsel container for these vertex handles
00314     damsel_container vertex_cont =
00315         DMSLcontainer_create_sequence( dU.dmslModel, start_vert, (int)( end_vert - start_vert + 1 ), 1 );
00316     std::cerr << "MOAB: created model container: vertex_cont = " << vertex_cont << std::endl;
00317     if( DAMSEL_CONTAINER_INVALID == vertex_cont )
00318         MB_SET_ERR( MB_FAILURE,
00319                     "Failed to create vertex sequence for vertices starting with handle " << rsi.get_start_handle() );
00320
00321     damsel_err_t err = DMSLmodel_map_handles_inventing_file_handles( vertex_cont );
00322     CHK_DMSL_ERR( err, "Failed to map handles" );
00323
00324     // Define the entities to damsel
00325     err = DMSLentity_define( vertex_cont, DAMSEL_ENTITY_TYPE_VERTEX, 1, vertex_cont );
00326     CHK_DMSL_ERR( err, "Failure in DMSLentity_define for vertices starting with handle " << rsi.get_start_handle() );
00327
00328     // Get the vertex coordinates storage locations and pass to damsel
00329     Range vert_range( start_vert, end_vert );
00330     double *xcoords = NULL, *ycoords = NULL, *zcoords = NULL;
00331     int count;
00332     ErrorCode rval = mbImpl->coords_iterate( vert_range.begin(), vert_range.end(), xcoords, ycoords, zcoords, count );MB_CHK_SET_ERR( rval,
00333                     "Failed to get coordinate iterator for vertices starting with handle " << rsi.get_start_handle() );
00334     if( count != (int)vert_range.size() )
00335     {
00336         MB_SET_ERR( MB_FAILURE, "Vertex subrange not in the same sequence for vertices starting with handle "
00337                                     << rsi.get_start_handle() );
00338     }
00339
00340     if( xcoords && !ycoords && !zcoords )
00341     {
00342         // Interleaved
00343
00344         // Map the data to damsel
00345         err = DMSLmodel_map_tag( xcoords, vertex_cont, (damsel_handle_ptr)&dU.xcoordsTag.mTagh );
00346         CHK_DMSL_ERR( err, "Failed to assign vertex coordinates tag for vertices starting with handle "
00347                                << rsi.get_start_handle() );
00348     }
00349     else
00350     {
00351         // Map the data to damsel
00352         err = DMSLmodel_map_tag( xcoords, vertex_cont, (damsel_handle_ptr)&dU.xcoordsTag.mTagh );
00353         CHK_DMSL_ERR( err, "Failed to assign vertex x coordinates tag for vertices starting with handle "
00354                                << rsi.get_start_handle() );
00355         err = DMSLmodel_map_tag( ycoords, vertex_cont, (damsel_handle_ptr)&dU.ycoordsTag.mTagh );
00356         CHK_DMSL_ERR( err, "Failed to assign vertex y coordinates tag for vertices starting with handle "
00357                                << rsi.get_start_handle() );
00358         err = DMSLmodel_map_tag( zcoords, vertex_cont, (damsel_handle_ptr)&dU.zcoordsTag.mTagh );
00359         CHK_DMSL_ERR( err, "Failed to assign vertex z coordinates tag for vertices starting with handle "
00360                                << rsi.get_start_handle() );
00361     }
00362
00363     // Write/map dense tags
00364     rval = map_dense_tags( rsi, vertex_cont );MB_CHK_ERR( rval );
00365
00366     err = DMSLcontainer_release( vertex_cont );
00367     CHK_DMSL_ERR( err, "Problem releasing vertex handle container" );
00368
00369     return MB_SUCCESS;
00370 }
00371
00372 ErrorCode WriteDamsel::write_entities( RangeSeqIntersectIter& rsi )
00373 {
00374     // Write the entities; these entities will be in the same sequence and will be contiguous,
00375     // guaranteed
00376     EntityHandle start_ent = rsi.get_start_handle(), end_ent = rsi.get_end_handle();
00377
00378     // Create a damsel container for these entity handles
00379     damsel_container ent_cont;
00380     ent_cont = DMSLcontainer_create_sequence( dU.dmslModel, start_ent, (int)( end_ent - start_ent + 1 ), 1 );
00381     std::cerr << "MOAB: created model container: ent_cont = " << ent_cont << std::endl;
00382     if( DAMSEL_CONTAINER_INVALID == ent_cont ) MB_SET_ERR( MB_FAILURE, "Bad sequence returned by Damsel" );
00383
00384     damsel_err_t err = DMSLmodel_map_handles_inventing_file_handles( ent_cont );
00385     CHK_DMSL_ERR( err, "Failed to map handles" );
00386
00387     // Get # verts per entity and entity type
00388     EntityType etype = mbImpl->type_from_handle( start_ent );
00389     assert( MBMAXTYPE != etype );
00390     int num_connect = rsi.get_sequence()->values_per_entity();
00391     assert( 0 < num_connect );
00392
00393     // Get the connectivity storage location and pass to damsel
00394     Range ent_range( start_ent, end_ent );
00395     int count;
00396     EntityHandle* connect;
00397     int verts_per_ent;
00398     ErrorCode rval = mbImpl->connect_iterate( ent_range.begin(), ent_range.end(), connect, verts_per_ent, count );MB_CHK_SET_ERR( rval,
00399                     "Failed to get connect iterator for entities starting with handle " << rsi.get_start_handle() );
00400     if( count != (int)ent_range.size() )
00401         MB_SET_ERR( MB_FAILURE, "Entity subrange not in the same sequence for entities starting with handle "
00402                                     << rsi.get_start_handle() );
00403
00404     // Define the entities to damsel
00405     err = DMSLentity_define_fast( ent_cont, DamselUtil::mtod_entity_type[etype], num_connect, (damsel_handle*)connect );
00406     CHK_DMSL_ERR( err, "DMSLentity_define failed for entities starting with handle " << rsi.get_start_handle() );
00407
00408     // Write dense tags
00409     rval = map_dense_tags( rsi, ent_cont );MB_CHK_ERR( rval );
00410
00411     err = DMSLcontainer_release( ent_cont );
00412     CHK_DMSL_ERR( err, "Problem releasing entity handle container" );
00413
00414     return MB_SUCCESS;
00415 }
00416
00417 ErrorCode WriteDamsel::map_dense_tags( RangeSeqIntersectIter& rsi, damsel_container& ent_cont )
00418 {
00419     // All dense_tags have been initialized before this, so here we just go through
00420     // them and map data if there is any
00421     const unsigned char* val_ptr;
00422     ErrorCode rval = MB_SUCCESS;
00423     std::vector< DamselUtil::tinfo >::iterator tagit;
00424     damsel_err_t err;
00425     for( tagit = dU.tagMap.begin(); tagit != dU.tagMap.end(); ++tagit )
00426     {
00427         if( ( *tagit ).tagType != MB_TAG_DENSE ) continue;
00428
00429         // Get a ptr to memory for this tag/sequence
00430         DenseTag* dtag = dynamic_cast< DenseTag* >( ( *tagit ).mTagh );
00431         assert( dtag );
00432         rval = dtag->get_array( rsi.get_sequence(), val_ptr );MB_CHK_SET_ERR( rval, "Failed to get tag coordinates pointer for vertices starting with handle "
00433                                   << rsi.get_start_handle() );
00434
00435         // If ptr is NULL, no data for this tag in this sequence
00436         if( !val_ptr ) continue;
00437
00438         // Else, register with damsel
00439         err = DMSLmodel_map_tag( (void*)val_ptr, ent_cont, (damsel_handle_ptr)&dtag );
00440         CHK_DMSL_ERR( err,
00441                       "Failed to write coordinates tag for vertices starting with handle " << rsi.get_start_handle() );
00442     }
00443
00444     return rval;
00445 }
00446
00447 ErrorCode WriteDamsel::map_sparse_tags()
00448 {
00449     // All sparse_tags have been initialized before this, so here we just go through
00450     // them and map data if there is any
00451     ErrorCode rval = MB_SUCCESS;
00452     damsel_err_t err;
00453     std::vector< DamselUtil::tinfo >::iterator tagit;
00454     std::vector< unsigned char > tag_values;
00455     std::vector< EntityHandle > tagged_ents;
00456     damsel_container ent_cont;
00457     for( tagit = dU.tagMap.begin(); tagit != dU.tagMap.end(); ++tagit )
00458     {
00459         if( ( *tagit ).tagType != MB_TAG_SPARSE ) continue;
00460         // Get a ptr to memory for this tag/sequence
00461         SparseTag* stag = dynamic_cast< SparseTag* >( ( *tagit ).mTagh );
00462         assert( stag );
00463         Range output_ents;
00464         rval = stag->get_tagged_entities( sequenceManager, output_ents );MB_CHK_SET_ERR( rval, "Trouble getting tagged entities for tag " << stag->get_name() );
00465
00466         // If no entities have this tag set, don't map it
00467         if( output_ents.empty() ) continue;
00468
00469         // Else, register with damsel
00470         // Allocate space for and get values
00471         tag_values.resize( stag->get_size() * output_ents.size() );
00472         rval = mbImpl->tag_get_data( stag, output_ents, &tag_values[0] );MB_CHK_SET_ERR( rval, "Trouble getting tag values for tag " << stag->get_name() );
00473
00474         // Build a vector of entity handles from the range, and a container from that
00475         tagged_ents.resize( output_ents.size() );
00476         std::copy( output_ents.begin(), output_ents.end(), tagged_ents.begin() );
00477         ent_cont = DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle_ptr)&tagged_ents[0], tagged_ents.size() );
00478         std::cerr << "MOAB: created model container: sparse_tag_ent_cont = " << ent_cont << std::endl;
00479         if( DAMSEL_CONTAINER_INVALID == ent_cont )
00480             MB_SET_ERR( MB_FAILURE, "Trouble creating entity handle container for tag " << stag->get_name() );
00481
00482         // Now map it
00483         err = DMSLmodel_map_tag( (void*)&tag_values[0], ent_cont, (damsel_handle_ptr)&stag );
00484         CHK_DMSL_ERR( err, "Failed to write tag " << stag->get_name() );
00485
00486         err = DMSLcontainer_release( ent_cont );
00487         CHK_DMSL_ERR( err, "Problem releasing entity handle container" );
00488     }
00489
00490     return rval;
00491 }
00492
00493 ErrorCode WriteDamsel::write_sets( RangeSeqIntersectIter& rsi )
00494 {
00495     // Write the sets
00496     ErrorCode rval = MB_SUCCESS;
00497     std::vector< EntityHandle > ents;
00498     damsel_container mcont;
00499     damsel_err_t err;
00500     unsigned int i, num_sets = rsi.get_end_handle() - rsi.get_start_handle() + 1;
00501     std::vector< unsigned int > set_flags( num_sets, 0 );
00502     EntityHandle seth;
00503     for( seth = rsi.get_start_handle(), i = 0; seth <= rsi.get_end_handle(); seth++, i++ )
00504     {
00505         // Get all the entities in the set
00506         ents.clear();
00507         rval = mbImpl->get_entities_by_handle( seth, ents );MB_CHK_SET_ERR( rval, "get_entities_by_handle failed for set " << seth );
00508         if( !ents.empty() )
00509         {
00510             mcont = DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle*)&ents[0], ents.size() );
00511         }
00512         else
00513         {
00514             mcont = DMSLcontainer_create_vector( dU.dmslModel, (damsel_handle*)NULL, 0 );
00515         }
00516         std::cerr << "MOAB: created model container: sets_cont = " << mcont << std::endl;
00517
00518         // Get the set type (range or set)
00519         unsigned int opts;
00520         rval = mbImpl->get_meshset_options( seth, opts );MB_CHK_SET_ERR( rval, "Failed to get options for meshset " << seth );
00521         damsel_collection_type coll_type =
00522             ( opts & MESHSET_SET ? DAMSEL_HANDLE_COLLECTION_TYPE_SET : DAMSEL_HANDLE_COLLECTION_TYPE_VECTOR );
00523
00524         // Parents/children...
00525
00526         // Set flags
00527         if( opts & MESHSET_TRACK_OWNER )
00528             set_flags[i] |= MESHSET_TRACK_OWNER;
00529         else
00530             set_flags[i] &= !MESHSET_TRACK_OWNER;
00531
00532         // Create the collection
00533         DMSLcoll_create( dU.dmslModel, (damsel_handle_ptr)&seth, mcont, coll_type );
00534
00535         // Release the container
00536         err = DMSLcontainer_release( mcont );
00537         CHK_DMSL_ERR( err, "Problem releasing set entity handle container" );
00538     }
00539
00540     // Set the COLL_FLAGS tag, using assign (direct)
00541     // Make a container of set handles...
00542     mcont = DMSLcontainer_create_sequence( dU.dmslModel, rsi.get_start_handle(), num_sets, 1 );
00543     std::cerr << "MOAB: created model container: sets_cont = " << mcont << std::endl;
00544
00545     // Assign the tags on them
00546     err = DMSLmodel_map_tag( &set_flags[0], mcont, ( damsel_handle_ptr ) & ( dU.collFlagsTag.mTagh ) );
00547     CHK_DMSL_ERR( err, "Failed to assign COLL_FLAGS tag for sets" );
00548
00549     // Map set handles
00550     err = DMSLmodel_map_handles_inventing_file_handles( mcont );
00551     CHK_DMSL_ERR( err, "Failed to map set handles" );
00552
00553     // Map other dense tags
00554     rval = map_dense_tags( rsi, mcont );MB_CHK_SET_ERR( rval, "Failed to map dense tags for sets" );
00555
00556     return rval;
00557 }
00558
00559 }  // namespace moab
