EntityRefinerOutputFunctor Class Reference
#include <EntityRefiner.hpp>
Detailed Description
This is an abstract class used by EntityRefiner to output entities that are the product of refinement. The parenthesis operator is overloaded with two forms: one used for appending a vertex to an entity, the other used to finalize the creation of the entity by specifying its type.
You are also responsible for implementing the map_vertex() function to map an input vertex handle into an output vertex handle (which may then be appended to an entity using the first form of the parenthesis operator above).
Author:
David Thompson
Philippe Pebay
Date:
26 December 2007
