ZoltanPartitioner.cpp
00001 /* $Id$
00002  *
00003  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00004  * storing and accessing finite element mesh data.
00005  *
00006  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00007  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00008  * retains certain rights in this software.
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or (at your option) any later version.
00014  *
00015  */
00016
00017 /** Get a mesh from MOAB and write a Zoltan partition set back into MOAB and to
00018  *  a file
00019  *
00020  *
00021  */
00022
00023 #include <iostream>
00024 #include <cassert>
00025 #include <sstream>
00026 #include <algorithm>
00027
00028 #include "moab/ZoltanPartitioner.hpp"
00029 #include "moab/Interface.hpp"
00030 #include "Internals.hpp"
00031 #include "moab/Range.hpp"
00032 #include "moab/WriteUtilIface.hpp"
00033 #include "moab/MeshTopoUtil.hpp"
00034 #include "MBTagConventions.hpp"
00035 #include "moab/CN.hpp"
00036 // used for gnomonic projection
00037 #include "moab/IntxMesh/IntxUtils.hpp"
00038
00039 #ifdef MOAB_HAVE_CGM
00040 #include "CGMConfig.h"
00041 #include <limits>
00042 #include "RefEntity.hpp"
00043 #include "RefFace.hpp"
00044 #include "RefEdge.hpp"
00045 #include "RefVertex.hpp"
00046 #include "Body.hpp"
00047 #include "TopologyEntity.hpp"
00048 #include "CastTo.hpp"
00049 #include "CABodies.hpp"
00050 #include "TDParallel.hpp"
00051 #include "TDUniqueId.hpp"
00052 #endif
00053
00054 using namespace moab;
00055
00056 #define RR \
00057     if( MB_SUCCESS != result ) return result
00058
00059 static double* Points      = NULL;
00060 static int* GlobalIds      = NULL;
00061 static int NumPoints       = 0;
00062 static int* NumEdges       = NULL;
00063 static int* NborGlobalId   = NULL;
00064 static int* NborProcs      = NULL;
00065 static double* ObjWeights  = NULL;
00066 static double* EdgeWeights = NULL;
00067 static int* Parts          = NULL;
00068
00069 const bool debug = false;
00070
00071 ZoltanPartitioner::ZoltanPartitioner( Interface* impl,
00072 #ifdef MOAB_HAVE_MPI
00073                                       ParallelComm* parcomm,
00074 #endif
00075                                       const bool use_coords,
00076                                       int argc,
00077                                       char** argv
00078 #ifdef MOAB_HAVE_CGM
00079                                       ,
00080                                       GeometryQueryTool* gqt
00081 #endif
00082
00083                                       )
00084     : PartitionerBase< int >( impl,
00085                               use_coords
00086 #ifdef MOAB_HAVE_MPI
00087                               ,
00088                               parcomm
00089 #endif
00090                               ),
00091       myZZ( NULL ), myNumPts( 0 ), argcArg( argc ), argvArg( argv )
00092 #ifdef MOAB_HAVE_CGM
00093       ,
00094       gti( gqt )
00095 #endif
00096 {
00097 }
00098
00099 ZoltanPartitioner::~ZoltanPartitioner()
00100 {
00101     if( NULL != myZZ ) delete myZZ;
00102 }
00103
00104 ErrorCode ZoltanPartitioner::balance_mesh( const char* zmethod,
00105                                            const char* other_method,
00106                                            const bool write_as_sets,
00107                                            const bool write_as_tags )
00108 {
00109     if( !strcmp( zmethod, "RR" ) && !strcmp( zmethod, "RCB" ) && !strcmp( zmethod, "RIB" ) &&
00110         !strcmp( zmethod, "HSFC" ) && !strcmp( zmethod, "Hypergraph" ) && !strcmp( zmethod, "PHG" ) &&
00111         !strcmp( zmethod, "PARMETIS" ) && !strcmp( zmethod, "OCTPART" ) )
00112     {
00113         std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be "
00114                   << "RR, RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl;
00115         return MB_FAILURE;
00116     }
00117
00118     std::vector< double > pts;  // x[0], y[0], z[0], ... from MOAB
00119     std::vector< int > ids;     // point ids from MOAB
00120     std::vector< int > adjs, length;
00121     Range elems;
00122
00123     // Get a mesh from MOAB and divide it across processors.
00124
00125     ErrorCode result;
00126
00127     if( mbpc->proc_config().proc_rank() == 0 )
00128     {
00129         result = assemble_graph( 3, pts, ids, adjs, length, elems );RR;
00130     }
00131
00132     myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0] );
00133
00134     // Initialize Zoltan.  This is a C call.  The simple C++ code
00135     // that creates Zoltan objects does not keep track of whether
00136     // Zoltan_Initialize has been called.
00137
00138     float version;
00139
00140     Zoltan_Initialize( argcArg, argvArg, &version );
00141
00142     // Create Zoltan object.  This calls Zoltan_Create.
00143     if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
00144
00145     if( NULL == zmethod || !strcmp( zmethod, "RCB" ) )
00146         SetRCB_Parameters();
00147     else if( !strcmp( zmethod, "RIB" ) )
00148         SetRIB_Parameters();
00149     else if( !strcmp( zmethod, "HSFC" ) )
00150         SetHSFC_Parameters();
00151     else if( !strcmp( zmethod, "Hypergraph" ) || !strcmp( zmethod, "PHG" ) )
00152         if( NULL == other_method )
00153             SetHypergraph_Parameters( "auto" );
00154         else
00155             SetHypergraph_Parameters( other_method );
00156     else if( !strcmp( zmethod, "PARMETIS" ) )
00157     {
00158         if( NULL == other_method )
00159             SetPARMETIS_Parameters( "RepartGDiffusion" );
00160         else
00161             SetPARMETIS_Parameters( other_method );
00162     }
00163     else if( !strcmp( zmethod, "OCTPART" ) )
00164     {
00165         if( NULL == other_method )
00166             SetOCTPART_Parameters( "2" );
00167         else
00168             SetOCTPART_Parameters( other_method );
00169     }
00170
00171     // Call backs:
00172
00173     myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL );
00174     myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL );
00175     myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL );
00176     myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL );
00177     myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL );
00178     myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL );
00179
00180     // Perform the load balancing partitioning
00181
00182     int changes;
00183     int numGidEntries;
00184     int numLidEntries;
00185     int numImport;
00186     ZOLTAN_ID_PTR importGlobalIds;
00187     ZOLTAN_ID_PTR importLocalIds;
00188     int* importProcs;
00189     int* importToPart;
00190     int numExport;
00191     ZOLTAN_ID_PTR exportGlobalIds;
00192     ZOLTAN_ID_PTR exportLocalIds;
00193     int* exportProcs;
00194     int* exportToPart;
00195
00196     int rc = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, numImport, importGlobalIds, importLocalIds,
00197                                  importProcs, importToPart, numExport, exportGlobalIds, exportLocalIds, exportProcs,
00198                                  exportToPart );
00199
00200     rc = mbGlobalSuccess( rc );
00201
00202     if( !rc )
00203     {
00204         mbPrintGlobalResult( "==============Result==============", myNumPts, numImport, numExport, changes );
00205     }
00206     else
00207     {
00208         return MB_FAILURE;
00209     }
00210
00211     // take results & write onto MOAB partition sets
00212
00213     int* assignment;
00214
00215     mbFinalizePoints( (int)ids.size(), numExport, exportLocalIds, exportProcs, &assignment );
00216
00217     if( mbpc->proc_config().proc_rank() == 0 )
00218     {
00219         result = write_partition( mbpc->proc_config().proc_size(), elems, assignment, write_as_sets, write_as_tags );
00220
00221         if( MB_SUCCESS != result ) return result;
00222
00223         free( (int*)assignment );
00224     }
00225
00226     // Free the memory allocated for lists returned by LB_Parition()
00227
00228     myZZ->LB_Free_Part( &importGlobalIds, &importLocalIds, &importProcs, &importToPart );
00229     myZZ->LB_Free_Part( &exportGlobalIds, &exportLocalIds, &exportProcs, &exportToPart );
00230
00231     // Implementation note:  A Zoltan object contains an MPI communicator.
00232     //   When the Zoltan object is destroyed, it uses it's MPI communicator.
00233     //   So it is important that the Zoltan object is destroyed before
00234     //   the MPI communicator is destroyed.  To ensure this, dynamically
00235     //   allocate the Zoltan object, so you can explicitly destroy it.
00236     //   If you create a Zoltan object on the stack, it's destructor will
00237     //   be invoked atexit, possibly after the communicator's
00238     //   destructor.
00239
00240     return MB_SUCCESS;
00241 }
00242
00243 ErrorCode ZoltanPartitioner::repartition( std::vector< double >& x,
00244                                           std::vector< double >& y,
00245                                           std::vector< double >& z,
00246                                           int StartID,
00247                                           const char* zmethod,
00248                                           Range& localGIDs )
00249 {
00250     //
00251     int nprocs = mbpc->proc_config().proc_size();
00252     int rank   = mbpc->proc_config().proc_rank();
00253     clock_t t  = clock();
00254     // form pts and ids, as in assemble_graph
00255     std::vector< double > pts;  // x[0], y[0], z[0], ... from MOAB
00256     pts.resize( x.size() * 3 );
00257     std::vector< int > ids;  // point ids from MOAB
00258     ids.resize( x.size() );
00259     for( size_t i = 0; i < x.size(); i++ )
00260     {
00261         pts[3 * i]     = x[i];
00262         pts[3 * i + 1] = y[i];
00263         pts[3 * i + 2] = z[i];
00264         ids[i]         = StartID + (int)i;
00265     }
00266     // do not get out until done!
00267
00268     Points       = &pts[0];
00269     GlobalIds    = &ids[0];
00270     NumPoints    = (int)x.size();
00271     NumEdges     = NULL;
00272     NborGlobalId = NULL;
00273     NborProcs    = NULL;
00274     ObjWeights   = NULL;
00275     EdgeWeights  = NULL;
00276     Parts        = NULL;
00277
00278     float version;
00279     if( rank == 0 ) std::cout << "Initializing zoltan..." << std::endl;
00280
00281     Zoltan_Initialize( argcArg, argvArg, &version );
00282
00283     // Create Zoltan object.  This calls Zoltan_Create.
00284     if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
00285
00286     if( NULL == zmethod || !strcmp( zmethod, "RCB" ) )
00287         SetRCB_Parameters();
00288     else if( !strcmp( zmethod, "RIB" ) )
00289         SetRIB_Parameters();
00290     else if( !strcmp( zmethod, "HSFC" ) )
00291         SetHSFC_Parameters();
00292
00293     // set # requested partitions
00294     char buff[10];
00295     sprintf( buff, "%d", nprocs );
00296     int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff );
00297     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00298
00299     // request all, import and export
00300     retval = myZZ->Set_Param( "RETURN_LISTS", "ALL" );
00301     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00302
00303     myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL );
00304     myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL );
00305     myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL );
00306     myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL );
00307     myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL );
00308     myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL );
00309
00310     // Perform the load balancing partitioning
00311
00312     int changes;
00313     int numGidEntries;
00314     int numLidEntries;
00315     int num_import;
00316     ZOLTAN_ID_PTR import_global_ids, import_local_ids;
00317     int* import_procs;
00318     int* import_to_part;
00319     int num_export;
00320     ZOLTAN_ID_PTR export_global_ids, export_local_ids;
00321     int *assign_procs, *assign_parts;
00322
00323     if( rank == 0 )
00324         std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nprocs
00325                   << " processors..." << std::endl;
00326
00327     retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids, import_local_ids,
00328                                  import_procs, import_to_part, num_export, export_global_ids, export_local_ids,
00329                                  assign_procs, assign_parts );
00330     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00331
00332     if( rank == 0 )
00333     {
00334         std::cout << " time to LB_partition " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
00335         t = clock();
00336     }
00337
00338     std::sort( import_global_ids, import_global_ids + num_import, std::greater< int >() );
00339     std::sort( export_global_ids, export_global_ids + num_export, std::greater< int >() );
00340
00341     Range iniGids( (EntityHandle)StartID, (EntityHandle)StartID + x.size() - 1 );
00342     Range imported, exported;
00343     std::copy( import_global_ids, import_global_ids + num_import, range_inserter( imported ) );
00344     std::copy( export_global_ids, export_global_ids + num_export, range_inserter( exported ) );
00345     localGIDs = subtract( iniGids, exported );
00346     localGIDs = unite( localGIDs, imported );
00347     // Free data structures allocated by Zoltan::LB_Partition
00348     retval = myZZ->LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part );
00349     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00350     retval = myZZ->LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts );
00351     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00352
00353     return MB_SUCCESS;
00354 }
00355
00356 ErrorCode ZoltanPartitioner::partition_inferred_mesh( EntityHandle sfileset,
00357                                                       size_t num_parts,
00358                                                       int part_dim,
00359                                                       const bool write_as_sets,
00360                                                       int projection_type )
00361 {
00362     ErrorCode result;
00363
00364     moab::Range elverts;
00365     result = mbImpl->get_entities_by_dimension( sfileset, part_dim, elverts );RR;
00366
00367     std::vector< double > elcoords( elverts.size() * 3 );
00368     result = mbImpl->get_coords( elverts, &elcoords[0] );RR;
00369
00370     std::vector< std::vector< EntityHandle > > part_assignments( num_parts );
00371     int part, proc;
00372
00373     // Loop over coordinates
00374     for( size_t iel = 0; iel < elverts.size(); iel++ )
00375     {
00376         // Gather coordinates into temporary array
00377         double* ecoords = &elcoords[iel * 3];
00378
00379         // do a projection if needed
00380         if( projection_type > 0 ) IntxUtils::transform_coordinates( ecoords, projection_type );
00381
00382         // Compute the coordinate's part assignment
00383         myZZ->LB_Point_PP_Assign( ecoords, proc, part );
00384
00385         // Store the part assignment in the return array
00386         part_assignments[part].push_back( elverts[iel] );
00387     }
00388
00389     // get the partition set tag
00390     Tag part_set_tag = mbpc->partition_tag();
00391
00392     // If some entity sets exist, let us delete those first.
00393     if( write_as_sets )
00394     {
00395         moab::Range oldpsets;
00396         result = mbImpl->get_entities_by_type_and_tag( sfileset, MBENTITYSET, &part_set_tag, NULL, 1, oldpsets,
00397                                                        Interface::UNION );RR;
00398         result = mbImpl->remove_entities( sfileset, oldpsets );RR;
00399     }
00400
00401     size_t nparts_assigned = 0;
00402     for( size_t partnum = 0; partnum < num_parts; ++partnum )
00403     {
00404         std::vector< EntityHandle >& partvec = part_assignments[partnum];
00405
00406         nparts_assigned += ( partvec.size() ? 1 : 0 );
00407
00408         if( write_as_sets )
00409         {
00410             EntityHandle partNset;
00411             result = mbImpl->create_meshset( moab::MESHSET_SET, partNset );RR;
00412             if( partvec.size() )
00413             {
00414                 result = mbImpl->add_entities( partNset, &partvec[0], partvec.size() );RR;
00415             }
00416             result = mbImpl->add_parent_child( sfileset, partNset );RR;
00417
00418             // part numbering should start from 0
00419             int ipartnum = (int)partnum;
00420
00421             // assign partitions as a sparse tag by grouping elements under sets
00422             result = mbImpl->tag_set_data( part_set_tag, &partNset, 1, &ipartnum );RR;
00423         }
00424         else
00425         {
00426             /* assign as a dense vector to all elements
00427                allocate integer-size partitions */
00428             std::vector< int > assignment( partvec.size(),
00429                                            partnum );  // initialize all values to partnum
00430             result = mbImpl->tag_set_data( part_set_tag, &partvec[0], partvec.size(), &assignment[0] );RR;
00431         }
00432     }
00433
00434     if( nparts_assigned != num_parts )
00435     {
00436         std::cout << "WARNING: The inference yielded lesser number of parts (" << nparts_assigned
00437                   << ") than requested by user (" << num_parts << ").\n";
00438     }
00439
00440     return MB_SUCCESS;
00441 }
00442
00443 ErrorCode ZoltanPartitioner::partition_mesh_and_geometry( const double part_geom_mesh_size,
00444                                                           const int nparts,
00445                                                           const char* zmethod,
00446                                                           const char* other_method,
00447                                                           double imbal_tol,
00448                                                           const int part_dim,
00449                                                           const bool write_as_sets,
00450                                                           const bool write_as_tags,
00451                                                           const int obj_weight,
00452                                                           const int edge_weight,
00453 #ifdef MOAB_HAVE_CGM
00454                                                           const bool part_surf,
00455                                                           const bool ghost,
00456 #else
00457                                                           const bool,
00458                                                           const bool,
00459 #endif
00460                                                           const int projection_type,
00461                                                           const bool recompute_rcb_box,
00462                                                           const bool print_time )
00463 {
00464     // should only be called in serial
00465     if( mbpc->proc_config().proc_size() != 1 )
00466     {
00467         std::cout << "ZoltanPartitioner::partition_mesh_and_geometry must be called in serial." << std::endl;
00468         return MB_FAILURE;
00469     }
00470     clock_t t = clock();
00471     if( NULL != zmethod && strcmp( zmethod, "RR" ) && strcmp( zmethod, "RCB" ) && strcmp( zmethod, "RIB" ) &&
00472         strcmp( zmethod, "HSFC" ) && strcmp( zmethod, "Hypergraph" ) && strcmp( zmethod, "PHG" ) &&
00473         strcmp( zmethod, "PARMETIS" ) && strcmp( zmethod, "OCTPART" ) )
00474     {
00475         std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be "
00476                   << "RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART" << std::endl;
00477         return MB_FAILURE;
00478     }
00479
00480     bool part_geom = false;
00481     if( 0 == strcmp( zmethod, "RR" ) || 0 == strcmp( zmethod, "RCB" ) || 0 == strcmp( zmethod, "RIB" ) ||
00482         0 == strcmp( zmethod, "HSFC" ) )
00483         part_geom = true;       // so no adjacency / edges needed
00484     std::vector< double > pts;  // x[0], y[0], z[0], ... from MOAB
00485     std::vector< int > ids;     // point ids from MOAB
00486     std::vector< int > adjs, length, parts;
00487     std::vector< double > obj_weights, edge_weights;
00488     Range elems;
00489 #ifdef MOAB_HAVE_CGM
00490     DLIList< RefEntity* > entities;
00491 #endif
00492
00493     // Get a mesh from MOAB and diide it across processors.
00494
00495     ErrorCode result = MB_SUCCESS;
00496
00497     // short-circuit everything if RR partition is requested
00498     if( !strcmp( zmethod, "RR" ) )
00499     {
00500         if( part_geom_mesh_size < 0. )
00501         {
00502             // get all elements
00503             result = mbImpl->get_entities_by_dimension( 0, part_dim, elems );RR;
00504             if( elems.empty() ) return MB_FAILURE;
00505             // make a trivial assignment vector
00506             std::vector< int > assign_vec( elems.size() );
00507             int num_per = elems.size() / nparts;
00508             int extra   = elems.size() % nparts;
00509             if( extra ) num_per++;
00510             int nstart = 0;
00511             for( int i = 0; i < nparts; i++ )
00512             {
00513                 if( i == extra ) num_per--;
00514                 std::fill( &assign_vec[nstart], &assign_vec[nstart + num_per], i );
00515                 nstart += num_per;
00516             }
00517
00518             result = write_partition( nparts, elems, &assign_vec[0], write_as_sets, write_as_tags );RR;
00519         }
00520         else
00521         {
00522 #ifdef MOAB_HAVE_CGM
00523             result = partition_round_robin( nparts );RR;
00524 #endif
00525         }
00526
00527         return result;
00528     }
00529
00530     std::cout << "Assembling graph..." << std::endl;
00531
00532     if( part_geom_mesh_size < 0. )
00533     {
00534         // if (!part_geom) {
00535         result = assemble_graph( part_dim, pts, ids, adjs, length, elems, part_geom, projection_type );RR;
00536     }
00537     else
00538     {
00539 #ifdef MOAB_HAVE_CGM
00540         result = assemble_graph( part_dim, pts, ids, adjs, length, obj_weights, edge_weights, parts, entities,
00541                                  part_geom_mesh_size, nparts );RR;
00542
00543         if( debug )
00544         {
00545             int n_ids = ids.size();
00546             entities.reset();
00547             int i_leng = 0;
00548             for( int i = 0; i < n_ids; i++ )
00549             {
00550                 std::cout << "graph_input_ids[" << i << "]=" << ids[i] << ",obj_weights=" << obj_weights[i]
00551                           << ",entity_id=" << entities.get_and_step()->id() << ",part=" << parts[i] << std::endl;
00552                 for( int j = 0; j < length[i]; j++ )
00553                 {
00554                     std::cout << "adjs[" << j << "]=" << adjs[i_leng] << ",edge_weights=" << edge_weights[i_leng]
00555                               << std::endl;
00556                     i_leng++;
00557                 }
00558             }
00559         }
00560 #endif
00561     }
00562     if( print_time )
00563     {
00564         std::cout << " time to assemble graph: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
00565         t = clock();
00566     }
00567     double* o_wgt = NULL;
00568     double* e_wgt = NULL;
00569     if( obj_weights.size() > 0 ) o_wgt = &obj_weights[0];
00570     if( edge_weights.size() > 0 ) e_wgt = &edge_weights[0];
00571
00572     myNumPts = mbInitializePoints( (int)ids.size(), &pts[0], &ids[0], &adjs[0], &length[0], o_wgt, e_wgt, &parts[0],
00573                                    part_geom );
00574
00575     // Initialize Zoltan.  This is a C call.  The simple C++ code
00576     // that creates Zoltan objects does not keep track of whether
00577     // Zoltan_Initialize has been called.
00578
00579     if( print_time )
00580     {
00581         std::cout << " time to initialize points: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
00582         t = clock();
00583     }
00584     float version;
00585
00586     std::cout << "Initializing zoltan..." << std::endl;
00587
00588     Zoltan_Initialize( argcArg, argvArg, &version );
00589
00590     // Create Zoltan object.  This calls Zoltan_Create.
00591     if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
00592
00593     if( NULL == zmethod || !strcmp( zmethod, "RCB" ) )
00594     {
00595         if( projection_type == 2 )
00596             SetRCB_Parameters( true );
00597         else
00598             SetRCB_Parameters( recompute_rcb_box );
00599     }
00600     else if( !strcmp( zmethod, "RIB" ) )
00601         SetRIB_Parameters();
00602     else if( !strcmp( zmethod, "HSFC" ) )
00603         SetHSFC_Parameters();
00604     else if( !strcmp( zmethod, "Hypergraph" ) || !strcmp( zmethod, "PHG" ) )
00605     {
00606         if( NULL == other_method || ( other_method[0] == '\0' ) )
00607             SetHypergraph_Parameters( "auto" );
00608         else
00609             SetHypergraph_Parameters( other_method );
00610
00611         if( imbal_tol )
00612         {
00613             std::ostringstream str;
00614             str << imbal_tol;
00615             myZZ->Set_Param( "IMBALANCE_TOL", str.str().c_str() );  // no debug messages
00616         }
00617     }
00618     else if( !strcmp( zmethod, "PARMETIS" ) )
00619     {
00620         if( NULL == other_method )
00621             SetPARMETIS_Parameters( "RepartGDiffusion" );
00622         else
00623             SetPARMETIS_Parameters( other_method );
00624     }
00625     else if( !strcmp( zmethod, "OCTPART" ) )
00626     {
00627         if( NULL == other_method )
00628             SetOCTPART_Parameters( "2" );
00629         else
00630             SetOCTPART_Parameters( other_method );
00631     }
00632
00633     // set # requested partitions
00634     char buff[10];
00635     sprintf( buff, "%d", nparts );
00636     int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff );
00637     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00638
00639     // request only partition assignments
00640     retval = myZZ->Set_Param( "RETURN_LISTS", "PARTITION ASSIGNMENTS" );
00641     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00642
00643     if( obj_weight > 0 )
00644     {
00645         std::ostringstream str;
00646         str << obj_weight;
00647         retval = myZZ->Set_Param( "OBJ_WEIGHT_DIM", str.str().c_str() );
00648         if( ZOLTAN_OK != retval ) return MB_FAILURE;
00649     }
00650
00651     if( edge_weight > 0 )
00652     {
00653         std::ostringstream str;
00654         str << edge_weight;
00655         retval = myZZ->Set_Param( "EDGE_WEIGHT_DIM", str.str().c_str() );
00656         if( ZOLTAN_OK != retval ) return MB_FAILURE;
00657     }
00658
00659     // Call backs:
00660
00661     myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL );
00662     myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL );
00663     myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL );
00664     myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL );
00665     myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL );
00666     myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL );
00667     if( part_geom_mesh_size > 0. )
00668     {
00669         myZZ->Set_Part_Multi_Fn( mbGetPart, NULL );
00670     }
00671
00672     // Perform the load balancing partitioning
00673
00674     int changes;
00675     int numGidEntries;
00676     int numLidEntries;
00677     int dumnum1;
00678     ZOLTAN_ID_PTR dum_local, dum_global;
00679     int *dum1, *dum2;
00680     int num_assign;
00681     ZOLTAN_ID_PTR assign_gid, assign_lid;
00682     int *assign_procs, *assign_parts;
00683
00684     std::cout << "Computing partition using " << ( zmethod ? zmethod : "RCB" ) << " method for " << nparts
00685               << " processors..." << std::endl;
00686 #ifndef NDEBUG
00687 #if 0
00688   if (NULL == zmethod || !strcmp(zmethod, "RCB"))
00689     Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 1, 0, 0);
00690
00691   if ( !strcmp(zmethod, "PHG"))
00692       Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)zmethod, 1, 0, 1, 1);
00693 #endif
00694 #endif
00695     retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, dumnum1, dum_global, dum_local, dum1, dum2,
00696                                  num_assign, assign_gid, assign_lid, assign_procs, assign_parts );
00697     if( ZOLTAN_OK != retval ) return MB_FAILURE;
00698
00699     if( print_time )
00700     {
00701         std::cout << " time to LB_partition " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
00702         t = clock();
00703     }
00704     // take results & write onto MOAB partition sets
00705     std::cout << "Saving partition information to MOAB..." << std::endl;
00706
00707     if( part_geom_mesh_size < 0. )
00708     {
00709         // if (!part_geom) {
00710         result = write_partition( nparts, elems, assign_parts, write_as_sets, write_as_tags );
00711     }
00712     else
00713     {
00714 #ifdef MOAB_HAVE_CGM
00715         result = write_partition( nparts, entities, assign_parts, obj_weights, part_surf, ghost );
00716 #endif
00717     }
00718
00719     if( print_time )
00720     {
00721         std::cout << " time to write partition in memory " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n";
00722         t = clock();
00723     }
00724
00725     if( MB_SUCCESS != result ) return result;
00726
00727     // Free the memory allocated for lists returned by LB_Parition()
00728     myZZ->LB_Free_Part( &assign_gid, &assign_lid, &assign_procs, &assign_parts );
00729
00730     return MB_SUCCESS;
00731 }
00732
00733 ErrorCode ZoltanPartitioner::include_closure()
00734 {
00735     ErrorCode result;
00736     Range ents;
00737     Range adjs;
00738     std::cout << "Adding closure..." << std::endl;
00739
00740     for( Range::iterator rit = partSets.begin(); rit != partSets.end(); ++rit )
00741     {
00742
00743         // get the top-dimensional entities in the part
00744         result = mbImpl->get_entities_by_handle( *rit, ents, true );RR;
00745
00746         if( ents.empty() ) continue;
00747
00748         // get intermediate-dimensional adjs and add to set
00749         for( int d = mbImpl->dimension_from_handle( *ents.begin() ) - 1; d >= 1; d-- )
00750         {
00751             adjs.clear();
00752             result = mbImpl->get_adjacencies( ents, d, false, adjs, Interface::UNION );RR;
00753             result = mbImpl->add_entities( *rit, adjs );RR;
00754         }
00755
00756         // now get vertices and add to set; only need to do for ents, not for adjs
00757         adjs.clear();
00758         result = mbImpl->get_adjacencies( ents, 0, false, adjs, Interface::UNION );RR;
00759         result = mbImpl->add_entities( *rit, adjs );RR;
00760
00761         ents.clear();
00762     }
00763
00764     // now go over non-part entity sets, looking for contained entities
00765     Range sets, part_ents;
00766     result = mbImpl->get_entities_by_type( 0, MBENTITYSET, sets );RR;
00767     for( Range::iterator rit = sets.begin(); rit != sets.end(); ++rit )
00768     {
00769         // skip parts
00770         if( partSets.find( *rit ) != partSets.end() ) continue;
00771
00772         // get entities in this set, recursively
00773         ents.clear();
00774         result = mbImpl->get_entities_by_handle( *rit, ents, true );RR;
00775
00776         // now check over all parts
00777         for( Range::iterator rit2 = partSets.begin(); rit2 != partSets.end(); ++rit2 )
00778         {
00779             part_ents.clear();
00780             result = mbImpl->get_entities_by_handle( *rit2, part_ents, false );RR;
00781             Range int_range = intersect( ents, part_ents );
00782             if( !int_range.empty() )
00783             {
00784                 // non-empty intersection, add to part set
00785                 result = mbImpl->add_entities( *rit2, &( *rit ), 1 );RR;
00786             }
00787         }
00788     }
00789
00790     // finally, mark all the part sets as having the closure
00791     Tag closure_tag;
00792     result =
00793         mbImpl->tag_get_handle( "INCLUDES_CLOSURE", 1, MB_TYPE_INTEGER, closure_tag, MB_TAG_SPARSE | MB_TAG_CREAT );RR;
00794
00795     std::vector< int > closure_vals( partSets.size(), 1 );
00796     result = mbImpl->tag_set_data( closure_tag, partSets, &closure_vals[0] );RR;
00797
00798     return MB_SUCCESS;
00799 }
00800
00801 ErrorCode ZoltanPartitioner::assemble_graph( const int dimension,
00802                                              std::vector< double >& coords,
00803                                              std::vector< int >& moab_ids,
00804                                              std::vector< int >& adjacencies,
00805                                              std::vector< int >& length,
00806                                              Range& elems,
00807                                              bool part_geom,
00808                                              int projection_type )
00809 {
00810     // assemble a graph with vertices equal to elements of specified dimension, edges
00811     // signified by list of other elements to which an element is connected
00812
00813     // get the elements of that dimension
00814     ErrorCode result = mbImpl->get_entities_by_dimension( 0, dimension, elems );
00815     if( MB_SUCCESS != result || elems.empty() ) return result;
00816
00817     // assign global ids
00818     if( assign_global_ids )
00819     {
00820         EntityHandle rootset = 0;
00821         result               = mbpc->assign_global_ids( rootset, dimension, 1, true, true );RR;
00822     }
00823
00824     // now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1
00825     // dimensional neighbors
00826     MeshTopoUtil mtu( mbImpl );
00827     Range adjs;
00828     // can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited
00829     // by MBCN
00830     int neighbors[5 * MAX_SUB_ENTITIES];
00831     double avg_position[3];
00832     int moab_id;
00833
00834     // get the global id tag handle
00835     Tag gid = mbImpl->globalId_tag();
00836
00837     for( Range::iterator rit = elems.begin(); rit != elems.end(); ++rit )
00838     {
00839
00840         if( !part_geom )
00841         {
00842             // get bridge adjacencies
00843             adjs.clear();
00844             result = mtu.get_bridge_adjacencies( *rit, ( dimension > 0 ? dimension - 1 : 3 ), dimension, adjs );RR;
00845
00846             // get the graph vertex ids of those
00847             if( !adjs.empty() )
00848             {
00849                 assert( adjs.size() < 5 * MAX_SUB_ENTITIES );
00850                 result = mbImpl->tag_get_data( gid, adjs, neighbors );RR;
00851             }
00852
00853             // copy those into adjacencies vector
00854             length.push_back( (int)adjs.size() );
00855             std::copy( neighbors, neighbors + adjs.size(), std::back_inserter( adjacencies ) );
00856         }
00857
00858         // get average position of vertices
00859         result = mtu.get_average_position( *rit, avg_position );RR;
00860
00861         // get the graph vertex id for this element
00862         result = mbImpl->tag_get_data( gid, &( *rit ), 1, &moab_id );RR;
00863
00864         // copy those into coords vector
00865         moab_ids.push_back( moab_id );
00866         // transform coordinates to spherical coordinates, if requested
00867         if( projection_type > 0 ) IntxUtils::transform_coordinates( avg_position, projection_type );
00868
00869         std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) );
00870     }
00871
00872     if( debug )
00873     {
00874         std::cout << "Length vector: " << std::endl;
00875         std::copy( length.begin(), length.end(), std::ostream_iterator< int >( std::cout, ", " ) );
00876         std::cout << std::endl;
00877         std::cout << "Adjacencies vector: " << std::endl;
00878         std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( std::cout, ", " ) );
00879         std::cout << std::endl;
00880         std::cout << "Moab_ids vector: " << std::endl;
00881         std::copy( moab_ids.begin(), moab_ids.end(), std::ostream_iterator< int >( std::cout, ", " ) );
00882         std::cout << std::endl;
00883         std::cout << "Coords vector: " << std::endl;
00884         std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( std::cout, ", " ) );
00885         std::cout << std::endl;
00886     }
00887
00888     return MB_SUCCESS;
00889 }
00890
00891 #ifdef MOAB_HAVE_CGM
00892 ErrorCode ZoltanPartitioner::assemble_graph( const int /* dimension */,
00893                                              std::vector< double >& /* coords */,
00894                                              std::vector< int >& moab_ids,
00895                                              std::vector< int >& adjacencies,
00896                                              std::vector< int >& length,
00897                                              std::vector< double >& obj_weights,
00898                                              std::vector< double >& edge_weights,
00899                                              std::vector< int >& parts,
00900                                              DLIList< RefEntity* >& entities,
00901                                              const double part_geom_mesh_size,
00902                                              const int n_part )
00903 {
00904     // get body vertex weights
00905     DLIList< RefEntity* > body_list;
00906     gti->ref_entity_list( "body", body_list, CUBIT_FALSE );
00907     DLIList< RefFace* > all_shared_surfs;
00908     int n_bodies       = body_list.size();
00909     int body_map_index = 1;
00910     int surf_map_index = n_bodies + 1;
00911     int n_bodies_proc  = n_bodies / n_part;  // # of entities per processor
00912     int i_bodies_proc  = n_bodies_proc;      // entity index limit for each processor
00913     int proc           = 0;
00914
00915     body_list.reset();
00916     for( int i = 0; i < n_bodies; i++ )
00917     {
00918         // assign part in round-robin
00919         if( i == i_bodies_proc )
00920         {
00921             proc++;
00922             if( proc < n_part )
00923                 i_bodies_proc += n_bodies_proc;
00924             else
00925             {
00926                 proc %= n_part;
00927                 i_bodies_proc++;
00928             }
00929         }
00930         parts.push_back( proc );
00931
00932         // volume mesh generation load estimation
00933         RefEntity* body = body_list.get_and_step();
00934         double vertex_w = body->measure();
00935         vertex_w /= part_geom_mesh_size * part_geom_mesh_size * part_geom_mesh_size;
00936         vertex_w = 3.8559e-5 * vertex_w * log( vertex_w );
00937
00938         // add child non-interface face weights
00939         DLIList< RefFace* > shared_surfs;
00940         DLIList< RefFace* > faces;
00941         ( dynamic_cast< TopologyEntity* >( body ) )->ref_faces( faces );
00942         int n_face = faces.size();
00943         faces.reset();
00944         for( int j = 0; j < n_face; j++ )
00945         {
00946             RefFace* face      = faces.get_and_step();
00947             TopologyEntity* te = CAST_TO( face, TopologyEntity );
00948             if( te->bridge_manager()->number_of_bridges() > 1 )
00949             {  // shared
00950                 shared_surfs.append( face );
00951             }
00952             else
00953             {  // non-shared
00954                 vertex_w += estimate_face_mesh_load( face, face->measure() );
00955             }
00956         }
00957
00958         int temp_index              = body_map_index++;
00959         body_vertex_map[body->id()] = temp_index;
00960         moab_ids.push_back( temp_index );   // add body as graph vertex
00961         obj_weights.push_back( vertex_w );  // add weight for body graph vertex
00962
00963         if( debug )
00964         {
00965             std::cout << "body=" << body->id() << ",graph_id=" << temp_index << ",weight=" << vertex_w
00966                       << ",part=" << proc << std::endl;
00967         }
00968
00969         // treat shared surfaces connected to this body
00970         int n_shared = shared_surfs.size();
00971         shared_surfs.reset();
00972         for( int k = 0; k < n_shared; k++ )
00973         {  // add adjacencies
00974             RefFace* face                       = shared_surfs.get_and_step();
00975             std::map< int, int >::iterator iter = surf_vertex_map.find( face->id() );
00976             if( iter != surf_vertex_map.end() )
00977             {
00978                 temp_index = ( *iter ).second;
00979             }
00980             else
00981             {
00982                 temp_index                  = surf_map_index++;
00983                 surf_vertex_map[face->id()] = temp_index;
00984                 all_shared_surfs.append( face );
00985             }
00986             adjacencies.push_back( temp_index );
00987             double tmp_sw = estimate_face_comm_load( face, part_geom_mesh_size );
00988             edge_weights.push_back( tmp_sw );
00989
00990             if( debug )
00991             {
00992                 std::cout << "adjac=" << temp_index << ",weight=" << tmp_sw << std::endl;
00993             }
00994         }
00995         length.push_back( n_shared );
00996     }
00997     entities += body_list;
00998
00999     // add shared surface as graph vertex
01000     int n_all_shared_surf = all_shared_surfs.size();
01001     all_shared_surfs.reset();
01002     for( int i = 0; i < n_all_shared_surf; i++ )
01003     {
01004         RefEntity* face = all_shared_surfs.get_and_step();
01005         moab_ids.push_back( surf_vertex_map[face->id()] );
01006         double face_mesh_load = estimate_face_mesh_load( face, part_geom_mesh_size );
01007         obj_weights.push_back( face_mesh_load );
01008
01009         // set surface object graph edges
01010         int min_ind     = -1;
01011         double min_load = std::numeric_limits< double >::max();
01012         ;
01013         DLIList< Body* > parents;
01014         dynamic_cast< TopologyEntity* >( face )->bodies( parents );
01015         int n_parents = parents.size();
01016         parents.reset();
01017         for( int j = 0; j < n_parents; j++ )
01018         {
01019             int body_gid = body_vertex_map[parents.get_and_step()->id()];
01020             adjacencies.push_back( body_gid );  // add adjacency
01021             edge_weights.push_back( estimate_face_comm_load( face, part_geom_mesh_size ) );
01022
01023             if( obj_weights[body_gid - 1] < min_load )
01024             {
01025                 min_ind  = body_gid - 1;
01026                 min_load = obj_weights[min_ind];
01027             }
01028         }
01029         length.push_back( n_parents );
01030         entities.append( dynamic_cast< RefEntity* >( face ) );
01031         obj_weights[min_ind] += face_mesh_load;
01032         parts.push_back( parts[min_ind] );
01033
01034         if( debug )
01035         {
01036             std::cout << "shared_surf=" << face->id() << ",graph_id=" << surf_vertex_map[face->id()]
01037                       << ",weight=" << face_mesh_load << ",part=" << parts[min_ind] << std::endl;
01038         }
01039     }
01040
01041     for( size_t i = 0; i < obj_weights.size(); i++ )
01042         if( obj_weights[i] < 1. ) obj_weights[i] = 1.;
01043     for( size_t i = 0; i < edge_weights.size(); i++ )
01044         if( edge_weights[i] < 1. ) edge_weights[i] = 1.;
01045
01046     return MB_SUCCESS;
01047 }
01048
01049 double ZoltanPartitioner::estimate_face_mesh_load( RefEntity* face, const double h )
01050 {
01051     GeometryType type = CAST_TO( face, RefFace )->geometry_type();
01052     double n          = face->measure() / h / h;
01053     double n_logn     = n * log( n );
01054
01055     if( type == PLANE_SURFACE_TYPE )
01056     {
01057         return 1.536168737505151e-4 * n_logn;
01058     }
01059     else if( type == SPLINE_SURFACE_TYPE )
01060     {
01061         return 5.910511018383144e-4 * n_logn;
01062     }
01063     else if( type == CONE_SURFACE_TYPE || type == SPHERE_SURFACE_TYPE || type == TORUS_SURFACE_TYPE )
01064     {
01065         return 2.352511671418708e-4 * n_logn;
01066     }
01067
01068     return 0.0;
01069 }
01070
01071 double ZoltanPartitioner::estimate_face_comm_load( RefEntity* face, const double h )
01072 {
01073     double peri = 0.;
01074 #if( ( CGM_MAJOR_VERSION == 14 && CGM_MINOR_VERSION > 2 ) || CGM_MAJOR_VERSION >= 15 )
01075     DLIList< DLIList< RefEdge* > > ref_edge_loops;
01076 #else
01077     DLIList< DLIList< RefEdge* >* > ref_edge_loops;
01078 #endif
01079     CAST_TO( face, RefFace )->ref_edge_loops( ref_edge_loops );
01080     ref_edge_loops.reset();
01081
01082 #if( ( CGM_MAJOR_VERSION == 14 && CGM_MINOR_VERSION > 2 ) || CGM_MAJOR_VERSION >= 15 )
01083     for( int i = 0; i < ref_edge_loops.size(); i++ )
01084     {
01085         DLIList< RefEdge* > eloop = ref_edge_loops.get_and_step();
01086         eloop.reset();
01087         for( int j = 0; j < eloop.size(); j++ )
01088         {
01089             peri += eloop.get_and_step()->measure();
01090         }
01091     }
01092 #else
01093     for( int i = 0; i < ref_edge_loops.size(); i++ )
01094     {
01095         DLIList< RefEdge* >* eloop = ref_edge_loops.get_and_step();
01096         eloop->reset();
01097         for( int j = 0; j < eloop->size(); j++ )
01098         {
01099             peri += eloop->get_and_step()->measure();
01100         }
01101     }
01102 #endif
01103
01104     // return 104*face->measure()/sqrt(3)/h/h + 56/3*peri/h;
01105     return ( 104 * face->measure() / sqrt( 3 ) / h / h + 56 / 3 * peri / h ) / 700000.;
01106 }
01107
01108 ErrorCode ZoltanPartitioner::write_partition( const int nparts,
01109                                               DLIList< RefEntity* > entities,
01110                                               const int* assignment,
01111                                               std::vector< double >& obj_weights,
01112                                               const bool part_surf,
01113                                               const bool ghost )
01114 {
01115     ErrorCode result;
01116
01117     // actuate CA_BODIES and turn on auto flag for other attributes
01118     CGMApp::instance()->attrib_manager()->register_attrib_type( CA_BODIES, "bodies", "BODIES", CABodies_creator,
01119        CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
01120        CUBIT_TRUE, CUBIT_FALSE );
01121     CGMApp::instance()->attrib_manager()->auto_flag( CUBIT_TRUE );
01122
01123     // set partition info to Body at first
01124     int n_entities = entities.size();
01125     entities.reset();
01126     for( int i = 0; i < n_entities; i++ )
01127     {
01128         int proc = assignment[i];
01129         DLIList< int > shared_procs;
01130         RefEntity* entity = entities.get_and_step();
01131
01132         if( entity->entity_type_info() == typeid( Body ) )
01133         {
01134             shared_procs.append( proc );
01135             TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel );
01136             if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs );
01137
01138             if( debug )
01139             {
01140                 std::cout << "body" << entity->id() << "_is_partitioned_to_p" << proc << std::endl;
01141             }
01142
01143             // assign to volumes, it should be removed in future
01144             DLIList< RefVolume* > volumes;
01145             ( dynamic_cast< TopologyEntity* >( entity ) )->ref_volumes( volumes );
01146             int n_vol = volumes.size();
01147             volumes.reset();
01148             for( int j = 0; j < n_vol; j++ )
01149             {
01150                 RefEntity* vol = volumes.get_and_step();
01151                 td_par         = (TDParallel*)vol->get_TD( &TDParallel::is_parallel );
01152                 if( td_par == NULL ) td_par = new TDParallel( vol, NULL, &shared_procs );
01153             }
01154         }
01155     }
01156
01157     // set partition info to shared surfaces
01158     entities.reset();
01159     for( int i = 0; i < n_entities; i++ )
01160     {
01161         int proc = assignment[i];
01162         DLIList< int > shared_procs;
01163         RefEntity* entity = entities.get_and_step();
01164
01165         if( entity->entity_type_info() == typeid( RefFace ) )
01166         {  // surface
01167             DLIList< Body* > parents;
01168             ( dynamic_cast< TopologyEntity* >( entity ) )->bodies( parents );
01169             int n_parents = parents.size();
01170             if( n_parents != 2 )
01171             {  // check # of parents
01172                 std::cerr << "# of parent bodies of interface surface should be 2." << std::endl;
01173                 return MB_FAILURE;
01174             }
01175             shared_procs.append( proc );  // local proc
01176             parents.reset();
01177             for( int j = 0; j < 2; j++ )
01178             {
01179                 RefEntity* parent     = parents.get_and_step();
01180                 TDParallel* parent_td = (TDParallel*)parent->get_TD( &TDParallel::is_parallel );
01181
01182                 if( parent_td == NULL )
01183                 {
01184                     std::cerr << "parent body should have balanced process." << std::endl;
01185                     return MB_FAILURE;
01186                 }
01187                 int temp_proc = parent_td->get_charge_proc();
01188                 if( temp_proc != proc ) shared_procs.append( temp_proc );  // remote proc
01189             }
01190
01191             if( shared_procs.size() > 1 )
01192             {  // if it is shared by 2 processors
01193                 int merge_id       = TDUniqueId::get_unique_id( entity );
01194                 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel );
01195                 if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs, NULL, merge_id, 1 );
01196
01197                 if( debug )
01198                 {
01199                     std::cout << "surf" << entity->id() << "_is_partitioned_to_p";
01200                     for( int j = 0; j < shared_procs.size(); j++ )
01201                     {
01202                         std::cout << "," << shared_procs[j];
01203                     }
01204                     std::cout << std::endl;
01205                 }
01206             }
01207         }
01208     }
01209
01210     // do non-shared surface partition too
01211     if( part_surf )
01212     {
01213         result = partition_surface( nparts, entities, assignment, obj_weights );RR;
01214     }
01215
01216     // partition shared edges and vertex
01217     result = partition_child_entities( 1, nparts, part_surf, ghost );RR;
01218     result = partition_child_entities( 0, nparts, part_surf );RR;
01219
01220     if( debug )
01221     {
01222         entities.reset();
01223         for( int i = 0; i < n_entities; i++ )
01224         {
01225             RefEntity* entity = entities.get_and_step();
01226             if( entity->entity_type_info() == typeid( Body ) )
01227             {
01228                 TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel );
01229                 CubitString st     = entity->entity_name();
01230                 DLIList< int >* sp = td_par->get_shared_proc_list();
01231                 int n_sp           = sp->size();
01232                 sp->reset();
01233                 for( int j = 0; j < n_sp; j++ )
01234                 {
01235                     std::cout << "partitioned_" << st.c_str() << ",proc=" << sp->get_and_step() << std::endl;
01236                 }
01237                 DLIList< int >* gp = td_par->get_ghost_proc_list();
01238                 int n_gp           = gp->size();
01239                 sp->reset();
01240                 for( int j = 0; j < n_gp; j++ )
01241                 {
01242                     std::cout << "partitioned_" << st.c_str() << ",ghost=" << gp->get_and_step() << std::endl;
01243                 }
01244             }
01245         }
01246     }
01247
01248     return MB_SUCCESS;
01249 }
01250
01251 ErrorCode ZoltanPartitioner::partition_surface( const int nparts,
01252                                                 DLIList< RefEntity* > entities,
01253                                                 const int* assignment,
01254                                                 std::vector< double >& obj_weights )
01255 {
01256     int i;
01257     double ave_load = 0.;
01258     double* loads   = new double[nparts];
01259     for( i = 0; i < nparts; i++ )
01260         loads[i] = 0.;
01261
01262     int n_entities = entities.size();
01263     entities.reset();
01264     for( i = 0; i < n_entities; i++ )
01265     {
01266         loads[assignment[i]] += obj_weights[i];
01267         ave_load += obj_weights[i];
01268     }
01269     ave_load /= nparts;
01270
01271     if( debug )
01272     {
01273         for( i = 0; i < nparts; i++ )
01274         {
01275             std::cout << "loads_before_surface_partition[" << i << "]=" << loads[i] << std::endl;
01276         }
01277     }
01278
01279     int n_iter  = 0;
01280     bool b_stop = false;
01281     do
01282     {
01283         // get max and min load processors
01284         int max_proc = nparts, min_proc = 0;
01285         double min_load = std::numeric_limits< double >::max();
01286         double max_load = std::numeric_limits< double >::min();
01287         for( i = 0; i < nparts; i++ )
01288         {
01289             if( loads[i] < min_load )
01290             {
01291                 min_load = loads[i];
01292                 min_proc = i;
01293             }
01294             if( loads[i] > max_load )
01295             {
01296                 max_load = loads[i];
01297                 max_proc = i;
01298             }
01299         }
01300
01301         double load_diff = max_load - ave_load;
01302         if( load_diff > ave_load / 10. )
01303         {
01304             bool b_moved = false;
01305             entities.reset();
01306             for( i = 0; i < n_entities; i++ )
01307             {
01308                 if( b_moved ) break;
01309                 if( assignment[i] == max_proc &&  // find maximum load processor bodies
01310                     entities[i]->entity_type_info() == typeid( Body ) )
01311                 {
01312                     DLIList< RefFace* > faces;
01313                     ( dynamic_cast< TopologyEntity* >( entities[i] ) )->ref_faces( faces );
01314                     int n_face = faces.size();
01315                     faces.reset();
01316                     for( int j = 0; j < n_face; j++ )
01317                     {
01318                         RefFace* face      = faces.get_and_step();
01319                         TopologyEntity* te = CAST_TO( face, TopologyEntity );
01320                         if( te->bridge_manager()->number_of_bridges() < 2 )
01321                         {  // non-shared
01322                             TDParallel* td_par = (TDParallel*)face->get_TD( &TDParallel::is_parallel );
01323                             if( td_par == NULL )
01324                             {  // only consider unpartitioned surfaces
01325                                 double face_load = face->measure();
01326                                 if( load_diff > min_load + face_load - ave_load )
01327                                 {
01328                                     loads[max_proc] -= face_load;
01329                                     loads[min_proc] += face_load;
01330                                     int merge_id = TDUniqueId::get_unique_id( face );
01331                                     DLIList< int > shared_procs;
01332                                     shared_procs.append( min_proc );
01333                                     shared_procs.append( max_proc );
01334                                     td_par = new TDParallel( face, NULL, &shared_procs, NULL, merge_id, 1 );
01335
01336                                     if( debug )
01337                                     {
01338                                         std::cout << "non-shared surface " << face->id() << " is moved from p"
01339                                                   << max_proc << " to p" << min_proc << std::endl;
01340                                     }
01341                                     b_moved = true;
01342                                     break;
01343                                 }
01344                             }
01345                         }
01346                     }
01347                 }
01348             }
01349         }
01350         else
01351             b_stop = true;
01352
01353         n_iter++;
01354     } while( !b_stop && n_iter < 50 );
01355
01356     if( debug )
01357     {
01358         for( i = 0; i < nparts; i++ )
01359         {
01360             std::cout << "loads_after_surface_partition[" << i << "]=" << loads[i] << std::endl;
01361         }
01362     }
01363
01364     delete loads;
01365     return MB_SUCCESS;
01366 }
01367
01368 ErrorCode ZoltanPartitioner::partition_round_robin( const int n_part )
01369 {
01370     int i, j, k;
01371     double* loads    = new double[n_part];  // estimated loads for each processor
01372     double* ve_loads = new double[n_part];  // estimated loads for each processor
01373     for( i = 0; i < n_part; i++ )
01374     {
01375         loads[i]    = 0.0;
01376         ve_loads[i] = 0.0;
01377     }
01378     DLIList< RefEntity* > body_entity_list;
01379     gti->ref_entity_list( "body", body_entity_list, CUBIT_FALSE );
01380     int n_entity      = body_entity_list.size();
01381     int n_entity_proc = n_entity / n_part;  // # of entities per processor
01382     int i_entity_proc = n_entity_proc;      // entity index limit for each processor
01383     int proc          = 0;
01384     RefEntity* entity;
01385
01386     // assign processors to bodies
01387     body_entity_list.reset();
01388     for( i = 0; i < n_entity; i++ )
01389     {
01390         if( i == i_entity_proc )
01391         {
01392             proc++;
01393             if( proc < n_part )
01394                 i_entity_proc += n_entity_proc;
01395             else
01396             {
01397                 proc %= n_part;
01398                 i_entity_proc++;
01399             }
01400         }
01401
01402         // assign to bodies
01403         entity = body_entity_list.get_and_step();
01404         DLIList< int > shared_procs;
01405         shared_procs.append( proc );
01406         TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel );
01407         if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs );
01408         loads[proc] += entity->measure();
01409
01410         // assign to volumes, it should be removed in future
01411         DLIList< RefVolume* > volumes;
01412         ( dynamic_cast< TopologyEntity* >( entity ) )->ref_volumes( volumes );
01413         int n_vol = volumes.size();
01414         volumes.reset();
01415         for( j = 0; j < n_vol; j++ )
01416         {
01417             RefEntity* vol = volumes.get_and_step();
01418             td_par         = (TDParallel*)vol->get_TD( &TDParallel::is_parallel );
01419             if( td_par == NULL ) td_par = new TDParallel( vol, NULL, &shared_procs );
01420         }
01421
01422         // add local surface load
01423         DLIList< RefFace* > faces;
01424         ( dynamic_cast< TopologyEntity* >( entity ) )->ref_faces( faces );
01425         int n_face = faces.size();
01426         faces.reset();
01427         for( j = 0; j < n_face; j++ )
01428         {
01429             RefFace* face      = faces.get_and_step();
01430             TopologyEntity* te = CAST_TO( face, TopologyEntity );
01431             if( te->bridge_manager()->number_of_bridges() < 2 ) loads[proc] = loads[proc] + face->measure();
01432         }
01433
01434         // Get all child entities
01435         DLIList< RefEntity* > child_list;
01436         RefEntity::get_all_child_ref_entities( body_entity_list, child_list );
01437         int n_child = child_list.size();
01438
01439         // assign processors to interface entities
01440         child_list.reset();
01441         for( j = 0; j < n_child; j++ )
01442         {
01443             entity             = child_list.get_and_step();
01444             TopologyEntity* te = CAST_TO( entity, TopologyEntity );
01445
01446             if( te->bridge_manager()->number_of_bridges() > 1 )
01447             {
01448                 DLIList< Body* > parent_bodies;
01449                 DLIList< int > child_shared_procs;  // Shared processors of each child entity
01450                 ( dynamic_cast< TopologyEntity* >( entity ) )->bodies( parent_bodies );
01451                 int n_parent = parent_bodies.size();
01452
01453                 for( k = 0; k < n_parent; k++ )
01454                 {
01455                     RefEntity* parent_vol = CAST_TO( parent_bodies.get_and_step(), RefEntity );
01456                     TDParallel* parent_td = (TDParallel*)parent_vol->get_TD( &TDParallel::is_parallel );
01457
01458                     if( parent_td == NULL )
01459                     {
01460                         PRINT_ERROR( "parent Volume has to be partitioned." );
01461                         delete[] loads;
01462                         delete[] ve_loads;
01463                         return MB_FAILURE;
01464                     }
01465                     child_shared_procs.append_unique( parent_td->get_charge_proc() );
01466                 }
01467
01468                 if( child_shared_procs.size() > 1 )
01469                 {  // if it is interface
01470                     td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel );
01471                     if( td_par == NULL )
01472                     {
01473                         int merge_id = TDUniqueId::get_unique_id( entity );
01474                         if( entity->entity_type_info() == typeid( RefFace ) )
01475                         {  // face
01476                             if( child_shared_procs.size() != 2 )
01477                             {
01478                                 PRINT_ERROR( "Error: # of shared processors of interface surface "
01479                                              "should be 2." );
01480                                 delete[] loads;
01481                                 delete[] ve_loads;
01482                                 return MB_FAILURE;
01483                             }
01484
01485                             // balance interface surface loads
01486                             if( loads[child_shared_procs[0]] > loads[child_shared_procs[1]] )
01487                                 child_shared_procs.reverse();
01488
01489                             loads[child_shared_procs[0]] = loads[child_shared_procs[0]] + entity->measure();
01490                             td_par = new TDParallel( entity, NULL, &child_shared_procs, NULL, merge_id, 1 );
01491                         }  // face
01492                         else if( entity->entity_type_info() == typeid( RefEdge ) ||
01493                                  entity->entity_type_info() == typeid( RefVertex ) )
01494                         {  // edge or vertex
01495                             // balance interface surface loads
01496                             int min_p         = child_shared_procs[0];
01497                             int n_shared_proc = child_shared_procs.size();
01498                             for( k = 1; k < n_shared_proc; k++ )
01499                             {
01500                                 if( ve_loads[child_shared_procs[k]] < ve_loads[min_p] ) min_p = child_shared_procs[k];
01501                             }
01502                             ve_loads[min_p] = ve_loads[min_p] + entity->measure();
01503                             child_shared_procs.remove( min_p );
01504                             child_shared_procs.insert_first( min_p );
01505                             td_par = new TDParallel( entity, NULL, &child_shared_procs, NULL, merge_id, 1 );
01506                         }  // edge or vertex
01507                     }      // if (td_par == NULL)
01508                 }          // if it is interface
01509             }              // if (te->bridge_manager()->number_of_bridges() > 1)
01510         }                  // for (j = 0; j < n_child; j++)
01511     }                      // for (i = 0; i < n_entity; i++)
01512
01513     delete[] loads;
01514     delete[] ve_loads;
01515
01516     return MB_SUCCESS;
01517 }
01518
01519 // partition child entities to one of parent entity shared processors
01520 ErrorCode ZoltanPartitioner::partition_child_entities( const int dim,
01521                                                        const int n_part,
01522                                                        const bool part_surf,
01523                                                        const bool ghost )
01524 {
01525     DLIList< RefEntity* > entity_list;
01526     if( dim == 0 )
01527         gti->ref_entity_list( "vertex", entity_list, CUBIT_FALSE );
01528     else if( dim == 1 )
01529         gti->ref_entity_list( "curve", entity_list, CUBIT_FALSE );
01530     else
01531     {
01532         std::cerr << "Dimention should be from 0 to 1." << std::endl;
01533         return MB_FAILURE;
01534     }
01535
01536     int i, j, k;
01537     int n_entity  = entity_list.size();
01538     double* loads = new double[n_part];
01539     for( i = 0; i < n_part; i++ )
01540         loads[i] = 0.;
01541     entity_list.reset();
01542
01543     for( i = 0; i < n_entity; i++ )
01544     {  // for all entities
01545         RefEntity* entity  = entity_list.get_and_step();
01546         TopologyEntity* te = CAST_TO( entity, TopologyEntity );
01547
01548         if( !part_surf && te->bridge_manager()->number_of_bridges() < 2 ) continue;
01549
01550         DLIList< int > shared_procs;
01551         DLIList< Body* > parents;
01552         ( dynamic_cast< TopologyEntity* >( entity ) )->bodies( parents );
01553         int n_parents = parents.size();
01554         std::set< int > s_proc;
01555         parents.reset();
01556
01557         // get shared processors from parent bodies
01558         for( j = 0; j < n_parents; j++ )
01559         {
01560             RefEntity* parent     = parents.get_and_step();
01561             TDParallel* parent_td = (TDParallel*)parent->get_TD( &TDParallel::is_parallel );
01562
01563             if( parent_td != NULL )
01564             {
01565                 DLIList< int >* parent_procs = parent_td->get_shared_proc_list();
01566                 int n_shared                 = parent_procs->size();
01567                 parent_procs->reset();
01568                 for( k = 0; k < n_shared; k++ )
01569                 {
01570                     int p = parent_procs->get_and_step();
01571                     s_proc.insert( p );
01572                 }
01573             }
01574         }
01575
01576         if( part_surf )
01577         {  // also get shared procs from parent surfaces
01578             DLIList< RefFace* > parent_faces;
01579             ( dynamic_cast< TopologyEntity* >( entity ) )->ref_faces( parent_faces );
01580             int n_pface = parent_faces.size();
01581             parent_faces.reset();
01582
01583             // get shared processors from parent faces
01584             for( j = 0; j < n_pface; j++ )
01585             {
01586                 RefEntity* parent     = parent_faces.get_and_step();
01587                 TDParallel* parent_td = (TDParallel*)parent->get_TD( &TDParallel::is_parallel );
01588
01589                 if( parent_td != NULL )
01590                 {
01591                     DLIList< int >* parent_procs = parent_td->get_shared_proc_list();
01592                     int n_shared                 = parent_procs->size();
01593                     parent_procs->reset();
01594
01595                     for( k = 0; k < n_shared; k++ )
01596                     {
01597                         int p = parent_procs->get_and_step();
01598                         s_proc.insert( p );
01599                     }
01600                 }
01601             }
01602         }
01603
01604         // find the minimum load processor and put it
01605         // at the front of the shared_procs list
01606         if( s_proc.size() > 1 )
01607         {
01608             int min_proc                       = 0;
01609             double min_load                    = std::numeric_limits< double >::max();
01610             std::set< int >::iterator iter     = s_proc.begin();
01611             std::set< int >::iterator end_iter = s_proc.end();
01612             for( ; iter != end_iter; ++iter )
01613             {
01614                 if( loads[*iter] < min_load )
01615                 {
01616                     min_load = loads[*iter];
01617                     min_proc = *iter;
01618                 }
01619             }
01620
01621             if( dim == 1 )
01622                 loads[min_proc] += entity->measure();
01623             else if( dim == 0 )
01624                 loads[min_proc] += 1.;
01625             shared_procs.append( min_proc );
01626             iter     = s_proc.begin();
01627             end_iter = s_proc.end();
01628             for( ; iter != end_iter; ++iter )
01629             {
01630                 if( *iter != min_proc )
01631                 {
01632                     shared_procs.append( *iter );
01633                 }
01634             }
01635
01636             // add ghost geometries to shared processors for edge
01637             if( ghost )
01638             {
01639                 parents.reset();
01640                 for( j = 0; j < n_parents; j++ )
01641                 {  // for all parent bodies
01642                     RefEntity* parent_vol = CAST_TO( parents.get_and_step(), RefEntity );
01643                     TDParallel* parent_td = (TDParallel*)parent_vol->get_TD( &TDParallel::is_parallel );
01644                     int n_shared_proc     = shared_procs.size();
01645
01646                     for( k = 0; k < n_shared_proc; k++ )
01647                     {
01648                         parent_td->add_ghost_proc( shared_procs[k] );
01649                     }
01650                 }
01651             }
01652
01653             // initialize tool data
01654             int merge_id       = TDUniqueId::get_unique_id( entity );
01655             TDParallel* td_par = (TDParallel*)entity->get_TD( &TDParallel::is_parallel );
01656             if( td_par == NULL ) td_par = new TDParallel( entity, NULL, &shared_procs, NULL, merge_id, 1 );
01657         }
01658     }
01659
01660     delete loads;
01661     return MB_SUCCESS;
01662 }
01663 #endif
01664
01665 ErrorCode ZoltanPartitioner::write_partition( const int nparts,
01666                                               Range& elems,
01667                                               const int* assignment,
01668                                               const bool write_as_sets,
01669                                               const bool write_as_tags )
01670 {
01671     ErrorCode result;
01672
01673     // get the partition set tag
01674     Tag part_set_tag;
01675     int dum_id = -1, i;
01676     result     = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag,
01677                                      MB_TAG_SPARSE | MB_TAG_CREAT, &dum_id );RR;
01678
01679     // get any sets already with this tag, and clear them
01680     Range tagged_sets;
01681     result =
01682         mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );RR;
01683     if( !tagged_sets.empty() )
01684     {
01685         result = mbImpl->clear_meshset( tagged_sets );RR;
01686         if( !write_as_sets )
01687         {
01688             result = mbImpl->tag_delete_data( part_set_tag, tagged_sets );RR;
01689         }
01690     }
01691
01692     if( write_as_sets )
01693     {
01694         // first, create partition sets and store in vector
01695         partSets.clear();
01696
01697         if( nparts > (int)tagged_sets.size() )
01698         {
01699             // too few partition sets - create missing ones
01700             int num_new = nparts - tagged_sets.size();
01701             for( i = 0; i < num_new; i++ )
01702             {
01703                 EntityHandle new_set;
01704                 result = mbImpl->create_meshset( MESHSET_SET, new_set );RR;
01705                 tagged_sets.insert( new_set );
01706             }
01707         }
01708         else if( nparts < (int)tagged_sets.size() )
01709         {
01710             // too many partition sets - delete extras
01711             int num_del = tagged_sets.size() - nparts;
01712             for( i = 0; i < num_del; i++ )
01713             {
01714                 EntityHandle old_set = tagged_sets.pop_back();
01715                 result               = mbImpl->delete_entities( &old_set, 1 );RR;
01716             }
01717         }
01718         // assign partition sets to vector
01719         partSets.swap( tagged_sets );
01720
01721         // write a tag to those sets denoting they're partition sets, with a value of the
01722         // proc number
01723         int* dum_ids = new int[nparts];
01724         for( i = 0; i < nparts; i++ )
01725             dum_ids[i] = i;
01726
01727         result = mbImpl->tag_set_data( part_set_tag, partSets, dum_ids );RR;
01728         // found out by valgrind when we run mbpart
01729         delete[] dum_ids;
01730         dum_ids = NULL;
01731
01732         // assign entities to the relevant sets
01733         std::vector< EntityHandle > tmp_part_sets;
01734         // int N = (int)elems.size();
01735         std::copy( partSets.begin(), partSets.end(), std::back_inserter( tmp_part_sets ) );
01736         /*Range::reverse_iterator riter;
01737         for (i = N-1, riter = elems.rbegin(); riter != elems.rend(); ++riter, i--) {
01738           int assigned_part = assignment[i];
01739           part_ranges[assigned_part].insert(*riter);
01740           //result = mbImpl->add_entities(tmp_part_sets[assignment[i]], &(*rit), 1); RR;
01741         }*/
01742
01743         Range::iterator rit;
01744         for( i = 0, rit = elems.begin(); rit != elems.end(); ++rit, i++ )
01745         {
01746             result = mbImpl->add_entities( tmp_part_sets[assignment[i]], &( *rit ), 1 );RR;
01747         }
01748         /*for (i=0; i<nparts; i++)
01749         {
01750           result = mbImpl->add_entities(tmp_part_sets[i], part_ranges[i]); RR;
01751         }
01752         delete [] part_ranges;*/
01753         // check for empty sets, warn if there are any
01754         Range empty_sets;
01755         for( rit = partSets.begin(); rit != partSets.end(); ++rit )
01756         {
01757             int num_ents = 0;
01758             result       = mbImpl->get_number_entities_by_handle( *rit, num_ents );
01759             if( MB_SUCCESS != result || !num_ents ) empty_sets.insert( *rit );
01760         }
01761         if( !empty_sets.empty() )
01762         {
01763             std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: ";
01764             for( rit = empty_sets.begin(); rit != empty_sets.end(); ++rit )
01765                 std::cout << *rit << " ";
01766             std::cout << std::endl;
01767         }
01768     }
01769
01770     if( write_as_tags )
01771     {
01772         // allocate integer-size partitions
01773         result = mbImpl->tag_set_data( part_set_tag, elems, assignment );RR;
01774     }
01775
01776     return MB_SUCCESS;
01777 }
01778
01779 void ZoltanPartitioner::SetRCB_Parameters( const bool recompute_rcb_box )
01780 {
01781     if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
01782     // General parameters:
01783
01784     myZZ->Set_Param( "DEBUG_LEVEL", "0" );  // no debug messages
01785     myZZ->Set_Param( "LB_METHOD", "RCB" );  // recursive coordinate bisection
01786     // myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" );  // recompute RCB box if needed ?
01787
01788     // RCB parameters:
01789
01790     myZZ->Set_Param( "RCB_OUTPUT_LEVEL", "1" );
01791     myZZ->Set_Param( "KEEP_CUTS", "1" );  // save decomposition so that we can infer partitions
01792     // myZZ->Set_Param("RCB_RECTILINEAR_BLOCKS", "1"); // don't split point on boundary
01793     if( recompute_rcb_box ) myZZ->Set_Param( "RCB_RECOMPUTE_BOX", "1" );
01794 }
01795
01796 void ZoltanPartitioner::SetRIB_Parameters()
01797 {
01798     if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nRecursive Inertial Bisection" << std::endl;
01799     // General parameters:
01800
01801     myZZ->Set_Param( "DEBUG_LEVEL", "0" );  // no debug messages
01802     myZZ->Set_Param( "LB_METHOD", "RIB" );  // Recursive Inertial Bisection
01803
01804     // RIB parameters:
01805
01806     myZZ->Set_Param( "KEEP_CUTS", "1" );  // save decomposition
01807     myZZ->Set_Param( "AVERAGE_CUTS", "1" );
01808 }
01809
01810 void ZoltanPartitioner::SetHSFC_Parameters()
01811 {
01812     if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHilbert Space Filling Curve" << std::endl;
01813     // General parameters:
01814
01815     myZZ->Set_Param( "DEBUG_LEVEL", "0" );   // no debug messages
01816     myZZ->Set_Param( "LB_METHOD", "HSFC" );  // perform Hilbert space filling curve
01817
01818     // HSFC parameters:
01819
01820     myZZ->Set_Param( "KEEP_CUTS", "1" );  // save decomposition
01821 }
01822
01823 void ZoltanPartitioner::SetHypergraph_Parameters( const char* phg_method )
01824 {
01825     if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nHypergraph (or PHG): " << std::endl;
01826     // General parameters:
01827
01828     myZZ->Set_Param( "DEBUG_LEVEL", "0" );         // no debug messages
01829     myZZ->Set_Param( "LB_METHOD", "Hypergraph" );  // Hypergraph (or PHG)
01830
01831     // Hypergraph (or PHG) parameters:
01832     myZZ->Set_Param( "PHG_COARSEPARTITION_METHOD", phg_method );  // CoarsePartitionMethod
01833 }
01834
01835 void ZoltanPartitioner::SetPARMETIS_Parameters( const char* parmetis_method )
01836 {
01837     if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
01838     // General parameters:
01839
01840     myZZ->Set_Param( "DEBUG_LEVEL", "0" );       // no debug messages
01841     myZZ->Set_Param( "LB_METHOD", "PARMETIS" );  // the ParMETIS library
01842
01843     // PARMETIS parameters:
01844
01845     myZZ->Set_Param( "PARMETIS_METHOD", parmetis_method );  // method in the library
01846 }
01847
01848 void ZoltanPartitioner::SetOCTPART_Parameters( const char* oct_method )
01849 {
01850     if( mbpc->proc_config().proc_rank() == 0 ) std::cout << "\nOctree Partitioning: " << oct_method << std::endl;
01851     // General parameters:
01852
01853     myZZ->Set_Param( "DEBUG_LEVEL", "0" );      // no debug messages
01854     myZZ->Set_Param( "LB_METHOD", "OCTPART" );  // octree partitioning
01855
01856     // OCTPART parameters:
01857
01858     myZZ->Set_Param( "OCT_METHOD", oct_method );  // the SFC to be used
01859     myZZ->Set_Param( "OCT_OUTPUT_LEVEL", "3" );
01860 }
01861
01862 int ZoltanPartitioner::mbInitializePoints( int npts,
01863                                            double* pts,
01864                                            int* ids,
01865                                            int* adjs,
01866                                            int* length,
01867                                            double* obj_weights,
01868                                            double* edge_weights,
01869                                            int* parts,
01870                                            bool part_geom )
01871 {
01872     unsigned int i;
01873     int j;
01874     int *numPts, *nborProcs = NULL;
01875     int sum, ptsPerProc, ptsAssigned, mySize;
01876     MPI_Status stat;
01877     double* sendPts;
01878     int* sendIds;
01879     int* sendEdges  = NULL;
01880     int* sendNborId = NULL;
01881     int* sendProcs;
01882
01883     if( mbpc->proc_config().proc_rank() == 0 )
01884     {
01885         /* divide pts to start */
01886
01887         numPts      = (int*)malloc( sizeof( int ) * mbpc->proc_config().proc_size() );
01888         ptsPerProc  = npts / mbpc->proc_config().proc_size();
01889         ptsAssigned = 0;
01890
01891         for( i = 0; i < mbpc->proc_config().proc_size() - 1; i++ )
01892         {
01893             numPts[i] = ptsPerProc;
01894             ptsAssigned += ptsPerProc;
01895         }
01896
01897         numPts[mbpc->proc_config().proc_size() - 1] = npts - ptsAssigned;
01898
01899         mySize  = numPts[mbpc->proc_config().proc_rank()];
01900         sendPts = pts + ( 3 * numPts[0] );
01901         sendIds = ids + numPts[0];
01902         sum     = 0;  // possible no adjacency sent
01903         if( !part_geom )
01904         {
01905             sendEdges = length + numPts[0];
01906
01907             for( j = 0; j < numPts[0]; j++ )
01908                 sum += length[j];
01909
01910             sendNborId = adjs + sum;
01911
01912             for( j = numPts[0]; j < npts; j++ )
01913                 sum += length[j];
01914
01915             nborProcs = (int*)malloc( sizeof( int ) * sum );
01916         }
01917         for( j = 0; j < sum; j++ )
01918             if( ( i = adjs[j] / ptsPerProc ) < mbpc->proc_config().proc_size() )
01919                 nborProcs[j] = i;
01920             else
01921                 nborProcs[j] = mbpc->proc_config().proc_size() - 1;
01922
01923         sendProcs = nborProcs + ( sendNborId - adjs );
01924
01925         for( i = 1; i < mbpc->proc_config().proc_size(); i++ )
01926         {
01927             MPI_Send( &numPts[i], 1, MPI_INT, i, 0x00, mbpc->comm() );
01928             MPI_Send( sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01, mbpc->comm() );
01929             MPI_Send( sendIds, numPts[i], MPI_INT, i, 0x03, mbpc->comm() );
01930             MPI_Send( sendEdges, numPts[i], MPI_INT, i, 0x06, mbpc->comm() );
01931             sum = 0;
01932
01933             for( j = 0; j < numPts[i]; j++ )
01934                 sum += sendEdges[j];
01935
01936             MPI_Send( sendNborId, sum, MPI_INT, i, 0x07, mbpc->comm() );
01937             MPI_Send( sendProcs, sum, MPI_INT, i, 0x08, mbpc->comm() );
01938             sendPts += ( 3 * numPts[i] );
01939             sendIds += numPts[i];
01940             sendEdges += numPts[i];
01941             sendNborId += sum;
01942             sendProcs += sum;
01943         }
01944
01945         free( numPts );
01946     }
01947     else
01948     {
01949         MPI_Recv( &mySize, 1, MPI_INT, 0, 0x00, mbpc->comm(), &stat );
01950         pts    = (double*)malloc( sizeof( double ) * 3 * mySize );
01951         ids    = (int*)malloc( sizeof( int ) * mySize );
01952         length = (int*)malloc( sizeof( int ) * mySize );
01953         if( obj_weights != NULL ) obj_weights = (double*)malloc( sizeof( double ) * mySize );
01954         MPI_Recv( pts, 3 * mySize, MPI_DOUBLE, 0, 0x01, mbpc->comm(), &stat );
01955         MPI_Recv( ids, mySize, MPI_INT, 0, 0x03, mbpc->comm(), &stat );
01956         MPI_Recv( length, mySize, MPI_INT, 0, 0x06, mbpc->comm(), &stat );
01957         sum = 0;
01958
01959         for( j = 0; j < mySize; j++ )
01960             sum += length[j];
01961
01962         adjs = (int*)malloc( sizeof( int ) * sum );
01963         if( edge_weights != NULL ) edge_weights = (double*)malloc( sizeof( double ) * sum );
01964         nborProcs = (int*)malloc( sizeof( int ) * sum );
01965         MPI_Recv( adjs, sum, MPI_INT, 0, 0x07, mbpc->comm(), &stat );
01966         MPI_Recv( nborProcs, sum, MPI_INT, 0, 0x08, mbpc->comm(), &stat );
01967     }
01968
01969     Points       = pts;
01970     GlobalIds    = ids;
01971     NumPoints    = mySize;
01972     NumEdges     = length;
01973     NborGlobalId = adjs;
01974     NborProcs    = nborProcs;
01975     ObjWeights   = obj_weights;
01976     EdgeWeights  = edge_weights;
01977     Parts        = parts;
01978
01979     return mySize;
01980 }
01981
01982 void ZoltanPartitioner::mbFinalizePoints( int npts,
01983                                           int numExport,
01984                                           ZOLTAN_ID_PTR exportLocalIDs,
01985                                           int* exportProcs,
01986                                           int** assignment )
01987 {
01988     int* MyAssignment;
01989     int i;
01990     int numPts;
01991     MPI_Status stat;
01992     int* recvA;
01993
01994     /* assign pts to start */
01995
01996     if( mbpc->proc_config().proc_rank() == 0 )
01997         MyAssignment = (int*)malloc( sizeof( int ) * npts );
01998     else
01999         MyAssignment = (int*)malloc( sizeof( int ) * NumPoints );
02000
02001     for( i = 0; i < NumPoints; i++ )
02002         MyAssignment[i] = mbpc->proc_config().proc_rank();
02003
02004     for( i = 0; i < numExport; i++ )
02005         MyAssignment[exportLocalIDs[i]] = exportProcs[i];
02006
02007     if( mbpc->proc_config().proc_rank() == 0 )
02008     {
02009         /* collect pts */
02010         recvA = MyAssignment + NumPoints;
02011
02012         for( i = 1; i < (int)mbpc->proc_config().proc_size(); i++ )
02013         {
02014             MPI_Recv( &numPts, 1, MPI_INT, i, 0x04, mbpc->comm(), &stat );
02015             MPI_Recv( recvA, numPts, MPI_INT, i, 0x05, mbpc->comm(), &stat );
02016             recvA += numPts;
02017         }
02018
02019         *assignment = MyAssignment;
02020     }
02021     else
02022     {
02023         MPI_Send( &NumPoints, 1, MPI_INT, 0, 0x04, mbpc->comm() );
02024         MPI_Send( MyAssignment, NumPoints, MPI_INT, 0, 0x05, mbpc->comm() );
02025         free( MyAssignment );
02026     }
02027 }
02028
02029 int ZoltanPartitioner::mbGlobalSuccess( int rc )
02030 {
02031     int fail = 0;
02032     unsigned int i;
02033     int* vals = (int*)malloc( mbpc->proc_config().proc_size() * sizeof( int ) );
02034
02035     MPI_Allgather( &rc, 1, MPI_INT, vals, 1, MPI_INT, mbpc->comm() );
02036
02037     for( i = 0; i < mbpc->proc_config().proc_size(); i++ )
02038     {
02039         if( vals[i] != ZOLTAN_OK )
02040         {
02041             if( 0 == mbpc->proc_config().proc_rank() )
02042             {
02043                 mbShowError( vals[i], "Result on process " );
02044             }
02045             fail = 1;
02046         }
02047     }
02048
02049     free( vals );
02050     return fail;
02051 }
02052
02053 void ZoltanPartitioner::mbPrintGlobalResult( const char* s, int begin, int import, int exp, int change )
02054 {
02055     unsigned int i;
02056     int* v1 = (int*)malloc( 4 * sizeof( int ) );
02057     int* v2 = NULL;
02058     int* v;
02059
02060     v1[0] = begin;
02061     v1[1] = import;
02062     v1[2] = exp;
02063     v1[3] = change;
02064
02065     if( mbpc->proc_config().proc_rank() == 0 )
02066     {
02067         v2 = (int*)malloc( 4 * mbpc->proc_config().proc_size() * sizeof( int ) );
02068     }
02069
02070     MPI_Gather( v1, 4, MPI_INT, v2, 4, MPI_INT, 0, mbpc->comm() );
02071
02072     if( mbpc->proc_config().proc_rank() == 0 )
02073     {
02074         fprintf( stdout, "======%s======\n", s );
02075         for( i = 0, v = v2; i < mbpc->proc_config().proc_size(); i++, v += 4 )
02076         {
02077             fprintf( stdout, "%u: originally had %d, import %d, exp %d, %s\n", i, v[0], v[1], v[2],
02078                      v[3] ? "a change of partitioning" : "no change" );
02079         }
02080         fprintf( stdout, "==========================================\n" );
02081         fflush( stdout );
02082
02083         free( v2 );
02084     }
02085
02086     free( v1 );
02087 }
02088
02089 void ZoltanPartitioner::mbShowError( int val, const char* s )
02090 {
02091     if( s ) printf( "%s ", s );
02092
02093     switch( val )
02094     {
02095         case ZOLTAN_OK:
02096             printf( "%d: SUCCESSFUL\n", mbpc->proc_config().proc_rank() );
02097             break;
02098         case ZOLTAN_WARN:
02099             printf( "%d: WARNING\n", mbpc->proc_config().proc_rank() );
02100             break;
02101         case ZOLTAN_FATAL:
02102             printf( "%d: FATAL ERROR\n", mbpc->proc_config().proc_rank() );
02103             break;
02104         case ZOLTAN_MEMERR:
02105             printf( "%d: MEMORY ALLOCATION ERROR\n", mbpc->proc_config().proc_rank() );
02106             break;
02107         default:
02108             printf( "%d: INVALID RETURN CODE\n", mbpc->proc_config().proc_rank() );
02109             break;
02110     }
02111 }
02112
02113 /**********************
02114 ** call backs
02115 **********************/
02116
02117 int mbGetNumberOfAssignedObjects( void* /* userDefinedData */, int* err )
02118 {
02119     *err = 0;
02120     return NumPoints;
02121 }
02122
02123 void mbGetObjectList( void* /* userDefinedData */,
02124                       int /* numGlobalIds */,
02125                       int /* numLids */,
02126                       ZOLTAN_ID_PTR gids,
02127                       ZOLTAN_ID_PTR lids,
02128                       int wgt_dim,
02129                       float* obj_wgts,
02130                       int* err )
02131 {
02132     for( int i = 0; i < NumPoints; i++ )
02133     {
02134         gids[i] = GlobalIds[i];
02135         lids[i] = i;
02136         if( wgt_dim > 0 ) obj_wgts[i] = ObjWeights[i];
02137     }
02138
02139     *err = 0;
02140 }
02141
02142 int mbGetObjectSize( void* /* userDefinedData */, int* err )
02143 {
02144     *err = 0;
02145     return 3;
02146 }
02147
02148 void mbGetObject( void* /* userDefinedData */,
02149                   int /* numGlobalIds */,
02150                   int /* numLids */,
02151                   int numObjs,
02152                   ZOLTAN_ID_PTR /* gids */,
02153                   ZOLTAN_ID_PTR lids,
02154                   int numDim,
02155                   double* pts,
02156                   int* err )
02157 {
02158     int i, id, id3;
02159     int next = 0;
02160
02161     if( numDim != 3 )
02162     {
02163         *err = 1;
02164         return;
02165     }
02166
02167     for( i = 0; i < numObjs; i++ )
02168     {
02169         id = lids[i];
02170
02171         if( ( id < 0 ) || ( id >= NumPoints ) )
02172         {
02173             *err = 1;
02174             return;
02175         }
02176
02177         id3 = lids[i] * 3;
02178
02179         pts[next++] = Points[id3];
02180         pts[next++] = Points[id3 + 1];
02181         pts[next++] = Points[id3 + 2];
02182     }
02183 }
02184
02185 void mbGetNumberOfEdges( void* /* userDefinedData */,
02186                          int /* numGlobalIds */,
02187                          int /* numLids */,
02188                          int numObjs,
02189                          ZOLTAN_ID_PTR /* gids */,
02190                          ZOLTAN_ID_PTR lids,
02191                          int* numEdges,
02192                          int* err )
02193 {
02194     int i, id;
02195     int next = 0;
02196
02197     for( i = 0; i < numObjs; i++ )
02198     {
02199         id = lids[i];
02200
02201         if( ( id < 0 ) || ( id >= NumPoints ) )
02202         {
02203             *err = 1;
02204             return;
02205         }
02206
02207         numEdges[next++] = NumEdges[id];
02208     }
02209 }
02210
02211 void mbGetEdgeList( void* /* userDefinedData */,
02212                     int /* numGlobalIds */,
02213                     int /* numLids */,
02214                     int numObjs,
02215                     ZOLTAN_ID_PTR /* gids */,
02216                     ZOLTAN_ID_PTR lids,
02217                     int* /* numEdges */,
02218                     ZOLTAN_ID_PTR nborGlobalIds,
02219                     int* nborProcs,
02220                     int wgt_dim,
02221                     float* edge_wgts,
02222                     int* err )
02223 {
02224     int i, id, idSum, j;
02225     int next = 0;
02226
02227     for( i = 0; i < numObjs; i++ )
02228     {
02229         id = lids[i];
02230
02231         if( ( id < 0 ) || ( id >= NumPoints ) )
02232         {
02233             *err = 1;
02234             return;
02235         }
02236
02237         idSum = 0;
02238
02239         for( j = 0; j < id; j++ )
02240             idSum += NumEdges[j];
02241
02242         for( j = 0; j < NumEdges[id]; j++ )
02243         {
02244             nborGlobalIds[next] = NborGlobalId[idSum];
02245             nborProcs[next]     = NborProcs[idSum];
02246             if( wgt_dim > 0 ) edge_wgts[next] = EdgeWeights[idSum];
02247             next++;
02248             idSum++;
02249         }
02250     }
02251 }
02252
02253 void mbGetPart( void* /* userDefinedData */,
02254                 int /* numGlobalIds */,
02255                 int /* numLids */,
02256                 int numObjs,
02257                 ZOLTAN_ID_PTR /* gids */,
02258                 ZOLTAN_ID_PTR lids,
02259                 int* part,
02260                 int* err )
02261 {
02262     int i, id;
02263     int next = 0;
02264
02265     for( i = 0; i < numObjs; i++ )
02266     {
02267         id = lids[i];
02268
02269         if( ( id < 0 ) || ( id >= NumPoints ) )
02270         {
02271             *err = 1;
02272             return;
02273         }
02274
02275         part[next++] = Parts[id];
02276     }
02277 }
02278
02279 // new methods for partition in parallel, used by migrate in iMOAB
02280 ErrorCode ZoltanPartitioner::partition_owned_cells( Range& primary,
02281                                                     std::multimap< int, int >& extraGraphEdges,
02282                                                     std::map< int, int > procs,
02283                                                     int& numNewPartitions,
02284                                                     std::map< int, Range >& distribution,
02285                                                     int met,
02286                                                     std::vector< char >& ZoltanBuffer )
02287 {
02288     // start copy
02289     MeshTopoUtil mtu( mbImpl );
02290     Range adjs;
02291
02292     std::vector< int > adjacencies;
02293     std::vector< int > ids;
02294     ids.resize( primary.size() );
02295     std::vector< int > length;
02296     std::vector< double > coords;
02297     std::vector< int > nbor_proc;
02298     // can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited
02299     // by MBCN
02300     int neighbors[5 * MAX_SUB_ENTITIES];
02301     int neib_proc[5 * MAX_SUB_ENTITIES];
02302     double avg_position[3];
02303     int moab_id;
02304     int primaryDim = mbImpl->dimension_from_handle( *primary.rbegin() );
02305     // get the global id tag handle
02306     Tag gid = mbImpl->globalId_tag();
02307
02308     ErrorCode rval = mbImpl->tag_get_data( gid, primary, &ids[0] );MB_CHK_ERR( rval );
02309
02310     // mbpc is member in base class, PartitionerBase
02311     int rank = mbpc->rank();  // current rank , will be put on regular neighbors
02312     int i    = 0;
02313     for( Range::iterator rit = primary.begin(); rit != primary.end(); ++rit, i++ )
02314     {
02315         EntityHandle cell = *rit;
02316         // get bridge adjacencies for each cell
02317         if( 1 == met )
02318         {
02319             adjs.clear();
02320             rval = mtu.get_bridge_adjacencies( cell, ( primaryDim > 0 ? primaryDim - 1 : 3 ), primaryDim, adjs );MB_CHK_ERR( rval );
02321
02322             // get the graph vertex ids of those
02323             if( !adjs.empty() )
02324             {
02325                 assert( adjs.size() < 5 * MAX_SUB_ENTITIES );
02326                 rval = mbImpl->tag_get_data( gid, adjs, neighbors );MB_CHK_ERR( rval );
02327             }
02328             // if adjacent to neighbor partitions, add to the list
02329             int size_adjs = (int)adjs.size();
02330             moab_id       = ids[i];
02331             for( int k = 0; k < size_adjs; k++ )
02332                 neib_proc[k] = rank;  // current rank
02333             if( extraGraphEdges.find( moab_id ) != extraGraphEdges.end() )
02334             {
02335                 // it means that the current cell is adjacent to a cell in another partition ; maybe
02336                 // a few
02337                 std::pair< std::multimap< int, int >::iterator, std::multimap< int, int >::iterator > ret;
02338                 ret = extraGraphEdges.equal_range( moab_id );
02339                 for( std::multimap< int, int >::iterator it = ret.first; it != ret.second; ++it )
02340                 {
02341                     int otherID          = it->second;
02342                     neighbors[size_adjs] = otherID;         // the id of the other cell, across partition
02343                     neib_proc[size_adjs] = procs[otherID];  // this is how we built this map, the cell id maps to
02344                                                             // what proc it came from
02345                     size_adjs++;
02346                 }
02347             }
02348             // copy those into adjacencies vector
02349             length.push_back( size_adjs );
02350             std::copy( neighbors, neighbors + size_adjs, std::back_inserter( adjacencies ) );
02351             std::copy( neib_proc, neib_proc + size_adjs, std::back_inserter( nbor_proc ) );
02352         }
02353         else if( 2 <= met )  // include 2 RCB or 3, RCB + gnomonic projection
02354         {
02355             if( TYPE_FROM_HANDLE( cell ) == MBVERTEX )
02356             {
02357                 rval = mbImpl->get_coords( &cell, 1, avg_position );MB_CHK_ERR( rval );
02358             }
02359             else
02360             {
02361                 rval = mtu.get_average_position( cell, avg_position );MB_CHK_ERR( rval );
02362             }
02363             if( 3 <= met )
02364             {
02365                 IntxUtils::transform_coordinates( avg_position, 2 );  // 2 means gnomonic projection
02366             }
02367             std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) );
02368         }
02369     }
02370
02371 #ifdef VERBOSE
02372     std::stringstream ff2;
02373     ff2 << "zoltanInput_" << mbpc->rank() << ".txt";
02374     std::ofstream ofs;
02375     ofs.open( ff2.str().c_str(), std::ofstream::out );
02376     ofs << "Length vector: " << std::endl;
02377     std::copy( length.begin(), length.end(), std::ostream_iterator< int >( ofs, ", " ) );
02378     ofs << std::endl;
02379     ofs << "Adjacencies vector: " << std::endl;
02380     std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< int >( ofs, ", " ) );
02381     ofs << std::endl;
02382     ofs << "Moab_ids vector: " << std::endl;
02383     std::copy( ids.begin(), ids.end(), std::ostream_iterator< int >( ofs, ", " ) );
02384     ofs << std::endl;
02385     ofs << "Coords vector: " << std::endl;
02386     std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( ofs, ", " ) );
02387     ofs << std::endl;
02388     ofs.close();
02389 #endif
02390
02391     // these are static var in this file, and used in the callbacks
02392     Points = NULL;
02393     if( 1 != met ) Points = &coords[0];
02394     GlobalIds    = &ids[0];
02395     NumPoints    = (int)ids.size();
02396     NumEdges     = &length[0];
02397     NborGlobalId = &adjacencies[0];
02398     NborProcs    = &nbor_proc[0];
02399     ObjWeights   = NULL;
02400     EdgeWeights  = NULL;
02401     Parts        = NULL;
02402
02403     float version;
02404     if( mbpc->rank() == 0 ) std::cout << "Initializing zoltan..." << std::endl;
02405
02406     Zoltan_Initialize( argcArg, argvArg, &version );
02407
02408     // Create Zoltan object.  This calls Zoltan_Create.
02409     // old code
02410     if( met <= 4 )
02411     {
02412
02413         if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
02414
02415         // set # requested partitions
02416         char buff[10];
02417         sprintf( buff, "%d", numNewPartitions );
02418         int retval = myZZ->Set_Param( "NUM_GLOBAL_PARTITIONS", buff );
02419         if( ZOLTAN_OK != retval ) return MB_FAILURE;
02420
02421         // request parts assignment
02422         retval = myZZ->Set_Param( "RETURN_LISTS", "PARTS" );
02423         if( ZOLTAN_OK != retval ) return MB_FAILURE;
02424
02425         myZZ->Set_Num_Obj_Fn( mbGetNumberOfAssignedObjects, NULL );
02426         myZZ->Set_Obj_List_Fn( mbGetObjectList, NULL );
02427         // due to a bug in zoltan, if method is graph partitioning, do not pass coordinates!!
02428         if( 2 <= met )
02429         {
02430             myZZ->Set_Num_Geom_Fn( mbGetObjectSize, NULL );
02431             myZZ->Set_Geom_Multi_Fn( mbGetObject, NULL );
02432             if( 3 <= met )
02433                 SetRCB_Parameters( /*const bool recompute_rcb_box*/ true );  // recompute rcb box
02434             else
02435                 SetRCB_Parameters( /*const bool recompute_rcb_box*/ false );  // recompute rcb box // is it faster ?
02436         }
02437         else if( 1 == met )
02438         {
02439             myZZ->Set_Num_Edges_Multi_Fn( mbGetNumberOfEdges, NULL );
02440             myZZ->Set_Edge_List_Multi_Fn( mbGetEdgeList, NULL );
02441             SetHypergraph_Parameters( "auto" );
02442         }
02443
02444         // Perform the load balancing partitioning
02445
02446         int changes;
02447         int numGidEntries;
02448         int numLidEntries;
02449         int num_import;
02450         ZOLTAN_ID_PTR import_global_ids, import_local_ids;
02451         int* import_procs;
02452         int* import_to_part;
02453         int num_export;
02454         ZOLTAN_ID_PTR export_global_ids, export_local_ids;
02455         int *assign_procs, *assign_parts;
02456
02457         if( mbpc->rank() == 0 )
02458             std::cout << "Computing partition using method (1-graph, 2-geom):" << met << " for " << numNewPartitions
02459                       << " parts..." << std::endl;
02460
02461 #ifndef NDEBUG
02462 #if 0
02463       static int counter=0; // it may be possible to call function multiple times in a simulation
02464       // give a way to not overwrite the files
02465       // it should work only with a modified version of Zoltan
02466       std::stringstream basename;
02467       if (1==met)
02468       {
02469         basename << "phg_" << counter++;
02470         Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 0, 1, 0);
02471       }
02472       else if (2==met)
02473       {
02474         basename << "rcb_" << counter++;
02475         Zoltan_Generate_Files(myZZ->Get_C_Handle(), (char*)(basename.str().c_str()), 1, 1, 0, 0);
02476       }
02477 #endif
02478 #endif
02479         retval = myZZ->LB_Partition( changes, numGidEntries, numLidEntries, num_import, import_global_ids,
02480                                      import_local_ids, import_procs, import_to_part, num_export, export_global_ids,
02481                                      export_local_ids, assign_procs, assign_parts );
02482         if( ZOLTAN_OK != retval ) return MB_FAILURE;
02483
02484 #ifdef VERBOSE
02485         std::stringstream ff3;
02486         ff3 << "zoltanOutput_" << mbpc->rank() << ".txt";
02487         std::ofstream ofs3;
02488         ofs3.open( ff3.str().c_str(), std::ofstream::out );
02489         ofs3 << " export elements on rank " << rank << " \n";
02490         ofs3 << "\t index \t gb_id \t local \t proc \t part \n";
02491         for( int k = 0; k < num_export; k++ )
02492         {
02493             ofs3 << "\t" << k << "\t" << export_global_ids[k] << "\t" << export_local_ids[k] << "\t" << assign_procs[k]
02494                  << "\t" << assign_parts[k] << "\n";
02495         }
02496         ofs3.close();
02497 #endif
02498
02499         // basically each local cell is assigned to a part
02500
02501         // new code: if method == 4, we need to serialize, and send it to root of the coupler
02502         // here, we serialize it; sending it will happen in the calling method, where we have access to
02503         // the root of the coupler, which will store the buffer
02504         if( 4 == met )
02505         {
02506             if( 0 == rank )
02507             {
02508                 size_t bufSize = myZZ->Serialize_Size();
02509                 /* Then allocate  the buffer */
02510                 ZoltanBuffer.resize( bufSize );
02511                 int ierr = myZZ->Serialize( bufSize, &ZoltanBuffer[0] );
02512                 if( ierr != 0 ) MB_CHK_ERR( MB_FAILURE );
02513             }
02514         }
02515         assert( num_export == (int)primary.size() );
02516         for( i = 0; i < num_export; i++ )
02517         {
02518             EntityHandle cell = primary[export_local_ids[i]];
02519             distribution[assign_parts[i]].insert( cell );
02520         }
02521
02522         Zoltan::LB_Free_Part( &import_global_ids, &import_local_ids, &import_procs, &import_to_part );
02523         Zoltan::LB_Free_Part( &export_global_ids, &export_local_ids, &assign_procs, &assign_parts );
02524
02525         delete myZZ;
02526         myZZ = NULL;
02527     }
02528     else if( 5 == met )
02529     {
02530         if( NULL == myZZ ) myZZ = new Zoltan( mbpc->comm() );
02531         // zoltan buffer is only on rank 0 right now
02532         // broadcast it first:
02533         int rank = mbpc->rank();
02534         size_t bufSize;
02535         if( rank == 0 ) bufSize = ZoltanBuffer.size();
02536         MPI_Bcast( (char*)&bufSize, sizeof( bufSize ), MPI_CHAR, 0, mbpc->comm() );
02537         if( 0 != rank ) ZoltanBuffer.resize( bufSize );
02538
02539         MPI_Bcast( &ZoltanBuffer[0], bufSize, MPI_CHAR, 0, mbpc->comm() );
02540         // deserialize on each task
02541         int ierr = myZZ->Deserialize( ZoltanBuffer.size(), &ZoltanBuffer[0] );
02542         if( ierr != 0 ) MB_CHK_ERR( MB_FAILURE );
02543
02544         // use here the partitioning !!
02545         /* code in inferred partitions:
02546         // Compute the coordinate's part assignment
02547         myZZ->LB_Point_PP_Assign( ecoords, proc, part );
02548
02549         // Store the part assignment in the return array
02550         part_assignments[part].push_back( elverts[iel] );*/
02551         i = 0;
02552         for( Range::iterator rit = primary.begin(); rit != primary.end(); ++rit, i++ )
02553         {
02554             EntityHandle cell = *rit;
02555             int proc = 0, part = 0;
02556             // coords are calculated in advance, contain the centers of the cells, maybe in gnomonic plane
02557             myZZ->LB_Point_PP_Assign( &coords[3 * i], proc, part );
02558             distribution[part].insert( cell );
02559         }
02560         // TODO
02561         delete myZZ;
02562         myZZ = NULL;
02563     }
02564
02565     // clear arrays that were resized locally, to free up local memory
02566
02567     std::vector< int >().swap( adjacencies );
02568     std::vector< int >().swap( ids );
02569     std::vector< int >().swap( length );
02570     std::vector< int >().swap( nbor_proc );
02571     std::vector< double >().swap( coords );
02572
02573     return MB_SUCCESS;
02574 }
