cgns_test.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/FileOptions.hpp"
+ Include dependency graph for cgns_test.cpp:
Defines
#define IS_BUILDING_MB
Functions
void test_read_write ()
int main ()
Variables
std::string cgnsfile = "unittest/io/2d_naca0012.cgns"
std::string cgnsfilew = "unittest/io/test.cgns"
Define Documentation
Definition at line 3 of file cgns_test.cpp.
Function Documentation
int main ( )
Definition at line 14 of file cgns_test.cpp.
References RUN_TEST, and test_read_write().
    int result = 0;
    result += RUN_TEST( test_read_write );
    return result;
void test_read_write ( )
Definition at line 23 of file cgns_test.cpp.
References cgnsfile, cgnsfilew, CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, MB_SUCCESS, and moab::Interface::write_file().
Referenced by main().
    ErrorCode rval;
    Core moab;
    Interface& mb = moab;
    rval          = mb.load_file( cgnsfile.c_str() );
    if( MB_SUCCESS != rval ) std::cerr << "Trouble reading file " << cgnsfile << std::endl;CHECK_ERR( rval );
    rval = mb.write_file( cgnsfilew.c_str() );
    if( MB_SUCCESS != rval ) std::cerr << "Trouble writing file " << cgnsfilew << std::endl;CHECK_ERR( rval );
Variable Documentation
Definition at line 9 of file cgns_test.cpp.
Referenced by test_read_write().
Definition at line 10 of file cgns_test.cpp.
