MOAB: Mesh Oriented datABase
(version 5.4.1)
Definition at line 39 of file ConditionNumberTest.cpp.
ConditionNumberTest::ConditionNumberTest | ( | ) | [inline] |
Definition at line 67 of file ConditionNumberTest.cpp.
ConditionNumberTest::CPPUNIT_TEST | ( | test_supported_types | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_ideal_element_eval | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_ideal_element_grad | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_ideal_element_hess | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_measures_quality | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_domain_deviation | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_inverted_elements | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_degenerate_elements | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_get_evaluations | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_get_element_indices | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_get_fixed_indices | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_eval_with_indices | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_location_invariant | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_scale_invariant | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST | ( | test_orient_invariant | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST_SUITE | ( | ConditionNumberTest | ) | [private] |
ConditionNumberTest::CPPUNIT_TEST_SUITE_END | ( | ) | [private] |
void ConditionNumberTest::test_degenerate_elements | ( | ) | [inline] |
Definition at line 118 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_evaluate_degenerate_element( &mMetric, false ); }
void ConditionNumberTest::test_domain_deviation | ( | ) | [inline] |
Definition at line 107 of file ConditionNumberTest.cpp.
References mMetric.
void ConditionNumberTest::test_eval_with_indices | ( | ) | [inline] |
Definition at line 138 of file ConditionNumberTest.cpp.
References mMetric.
void ConditionNumberTest::test_get_element_indices | ( | ) | [inline] |
Definition at line 128 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_get_element_indices( &mMetric ); }
void ConditionNumberTest::test_get_evaluations | ( | ) | [inline] |
Definition at line 123 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_get_element_evaluations( &mMetric ); }
void ConditionNumberTest::test_get_fixed_indices | ( | ) | [inline] |
Definition at line 133 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_get_indices_fixed( &mMetric ); }
void ConditionNumberTest::test_gradient_reflects_quality | ( | ) | [inline] |
Definition at line 102 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_gradient_reflects_quality( &mMetric ); }
void ConditionNumberTest::test_ideal_element_eval | ( | ) | [inline] |
Definition at line 77 of file ConditionNumberTest.cpp.
References MBMesquite::HEXAHEDRON, mMetric, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, and MBMesquite::TRIANGLE.
{ tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, QUADRILATERAL, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, HEXAHEDRON, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, PRISM, 1.0 ); tester.test_evaluate_unit_edge_element( &mMetric, PYRAMID, 1.0 ); }
void ConditionNumberTest::test_ideal_element_grad | ( | ) | [inline] |
Definition at line 87 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_ideal_element_zero_gradient( &mMetric, false ); }
void ConditionNumberTest::test_ideal_element_hess | ( | ) | [inline] |
Definition at line 92 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_ideal_element_positive_definite_Hessian( &mMetric, false ); }
void ConditionNumberTest::test_inverted_elements | ( | ) | [inline] |
Definition at line 113 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_evaluate_inverted_element( &mMetric, false ); }
void ConditionNumberTest::test_location_invariant | ( | ) | [inline] |
Definition at line 143 of file ConditionNumberTest.cpp.
References mMetric.
void ConditionNumberTest::test_measures_quality | ( | ) | [inline] |
Definition at line 97 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_measures_quality( &mMetric ); }
void ConditionNumberTest::test_orient_invariant | ( | ) | [inline] |
Definition at line 155 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_orient_invariant( &mMetric ); tester.test_grad_orient_invariant( &mMetric ); }
void ConditionNumberTest::test_scale_invariant | ( | ) | [inline] |
Definition at line 150 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_scale_invariant( &mMetric ); }
void ConditionNumberTest::test_supported_types | ( | ) | [inline] |
Definition at line 72 of file ConditionNumberTest.cpp.
References mMetric.
{ tester.test_supported_element_types( &mMetric ); }
Definition at line 63 of file ConditionNumberTest.cpp.
Definition at line 64 of file ConditionNumberTest.cpp.
