EdgeLengthMetricTest Class Reference
+ Inheritance diagram for EdgeLengthMetricTest:
+ Collaboration diagram for EdgeLengthMetricTest:
Public Member Functions
 EdgeLengthMetricTest ()
void test_supported_types ()
void test_ideal_element_eval ()
void test_valid_hessian ()
void test_get_evaluations ()
void test_get_edge_indices ()
void test_eval_with_indices ()
void test_eval_with_gradient ()
void test_location_invariant ()
void test_orient_invariant ()
void test_inverted_elements ()
void test_degenerate_elements ()
void test_get_vertex_indices ()
void test_get_fixed_indices ()
Private Member Functions
 CPPUNIT_TEST_SUITE (EdgeLengthMetricTest)
 CPPUNIT_TEST (test_supported_types)
 CPPUNIT_TEST (test_ideal_element_eval)
 CPPUNIT_TEST (test_valid_hessian)
 CPPUNIT_TEST (test_get_evaluations)
 CPPUNIT_TEST (test_get_edge_indices)
 CPPUNIT_TEST (test_eval_with_indices)
 CPPUNIT_TEST (test_eval_with_gradient)
 CPPUNIT_TEST (test_location_invariant)
 CPPUNIT_TEST (test_orient_invariant)
 CPPUNIT_TEST_SUITE_END ()
 CPPUNIT_TEST (test_inverted_elements)
 CPPUNIT_TEST (test_degenerate_elements)
 CPPUNIT_TEST (test_get_vertex_indices)
 CPPUNIT_TEST (test_get_fixed_indices)
Private Attributes
EdgeLengthMetric mMetric
QualityMetricTester tester
EdgeLengthQualityMetric mMetric
Detailed Description
Definition at line 39 of file EdgeLengthMetricTest.cpp.
Member Function Documentation
Definition at line 87 of file EdgeLengthMetricTest.cpp.
References mMetric.
Member Data Documentation
List of all members.
