bsp_tree_poly_test.cpp
00001 #include "moab/BSPTreePoly.hpp"
00002 #include "TestUtil.hpp"
00003 #include "moab/CartVect.hpp"
00004
00005 using namespace moab;
00006
00007 void test_construct_from_hex();
00008 void test_cut_with_plane();
00009 void test_volume();
00010
00011 int main()
00012 {
00013     int error_count = 0;
00014     error_count += RUN_TEST( test_construct_from_hex );
00015     error_count += RUN_TEST( test_cut_with_plane );
00016     error_count += RUN_TEST( test_volume );
00017     return error_count;
00018 }
00019
00020 const int hex_faces[6][4] = { { 0, 1, 5, 4 }, { 1, 2, 6, 5 }, { 2, 3, 7, 6 },
00021                               { 3, 0, 4, 7 }, { 3, 2, 1, 0 }, { 4, 5, 6, 7 } };
00022
00023 static void get_corners( CartVect corners[8] )
00024 {
00025     corners[0] = CartVect( 1, 1, 0 );
00026     corners[1] = CartVect( 6, 1, 0 );
00027     corners[2] = CartVect( 6, 3, 0 );
00028     corners[3] = CartVect( 1, 3, 0 );
00029     corners[4] = CartVect( 1, 1, 2 );
00030     corners[5] = CartVect( 4, 1, 2 );
00031     corners[6] = CartVect( 4, 3, 2 );
00032     corners[7] = CartVect( 1, 3, 2 );
00033 }
00034
00035 const BSPTreePoly::Face* find_face( const BSPTreePoly& poly,
00036                                     const CartVect* coords,
00037                                     int num_corners,
00038                                     const int* face_indices = 0 )
00039 {
00040     std::vector< const BSPTreePoly::Face* >::iterator i;
00041     std::vector< const BSPTreePoly::Face* > faces;
00042     std::vector< CartVect > corners;
00043     poly.get_faces( faces );
00044     for( i = faces.begin(); i != faces.end(); ++i )
00045     {
00046         corners.clear();
00047         poly.get_vertices( *i, corners );
00048         if( corners.size() != (unsigned)num_corners ) continue;
00049
00050         int j;
00051         for( j = 0; j < num_corners; ++j )
00052         {
00053             int corner = face_indices ? face_indices[j] : j;
00054             if( ( coords[corner] - corners.front() ).length_squared() < 1e-12 ) break;
00055         }
00056         if( j == num_corners ) continue;
00057
00058         int k;
00059         for( k = 1; k < num_corners; ++k )
00060         {
00061             int corner = face_indices ? face_indices[( j + k ) % num_corners] : ( j + k ) % num_corners;
00062             if( ( coords[corner] - corners[k] ).length_squared() > 1e-12 ) break;
00063         }
00064
00065         if( k == num_corners ) return *i;
00066     }
00067     return 0;
00068 }
00069
00070 void test_construct_from_hex()
00071 {
00072     BSPTreePoly::reset_debug_ids();
00073
00074     CartVect corners[8];
00075     get_corners( corners );
00076     BSPTreePoly poly( corners );
00077     CHECK( poly.is_valid() );
00078
00079     std::vector< const BSPTreePoly::Face* > faces;
00080     poly.get_faces( faces );
00081     CHECK_EQUAL( (size_t)6, faces.size() );
00082
00083     CHECK( 0 != find_face( poly, corners, 4, hex_faces[0] ) );
00084     CHECK( 0 != find_face( poly, corners, 4, hex_faces[1] ) );
00085     CHECK( 0 != find_face( poly, corners, 4, hex_faces[2] ) );
00086     CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) );
00087     CHECK( 0 != find_face( poly, corners, 4, hex_faces[4] ) );
00088     CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) );
00089 }
00090
00091 void test_cut_with_plane()
00092 {
00093     // create a hexahedron
00094     BSPTreePoly::reset_debug_ids();
00095     CartVect corners[8];
00096     get_corners( corners );
00097     BSPTreePoly poly( corners );
00098     CHECK( poly.is_valid() );
00099
00100     // check that a plane entirely above the
00101     // polyhedron (coincident with one face)
00102     // doesn't modify the polyhedron
00103     bool r = poly.cut_polyhedron( CartVect( 0, 0, 1 ), -2 );
00104     CHECK( !r );
00105     CHECK( poly.is_valid() );
00106
00107     // cut in half with Z=1 plane
00108     r = poly.cut_polyhedron( CartVect( 0, 0, 1 ), -1 );
00109     CHECK( r );
00110     CHECK( poly.is_valid() );
00111     for( int i = 0; i < 8; ++i )
00112     {
00113         if( fabs( corners[i][2] - 2 ) < 1e-6 ) corners[i][2] = 1;
00114         if( fabs( corners[i][0] - 4 ) < 1e-6 ) corners[i][0] = 5;
00115     }
00116
00117     std::vector< const BSPTreePoly::Face* > faces;
00118     poly.get_faces( faces );
00119     CHECK_EQUAL( (size_t)6, faces.size() );
00120
00121     CHECK( 0 != find_face( poly, corners, 4, hex_faces[0] ) );
00122     CHECK( 0 != find_face( poly, corners, 4, hex_faces[1] ) );
00123     CHECK( 0 != find_face( poly, corners, 4, hex_faces[2] ) );
00124     CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) );
00125     CHECK( 0 != find_face( poly, corners, 4, hex_faces[4] ) );
00126     CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) );
00127
00128     // create a hexahedron
00129     BSPTreePoly::reset_debug_ids();
00130     get_corners( corners );
00131     poly.set( corners );
00132     CHECK( poly.is_valid() );
00133
00134     // cut off two corners using X=5 plane
00135     r = poly.cut_polyhedron( CartVect( 1, 0, 0 ), -5 );
00136     CHECK( r );
00137     CHECK( poly.is_valid() );
00138
00139     faces.clear();
00140     poly.get_faces( faces );
00141     CHECK_EQUAL( (size_t)7, faces.size() );
00142
00143     CartVect new_vtx1( 5, 1, 1 );
00144     CartVect new_vtx2( 5, 1, 0 );
00145     CartVect new_vtx3( 5, 3, 0 );
00146     CartVect new_vtx4( 5, 3, 1 );
00147
00148     CartVect face1[5] = { corners[0], new_vtx2, new_vtx1, corners[5], corners[4] };
00149     CartVect face2[4] = { new_vtx1, new_vtx4, corners[6], corners[5] };
00150     CartVect face3[5] = { new_vtx4, new_vtx3, corners[3], corners[7], corners[6] };
00151     CartVect face5[4] = { corners[3], new_vtx3, new_vtx2, corners[0] };
00152     CartVect face7[4] = { new_vtx1, new_vtx2, new_vtx3, new_vtx4 };
00153
00154     CHECK( 0 != find_face( poly, face1, 5 ) );
00155     CHECK( 0 != find_face( poly, face2, 4 ) );
00156     CHECK( 0 != find_face( poly, face3, 5 ) );
00157     CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) );
00158     CHECK( 0 != find_face( poly, face5, 4 ) );
00159     CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) );
00160     CHECK( 0 != find_face( poly, face7, 4 ) );
00161 }
00162
00163 void test_volume()
00164 {
00165     CartVect corners[8];
00166     get_corners( corners );
00167     BSPTreePoly poly( corners );
00168     CHECK( poly.is_valid() );
00169
00170     CHECK_REAL_EQUAL( 16.0, poly.volume(), 1e-6 );
00171 }
