CLArgs::KeyWordArg Class Reference
String arugment that is limited to a list of acceptable keywords. More...
#include <CLArgs.hpp>
+ Inheritance diagram for CLArgs::KeyWordArg:
+ Collaboration diagram for CLArgs::KeyWordArg:
Public Member Functions
 KeyWordArg (const char *keyword_list[], int list_length)
 KeyWordArg (const char *default_val, const char *keyword_list[], int list_length)
virtual bool value (const std::string &val)
virtual std::string brief () const
 Get short description string for usage output or empty string for default.
virtual std::string manstr () const
 Get short description string for UNIX man page output or empty string for default.
Static Public Member Functions
static bool compare_no_case (const char *s1, const char *s2)
Private Member Functions
void initialize (const char *keyword_list[], int list_length)
Private Attributes
std::vector< std::string > mKeyWords
Detailed Description
A specialized string arugment implementation that limits the acceptable string argument to one of a list of keywords. A case-insensitive comparison is done with the allowed keywords. The "value" has the case of the keyword rather than the case used in the literal value specified in the command line argument.
Definition at line 218 of file CLArgs.hpp.
CLArgs::KeyWordArg::KeyWordArg ( const char *  keyword_list[],
int  list_length
) [inline]
Definition at line 225 of file CLArgs.hpp.
References initialize().
            initialize( keyword_list, list_length );
CLArgs::KeyWordArg::KeyWordArg ( const char *  default_val,
int  list_length
) [inline]
Definition at line 229 of file CLArgs.hpp.
        : StringArg( default_val )
Member Function Documentation
std::string CLArgs::KeyWordArg::brief ( ) const [virtual]
Reimplemented from CLArgs::ArgIBase.
Definition at line 435 of file CLArgs.cpp.
    std::ostringstream ss;
    std::vector< std::string >::const_iterator i = mKeyWords.begin();
    if( i == mKeyWords.end() ) return std::string();
    ss << '{' << *i;
    for( ++i; i != mKeyWords.end(); ++i )
        ss << '|' << *i;
    ss << '}';
    return ss.str();
bool CLArgs::KeyWordArg::compare_no_case ( const char *  s1,
const char *  s2
) [static]
Definition at line 462 of file CLArgs.cpp.
    for( ; *s1; ++s1, ++s2 )
        if( toupper( *s1 ) != toupper( *s2 ) ) return false;
    return !*s2;
void CLArgs::KeyWordArg::initialize ( const char *  keyword_list[],
int  list_length
) [private]
Definition at line 417 of file CLArgs.cpp.
References mKeyWords.
Referenced by KeyWordArg().
    mKeyWords.resize( list_length );
    std::copy( keyword_list, keyword_list + list_length, mKeyWords.begin() );
std::string CLArgs::KeyWordArg::manstr ( ) const [virtual]
Definition at line 448 of file CLArgs.cpp.
References ManPage::bold().
    if( mKeyWords.empty() ) return std::string();
    ManPage::bold( ss, mKeyWords[0].c_str() );
    for( unsigned i = 1; i < mKeyWords.size(); ++i )
        ss << "|";
        ManPage::bold( ss, mKeyWords[i].c_str() );
    return ss.str();
bool CLArgs::KeyWordArg::value ( const std::string &  val) [virtual]
Definition at line 423 of file CLArgs.cpp.
References compare_no_case(), and value().
    std::vector< std::string >::const_iterator i;
    for( i = mKeyWords.begin(); i != mKeyWords.end(); ++i )
        if( compare_no_case( i->c_str(), val.c_str() ) )
            return value( *i );
    return false;
Member Data Documentation
std::vector< std::string > CLArgs::KeyWordArg::mKeyWords [private]
Definition at line 221 of file CLArgs.hpp.
Referenced by initialize().
List of all members.
