MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "TestUtil.hpp"
#include <iostream>
#include <cassert>
#include <ctime>
Functions | |
int | main () |
Variables | |
static const std::string | default_input_file = "unittest/64bricks_512hex.h5m" |
int main | ( | ) |
Definition at line 12 of file adj_time.cpp.
References MBMesquite::adj(), moab::Range::begin(), default_input_file, moab::Range::empty(), moab::Range::end(), ErrorCode, MBMesquite::faces, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::load_file(), mb, MB_SUCCESS, moab::Range::size(), and moab::Interface::UNION.
{ ErrorCode rval; Core moab; Interface& mb = moab; // load test file rval = mb.load_file( default_input_file.c_str() ); if( MB_SUCCESS != rval ) { std::cerr << default_input_file << ": failed to load file." << std::endl; return 1; } // get all region elements Range vols; rval = mb.get_entities_by_dimension( 0, 3, vols ); if( MB_SUCCESS != rval ) return 2; if( vols.empty() ) return 1; // create internal face elements Range faces; rval = mb.get_adjacencies( vols, 2, true, faces, Interface::UNION ); if( MB_SUCCESS != rval ) return 2; assert( faces.size() > vols.size() ); // time query of all adjacent volumes std::vector< EntityHandle > adj; clock_t t_0 = clock(); for( Range::iterator i = faces.begin(); i != faces.end(); ++i ) { adj.clear(); rval = mb.get_adjacencies( &*i, 1, 3, false, adj ); if( MB_SUCCESS != rval ) return 2; assert( adj.size() == 1 || adj.size() == 2 ); } clock_t t_up = clock() - t_0; std::cout << "Querying of volumes for " << faces.size() << " faces: " << t_up / (double)CLOCKS_PER_SEC << " seconds" << std::endl; // time downward adjacency query from volumes to faces t_0 = clock(); for( Range::iterator i = vols.begin(); i != vols.end(); ++i ) { adj.clear(); rval = mb.get_adjacencies( &*i, 1, 1, false, adj ); if( MB_SUCCESS != rval ) return 2; assert( adj.size() > 3 ); } clock_t t_down = clock() - t_0; std::cout << "Querying of faces for " << vols.size() << " volumes: " << t_down / (double)CLOCKS_PER_SEC << " seconds" << std::endl; return 0; }
const std::string default_input_file = "unittest/64bricks_512hex.h5m" [static] |
Definition at line 10 of file adj_time.cpp.
Referenced by main().
