WriteTemplate.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifdef WIN32
00017 #ifdef _DEBUG
00018 // turn off warnings that say they debugging identifier has been truncated
00019 // this warning comes up when using some STL containers
00020 #pragma warning( disable : 4786 )
00021 #endif
00022 #endif
00023
00024 #include "WriteTemplate.hpp"
00025
00026 #include <utility>
00027 #include <algorithm>
00028 #include <ctime>
00029 #include <string>
00030 #include <vector>
00031 #include <cstdio>
00032 #include <cstring>
00033 #include <iostream>
00034
00035 #include "moab/Interface.hpp"
00036 #include "moab/Range.hpp"
00037 #include "moab/CN.hpp"
00038 #include <cassert>
00039 #include "Internals.hpp"
00040 #include "ExoIIUtil.hpp"
00041 #include "MBTagConventions.hpp"
00042 #include "moab/WriteUtilIface.hpp"
00043
00044 namespace moab
00045 {
00046
00047 #define INS_ID( stringvar, prefix, id ) sprintf( stringvar, prefix, id )
00048
00049 WriterIface* WriteTemplate::factory( Interface* iface )
00050 {
00051     return new WriteTemplate( iface );
00052 }
00053
00054 WriteTemplate::WriteTemplate( Interface* impl ) : mbImpl( impl )
00055 {
00056     assert( impl != NULL );
00057
00058     impl->query_interface( mWriteIface );
00059
00060     // Initialize in case tag_get_handle fails below
00061     //! Get and cache predefined tag handles
00062     int negone = -1;
00063     impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
00064                           &negone );
00065
00066     impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
00067                           &negone );
00068
00069     impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
00070                           &negone );
00071
00072     mGlobalIdTag = impl->globalId_tag();
00073
00074     impl->tag_get_handle( "WriteTemplate element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT );
00075 }
00076
00077 WriteTemplate::~WriteTemplate()
00078 {
00079     mbImpl->release_interface( mWriteIface );
00080     mbImpl->tag_delete( mEntityMark );
00081 }
00082
00083 void WriteTemplate::reset_matset( std::vector< WriteTemplate::MaterialSetData >& matset_info )
00084 {
00085     std::vector< WriteTemplate::MaterialSetData >::iterator iter;
00086
00087     for( iter = matset_info.begin(); iter != matset_info.end(); ++iter )
00088         delete( *iter ).elements;
00089 }
00090
00091 ErrorCode WriteTemplate::write_file( const char* file_name,
00092                                      const bool /* overwrite (commented out to remove warning) */,
00093                                      const FileOptions& /*opts*/,
00094                                      const EntityHandle* ent_handles,
00095                                      const int num_sets,
00096                                      const std::vector< std::string >& /* qa_list */,
00097                                      const Tag* /* tag_list */,
00098                                      int /* num_tags */,
00099                                      int /* export_dimension */ )
00100 {
00101     assert( 0 != mMaterialSetTag && 0 != mNeumannSetTag && 0 != mDirichletSetTag );
00102
00103     // Check the file name
00104     if( NULL == strstr( file_name, ".template" ) ) return MB_FAILURE;
00105
00106     std::vector< EntityHandle > matsets, dirsets, neusets;
00107
00108     fileName = file_name;
00109
00110     // Separate into material sets, dirichlet sets, neumann sets
00111
00112     if( num_sets == 0 )
00113     {
00114         // Default to all defined sets
00115         Range this_range;
00116         mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mMaterialSetTag, NULL, 1, this_range );
00117         std::copy( this_range.begin(), this_range.end(), std::back_inserter( matsets ) );
00118         this_range.clear();
00119         mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mDirichletSetTag, NULL, 1, this_range );
00120         std::copy( this_range.begin(), this_range.end(), std::back_inserter( dirsets ) );
00121         this_range.clear();
00122         mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mNeumannSetTag, NULL, 1, this_range );
00123         std::copy( this_range.begin(), this_range.end(), std::back_inserter( neusets ) );
00124     }
00125     else
00126     {
00127         int dummy;
00128         for( const EntityHandle* iter = ent_handles; iter < ent_handles + num_sets; ++iter )
00129         {
00130             if( MB_SUCCESS == mbImpl->tag_get_data( mMaterialSetTag, &( *iter ), 1, &dummy ) )
00131                 matsets.push_back( *iter );
00132             else if( MB_SUCCESS == mbImpl->tag_get_data( mDirichletSetTag, &( *iter ), 1, &dummy ) )
00133                 dirsets.push_back( *iter );
00134             else if( MB_SUCCESS == mbImpl->tag_get_data( mNeumannSetTag, &( *iter ), 1, &dummy ) )
00135                 neusets.push_back( *iter );
00136         }
00137     }
00138
00139     // If there is nothing to write just return.
00140     if( matsets.empty() && dirsets.empty() && neusets.empty() ) return MB_FILE_WRITE_ERROR;
00141
00142     std::vector< WriteTemplate::MaterialSetData > matset_info;
00143     std::vector< WriteTemplate::DirichletSetData > dirset_info;
00144     std::vector< WriteTemplate::NeumannSetData > neuset_info;
00145
00146     MeshInfo mesh_info;
00147
00148     matset_info.clear();
00149     if( gather_mesh_information( mesh_info, matset_info, neuset_info, dirset_info, matsets, neusets, dirsets ) !=
00150         MB_SUCCESS )
00151     {
00152         reset_matset( matset_info );
00153         return MB_FAILURE;
00154     }
00155
00156     // Try to open the file after gather mesh info succeeds
00157     if( /* Test for file open failure */ false )
00158     {
00159         reset_matset( matset_info );
00160         return MB_FAILURE;
00161     }
00162
00163     if( initialize_file( mesh_info ) != MB_SUCCESS )
00164     {
00165         reset_matset( matset_info );
00166         return MB_FAILURE;
00167     }
00168
00169     if( write_nodes( mesh_info.num_nodes, mesh_info.nodes, mesh_info.num_dim ) != MB_SUCCESS )
00170     {
00171         reset_matset( matset_info );
00172         return MB_FAILURE;
00173     }
00174
00175     if( write_matsets( mesh_info, matset_info, neuset_info ) )
00176     {
00177         reset_matset( matset_info );
00178         return MB_FAILURE;
00179     }
00180
00181     return MB_SUCCESS;
00182 }
00183
00184 ErrorCode WriteTemplate::gather_mesh_information( MeshInfo& mesh_info,
00185                                                   std::vector< WriteTemplate::MaterialSetData >& matset_info,
00186                                                   std::vector< WriteTemplate::NeumannSetData >& neuset_info,
00187                                                   std::vector< WriteTemplate::DirichletSetData >& dirset_info,
00188                                                   std::vector< EntityHandle >& matsets,
00189                                                   std::vector< EntityHandle >& neusets,
00190                                                   std::vector< EntityHandle >& dirsets )
00191 {
00192     std::vector< EntityHandle >::iterator vector_iter, end_vector_iter;
00193
00194     mesh_info.num_nodes    = 0;
00195     mesh_info.num_elements = 0;
00196     mesh_info.num_matsets  = 0;
00197
00198     int id = 0;
00199
00200     vector_iter     = matsets.begin();
00201     end_vector_iter = matsets.end();
00202
00203     mesh_info.num_matsets = matsets.size();
00204
00205     std::vector< EntityHandle > parent_meshsets;
00206
00207     // Clean out the bits for the element mark
00208     mbImpl->tag_delete( mEntityMark );
00209     mbImpl->tag_get_handle( "WriteTemplate element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT );
00210
00211     int highest_dimension_of_element_matsets = 0;
00212
00213     for( vector_iter = matsets.begin(); vector_iter != matsets.end(); ++vector_iter )
00214     {
00215         WriteTemplate::MaterialSetData matset_data;
00216         matset_data.elements = new Range;
00217
00218         // For the purpose of qa records, get the parents of these matsets
00219         if( mbImpl->get_parent_meshsets( *vector_iter, parent_meshsets ) != MB_SUCCESS ) return MB_FAILURE;
00220
00221         // Get all Entity Handles in the mesh set
00222         Range dummy_range;
00223         mbImpl->get_entities_by_handle( *vector_iter, dummy_range, true );
00224
00225         // Find the dimension of the last entity in this range
00226         Range::iterator entity_iter = dummy_range.end();
00227         --entity_iter;
00228         int this_dim = CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) );
00229         entity_iter  = dummy_range.begin();
00230         while( entity_iter != dummy_range.end() && CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) ) != this_dim )
00231             ++entity_iter;
00232
00233         if( entity_iter != dummy_range.end() )
00234             std::copy( entity_iter, dummy_range.end(), range_inserter( *( matset_data.elements ) ) );
00235
00236         assert( matset_data.elements->begin() == matset_data.elements->end() ||
00237                 CN::Dimension( TYPE_FROM_HANDLE( *( matset_data.elements->begin() ) ) ) == this_dim );
00238
00239         // Get the matset's id
00240         if( mbImpl->tag_get_data( mMaterialSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS )
00241         {
00242             MB_SET_ERR( MB_FAILURE, "Couldn't get matset id from a tag for an element matset" );
00243         }
00244
00245         matset_data.id                = id;
00246         matset_data.number_attributes = 0;
00247
00248         // Iterate through all the elements in the meshset
00249         Range::iterator elem_range_iter, end_elem_range_iter;
00250         elem_range_iter     = matset_data.elements->begin();
00251         end_elem_range_iter = matset_data.elements->end();
00252
00253         // Get the entity type for this matset, verifying that it's the same for all elements
00254         // THIS ASSUMES HANDLES SORT BY TYPE!!!
00255         EntityType entity_type = TYPE_FROM_HANDLE( *elem_range_iter );
00256         --end_elem_range_iter;
00257         if( entity_type != TYPE_FROM_HANDLE( *( end_elem_range_iter++ ) ) )
00258         {
00259             MB_SET_ERR( MB_FAILURE, "Entities in matset " << id << " not of common type" );
00260         }
00261
00262         int dimension = CN::Dimension( entity_type );
00263
00264         if( dimension > highest_dimension_of_element_matsets ) highest_dimension_of_element_matsets = dimension;
00265
00266         matset_data.moab_type = mbImpl->type_from_handle( *( matset_data.elements->begin() ) );
00267         if( MBMAXTYPE == matset_data.moab_type ) return MB_FAILURE;
00268
00269         std::vector< EntityHandle > tmp_conn;
00270         mbImpl->get_connectivity( &( *( matset_data.elements->begin() ) ), 1, tmp_conn );
00271         matset_data.element_type =
00272             ExoIIUtil::get_element_type_from_num_verts( tmp_conn.size(), entity_type, dimension );
00273
00274         if( matset_data.element_type == EXOII_MAX_ELEM_TYPE )
00275         {
00276             MB_SET_ERR( MB_FAILURE, "Element type in matset " << id << " didn't get set correctly" );
00277         }
00278
00279         matset_data.number_nodes_per_element = ExoIIUtil::VerticesPerElement[matset_data.element_type];
00280
00281         // Number of nodes for this matset
00282         matset_data.number_elements = matset_data.elements->size();
00283
00284         // Total number of elements
00285         mesh_info.num_elements += matset_data.number_elements;
00286
00287         // Get the nodes for the elements
00288         mWriteIface->gather_nodes_from_elements( *matset_data.elements, mEntityMark, mesh_info.nodes );
00289
00290         if( !neusets.empty() )
00291         {
00292             // If there are neusets, keep track of which elements are being written out
00293             for( Range::iterator iter = matset_data.elements->begin(); iter != matset_data.elements->end(); ++iter )
00294             {
00295                 unsigned char bit = 0x1;
00296                 mbImpl->tag_set_data( mEntityMark, &( *iter ), 1, &bit );
00297             }
00298         }
00299
00300         matset_info.push_back( matset_data );
00301     }
00302
00303     // If user hasn't entered dimension, we figure it out
00304     if( mesh_info.num_dim == 0 )
00305     {
00306         // Never want 1 or zero dimensions
00307         if( highest_dimension_of_element_matsets < 2 )
00308             mesh_info.num_dim = 3;
00309         else
00310             mesh_info.num_dim = highest_dimension_of_element_matsets;
00311     }
00312
00313     Range::iterator range_iter, end_range_iter;
00314     range_iter     = mesh_info.nodes.begin();
00315     end_range_iter = mesh_info.nodes.end();
00316
00317     mesh_info.num_nodes = mesh_info.nodes.size();
00318
00319     //------dirsets--------
00320
00321     vector_iter     = dirsets.begin();
00322     end_vector_iter = dirsets.end();
00323
00324     for( ; vector_iter != end_vector_iter; ++vector_iter )
00325     {
00326         WriteTemplate::DirichletSetData dirset_data;
00327         dirset_data.id           = 0;
00328         dirset_data.number_nodes = 0;
00329
00330         // Get the dirset's id
00331         if( mbImpl->tag_get_data( mDirichletSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS )
00332         {
00333             MB_SET_ERR( MB_FAILURE, "Couldn't get id tag for dirset " << id );
00334         }
00335
00336         dirset_data.id = id;
00337
00338         std::vector< EntityHandle > node_vector;
00339         // Get the nodes of the dirset that are in mesh_info.nodes
00340         if( mbImpl->get_entities_by_handle( *vector_iter, node_vector, true ) != MB_SUCCESS )
00341         {
00342             MB_SET_ERR( MB_FAILURE, "Couldn't get nodes in dirset " << id );
00343         }
00344
00345         std::vector< EntityHandle >::iterator iter, end_iter;
00346         iter     = node_vector.begin();
00347         end_iter = node_vector.end();
00348
00349         int j                     = 0;
00350         unsigned char node_marked = 0;
00351         ErrorCode result;
00352         for( ; iter != end_iter; ++iter )
00353         {
00354             if( TYPE_FROM_HANDLE( *iter ) != MBVERTEX ) continue;
00355             result = mbImpl->tag_get_data( mEntityMark, &( *iter ), 1, &node_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
00356
00357             if( 0x1 == node_marked ) dirset_data.nodes.push_back( *iter );
00358             j++;
00359         }
00360
00361         dirset_data.number_nodes = dirset_data.nodes.size();
00362         dirset_info.push_back( dirset_data );
00363     }
00364
00365     //------neusets--------
00366     vector_iter     = neusets.begin();
00367     end_vector_iter = neusets.end();
00368
00369     for( ; vector_iter != end_vector_iter; ++vector_iter )
00370     {
00371         WriteTemplate::NeumannSetData neuset_data;
00372
00373         // Get the neuset's id
00374         if( mbImpl->tag_get_data( mNeumannSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS ) return MB_FAILURE;
00375
00376         neuset_data.id              = id;
00377         neuset_data.mesh_set_handle = *vector_iter;
00378
00379         // Get the sides in two lists, one forward the other reverse; starts with forward sense
00380         // by convention
00381         Range forward_elems, reverse_elems;
00382         if( get_neuset_elems( *vector_iter, 0, forward_elems, reverse_elems ) == MB_FAILURE ) return MB_FAILURE;
00383
00384         ErrorCode result = get_valid_sides( forward_elems, 1, neuset_data );MB_CHK_SET_ERR( result, "Couldn't get valid sides data" );
00385         result = get_valid_sides( reverse_elems, -1, neuset_data );MB_CHK_SET_ERR( result, "Couldn't get valid sides data" );
00386
00387         neuset_data.number_elements = neuset_data.elements.size();
00388         neuset_info.push_back( neuset_data );
00389     }
00390
00391     return MB_SUCCESS;
00392 }
00393
00394 ErrorCode WriteTemplate::get_valid_sides( Range& elems, const int sense, WriteTemplate::NeumannSetData& neuset_data )
00395 {
00396     // This is where we see if underlying element of side set element is included in output
00397
00398     unsigned char element_marked = 0;
00399     ErrorCode result;
00400     for( Range::iterator iter = elems.begin(); iter != elems.end(); ++iter )
00401     {
00402         // Should insert here if "side" is a quad/tri on a quad/tri mesh
00403         result = mbImpl->tag_get_data( mEntityMark, &( *iter ), 1, &element_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
00404
00405         if( 0x1 == element_marked )
00406         {
00407             neuset_data.elements.push_back( *iter );
00408
00409             // TJT TODO: the sense should really be # edges + 1or2
00410             neuset_data.side_numbers.push_back( ( sense == 1 ? 1 : 2 ) );
00411         }
00412         else
00413         {  // Then "side" is probably a quad/tri on a hex/tet mesh
00414             std::vector< EntityHandle > parents;
00415             int dimension = CN::Dimension( TYPE_FROM_HANDLE( *iter ) );
00416
00417             // Get the adjacent parent element of "side"
00418             if( mbImpl->get_adjacencies( &( *iter ), 1, dimension + 1, false, parents ) != MB_SUCCESS )
00419             {
00420                 MB_SET_ERR( MB_FAILURE, "Couldn't get adjacencies for neuset" );
00421             }
00422
00423             if( !parents.empty() )
00424             {
00425                 // Make sure the adjacent parent element will be output
00426                 for( unsigned int k = 0; k < parents.size(); k++ )
00427                 {
00428                     result = mbImpl->tag_get_data( mEntityMark, &( parents[k] ), 1, &element_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
00429
00430                     int side_no, this_sense, this_offset;
00431                     if( 0x1 == element_marked &&
00432                         mbImpl->side_number( parents[k], *iter, side_no, this_sense, this_offset ) == MB_SUCCESS &&
00433                         this_sense == sense )
00434                     {
00435                         neuset_data.elements.push_back( parents[k] );
00436                         neuset_data.side_numbers.push_back( side_no + 1 );
00437                         break;
00438                     }
00439                 }
00440             }
00441             else
00442             {
00443                 MB_SET_ERR( MB_FAILURE, "No parent element exists for element in neuset " << neuset_data.id );
00444             }
00445         }
00446     }
00447
00448     return MB_SUCCESS;
00449 }
00450
00451 ErrorCode WriteTemplate::write_nodes( const int num_nodes, const Range& nodes, const int dimension )
00452 {
00453     // See if should transform coordinates
00454     ErrorCode result;
00455     Tag trans_tag;
00456     result                = mbImpl->tag_get_handle( MESH_TRANSFORM_TAG_NAME, 16, MB_TYPE_DOUBLE, trans_tag );
00457     bool transform_needed = true;
00458     if( result == MB_TAG_NOT_FOUND ) transform_needed = false;
00459
00460     int num_coords_to_fill = transform_needed ? 3 : dimension;
00461
00462     std::vector< double* > coord_arrays( 3 );
00463     coord_arrays[0] = new double[num_nodes];
00464     coord_arrays[1] = new double[num_nodes];
00465     coord_arrays[2] = NULL;
00466
00467     if( num_coords_to_fill == 3 ) coord_arrays[2] = new double[num_nodes];
00468
00469     result = mWriteIface->get_node_coords( dimension, num_nodes, nodes, mGlobalIdTag, 0, coord_arrays );
00470     if( result != MB_SUCCESS )
00471     {
00472         delete[] coord_arrays[0];
00473         delete[] coord_arrays[1];
00474         if( coord_arrays[2] ) delete[] coord_arrays[2];
00475         return result;
00476     }
00477
00478     if( transform_needed )
00479     {
00480         double trans_matrix[16];
00481         const EntityHandle mesh = 0;
00482         result                  = mbImpl->tag_get_data( trans_tag, &mesh, 1, trans_matrix );MB_CHK_SET_ERR( result, "Couldn't get transform data" );
00483
00484         for( int i = 0; i < num_nodes; i++ )
00485         {
00486             double vec1[3];
00487             double vec2[3];
00488
00489             vec2[0] = coord_arrays[0][i];
00490             vec2[1] = coord_arrays[1][i];
00491             vec2[2] = coord_arrays[2][i];
00492
00493             for( int row = 0; row < 3; row++ )
00494             {
00495                 vec1[row] = 0.0;
00496                 for( int col = 0; col < 3; col++ )
00497                     vec1[row] += ( trans_matrix[( row * 4 ) + col] * vec2[col] );
00498             }
00499
00500             coord_arrays[0][i] = vec1[0];
00501             coord_arrays[1][i] = vec1[1];
00502             coord_arrays[2][i] = vec1[2];
00503         }
00504     }
00505
00506     // Write the nodes
00507
00508     /* Template - write nodes to file here in some way */
00509
00510     // Clean up
00511     delete[] coord_arrays[0];
00512     delete[] coord_arrays[1];
00513     if( coord_arrays[2] ) delete[] coord_arrays[2];
00514
00515     return MB_SUCCESS;
00516 }
00517
00518 ErrorCode WriteTemplate::write_matsets(
00519     MeshInfo& /* mesh_info (commented out to remove warning) */,
00520     std::vector< WriteTemplate::MaterialSetData >& matset_data,
00521     std::vector< WriteTemplate::NeumannSetData >& /* neuset_data (commented out to remove warning) */ )
00522 {
00523     unsigned int i;
00524     std::vector< int > connect;
00525     const EntityHandle* connecth;
00526     int num_connecth;
00527     ErrorCode result;
00528
00529     // Don't usually have anywhere near 31 nodes per element
00530     connect.reserve( 31 );
00531     Range::iterator rit;
00532
00533     WriteTemplate::MaterialSetData matset;
00534     for( i = 0; i < matset_data.size(); i++ )
00535     {
00536         matset = matset_data[i];
00537
00538         for( rit = matset.elements->begin(); rit != matset.elements->end(); ++rit )
00539         {
00540             // Get the connectivity of this element
00541             result = mbImpl->get_connectivity( *rit, connecth, num_connecth );
00542             if( MB_SUCCESS != result ) return result;
00543
00544             // Get the vertex ids
00545             result = mbImpl->tag_get_data( mGlobalIdTag, connecth, num_connecth, &connect[0] );
00546             if( MB_SUCCESS != result ) return result;
00547
00548             // Write the data
00549             /* Template - write element connectivity here */
00550
00551             if( /* Template - check for error condition! */ false ) return MB_FAILURE;
00552         }
00553     }
00554
00555     return MB_SUCCESS;
00556 }
00557
00558 ErrorCode WriteTemplate::initialize_file( MeshInfo& mesh_info )
00559 {
00560     // Perform the initializations
00561
00562     int coord_size, ncoords;
00563
00564     coord_size = mesh_info.num_dim;
00565     std::cout << "Coord_size = " << coord_size << std::endl;
00566     /* Template - write coord size */
00567
00568     ncoords = mesh_info.num_nodes;
00569     std::cout << "ncoords = " << ncoords << std::endl;
00570     /* Template - write num nodes*/
00571
00572     /* Template - write information on the element types & numbers (depends
00573        on material and other sets) */
00574
00575     /* Node coordinate arrays: */
00576     /* Template - initialize variable to hold coordinate arrays */
00577
00578     return MB_SUCCESS;
00579 }
00580
00581 ErrorCode WriteTemplate::open_file( const char* filename )
00582 {
00583     // Not a valid filename
00584     if( strlen( (const char*)filename ) == 0 )
00585     {
00586         MB_SET_ERR( MB_FAILURE, "Output filename not specified" );
00587     }
00588
00589     /* Template - open file & store somewhere */
00590
00591     // File couldn't be opened
00592     if( /* Template - check for file open error here! */ false )
00593     {
00594         MB_SET_ERR( MB_FAILURE, "Cannot open " << filename );
00595     }
00596
00597     return MB_SUCCESS;
00598 }
00599
00600 ErrorCode WriteTemplate::get_neuset_elems( EntityHandle neuset,
00601                                            int current_sense,
00602                                            Range& forward_elems,
00603                                            Range& reverse_elems )
00604 {
00605     Range neuset_elems, neuset_meshsets;
00606
00607     // Get the sense tag; don't need to check return, might be an error if the tag
00608     // hasn't been created yet
00609     Tag sense_tag = 0;
00610     mbImpl->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, sense_tag );
00611
00612     // Get the entities in this set
00613     ErrorCode result = mbImpl->get_entities_by_handle( neuset, neuset_elems, true );
00614     if( MB_FAILURE == result ) return result;
00615
00616     // Now remove the meshsets into the neuset_meshsets; first find the first meshset,
00617     Range::iterator range_iter = neuset_elems.begin();
00618     while( TYPE_FROM_HANDLE( *range_iter ) != MBENTITYSET && range_iter != neuset_elems.end() )
00619         ++range_iter;
00620
00621     // Then, if there are some, copy them into neuset_meshsets and erase from neuset_elems
00622     if( range_iter != neuset_elems.end() )
00623     {
00624         std::copy( range_iter, neuset_elems.end(), range_inserter( neuset_meshsets ) );
00625         neuset_elems.erase( range_iter, neuset_elems.end() );
00626     }
00627
00628     // OK, for the elements, check the sense of this set and copy into the right range
00629     // (if the sense is 0, copy into both ranges)
00630
00631     // Need to step forward on list until we reach the right dimension
00632     Range::iterator dum_it = neuset_elems.end();
00633     --dum_it;
00634     int target_dim = CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) );
00635     dum_it         = neuset_elems.begin();
00636     while( target_dim != CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) ) && dum_it != neuset_elems.end() )
00637         ++dum_it;
00638
00639     if( current_sense == 1 || current_sense == 0 )
00640         std::copy( dum_it, neuset_elems.end(), range_inserter( forward_elems ) );
00641     if( current_sense == -1 || current_sense == 0 )
00642         std::copy( dum_it, neuset_elems.end(), range_inserter( reverse_elems ) );
00643
00644     // Now loop over the contained meshsets, getting the sense of those and calling this
00645     // function recursively
00646     for( range_iter = neuset_meshsets.begin(); range_iter != neuset_meshsets.end(); ++range_iter )
00647     {
00648         // First get the sense; if it's not there, by convention it's forward
00649         int this_sense;
00650         if( 0 == sense_tag || MB_FAILURE == mbImpl->tag_get_data( sense_tag, &( *range_iter ), 1, &this_sense ) )
00651             this_sense = 1;
00652
00653         // Now get all the entities on this meshset, with the proper (possibly reversed) sense
00654         get_neuset_elems( *range_iter, this_sense * current_sense, forward_elems, reverse_elems );
00655     }
00656
00657     return result;
00658 }
00659
00660 }  // namespace moab
