FileTokenizerTest Class Reference
+ Inheritance diagram for FileTokenizerTest:
+ Collaboration diagram for FileTokenizerTest:
Public Member Functions
 FileTokenizerTest ()
void setUp ()
void tearDown ()
FILE * make_file ()
void token_test ()
void line_number_test ()
void newline_test ()
void match_one_test ()
void match_multiple_test ()
void double_test ()
void long_test ()
void boolean_test ()
void unget_test ()
Static Public Member Functions
static int count_newlines (const char *str)
Private Member Functions
 CPPUNIT_TEST_SUITE (FileTokenizerTest)
 CPPUNIT_TEST (token_test)
 CPPUNIT_TEST (line_number_test)
 CPPUNIT_TEST (newline_test)
 CPPUNIT_TEST (match_one_test)
 CPPUNIT_TEST (match_multiple_test)
 CPPUNIT_TEST (double_test)
 CPPUNIT_TEST (long_test)
 CPPUNIT_TEST (boolean_test)
 CPPUNIT_TEST (unget_test)
 CPPUNIT_TEST_SUITE_END ()
Detailed Description
Definition at line 27 of file FileTokenizerTest.cpp.
Definition at line 43 of file FileTokenizerTest.cpp.
Member Function Documentation
Definition at line 264 of file FileTokenizerTest.cpp.
References booleans, MBMesquite::MsqError::clear(), CPPUNIT_ASSERT, MBMesquite::ft, MBMesquite::FileTokenizer::get_booleans(), make_file(), tokens, and value().
        MsqPrintError err( cout );
        FileTokenizer ft( make_file() );
        for( int i = 0; tokens[i]; ++i )
            bool value;
            ft.get_booleans( 1, &value, err );
            if( booleans[i] )
                CPPUNIT_ASSERT( !err );
                CPPUNIT_ASSERT( value == !!atoi( tokens[i] ) );
            else
                CPPUNIT_ASSERT( err );
                err.clear();
static int FileTokenizerTest::count_newlines ( const char *  str) [inline, static]
Definition at line 103 of file FileTokenizerTest.cpp.
Referenced by line_number_test(), and newline_test().
        int result = 0;
        for( ; *str; ++str )
            if( *str == '\n' ) ++result;
        return result;
void FileTokenizerTest::double_test ( ) [inline]
Definition at line 220 of file FileTokenizerTest.cpp.
References MBMesquite::MsqError::clear(), CPPUNIT_ASSERT, doubles, MBMesquite::ft, MBMesquite::FileTokenizer::get_doubles(), make_file(), tokens, and value().
            double value;
            ft.get_doubles( 1, &value, err );
            if( doubles[i] )
                CPPUNIT_ASSERT( value == strtod( tokens[i], 0 ) );
            else
                err.clear();
Definition at line 111 of file FileTokenizerTest.cpp.
References count_newlines(), CPPUNIT_ASSERT, MBMesquite::ft, MBMesquite::FileTokenizer::get_string(), MBMesquite::FileTokenizer::line_number(), make_file(), and spaces.
        const char* token;
        int lineno = 1;
        token      = ft.get_string( err );
        CPPUNIT_ASSERT( token );
        for( const char* const* s_iter = spaces; *s_iter; ++s_iter )
            lineno += count_newlines( *s_iter );
            CPPUNIT_ASSERT( ft.line_number() == lineno );
void FileTokenizerTest::long_test ( ) [inline]
Definition at line 242 of file FileTokenizerTest.cpp.
References MBMesquite::MsqError::clear(), CPPUNIT_ASSERT, MBMesquite::ft, MBMesquite::FileTokenizer::get_long_ints(), longs, make_file(), tokens, and value().
            long value;
            ft.get_long_ints( 1, &value, err );
            if( longs[i] )
                CPPUNIT_ASSERT( value == strtol( tokens[i], 0, 0 ) );
            else
                err.clear();
FILE* FileTokenizerTest::make_file ( ) [inline]
Definition at line 49 of file FileTokenizerTest.cpp.
References buffer, CPPUNIT_ASSERT, spaces, and tokens.
Referenced by boolean_test(), double_test(), line_number_test(), long_test(), match_multiple_test(), match_one_test(), newline_test(), token_test(), and unget_test().
#ifdef WIN32
        char name1[L_tmpnam_s];
        errno_t err = tmpnam_s( name1, L_tmpnam_s );
        // Get the current working directory:
        char* buffer;
        buffer = _getcwd( NULL, 0 );
        std::string full_path( buffer );
        std::string temp_name( name1 );
        full_path  = full_path + temp_name;
        FILE* file = fopen( full_path.c_str(), "w+" );
#else
        FILE* file = tmpfile();
#endif
        CPPUNIT_ASSERT( !!file );
        const char* const* t_iter = tokens;
        fputs( *t_iter, file );
        ++t_iter;
        while( *t_iter )
            fputs( *s_iter, file );
            ++s_iter;
            ++t_iter;
        rewind( file );
        return file;
Definition at line 190 of file FileTokenizerTest.cpp.
References MBMesquite::MsqError::clear(), CPPUNIT_ASSERT, MBMesquite::ft, make_file(), MBMesquite::FileTokenizer::match_token(), and tokens.
        int result;
        const char* const test1[] = { *t_iter, "Mesquite", "x", 0 };
        result                    = ft.match_token( test1, err );
        CPPUNIT_ASSERT( result == 1 && !err );
        ++t_iter;
        const char* const test2[] = { "x", "y", *t_iter, 0 };
        result                    = ft.match_token( test2, err );
        CPPUNIT_ASSERT( result == 3 && !err );
        ++t_iter;
        const char* const test3[] = { *t_iter, 0 };
        result                    = ft.match_token( test3, err );
        ++t_iter;
        const char* const test4[] = { "Mesquite", "Mesh", 0 };
        result                    = ft.match_token( test4, err );
        CPPUNIT_ASSERT( result == 0 && err );
        err.clear();
        ++t_iter;
Definition at line 165 of file FileTokenizerTest.cpp.
References b, MBMesquite::MsqError::clear(), CPPUNIT_ASSERT, MBMesquite::ft, make_file(), MBMesquite::FileTokenizer::match_token(), and tokens.
        const char* const* t_iter;
        bool b;
        for( t_iter = tokens; *t_iter; ++t_iter )
            b = ft.match_token( *t_iter, err );
            CPPUNIT_ASSERT( b && !err );
        FileTokenizer ft2( make_file() );
        b = ft2.match_token( "", err );
        CPPUNIT_ASSERT( !b && err );
        err.clear();
        b = ft2.match_token( "Mesquite", err );
        err.clear();
Definition at line 134 of file FileTokenizerTest.cpp.
References b, MBMesquite::MsqError::clear(), count_newlines(), CPPUNIT_ASSERT, MBMesquite::ft, MBMesquite::FileTokenizer::get_newline(), MBMesquite::FileTokenizer::get_string(), make_file(), and spaces.
        const char* token;
            int count = count_newlines( *s_iter );
            bool b;
            while( count-- )
                b = ft.get_newline( err );
            err.clear();
void FileTokenizerTest::setUp ( ) [inline]
Definition at line 45 of file FileTokenizerTest.cpp.
void FileTokenizerTest::tearDown ( ) [inline]
Definition at line 47 of file FileTokenizerTest.cpp.
void FileTokenizerTest::token_test ( ) [inline]
Definition at line 82 of file FileTokenizerTest.cpp.
References MBMesquite::MsqError::clear(), CPPUNIT_ASSERT, MBMesquite::FileTokenizer::eof(), MBMesquite::ft, MBMesquite::FileTokenizer::get_string(), make_file(), and tokens.
        const char* token;
        for( const char* const* t_iter = tokens; *t_iter; ++t_iter )
            CPPUNIT_ASSERT( !strcmp( *t_iter, token ) );
        CPPUNIT_ASSERT( !token );
        CPPUNIT_ASSERT( ft.eof() );
        err.clear();
void FileTokenizerTest::unget_test ( ) [inline]
Definition at line 286 of file FileTokenizerTest.cpp.
References CPPUNIT_ASSERT, MBMesquite::ft, MBMesquite::FileTokenizer::get_string(), make_file(), tokens, and MBMesquite::FileTokenizer::unget_token().
        const char* token         = ft.get_string( err );
        CPPUNIT_ASSERT( !strcmp( token, *t_iter ) );
        ft.unget_token();
        ++t_iter;
        ++t_iter;
        ft.unget_token();
List of all members.
