MOAB: Mesh Oriented datABase
(version 5.4.1)
Functions | |
void | test_construct_from_hex () |
void | test_cut_with_plane () |
void | test_volume () |
int | main () |
static void | get_corners (CartVect corners[8]) |
const BSPTreePoly::Face * | find_face (const BSPTreePoly &poly, const CartVect *coords, int num_corners, const int *face_indices=0) |
Variables | |
const int | hex_faces [6][4] |
const BSPTreePoly::Face* find_face | ( | const BSPTreePoly & | poly, |
const CartVect * | coords, | ||
int | num_corners, | ||
const int * | face_indices = 0 |
Definition at line 35 of file bsp_tree_poly_test.cpp.
References corners, MBMesquite::faces, moab::BSPTreePoly::get_faces(), moab::BSPTreePoly::get_vertices(), and length_squared().
Referenced by TopologyInfoTest::find_face(), test_construct_from_hex(), and test_cut_with_plane().
{ std::vector< const BSPTreePoly::Face* >::iterator i; std::vector< const BSPTreePoly::Face* > faces; std::vector< CartVect > corners; poly.get_faces( faces ); for( i = faces.begin(); i != faces.end(); ++i ) { corners.clear(); poly.get_vertices( *i, corners ); if( corners.size() != (unsigned)num_corners ) continue; int j; for( j = 0; j < num_corners; ++j ) { int corner = face_indices ? face_indices[j] : j; if( ( coords[corner] - corners.front() ).length_squared() < 1e-12 ) break; } if( j == num_corners ) continue; int k; for( k = 1; k < num_corners; ++k ) { int corner = face_indices ? face_indices[( j + k ) % num_corners] : ( j + k ) % num_corners; if( ( coords[corner] - corners[k] ).length_squared() > 1e-12 ) break; } if( k == num_corners ) return *i; } return 0; }
static void get_corners | ( | CartVect | corners[8] | ) | [static] |
Definition at line 23 of file bsp_tree_poly_test.cpp.
Referenced by test_construct_from_hex(), test_cut_with_plane(), and test_volume().
int main | ( | ) |
Definition at line 11 of file bsp_tree_poly_test.cpp.
References error_count, RUN_TEST, test_construct_from_hex(), test_cut_with_plane(), and test_volume().
{ int error_count = 0; error_count += RUN_TEST( test_construct_from_hex ); error_count += RUN_TEST( test_cut_with_plane ); error_count += RUN_TEST( test_volume ); return error_count; }
void test_construct_from_hex | ( | ) |
Definition at line 70 of file bsp_tree_poly_test.cpp.
References CHECK, CHECK_EQUAL, corners, MBMesquite::faces, find_face(), get_corners(), moab::BSPTreePoly::get_faces(), hex_faces, moab::BSPTreePoly::is_valid(), and moab::BSPTreePoly::reset_debug_ids().
Referenced by main().
{ BSPTreePoly::reset_debug_ids(); CartVect corners[8]; get_corners( corners ); BSPTreePoly poly( corners ); CHECK( poly.is_valid() ); std::vector< const BSPTreePoly::Face* > faces; poly.get_faces( faces ); CHECK_EQUAL( (size_t)6, faces.size() ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[0] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[1] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[2] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[4] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) ); }
void test_cut_with_plane | ( | ) |
Definition at line 91 of file bsp_tree_poly_test.cpp.
References CHECK, CHECK_EQUAL, corners, moab::BSPTreePoly::cut_polyhedron(), MBMesquite::faces, find_face(), get_corners(), moab::BSPTreePoly::get_faces(), hex_faces, moab::BSPTreePoly::is_valid(), moab::BSPTreePoly::reset_debug_ids(), and moab::BSPTreePoly::set().
{ // create a hexahedron BSPTreePoly::reset_debug_ids(); CartVect corners[8]; get_corners( corners ); BSPTreePoly poly( corners ); CHECK( poly.is_valid() ); // check that a plane entirely above the // polyhedron (coincident with one face) // doesn't modify the polyhedron bool r = poly.cut_polyhedron( CartVect( 0, 0, 1 ), -2 ); CHECK( !r ); CHECK( poly.is_valid() ); // cut in half with Z=1 plane r = poly.cut_polyhedron( CartVect( 0, 0, 1 ), -1 ); CHECK( r ); CHECK( poly.is_valid() ); for( int i = 0; i < 8; ++i ) { if( fabs( corners[i][2] - 2 ) < 1e-6 ) corners[i][2] = 1; if( fabs( corners[i][0] - 4 ) < 1e-6 ) corners[i][0] = 5; } std::vector< const BSPTreePoly::Face* > faces; poly.get_faces( faces ); CHECK_EQUAL( (size_t)6, faces.size() ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[0] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[1] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[2] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[4] ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) ); // create a hexahedron BSPTreePoly::reset_debug_ids(); get_corners( corners ); poly.set( corners ); CHECK( poly.is_valid() ); // cut off two corners using X=5 plane r = poly.cut_polyhedron( CartVect( 1, 0, 0 ), -5 ); CHECK( r ); CHECK( poly.is_valid() ); faces.clear(); poly.get_faces( faces ); CHECK_EQUAL( (size_t)7, faces.size() ); CartVect new_vtx1( 5, 1, 1 ); CartVect new_vtx2( 5, 1, 0 ); CartVect new_vtx3( 5, 3, 0 ); CartVect new_vtx4( 5, 3, 1 ); CartVect face1[5] = { corners[0], new_vtx2, new_vtx1, corners[5], corners[4] }; CartVect face2[4] = { new_vtx1, new_vtx4, corners[6], corners[5] }; CartVect face3[5] = { new_vtx4, new_vtx3, corners[3], corners[7], corners[6] }; CartVect face5[4] = { corners[3], new_vtx3, new_vtx2, corners[0] }; CartVect face7[4] = { new_vtx1, new_vtx2, new_vtx3, new_vtx4 }; CHECK( 0 != find_face( poly, face1, 5 ) ); CHECK( 0 != find_face( poly, face2, 4 ) ); CHECK( 0 != find_face( poly, face3, 5 ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) ); CHECK( 0 != find_face( poly, face5, 4 ) ); CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) ); CHECK( 0 != find_face( poly, face7, 4 ) ); }
void test_volume | ( | ) |
Definition at line 163 of file bsp_tree_poly_test.cpp.
References CHECK, CHECK_REAL_EQUAL, corners, get_corners(), moab::BSPTreePoly::is_valid(), and moab::BSPTreePoly::volume().
{ CartVect corners[8]; get_corners( corners ); BSPTreePoly poly( corners ); CHECK( poly.is_valid() ); CHECK_REAL_EQUAL( 16.0, poly.volume(), 1e-6 ); }
const int hex_faces[6][4] |
{ { 0, 1, 5, 4 }, { 1, 2, 6, 5 }, { 2, 3, 7, 6 }, { 3, 0, 4, 7 }, { 3, 2, 1, 0 }, { 4, 5, 6, 7 } }
Definition at line 20 of file bsp_tree_poly_test.cpp.
Referenced by test_construct_from_hex(), test_cut_with_plane(), and VtkTest::test_read_quadratic().
