augment_with_ghosts.cpp
00001 #include "moab/ParallelComm.hpp"
00002 #include "moab/Core.hpp"
00003 #include "moab_mpi.h"
00004 #include "TestUtil.hpp"
00005 #include "MBTagConventions.hpp"
00006 #include <iostream>
00007 #include <sstream>
00008
00009 std::string filename = TestDir + "unittest/io/p8ex1.h5m";
00010
00011 using namespace moab;
00012 void report_sets( moab::Core* mb, int rank, int nproc )
00013 {
00014     // check neumann and material sets, and see if their number of quads / hexes  in them
00015     const char* const shared_set_tag_names[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME,
00016                                                  PARALLEL_PARTITION_TAG_NAME };
00017
00018     int num_tags = sizeof( shared_set_tag_names ) / sizeof( shared_set_tag_names[0] );
00019
00020     for( int p = 0; p < nproc; p++ )
00021     {
00022         if( rank == p )
00023         {
00024             std::cout << " Task no:" << rank << "\n";
00025             for( int i = 0; i < num_tags; i++ )
00026             {
00027                 Tag tag;
00028                 ErrorCode rval = mb->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tag, MB_TAG_ANY );CHECK_ERR( rval );
00029                 Range sets;
00030                 rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets, Interface::UNION );CHECK_ERR( rval );
00031
00032                 std::vector< int > vals( sets.size() );
00033                 rval = mb->tag_get_data( tag, sets, &vals[0] );CHECK_ERR( rval );
00034                 std::cout << "  sets: " << shared_set_tag_names[i] << "\n";
00035                 int j = 0;
00036                 for( Range::iterator it = sets.begin(); it != sets.end(); it++, j++ )
00037                 {
00038                     Range ents;
00039                     rval = mb->get_entities_by_handle( *it, ents );CHECK_ERR( rval );
00040                     std::cout << "    set " << mb->id_from_handle( *it ) << " with tagval=" << vals[j] << " has "
00041                               << ents.size() << " entities\n";
00042                 }
00043             }
00044         }
00045         MPI_Barrier( MPI_COMM_WORLD );
00046     }
00047 }
00048 void test_read_with_ghost()
00049 {
00050     int nproc, rank;
00051     MPI_Comm_size( MPI_COMM_WORLD, &nproc );
00052     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00053     moab::Core* mb = new moab::Core();
00054
00055     ErrorCode rval = MB_SUCCESS;
00056
00057     char read_opts[] = "PARALLEL=READ_PART;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1.3;"
00058                        "PARTITION=PARALLEL_PARTITION";
00059     rval             = mb->load_file( filename.c_str(), 0, read_opts );CHECK_ERR( rval );
00060
00061     report_sets( mb, rank, nproc );
00062     // write in serial the database , on each rank
00063     std::ostringstream outfile;
00064     outfile << "testReadGhost_n" << nproc << "." << rank << ".h5m";
00065     // the mesh contains ghosts too, but they were not part of mat/neumann set
00066     // write in serial the file, to see what tags are missing / or not
00067     rval = mb->write_file( outfile.str().c_str() );  // everything on root
00068     CHECK_ERR( rval );
00069     delete mb;
00070 }
00071
00072 void test_read_and_ghost_after()
00073 {
00074     int nproc, rank;
00075     MPI_Comm_size( MPI_COMM_WORLD, &nproc );
00076     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00077     moab::Core* mb         = new moab::Core();
00078     moab::ParallelComm* pc = new moab::ParallelComm( mb, MPI_COMM_WORLD );
00079     ErrorCode rval         = MB_SUCCESS;
00080
00081     // first read in parallel, then ghost, then augment
00082     char read_opts[] = "PARALLEL=READ_PART;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION=PARALLEL_PARTITION";
00083     rval             = mb->load_file( filename.c_str(), 0, read_opts );CHECK_ERR( rval );
00084
00085     int ghost_dim = 3, bridge = 0, layers = 1, addl_ents = 3;
00086     rval = pc->exchange_ghost_cells( ghost_dim, bridge, layers, addl_ents, true, true );CHECK_ERR( rval );
00087
00088     //
00089     pc->set_debug_verbosity( 1 );
00090     rval = pc->augment_default_sets_with_ghosts( 0 );CHECK_ERR( rval );
00091
00092     report_sets( mb, rank, nproc );
00093
00094     // write in serial the database , on each rank
00095     std::ostringstream outfile;
00096     outfile << "TaskMesh_n" << nproc << "." << rank << ".h5m";
00097     // the mesh contains ghosts too, but they were not part of mat/neumann set
00098     // write in serial the file, to see what tags are missing / or not
00099     rval = mb->write_file( outfile.str().c_str() );  // everything on root
00100     CHECK_ERR( rval );
00101
00102     delete pc;
00103     delete mb;
00104 }
00105
00106 void test_read_with_ghost_no_augment()
00107 {
00108     int nproc, rank;
00109     MPI_Comm_size( MPI_COMM_WORLD, &nproc );
00110     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00111     moab::Core* mb = new moab::Core();
00112
00113     ErrorCode rval = MB_SUCCESS;
00114
00115     char read_opts[] = "PARALLEL=READ_PART;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1.3;"
00116                        "PARTITION=PARALLEL_PARTITION;SKIP_AUGMENT_WITH_GHOSTS";
00117     rval             = mb->load_file( filename.c_str(), 0, read_opts );CHECK_ERR( rval );
00118
00119     report_sets( mb, rank, nproc );
00120     // write in serial the database , on each rank
00121     std::ostringstream outfile;
00122     outfile << "testReadGhost_n" << nproc << "." << rank << ".h5m";
00123     // the mesh contains ghosts too, but they were not part of mat/neumann set
00124     // write in serial the file, to see what tags are missing / or not
00125     rval = mb->write_file( outfile.str().c_str() );  // everything on root
00126     CHECK_ERR( rval );
00127     delete mb;
00128 }
00129 int main( int argc, char* argv[] )
00130 {
00131     MPI_Init( &argc, &argv );
00132
00133     int result = 0;
00134     if( argc >= 2 ) filename = argv[1];
00135
00136     result += RUN_TEST( test_read_with_ghost );
00137     result += RUN_TEST( test_read_and_ghost_after );
00138     result += RUN_TEST( test_read_with_ghost_no_augment );
00139
00140     MPI_Finalize();
00141     return 0;
00142 }
