MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>
#include <vector>
#include <algorithm>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/HalfFacetRep.hpp"
#include "TestUtil.hpp"
Functions | |
void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
ErrorCode | ahf_test (const char *filename) |
int | main (int argc, char *argv[]) |
Variables | |
int | number_tests_successful = 0 |
int | number_tests_failed = 0 |
Definition at line 48 of file adj_moab_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), moab::HalfFacetRep::deinitialize(), edges, moab::Range::end(), moab::error(), ErrorCode, MBMesquite::faces, moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_connectivity(), moab::HalfFacetRep::get_down_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::HalfFacetRep::get_neighbor_adjacencies(), moab::ParallelComm::get_pcomm(), moab::HalfFacetRep::get_up_adjacencies(), moab::HalfFacetRep::initialize(), moab::Interface::load_file(), MB_SUCCESS, MESHSET_SET, MPI_COMM_WORLD, read_options, moab::Range::size(), and moab::subtract().
Referenced by main().
{ Core moab; Interface* mbImpl = &moab; ParallelComm* pc = NULL; MeshTopoUtil mtu( mbImpl ); ErrorCode error; EntityHandle fileset; error = mbImpl->create_meshset( moab::MESHSET_SET, fileset );CHECK_ERR( error ); #ifdef MOAB_HAVE_MPI int procs = 1; MPI_Comm_size( MPI_COMM_WORLD, &procs ); if( procs > 1 ) { read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"; error = mbImpl->load_file( filename, &fileset, read_options.c_str() );CHECK_ERR( error ); } else if( procs == 1 ) { #endif error = mbImpl->load_file( filename, &fileset );CHECK_ERR( error ); #ifdef MOAB_HAVE_MPI } #endif /*Create ranges for handles of explicit elements of the mixed mesh*/ Range verts, edges, faces, cells; error = mbImpl->get_entities_by_dimension( fileset, 0, verts );CHECK_ERR( error ); error = mbImpl->get_entities_by_dimension( fileset, 1, edges );CHECK_ERR( error ); error = mbImpl->get_entities_by_dimension( fileset, 2, faces );CHECK_ERR( error ); error = mbImpl->get_entities_by_dimension( fileset, 3, cells );CHECK_ERR( error ); // Create an ahf instance #ifdef MOAB_HAVE_MPI pc = ParallelComm::get_pcomm( mbImpl, 0 ); if( !pc ) pc = new moab::ParallelComm( &moab, MPI_COMM_WORLD ); #endif HalfFacetRep ahf( &moab, pc, fileset ); // Call the initialize function which creates the maps for each dimension error = ahf.initialize();CHECK_ERR( error ); std::cout << "Finished AHF initialization" << std::endl; // Perform queries std::vector< EntityHandle > adjents; Range mbents, ahfents; // 1D Queries // // IQ1: For every vertex, obtain incident edges if( edges.size() ) { Range everts; error = mbImpl->get_connectivity( edges, everts, true );CHECK_ERR( error ); for( Range::iterator i = everts.begin(); i != everts.end(); ++i ) { adjents.clear(); error = ahf.get_up_adjacencies( *i, 1, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // NQ1: For every edge, obtain neighbor edges if( edges.size() ) { for( Range::iterator i = edges.begin(); i != edges.end(); ++i ) { adjents.clear(); error = ahf.get_neighbor_adjacencies( *i, adjents );CHECK_ERR( error ); mbents.clear(); error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } std::cout << "Finished 1D queries" << std::endl; // 2D Queries // IQ21: For every vertex, obtain incident faces if( faces.size() ) { Range fverts; error = mbImpl->get_connectivity( faces, fverts, true );CHECK_ERR( error ); for( Range::iterator i = fverts.begin(); i != fverts.end(); ++i ) { adjents.clear(); error = ahf.get_up_adjacencies( *i, 2, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // IQ22: For every edge, obtain incident faces if( edges.size() && faces.size() ) { for( Range::iterator i = edges.begin(); i != edges.end(); ++i ) { adjents.clear(); error = ahf.get_up_adjacencies( *i, 2, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // NQ2: For every face, obtain neighbor faces if( faces.size() ) { for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) { adjents.clear(); error = ahf.get_neighbor_adjacencies( *i, adjents );CHECK_ERR( error ); mbents.clear(); error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // DQ 21: For every face, obtain its edges if( edges.size() && faces.size() ) { for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) { adjents.clear(); error = ahf.get_down_adjacencies( *i, 1, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } std::cout << "Finished 2D queries: " << std::endl; // 3D Queries // IQ 31: For every vertex, obtain incident cells if( cells.size() ) { Range cverts; error = mbImpl->get_connectivity( cells, cverts, true );CHECK_ERR( error ); for( Range::iterator i = cverts.begin(); i != cverts.end(); ++i ) { adjents.clear(); error = ahf.get_up_adjacencies( *i, 3, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // IQ 32: For every edge, obtain incident cells if( edges.size() && cells.size() ) { for( Range::iterator i = edges.begin(); i != edges.end(); ++i ) { adjents.clear(); error = ahf.get_up_adjacencies( *i, 3, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error ); if( adjents.size() != mbents.size() ) { // std::cout<<"ahf results = "<<std::endl; // ahfents.print(); // std::cout<<"native results = "<<std::endl; // mbents.print(); } CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // IQ33: For every face, obtain incident cells if( faces.size() && cells.size() ) { for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) { adjents.clear(); error = ahf.get_up_adjacencies( *i, 3, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error ); if( adjents.size() != mbents.size() ) { // std::cout<<"ahf results = "<<std::endl; // ahfents.print(); // std::cout<<"native results = "<<std::endl; // mbents.print(); } CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // NQ3: For every cell, obtain neighbor cells if( cells.size() ) { for( Range::iterator i = cells.begin(); i != cells.end(); ++i ) { adjents.clear(); error = ahf.get_neighbor_adjacencies( *i, adjents );CHECK_ERR( error ); mbents.clear(); error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // DQ 31: For every cell, obtain its edges if( edges.size() && cells.size() ) { for( Range::iterator i = cells.begin(); i != cells.end(); ++i ) { adjents.clear(); error = ahf.get_down_adjacencies( *i, 1, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } // DQ 32: For every cell, obtain its faces if( faces.size() && cells.size() ) { for( Range::iterator i = cells.begin(); i != cells.end(); ++i ) { adjents.clear(); error = ahf.get_down_adjacencies( *i, 2, adjents );CHECK_ERR( error ); mbents.clear(); error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error ); CHECK_EQUAL( mbents.size(), adjents.size() ); std::sort( adjents.begin(), adjents.end() ); std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) ); mbents = subtract( mbents, ahfents ); CHECK( !mbents.size() ); } } std::cout << "Finished 3D queries" << std::endl; error = ahf.deinitialize();CHECK_ERR( error ); return MB_SUCCESS; }
void handle_error_code | ( | ErrorCode | rv, |
int & | number_failed, | ||
int & | number_successful | ||
Definition at line 28 of file adj_moab_test.cpp.
References MB_SUCCESS, MPI_COMM_WORLD, and rank.
{ if( rv == MB_SUCCESS ) { #ifdef MOAB_HAVE_MPI int rank = 0; MPI_Comm_rank( MPI_COMM_WORLD, &rank ); if( rank == 0 ) std::cout << "Success"; #else std::cout << "Success"; #endif number_successful++; } else { std::cout << "Failure"; number_failed++; } }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 353 of file adj_moab_test.cpp.
References ahf_test(), ErrorCode, filename, handle_error_code(), MPI_COMM_WORLD, number_tests_failed, number_tests_successful, and rank.
{ #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); int nprocs, rank; MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); #endif std::string filename; #ifdef MOAB_HAVE_HDF5 #ifdef MOAB_HAVE_AHF filename = TestDir + "unittest/spectral.h5m"; #else filename = TestDir + "unittest/32hex_ef.h5m"; #endif #else filename = TestDir + "unittest/hexes_mixed.vtk"; #endif if( argc == 1 ) { #ifdef MOAB_HAVE_MPI if( rank == 0 ) std::cout << "Using default input file:" << filename << std::endl; #else std::cout << "Using default input file:" << filename << std::endl; #endif } else if( argc == 2 ) filename = std::string( argv[1] ); else { std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl; return 1; } ErrorCode result; #ifdef MOAB_HAVE_MPI if( rank == 0 ) std::cout << " para_ahf_test: "; #else std::cout << "ahf_test:"; #endif result = ahf_test( filename.c_str() ); handle_error_code( result, number_tests_failed, number_tests_successful ); std::cout << "\n"; #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return number_tests_failed; }
int number_tests_failed = 0 |
Definition at line 26 of file adj_moab_test.cpp.
Referenced by _run_test(), check_split(), main(), and split_quads_test().
int number_tests_successful = 0 |
Definition at line 25 of file adj_moab_test.cpp.
Referenced by check_split(), main(), and split_quads_test().
