adaptive_kd_tree_tests.cpp File Reference
#include "moab/Core.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/CartVect.hpp"
#include "moab/GeomUtil.hpp"
#include "moab/Range.hpp"
#include "TestUtil.hpp"
#include <iostream>
#include <algorithm>
#include <sstream>
+ Include dependency graph for adaptive_kd_tree_tests.cpp:
Defines
#define CHECK_RAY_XSECTS(PT, DIR, T_IN, T_OUT)
Functions
bool box_equal (const AdaptiveKDTreeIter &iter, double x_min, double y_min, double z_min, double x_max, double y_max, double z_max)
void build_triangles (Interface *moab, Range &tris, int num_vert, const double *coords, int num_tri, const unsigned *conn)
void build_triangle_box_small (Interface *moab, Range &tris)
void build_triangle_box_large (Interface *moab, Range &tris)
void build_triangle_octahedron (Interface *moab, Range &tris)
void test_valid_tree (AdaptiveKDTree *tool, EntityHandle root, FileOptions &options, const Range &expected_tris)
void check_common_vertex (Interface *moab, const EntityHandle *tris, unsigned num_tri, CartVect point)
void check_point_in_triangles (Interface *moab, const EntityHandle *tris, unsigned num_tris, CartVect point)
void create_simple_2d_tree (AdaptiveKDTree &tool, EntityHandle &root, EntityHandle leaves[9]=0)
void leaf_iterator_test ()
void test_tree_merge_nodes ()
void test_build_tree_bisect_triangles ()
void test_closest_triangle ()
void test_sphere_intersect_triangles ()
void test_ray_intersect_triangles ()
void test_leaf_volume ()
void test_leaf_sibling ()
void test_leaf_intersects_plane ()
void test_leaf_intersects_ray ()
int main ()
Define Documentation
#define CHECK_RAY_XSECTS (   PT,
  DIR,
  T_IN,
  T_OUT
Value:
do                                                               \
        CHECK( iter.intersect_ray( ( PT ), ( DIR ), t_in, t_out ) ); \
        CHECK_REAL_EQUAL( ( T_IN ), t_in, 1e-6 );                    \
        CHECK_REAL_EQUAL( ( T_OUT ), t_out, 1e-6 );                  \
    } while( false )
Definition at line 1060 of file adaptive_kd_tree_tests.cpp.
Referenced by test_leaf_intersects_ray().
Function Documentation
bool box_equal ( const AdaptiveKDTreeIter iter,
double  x_min,
double  y_min,
double  z_min,
double  x_max,
double  y_max,
double  z_max
Definition at line 19 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTreeIter::box_max(), and moab::AdaptiveKDTreeIter::box_min().
Referenced by create_simple_2d_tree(), leaf_iterator_test(), and test_tree_merge_nodes().
    return iter.box_min()[0] == x_min && iter.box_min()[1] == y_min && iter.box_min()[2] == z_min &&
           iter.box_max()[0] == x_max && iter.box_max()[1] == y_max && iter.box_max()[2] == z_max;
void build_triangle_box_large ( Interface moab,
Range tris
Definition at line 67 of file adaptive_kd_tree_tests.cpp.
References build_triangles(), and conn.
Referenced by test_build_tree_bisect_triangles(), test_closest_triangle(), and test_sphere_intersect_triangles().
    const double coords[] = { // corners
                              -3, -3, -3, 3, -3, -3, 3, 3, -3, -3, 3, -3, -3, -3, 3, 3, -3, 3, 3, 3, 3, -3, 3, 3,
                              // edges
                              -1, -3, -3, 1, -3, -3, 3, -1, -3, 3, 1, -3, 1, 3, -3, -1, 3, -3, -3, 1, -3, -3, -1, -3,
                              -1, -3, 3, 1, -3, 3, 3, -1, 3, 3, 1, 3, 1, 3, 3, -1, 3, 3, -3, 1, 3, -3, -1, 3,
                              -3, -3, -1, -3, -3, 1, 3, -3, -1, 3, -3, 1, 3, 3, -1, 3, 3, 1, -3, 3, -1, -3, 3, 1,
                              // faces
                              -1, -3, -1, 1, -3, -1, 1, -3, 1, -1, -3, 1,
                              3, -1, -1, 3, 1, -1, 3, 1, 1, 3, -1, 1,
                              1, 3, -1, -1, 3, -1, -1, 3, 1, 1, 3, 1,
                              -3, 1, -1, -3, -1, -1, -3, -1, 1, -3, 1, 1,
                              -1, -1, -3, 1, -1, -3, 1, 1, -3, -1, 1, -3,
                              -1, -1, 3, 1, -1, 3, 1, 1, 3, -1, 1, 3 };
    const unsigned conn[] = {
        // face 0
        0, 8, 24, 8, 32, 24, 8, 33, 32, 8, 9, 33, 9, 1, 33, 1, 26, 33, 24, 35, 25, 24, 32, 35, 32, 33, 35, 33, 34, 35,
        33, 27, 34, 33, 26, 27, 35, 4, 25, 35, 16, 4, 35, 17, 16, 35, 34, 17, 27, 17, 34, 27, 5, 17,
        // face 1
        36, 26, 1, 36, 1, 10, 36, 10, 11, 36, 11, 37, 11, 28, 37, 11, 2, 28, 36, 27, 26, 36, 39, 27, 36, 38, 39, 36, 37,
        38, 37, 28, 38, 28, 29, 38, 18, 5, 27, 18, 27, 39, 18, 39, 38, 18, 38, 19, 6, 19, 38, 6, 38, 29,
        // face 2
        12, 28, 2, 12, 40, 28, 12, 41, 40, 12, 13, 41, 3, 41, 13, 3, 30, 41, 43, 29, 28, 43, 28, 40, 43, 40, 41, 43, 41,
        42, 41, 31, 42, 41, 30, 31, 43, 6, 29, 43, 20, 6, 43, 21, 20, 43, 42, 21, 21, 42, 31, 21, 31, 7,
        // face 3
        44, 30, 3, 44, 3, 14, 44, 14, 15, 44, 15, 45, 15, 24, 45, 15, 0, 24, 44, 31, 30, 44, 47, 31, 44, 46, 47, 44, 45,
        46, 46, 45, 24, 46, 24, 25, 31, 22, 7, 31, 47, 22, 46, 22, 47, 46, 23, 22, 46, 4, 23, 46, 25, 4,
        // face 4
        8, 15, 0, 8, 48, 15, 8, 49, 48, 8, 9, 49, 1, 49, 9, 1, 10, 49, 51, 14, 15, 51, 15, 48, 51, 48, 49, 51, 49, 50,
        11, 50, 49, 11, 49, 10, 51, 3, 14, 51, 13, 3, 51, 12, 13, 51, 50, 12, 11, 12, 50, 11, 2, 12,
        // face 5
        4, 52, 16, 4, 23, 52, 22, 52, 23, 22, 55, 52, 22, 21, 55, 22, 7, 21, 17, 16, 52, 17, 52, 53, 54, 53, 52, 54, 52,
        55, 54, 55, 21, 54, 21, 20, 18, 5, 17, 18, 17, 53, 18, 53, 54, 18, 54, 19, 6, 19, 54, 6, 54, 20 };
    build_triangles( moab, tris, 56, coords, 108, conn );
void build_triangle_box_small ( Interface moab,
Range tris
Definition at line 54 of file adaptive_kd_tree_tests.cpp.
Referenced by test_build_tree_bisect_triangles(), test_closest_triangle(), test_ray_intersect_triangles(), and test_sphere_intersect_triangles().
    const double coords[] = { -1, -1, -1, 1, -1, -1, 1, 1, -1, -1, 1, -1, -1, -1, 1, 1, -1, 1, 1, 1, 1, -1, 1, 1 };
    const unsigned conn[] = { 0, 1, 5, 0, 5, 4, 2, 6, 7, 2, 7, 3, 1, 2, 6, 1, 6, 5,
                              0, 3, 4, 3, 7, 4, 0, 1, 3, 1, 2, 3, 4, 5, 6, 4, 6, 7 };
    build_triangles( moab, tris, 8, coords, 12, conn );
void build_triangle_octahedron ( Interface moab,
Range tris
Definition at line 115 of file adaptive_kd_tree_tests.cpp.
Referenced by test_build_tree_bisect_triangles().
    const double coords[] = { 1, 0, 0, 0, 1, 0, -1, 0, 0, 0, -1, 0, 0, 0, 1, 0, 0, -1 };
    const unsigned conn[] = { 0, 1, 4, 1, 2, 4, 2, 3, 4, 3, 0, 4, 1, 0, 5, 2, 1, 5, 3, 2, 5, 0, 3, 5 };
    build_triangles( moab, tris, 6, coords, 8, conn );
void build_triangles ( Interface moab,
Range tris,
int  num_vert,
const double *  coords,
int  num_tri,
const unsigned *  conn
Definition at line 31 of file adaptive_kd_tree_tests.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::insert(), and MBTRI.
Referenced by build_triangle_box_large(), build_triangle_box_small(), and build_triangle_octahedron().
    std::vector< EntityHandle > verts( num_vert );
    for( int i = 0; i < num_vert; ++i )
        moab->create_vertex( coords + 3 * i, verts[i] );
    EntityHandle tri, tri_verts[3];
    for( int i = 0; i < num_tri; ++i )
        tri_verts[0] = verts[conn[3 * i]];
        tri_verts[1] = verts[conn[3 * i + 1]];
        tri_verts[2] = verts[conn[3 * i + 2]];
        moab->create_element( MBTRI, tri_verts, 3, tri );
        tris.insert( tri );
void check_common_vertex ( Interface moab,
const EntityHandle tris,
unsigned  num_tri,
CartVect  point
Definition at line 161 of file adaptive_kd_tree_tests.cpp.
References CHECK, conn, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), MB_SUCCESS, MBTRI, tri_coords(), and moab::Interface::type_from_handle().
Referenced by test_closest_triangle(), and test_sphere_intersect_triangles().
    for( unsigned i = 0; i < num_tri; ++i )
        CHECK( MBTRI == moab->type_from_handle( tris[i] ) );
    ErrorCode rval;
    CartVect tri_coords[3];
    const EntityHandle* conn;
    int conn_len;
    rval = moab->get_connectivity( tris[0], conn, conn_len );
    CHECK( MB_SUCCESS == rval );
    rval = moab->get_coords( conn, 3, tri_coords[0].array() );
    tri_coords[0] -= point;
    tri_coords[1] -= point;
    tri_coords[2] -= point;
    EntityHandle vertex = 0;
    if( tri_coords[0] % tri_coords[0] < 1e-6 )
        vertex = conn[0];
    else if( tri_coords[1] % tri_coords[1] < 1e-6 )
        vertex = conn[1];
    else if( tri_coords[2] % tri_coords[2] < 1e-6 )
        vertex = conn[2];
    else
        CHECK( false );
    for( unsigned j = 1; j < num_tri; ++j )
        rval = moab->get_connectivity( tris[j], conn, conn_len );
        CHECK( conn[0] == vertex || conn[1] == vertex || conn[2] == vertex );
void check_point_in_triangles ( Interface moab,
unsigned  num_tris,
CartVect  point
Definition at line 194 of file adaptive_kd_tree_tests.cpp.
References CHECK, moab::GeomUtil::closest_location_on_tri(), conn, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), MB_SUCCESS, MBTRI, tri_coords(), and moab::Interface::type_from_handle().
Referenced by test_closest_triangle(), and test_ray_intersect_triangles().
    ErrorCode rval;
    CartVect tri_coords[3], tript;
    int conn_len;
    for( unsigned i = 0; i < num_tris; ++i )
        rval = moab->get_connectivity( tris[i], conn, conn_len );
        GeomUtil::closest_location_on_tri( point, tri_coords, tript );
        tript -= point;
        CHECK( fabs( tript[0] ) < 1e-6 );
        CHECK( fabs( tript[1] ) < 1e-6 );
        CHECK( fabs( tript[2] ) < 1e-6 );
void create_simple_2d_tree ( AdaptiveKDTree tool,
EntityHandle root,
EntityHandle  leaves[9] = 0
Definition at line 238 of file adaptive_kd_tree_tests.cpp.
References box_equal(), CHECK, moab::AdaptiveKDTree::Plane::coord, moab::Tree::create_root(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AdaptiveKDTree::Plane::norm, moab::AdaptiveKDTree::split_leaf(), moab::AdaptiveKDTreeIter::step(), moab::AdaptiveKDTree::X, and moab::AdaptiveKDTree::Y.
Referenced by leaf_iterator_test(), test_leaf_sibling(), test_leaf_volume(), and test_tree_merge_nodes().
    ErrorCode rval;
    AdaptiveKDTree::Plane plane;
    // create a single-node tree
    double min[3] = { -5, -4, -1 };
    double max[3] = { 5, 4, 1 };
    rval          = tool.create_root( min, max, root );
    // get iterator for tree
    AdaptiveKDTreeIter iter;
    rval = tool.get_tree_iterator( root, iter );
    CHECK( box_equal( iter, -5, -4, -1, 5, 4, 1 ) );
    // split plane (1)
    plane.norm  = AdaptiveKDTree::Y;
    plane.coord = 0.0;
    rval        = tool.split_leaf( iter, plane );
    CHECK( box_equal( iter, -5, -4, -1, 5, 0, 1 ) );
    // split plane (2)
    plane.norm  = AdaptiveKDTree::X;
    plane.coord = -1.0;
    CHECK( box_equal( iter, -5, -4, -1, -1, 0, 1 ) );
    // split plane (3), leaf [1]
    plane.coord = -2.0;
    CHECK( box_equal( iter, -5, -4, -1, -1, -2, 1 ) );
    if( leaves ) leaves[1] = iter.handle();
    // leaf [2]
    rval = iter.step();
    CHECK( box_equal( iter, -5, -2, -1, -1, 0, 1 ) );
    if( leaves ) leaves[2] = iter.handle();
    // non-leaf right of split plane (2)
    rval = iter.step();
    CHECK( box_equal( iter, -1, -4, -1, 5, 0, 1 ) );
    // split plane (4) and leaf [3]
    plane.coord = 4.0;
    CHECK( box_equal( iter, -1, -4, -1, 4, 0, 1 ) );
    if( leaves ) leaves[3] = iter.handle();
    // leaf [4]
    rval = iter.step();
    CHECK( box_equal( iter, 4, -4, -1, 5, 0, 1 ) );
    if( leaves ) leaves[4] = iter.handle();
    // non-leaf above split plane (1)
    rval = iter.step();
    CHECK( box_equal( iter, -5, 0, -1, 5, 4, 1 ) );
    // split plane (5)
    plane.coord = 0.0;
    CHECK( box_equal( iter, -5, 0, -1, 0, 4, 1 ) );
    // split plane (6) and leaf [5]
    plane.coord = -3.0;
    CHECK( box_equal( iter, -5, 0, -1, -3, 4, 1 ) );
    if( leaves ) leaves[5] = iter.handle();
    // leaf [6];
    rval = iter.step();
    CHECK( box_equal( iter, -3, 0, -1, 0, 4, 1 ) );
    if( leaves ) leaves[6] = iter.handle();
    // non-leaf right of split plane (5)
    rval = iter.step();
    CHECK( box_equal( iter, 0, 0, -1, 5, 4, 1 ) );
    // split plane (7) and leaf [7]
    plane.coord = 3.0;
    CHECK( box_equal( iter, 0, 0, -1, 5, 3, 1 ) );
    if( leaves ) leaves[7] = iter.handle();
    // leaf [8];
    rval = iter.step();
    CHECK( box_equal( iter, 0, 3, -1, 5, 4, 1 ) );
    if( leaves ) leaves[8] = iter.handle();
    // the end
    rval = iter.step();
    CHECK( MB_ENTITY_NOT_FOUND == rval );
Definition at line 352 of file adaptive_kd_tree_tests.cpp.
References box_equal(), CHECK, moab::Tree::create_root(), create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTreeIter::get_neighbors(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), mb, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AdaptiveKDTree::reset_tree(), moab::AdaptiveKDTreeIter::step(), swap(), moab::AdaptiveKDTree::X, moab::AdaptiveKDTree::Y, and moab::AdaptiveKDTree::Z.
Referenced by main().
    ErrorCode rval;
    Core moab;
    Interface* mb = &moab;
    AdaptiveKDTree tool( mb );
    EntityHandle root;
    double min[3] = { -3, -2, -1 };
    double max[3] = { 1, 2, 3 };
    CHECK( box_equal( iter, -3, -2, -1, 1, 2, 3 ) );
    // check that steping the iterator fails correctly.
    rval = iter.step();
    rval = iter.step();
    CHECK( MB_SUCCESS != rval );
    rval = tool.reset_tree();
    root = 0;
    // construct a simple 2D tree for remaining tests
    EntityHandle leaves[9];
    create_simple_2d_tree( tool, root, leaves );
    /**** Now traverse tree again, and check neighbors of each leaf *****/
    std::vector< AdaptiveKDTreeIter > list;
    // leaf [1]
    CHECK( iter.handle() == leaves[1] );
    list.clear();
    rval = iter.get_neighbors( AdaptiveKDTree::X, true, list );
    CHECK( list.empty() );
    list.clear();
    rval = iter.get_neighbors( AdaptiveKDTree::X, false, list );
    CHECK( list.size() == 1 );
    // should be leaf [3]
    CHECK( box_equal( list.front(), -1, -4, -1, 4, 0, 1 ) );
    CHECK( list.front().handle() == leaves[3] );
    list.clear();
    rval = iter.get_neighbors( AdaptiveKDTree::Y, true, list );
    list.clear();
    rval = iter.get_neighbors( AdaptiveKDTree::Y, false, list );
    // should be leaf [2]
    CHECK( box_equal( list.front(), -5, -2, -1, -1, 0, 1 ) );
    CHECK( list.front().handle() == leaves[2] );
    list.clear();
    rval = iter.get_neighbors( AdaptiveKDTree::Z, true, list );
    list.clear();
    rval = iter.get_neighbors( AdaptiveKDTree::Z, false, list );
    // leaf [2]
    rval = iter.step();
    CHECK( iter.handle() == leaves[2] );
    list.clear();
    list.clear();
    list.clear();
    // should be leaf [1]
    CHECK( box_equal( list.front(), -5, -4, -1, -1, -2, 1 ) );
    CHECK( list.front().handle() == leaves[1] );
    list.clear();
    CHECK( list.size() == 2 );
    // should be leaf [5] and leaf[6]
    if( list[0].handle() == leaves[6] ) std::swap( list[0], list[1] );
    CHECK( list[0].handle() == leaves[5] );
    CHECK( list[1].handle() == leaves[6] );
    CHECK( box_equal( list[0], -5, 0, -1, -3, 4, 1 ) );
    CHECK( box_equal( list[1], -3, 0, -1, 0, 4, 1 ) );
    list.clear();
    list.clear();
    // leaf [3]
    rval = iter.step();
    CHECK( iter.handle() == leaves[3] );
    // leaf [4]
    rval = iter.step();
    CHECK( iter.handle() == leaves[4] );
    // leaf [5]
    rval = iter.step();
    CHECK( iter.handle() == leaves[5] );
    // leaf [6]
    rval = iter.step();
    CHECK( iter.handle() == leaves[6] );
    // leaf [7]
    rval = iter.step();
    CHECK( iter.handle() == leaves[7] );
    // leaf [8]
    rval = iter.step();
    CHECK( iter.handle() == leaves[8] );
int main ( )
Definition at line 1131 of file adaptive_kd_tree_tests.cpp.
References error_count, moab::fail(), leaf_iterator_test(), RUN_TEST, test_build_tree_bisect_triangles(), test_closest_triangle(), test_leaf_intersects_plane(), test_leaf_intersects_ray(), test_leaf_sibling(), test_leaf_volume(), test_ray_intersect_triangles(), test_sphere_intersect_triangles(), and test_tree_merge_nodes().
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( 0, 0 );
    if( fail ) return fail;
#endif
    int error_count = 0;
    error_count += RUN_TEST( leaf_iterator_test );
    error_count += RUN_TEST( test_build_tree_bisect_triangles );
    error_count += RUN_TEST( test_closest_triangle );
    error_count += RUN_TEST( test_sphere_intersect_triangles );
    error_count += RUN_TEST( test_ray_intersect_triangles );
    error_count += RUN_TEST( test_tree_merge_nodes );
    error_count += RUN_TEST( test_leaf_volume );
    error_count += RUN_TEST( test_leaf_sibling );
    error_count += RUN_TEST( test_leaf_intersects_plane );
    error_count += RUN_TEST( test_leaf_intersects_ray );
    fail = MPI_Finalize();
#endif
    return error_count;
Definition at line 552 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTree::build_tree(), build_triangle_box_large(), build_triangle_box_small(), build_triangle_octahedron(), CHECK, moab::Range::clear(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::AdaptiveKDTree::reset_tree(), and test_valid_tree().
    Core moab;
    AdaptiveKDTree tool( &moab );
    Range box_tris;
    std::ostringstream options;
    options << "MAX_PER_LEAF=1;SPLITS_PER_DIR=1;PLANE_SET=0;";
    FileOptions opts( options.str().c_str() );
    EntityHandle root;
    ErrorCode rval;
    moab.delete_mesh();
    box_tris.clear();
    build_triangle_box_small( &moab, box_tris );
    rval = tool.build_tree( box_tris, &root, &opts );
    test_valid_tree( &tool, root, opts, box_tris );
    tool.reset_tree();
    moab.delete_mesh();
    box_tris.clear();
    build_triangle_octahedron( &moab, box_tris );
    tool.reset_tree();
    moab.delete_mesh();
    box_tris.clear();
    build_triangle_box_large( &moab, box_tris );
    tool.reset_tree();
    options << "MAX_DEPTH=2;";
    opts = FileOptions( options.str().c_str() );
    tool.reset_tree();
Definition at line 597 of file adaptive_kd_tree_tests.cpp.
References moab::CartVect::array(), moab::AdaptiveKDTree::build_tree(), build_triangle_box_large(), build_triangle_box_small(), CHECK, check_common_vertex(), check_point_in_triangles(), moab::Range::clear(), moab::AdaptiveKDTree::closest_triangle(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTree::reset_tree(), test_valid_tree(), and z.
    Core moab;
    Range box_tris;
    EntityHandle root;
    ErrorCode rval;
    EntityHandle tri;
    moab.delete_mesh();
    box_tris.clear();
    // test closest to each corner of the box.
    for( unsigned i = 0; i < 8; ++i )
        int x           = i & 1 ? 1 : -1;
        int y           = i & 2 ? 1 : -1;
        int z           = i & 4 ? 1 : -1;
        double coords[] = { 2.0 * x, 2.0 * y, 2.0 * z };
        CartVect point;
        rval = tool.closest_triangle( root, coords, point.array(), tri );
        // check result position
        CHECK( fabs( x - point[0] ) < 1e-6 );
        CHECK( fabs( y - point[1] ) < 1e-6 );
        CHECK( fabs( z - point[2] ) < 1e-6 );
        // check point is at triangle vertex
        check_common_vertex( tool.moab(), &tri, 1, point );
    // test location on each face
    const CartVect facepts[] = { CartVect( -1.0, 0.5, 0.5 ), CartVect( 1.0, 0.5, 0.5 ),  CartVect( 0.5, -1.0, 0.5 ),
                                 CartVect( 0.5, 1.0, 0.5 ),  CartVect( 0.5, 0.5, -1.0 ), CartVect( 0.5, 0.5, 1.0 ) };
    for( unsigned i = 0; i < 6; ++i )
        CartVect point;
        rval = tool.closest_triangle( root, facepts[i].array(), point.array(), tri );
        const CartVect diff = facepts[i] - point;
        CHECK( fabs( diff[0] ) < 1e-6 );
        CHECK( fabs( diff[1] ) < 1e-6 );
        CHECK( fabs( diff[2] ) < 1e-6 );
        // check that point is contained within triangle
        check_point_in_triangles( tool.moab(), &tri, 1, point );
    // test a location really far from the tree
        const double far[] = { 0.75, 0.75, 200 };
        CartVect point;
        rval = tool.closest_triangle( root, far, point.array(), tri );
        CHECK( fabs( point[0] - 0.75 ) < 1e-6 );
        CHECK( fabs( point[1] - 0.75 ) < 1e-6 );
        CHECK( fabs( point[2] - 1.00 ) < 1e-6 );
    // now do it all again with a lot more triangles
    tool.reset_tree();
    moab.delete_mesh();
    box_tris.clear();
        double coords[] = { 4.0 * x, 4.0 * y, 4.0 * z };
        CartVect point;
        CHECK( fabs( 3.0 * x - point[0] ) < 1e-6 );
        CHECK( fabs( 3.0 * y - point[1] ) < 1e-6 );
        CHECK( fabs( 3.0 * z - point[2] ) < 1e-6 );
    const CartVect facepts2[] = { CartVect( -3.0, 0.5, 0.5 ), CartVect( 3.0, 0.5, 0.5 ),  CartVect( 0.5, -3.0, 0.5 ),
                                  CartVect( 0.5, 3.0, 0.5 ),  CartVect( 0.5, 0.5, -3.0 ), CartVect( 0.5, 0.5, 3.0 ) };
        CartVect point;
        rval = tool.closest_triangle( root, facepts2[i].array(), point.array(), tri );
        const CartVect diff = facepts2[i] - point;
        const double far[] = { 2.75, 2.75, 200 };
        CartVect point;
        CHECK( fabs( point[0] - 2.75 ) < 1e-6 );
        CHECK( fabs( point[1] - 2.75 ) < 1e-6 );
        CHECK( fabs( point[2] - 3.00 ) < 1e-6 );
Definition at line 1006 of file adaptive_kd_tree_tests.cpp.
References CHECK, CHECK_ERR, moab::Tree::create_root(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::intersects(), moab::AdaptiveKDTree::X, moab::AdaptiveKDTree::Y, and moab::AdaptiveKDTree::Z.
    ErrorCode rval;
    Core moab;
    EntityHandle root;
    const double min[3] = { -5, -4, -1 };
    const double max[3] = { 1, 2, 3 };
    rval                = tool.create_root( min, max, root );CHECK_ERR( rval );
    rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval );
    AdaptiveKDTree::Plane x1 = { min[0] - 1, AdaptiveKDTree::X };
    CHECK( !iter.intersects( x1 ) );
    AdaptiveKDTree::Plane x2 = { min[0], AdaptiveKDTree::X };
    CHECK( iter.intersects( x2 ) );
    AdaptiveKDTree::Plane x3 = { min[0] + 1, AdaptiveKDTree::X };
    CHECK( iter.intersects( x3 ) );
    AdaptiveKDTree::Plane x4 = { max[0] - 1, AdaptiveKDTree::X };
    CHECK( iter.intersects( x4 ) );
    AdaptiveKDTree::Plane x5 = { max[0], AdaptiveKDTree::X };
    CHECK( iter.intersects( x5 ) );
    AdaptiveKDTree::Plane x6 = { max[0] + 1, AdaptiveKDTree::X };
    CHECK( !iter.intersects( x6 ) );
    AdaptiveKDTree::Plane y1 = { min[1] - 1, AdaptiveKDTree::Y };
    CHECK( !iter.intersects( y1 ) );
    AdaptiveKDTree::Plane y2 = { min[1], AdaptiveKDTree::Y };
    CHECK( iter.intersects( y2 ) );
    AdaptiveKDTree::Plane y3 = { min[1] + 1, AdaptiveKDTree::Y };
    CHECK( iter.intersects( y3 ) );
    AdaptiveKDTree::Plane y4 = { max[1] - 1, AdaptiveKDTree::Y };
    CHECK( iter.intersects( y4 ) );
    AdaptiveKDTree::Plane y5 = { max[1], AdaptiveKDTree::Y };
    CHECK( iter.intersects( y5 ) );
    AdaptiveKDTree::Plane y6 = { max[1] + 1, AdaptiveKDTree::Y };
    CHECK( !iter.intersects( y6 ) );
    AdaptiveKDTree::Plane z1 = { min[2] - 1, AdaptiveKDTree::Z };
    CHECK( !iter.intersects( z1 ) );
    AdaptiveKDTree::Plane z2 = { min[2], AdaptiveKDTree::Z };
    CHECK( iter.intersects( z2 ) );
    AdaptiveKDTree::Plane z3 = { min[2] + 1, AdaptiveKDTree::Z };
    CHECK( iter.intersects( z3 ) );
    AdaptiveKDTree::Plane z4 = { max[2] - 1, AdaptiveKDTree::Z };
    CHECK( iter.intersects( z4 ) );
    AdaptiveKDTree::Plane z5 = { max[2], AdaptiveKDTree::Z };
    CHECK( iter.intersects( z5 ) );
    AdaptiveKDTree::Plane z6 = { max[2] + 1, AdaptiveKDTree::Z };
    CHECK( !iter.intersects( z6 ) );
Definition at line 1068 of file adaptive_kd_tree_tests.cpp.
References CHECK, CHECK_ERR, CHECK_RAY_XSECTS, moab::Tree::create_root(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), and moab::AdaptiveKDTreeIter::intersect_ray().
    ErrorCode rval;
    Core moab;
    double t_in, t_out;
    EntityHandle root;
    // start with point inside box
    const double pt1[]  = { 0, 0, 0 };
    const double dir1[] = { 0.1, 0.1, 0.1 };
    CHECK_RAY_XSECTS( pt1, dir1, 0, 10 );
    const double dir2[] = { 5, 5, 5 };
    CHECK_RAY_XSECTS( pt1, dir2, 0, 0.2 );
    const double pxdir[] = { 1, 0, 0 };
    CHECK_RAY_XSECTS( pt1, pxdir, 0, 1 );
    const double nxdir[] = { -1, 0, 0 };
    CHECK_RAY_XSECTS( pt1, nxdir, 0, 5 );
    const double pydir[] = { 0, 1, 0 };
    CHECK_RAY_XSECTS( pt1, pydir, 0, 2 );
    const double nydir[] = { 0, -1, 0 };
    CHECK_RAY_XSECTS( pt1, nydir, 0, 4 );
    const double pzdir[] = { 0, 0, 1 };
    CHECK_RAY_XSECTS( pt1, pzdir, 0, 3 );
    const double nzdir[] = { 0, 0, -1 };
    CHECK_RAY_XSECTS( pt1, nzdir, 0, 1 );
    // point below box
    const double pt2[] = { 0, 0, -2 };
    CHECK_RAY_XSECTS( pt2, dir1, 10, 10 );
    CHECK_RAY_XSECTS( pt2, dir2, 0.2, 0.2 );
    CHECK( !iter.intersect_ray( pt2, pxdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, nxdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, pydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, nydir, t_in, t_out ) );
    CHECK_RAY_XSECTS( pt2, pzdir, 1, 5 );
    CHECK( !iter.intersect_ray( pt2, nzdir, t_in, t_out ) );
    // point right of box
    const double pt3[] = { 3, 0, 0 };
    CHECK( !iter.intersect_ray( pt3, dir1, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, dir2, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, pxdir, t_in, t_out ) );
    CHECK_RAY_XSECTS( pt3, nxdir, 2, 8 );
    CHECK( !iter.intersect_ray( pt3, pydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, nydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, pzdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, nzdir, t_in, t_out ) );
    // a few more complex test cases
    const double dira[] = { -3, 0, 3 };
    CHECK_RAY_XSECTS( pt3, dira, 2. / 3., 1.0 );
    const double dirb[] = { -2, 0, 3.1 };
    CHECK( !iter.intersect_ray( pt3, dirb, t_in, t_out ) );
Definition at line 953 of file adaptive_kd_tree_tests.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), moab::AdaptiveKDTreeIter::is_sibling(), moab::AdaptiveKDTreeIter::sibling_is_forward(), and moab::AdaptiveKDTreeIter::step().
    ErrorCode rval;
    Core moab;
    EntityHandle root;
    create_simple_2d_tree( tool, root );
    AdaptiveKDTreeIter iter1, iter2;
    rval = tool.get_tree_iterator( root, iter1 );CHECK_ERR( rval );
    rval = tool.get_tree_iterator( root, iter2 );CHECK_ERR( rval );
    // iter1 == 1, iter2 == 1
    CHECK( !iter1.is_sibling( iter1 ) );
    CHECK( !iter1.is_sibling( iter1.handle() ) );
    CHECK( !iter1.is_sibling( iter2 ) );
    CHECK( iter1.sibling_is_forward() );
    // iter1 == 1, iter2 == 2
    rval = iter2.step();CHECK_ERR( rval );
    CHECK( iter1.is_sibling( iter2 ) );
    CHECK( iter1.is_sibling( iter2.handle() ) );
    CHECK( iter2.is_sibling( iter1 ) );
    CHECK( iter2.is_sibling( iter1.handle() ) );
    CHECK( !iter2.sibling_is_forward() );
    // iter1 == 1, iter2 == 3
    CHECK( !iter1.is_sibling( iter2.handle() ) );
    CHECK( !iter2.is_sibling( iter1 ) );
    CHECK( !iter2.is_sibling( iter1.handle() ) );
    CHECK( iter2.sibling_is_forward() );
    // iter1 == 2, iter2 == 3
    rval = iter1.step();CHECK_ERR( rval );
    CHECK( !iter1.sibling_is_forward() );
    // iter1 == 4, iter2 == 3
    CHECK_EQUAL( iter1.handle(), iter2.handle() );
void test_leaf_volume ( )
Definition at line 926 of file adaptive_kd_tree_tests.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::step(), and moab::AdaptiveKDTreeIter::volume().
Referenced by main(), test_leaf_volume_box(), and test_leaf_volume_gen().
    Core moab;
    EntityHandle root;
    ErrorCode rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval );
    CHECK_REAL_EQUAL( 16.0, iter.volume(), 1e-12 );  // 1
    CHECK_ERR( iter.step() );
    CHECK_REAL_EQUAL( 16.0, iter.volume(), 1e-12 );  // 2
    CHECK_REAL_EQUAL( 40.0, iter.volume(), 1e-12 );  // 3
    CHECK_REAL_EQUAL( 8.0, iter.volume(), 1e-12 );  // 4
    CHECK_REAL_EQUAL( 16.0, iter.volume(), 1e-12 );  // 5
    CHECK_REAL_EQUAL( 24.0, iter.volume(), 1e-12 );  // 6
    CHECK_REAL_EQUAL( 30.0, iter.volume(), 1e-12 );  // 7
    CHECK_REAL_EQUAL( 10.0, iter.volume(), 1e-12 );  // 8
Definition at line 790 of file adaptive_kd_tree_tests.cpp.
References moab::CartVect::array(), moab::AdaptiveKDTree::build_tree(), build_triangle_box_small(), CHECK, check_point_in_triangles(), moab::Range::clear(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::AdaptiveKDTree::ray_intersect_triangles(), and test_valid_tree().
    Core moab;
    Range box_tris;
    EntityHandle root;
    ErrorCode rval;
    std::vector< EntityHandle > tris;
    std::vector< double > dists;
    moab.delete_mesh();
    box_tris.clear();
    // test ray through box parallel to X axis
    CartVect dir( 1, 0, 0 );
    CartVect pt( -2, 0.75, 0.75 );
    tris.clear();
    dists.clear();
    rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists );
    CHECK( tris.size() == 3 );
    CHECK( dists.size() == tris.size() );
    for( unsigned i = 0; i < dists.size(); ++i )
        CHECK( fabs( dists[i] - 1 ) < 1e-6 || fabs( dists[i] - 3 ) < 1e-6 );
        CartVect tript = pt + dists[i] * dir;
        check_point_in_triangles( &moab, &tris[i], 1, tript );
    // test ray through box parallel to X axis, closest tri only
    tris.clear();
    dists.clear();
    rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists, 1 );
    CHECK( tris.size() == 1 );
    CHECK( fabs( dists[0] - 1 ) < 1e-6 );
    check_point_in_triangles( &moab, &tris[0], 1, pt + dists[0] * dir );
    // test ray ending within box, parallel to X axis
    tris.clear();
    dists.clear();
    rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists, 0, 2.0 );
    // test ray starting within box parallel to X axis
    tris.clear();
    dists.clear();
    pt   = CartVect( 0, .75, .75 );
    CHECK( tris.size() == 2 );
        CHECK( fabs( dists[i] - 1 ) < 1e-6 );
    // test skew ray through box
    dir = CartVect( 0.5 * sqrt( 2.0 ), 0.5 * sqrt( 2.0 ), 0.0 );
    pt  = CartVect( 0, -1.5, 0 );
    tris.clear();
    dists.clear();
    if( dists[0] < dists[1] )
        CHECK( fabs( dists[0] - 0.5 * sqrt( 2.0 ) ) < 1e-6 );
        CHECK( fabs( dists[1] - sqrt( 2.0 ) ) < 1e-6 );
    check_point_in_triangles( &moab, &tris[1], 1, pt + dists[1] * dir );
    // test ray through box parallel to -Y axis
    dir = CartVect( 0, -1, 0 );
    pt  = CartVect( 0, 2, 0 );
    tris.clear();
    dists.clear();
    CHECK( tris.size() == 4 );
    // test ray through box parallel to Z axis
    dir = CartVect( 0, 0, 1 );
    pt  = CartVect( 0, 0, -2 );
    tris.clear();
    dists.clear();
    // test ray through box parallel to Z axis, limit 2 first 2 intersections
    tris.clear();
    dists.clear();
    rval = tool.ray_intersect_triangles( root, 1e-6, dir.array(), pt.array(), tris, dists, 2 );
Definition at line 724 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTree::build_tree(), build_triangle_box_large(), build_triangle_box_small(), center(), CHECK, check_common_vertex(), moab::Range::clear(), moab::Core::delete_mesh(), ErrorCode, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTree::reset_tree(), moab::AdaptiveKDTree::sphere_intersect_triangles(), test_valid_tree(), and z.
    Core moab;
    Range box_tris;
    EntityHandle root;
    ErrorCode rval;
    std::vector< EntityHandle > triangles;
    moab.delete_mesh();
    box_tris.clear();
        double x        = i & 1 ? 1 : -1;
        double y        = i & 2 ? 1 : -1;
        double z        = i & 4 ? 1 : -1;
        double center[] = { x, y, z };
        triangles.clear();
        rval = tool.sphere_intersect_triangles( root, center, 0.26, triangles );
        // expect 3 to 6 triangles, depending on the corner
        CHECK( triangles.size() >= 3 );
        CHECK( triangles.size() <= 6 );
        // check point is at the same vertex for each triangle
        check_common_vertex( tool.moab(), &triangles[0], triangles.size(), CartVect( center ) );
    tool.reset_tree();
    moab.delete_mesh();
    box_tris.clear();
        double center[] = { 3.0 * x, 3.0 * y, 3.0 * z };
        triangles.clear();
Definition at line 518 of file adaptive_kd_tree_tests.cpp.
References box_equal(), CHECK, create_simple_2d_tree(), ErrorCode, moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), mb, MB_SUCCESS, moab::AdaptiveKDTree::merge_leaf(), and moab::AdaptiveKDTreeIter::step().
    // build simple tree for tests
    ErrorCode rval;
    Core moab;
    EntityHandle root;
    // merge leaves 1 and 2
    rval = tool.merge_leaf( iter );
    // merge leaf 1,2 with 3,4 (implicity merges 3 and 4)
    // make sure iterator remains valid
    rval = iter.step();
    // leaf 5
void test_valid_tree ( AdaptiveKDTree tool,
EntityHandle  root,
FileOptions options,
const Range expected_tris
Definition at line 123 of file adaptive_kd_tree_tests.cpp.
References moab::AdaptiveKDTreeIter::box_max(), moab::AdaptiveKDTreeIter::box_min(), moab::GeomUtil::box_tri_overlap(), CHECK, conn, moab::AdaptiveKDTreeIter::depth(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Tree::get_max_depth(), moab::FileOptions::get_real_option(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, MBTRI, moab::Range::merge(), moab::Tree::moab(), and moab::AdaptiveKDTreeIter::step().
    Range all_tris;
    ErrorCode rval;
    CHECK( MB_SUCCESS == tool->get_tree_iterator( root, iter ) );
    do
        double dep;
        rval = options.get_real_option( "MAX_DEPTH", dep );
        CHECK( MB_ENTITY_NOT_FOUND == rval || iter.depth() <= tool->get_max_depth() );
        Range tris;
        CHECK( tool->moab()->get_entities_by_type( iter.handle(), MBTRI, tris ) == MB_SUCCESS );
        // CHECK( !tris.empty() );
        all_tris.merge( tris );
        const CartVect min( iter.box_min() ), max( iter.box_max() );
        const CartVect cen( 0.5 * ( min + max ) ), hdim( 0.5 * ( max - min ) );
        for( Range::iterator i = tris.begin(); i != tris.end(); ++i )
            EntityHandle tri = *i;
            int conn_len;
            CHECK( tool->moab()->get_connectivity( tri, conn, conn_len ) == MB_SUCCESS );
            CHECK( conn_len == 3 );
            CartVect coords[3];
            CHECK( tool->moab()->get_coords( conn, 3, coords[0].array() ) == MB_SUCCESS );
            CHECK( GeomUtil::box_tri_overlap( coords, cen, hdim ) );
    } while( MB_SUCCESS == ( rval = iter.step() ) );
    CHECK( expected_tris == all_tris );
