CachingTargetTest Class Reference
+ Inheritance diagram for CachingTargetTest:
+ Collaboration diagram for CachingTargetTest:
Public Member Functions
void setUp ()
void tearDown ()
void test_surface_orient_flag ()
void test_3d_targets_cached ()
void test_2d_targets_cached ()
void test_surface_targets_cached ()
void test_3d_target_values ()
void test_2d_target_values ()
void test_surface_target_values ()
void test_3d_target_subpatch ()
void test_2d_target_subpatch ()
void test_surface_target_subpatch ()
void test_cache_cleared ()
Private Member Functions
 CPPUNIT_TEST_SUITE (CachingTargetTest)
 CPPUNIT_TEST (test_surface_orient_flag)
 CPPUNIT_TEST (test_3d_targets_cached)
 CPPUNIT_TEST (test_2d_targets_cached)
 CPPUNIT_TEST (test_surface_targets_cached)
 CPPUNIT_TEST (test_3d_target_values)
 CPPUNIT_TEST (test_2d_target_values)
 CPPUNIT_TEST (test_surface_target_values)
 CPPUNIT_TEST (test_3d_target_subpatch)
 CPPUNIT_TEST (test_2d_target_subpatch)
 CPPUNIT_TEST (test_surface_target_subpatch)
 CPPUNIT_TEST (test_cache_cleared)
 CPPUNIT_TEST_SUITE_END ()
unsigned request_all_targets_3d ()
unsigned request_all_targets_2d ()
unsigned request_all_targets_surf ()
Private Attributes
PatchData patch_3d
PatchData patch_2d
CachedTargetCalculatorcached
CachingTargetCalculatorcacher
Detailed Description
Definition at line 44 of file CachingTargetTest.cpp.
Member Function Documentation
Definition at line 216 of file CachingTargetTest.cpp.
References ASSERT_NO_ERROR, and CPPUNIT_ASSERT.
    unsigned total = 0;
    MsqMatrix< 2, 2 > W;
    MsqPrintError err( std::cout );
    std::vector< Sample > locations;
    for( size_t i = 0; i < patch_2d.num_elements(); ++i )
        patch_2d.get_samples( i, locations, err );
        ASSERT_NO_ERROR( err );
        total += locations.size();
        for( unsigned j = 0; j < locations.size(); ++j )
            bool rval = cacher->get_2D_target( patch_2d, i, locations[j], W, err );
            CPPUNIT_ASSERT( rval );
            CPPUNIT_ASSERT( !err );
    return total;
Definition at line 194 of file CachingTargetTest.cpp.
    unsigned total = 0;
    MsqMatrix< 3, 3 > W;
    for( size_t i = 0; i < patch_3d.num_elements(); ++i )
        patch_3d.get_samples( i, locations, err );
            bool rval = cacher->get_3D_target( patch_3d, i, locations[j], W, err );
    return total;
Definition at line 238 of file CachingTargetTest.cpp.
    unsigned total = 0;
    MsqMatrix< 3, 2 > W;
            bool rval = cacher->get_surface_target( patch_2d, i, locations[j], W, err );
    return total;
Definition at line 177 of file CachingTargetTest.cpp.
References CPPUNIT_ASSERT, MBMesquite::create_four_quads_patch(), and MBMesquite::create_qm_two_hex_patch().
    // make sure these are null so that if we fail within setUp,
    // tearDown doesn't try to delete stale pointers
    cached = 0;
    cacher = 0;
    MsqError err;
    create_four_quads_patch( patch_2d, err );
    create_qm_two_hex_patch( patch_3d, err );
    cached = new CachedTargetCalculator();
    cacher = new CachingTargetCalculator( cached );
Definition at line 260 of file CachingTargetTest.cpp.
    delete cacher;
    delete cached;
Definition at line 442 of file CachingTargetTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::get_subpatch(), CachedTargetCalculator::make_2d(), and u.
    // cache some values on the main patch
    cached->surf_orient( false );
    request_all_targets_2d();
    // clear the count so we know if any additional
    // evalutions of the base target calculator are
    // done during subpatch creation.
    cached->clear();
    // create a sub-patch
    CPPUNIT_ASSERT( patch_2d.num_nodes() > 1 );
    PatchData subpatch;
    patch_2d.get_subpatch( 1, 1, subpatch, err );
    // make sure we copied the cached values onto the subpatch
    CPPUNIT_ASSERT_EQUAL( cached->calls_2d(), 0u );
    // Test the values for each cached matrix on the subpatch
    // NOTE:  This test takes advantange of the fact that the
    // "handles" in the subpatch are indices into the main patch.
    // test each value
    for( size_t i = 0; i < subpatch.num_elements(); ++i )
        subpatch.get_samples( i, locations, err );
            bool rval = cacher->get_2D_target( subpatch, i, locations[j], W, err );
            CPPUNIT_ASSERT( rval && !err );
            Mesh::ElementHandle h      = subpatch.get_element_handles_array()[i];
            Mesh::ElementHandle* old_h = patch_2d.get_element_handles_array();
            size_t old_idx             = std::find( old_h, old_h + patch_2d.num_elements(), h ) - old_h;
            CPPUNIT_ASSERT( old_idx < patch_2d.num_elements() );
            MsqMatrix< 2, 2 > M = CachedTargetCalculator::make_2d( old_idx, locations[j] );
            ASSERT_MATRICES_EQUAL( W, M, DBL_EPSILON );
Definition at line 343 of file CachingTargetTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, and CachedTargetCalculator::make_2d().
    // evaluate all once to make sure we test the cached values
    // test each value
            MsqMatrix< 2, 2 > M = CachedTargetCalculator::make_2d( i, locations[j] );
Definition at line 395 of file CachingTargetTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::get_subpatch(), CachedTargetCalculator::make_3d(), and u.
    request_all_targets_3d();
    cached->clear();
    CPPUNIT_ASSERT( patch_3d.num_nodes() > 1 );
    PatchData subpatch;
    patch_3d.get_subpatch( 1, 1, subpatch, err );
    CPPUNIT_ASSERT_EQUAL( cached->calls_3d(), 0u );
    // test each value
            bool rval = cacher->get_3D_target( subpatch, i, locations[j], W, err );
            Mesh::ElementHandle* old_h = patch_3d.get_element_handles_array();
            size_t old_idx             = std::find( old_h, old_h + patch_3d.num_elements(), h ) - old_h;
            CPPUNIT_ASSERT( old_idx < patch_3d.num_elements() );
            MsqMatrix< 3, 3 > M = CachedTargetCalculator::make_3d( old_idx, locations[j] );
Definition at line 318 of file CachingTargetTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, and CachedTargetCalculator::make_3d().
    // test each value
            MsqMatrix< 3, 3 > M = CachedTargetCalculator::make_3d( i, locations[j] );
Definition at line 538 of file CachingTargetTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, and MBMesquite::create_twelve_hex_patch().
    // done.
    cached->clear();
    // now re-create the patch, which should result in the
    // cached data being notified that the mesh has changed
    create_twelve_hex_patch( patch_3d, err );
    // now get cached values for each element
    unsigned count = request_all_targets_3d();
    // and check that they were all re-calculated
    CPPUNIT_ASSERT_EQUAL( cached->calls_3d(), count );
Definition at line 490 of file CachingTargetTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::get_subpatch(), CachedTargetCalculator::make_surf(), and u.
    cached->surf_orient( true );
    request_all_targets_surf();
    cached->clear();
    PatchData subpatch;
    // test each value
            bool rval = cacher->get_surface_target( subpatch, i, locations[j], W, err );
            MsqMatrix< 3, 2 > M = CachedTargetCalculator::make_surf( old_idx, locations[j] );
Definition at line 369 of file CachingTargetTest.cpp.
References ASSERT_MATRICES_EQUAL, ASSERT_NO_ERROR, CPPUNIT_ASSERT, and CachedTargetCalculator::make_surf().
    // test each value
            MsqMatrix< 3, 2 > M = CachedTargetCalculator::make_surf( i, locations[j] );
Member Data Documentation
Definition at line 61 of file CachingTargetTest.cpp.
List of all members.
