LinearMappingFunctionTest Member List
This is the complete list of members for LinearMappingFunctionTest, including all inherited members.
CPPUNIT_TEST(test_linear_hex_coeff_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_coeff_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_coeff_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_coeff_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_coeff_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_coeff_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_coeff_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_coeff_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_coeff_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_coeff_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_coeff_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_coeff_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_coeff_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_coeff_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_coeff_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_coeff_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_coeff_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_coeff_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_coeff_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_coeff_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_coeff_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_coeff_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_coeff_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_deriv_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_deriv_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_deriv_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_deriv_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_deriv_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_deriv_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_deriv_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_deriv_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_deriv_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_deriv_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_deriv_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_deriv_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_deriv_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_deriv_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_deriv_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_deriv_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_deriv_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_deriv_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_deriv_corners)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_deriv_edges)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_deriv_faces)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_pyr_deriv_center)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_hex_ideal)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_quad_ideal)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tet_ideal)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_tri_ideal)LinearMappingFunctionTest [private]
CPPUNIT_TEST(test_linear_prism_ideal)LinearMappingFunctionTest [private]
CPPUNIT_TEST_SUITE(LinearMappingFunctionTest)LinearMappingFunctionTest [private]
CPPUNIT_TEST_SUITE_END()LinearMappingFunctionTest [private]
do_coeff_test(MappingFunction &mf, unsigned subdim, map_func mf2, unsigned count, double *xi)LinearMappingFunctionTest [private]
do_deriv_test(MappingFunction2D &mf, unsigned subdim, map_func mf2, unsigned count, double *xi)LinearMappingFunctionTest [private]
do_deriv_test(MappingFunction3D &mf, unsigned subdim, map_func mf2, unsigned count, double *xi)LinearMappingFunctionTest [private]
do_ideal_test(MappingFunction2D &mf)LinearMappingFunctionTest [private]
do_ideal_test(MappingFunction3D &mf)LinearMappingFunctionTest [private]
hexLinearMappingFunctionTest [private]
hex_coeff(double xi[3], double coeff[8])LinearMappingFunctionTest [private, static]
hex_deriv(double xi[3], double coeff_deriv[24])LinearMappingFunctionTest [private, static]
map_func typedefLinearMappingFunctionTest [private]
prismLinearMappingFunctionTest [private]
prism_coeff(double xi[3], double coeff[6])LinearMappingFunctionTest [private, static]
prism_deriv(double xi[3], double coeff_deriv[18])LinearMappingFunctionTest [private, static]
pyrLinearMappingFunctionTest [private]
pyr_coeff(double xi[3], double coeff[5])LinearMappingFunctionTest [private, static]
pyr_deriv(double xi[3], double coeff_deriv[15])LinearMappingFunctionTest [private, static]
quadLinearMappingFunctionTest [private]
quad_coeff(double xi[2], double coeff[4])LinearMappingFunctionTest [private, static]
quad_deriv(double xi[2], double coeff_deriv[8])LinearMappingFunctionTest [private, static]
setUp()LinearMappingFunctionTest
tearDown()LinearMappingFunctionTest
test_coeff_fail(MappingFunction &mf, unsigned subdim)LinearMappingFunctionTest [private]
test_deriv_fail(MappingFunction2D &mf, unsigned subdim)LinearMappingFunctionTest [private]
test_deriv_fail(MappingFunction3D &mf, unsigned subdim)LinearMappingFunctionTest [private]
test_linear_hex_coeff_center()LinearMappingFunctionTest
test_linear_hex_coeff_corners()LinearMappingFunctionTest
test_linear_hex_coeff_edges()LinearMappingFunctionTest
test_linear_hex_coeff_faces()LinearMappingFunctionTest
test_linear_hex_deriv_center()LinearMappingFunctionTest
test_linear_hex_deriv_corners()LinearMappingFunctionTest
test_linear_hex_deriv_edges()LinearMappingFunctionTest
test_linear_hex_deriv_faces()LinearMappingFunctionTest
test_linear_hex_ideal()LinearMappingFunctionTest [inline]
test_linear_prism_coeff_center()LinearMappingFunctionTest
test_linear_prism_coeff_corners()LinearMappingFunctionTest
test_linear_prism_coeff_edges()LinearMappingFunctionTest
test_linear_prism_coeff_faces()LinearMappingFunctionTest
test_linear_prism_deriv_center()LinearMappingFunctionTest
test_linear_prism_deriv_corners()LinearMappingFunctionTest
test_linear_prism_deriv_edges()LinearMappingFunctionTest
test_linear_prism_deriv_faces()LinearMappingFunctionTest
test_linear_prism_ideal()LinearMappingFunctionTest [inline]
test_linear_pyr_coeff_center()LinearMappingFunctionTest
test_linear_pyr_coeff_corners()LinearMappingFunctionTest
test_linear_pyr_coeff_edges()LinearMappingFunctionTest
test_linear_pyr_coeff_faces()LinearMappingFunctionTest
test_linear_pyr_deriv_center()LinearMappingFunctionTest
test_linear_pyr_deriv_corners()LinearMappingFunctionTest
test_linear_pyr_deriv_edges()LinearMappingFunctionTest
test_linear_pyr_deriv_faces()LinearMappingFunctionTest
test_linear_quad_coeff_center()LinearMappingFunctionTest
test_linear_quad_coeff_corners()LinearMappingFunctionTest
test_linear_quad_coeff_edges()LinearMappingFunctionTest
test_linear_quad_deriv_center()LinearMappingFunctionTest
test_linear_quad_deriv_corners()LinearMappingFunctionTest
test_linear_quad_deriv_edges()LinearMappingFunctionTest
test_linear_quad_ideal()LinearMappingFunctionTest [inline]
test_linear_tet_coeff_center()LinearMappingFunctionTest
test_linear_tet_coeff_corners()LinearMappingFunctionTest
test_linear_tet_coeff_edges()LinearMappingFunctionTest
test_linear_tet_coeff_faces()LinearMappingFunctionTest
test_linear_tet_deriv_center()LinearMappingFunctionTest
test_linear_tet_deriv_corners()LinearMappingFunctionTest
test_linear_tet_deriv_edges()LinearMappingFunctionTest
test_linear_tet_deriv_faces()LinearMappingFunctionTest
test_linear_tet_ideal()LinearMappingFunctionTest [inline]
test_linear_tri_coeff_center()LinearMappingFunctionTest
test_linear_tri_coeff_corners()LinearMappingFunctionTest
test_linear_tri_coeff_edges()LinearMappingFunctionTest
test_linear_tri_coeff_faces()LinearMappingFunctionTest
test_linear_tri_deriv_center()LinearMappingFunctionTest
test_linear_tri_deriv_corners()LinearMappingFunctionTest
test_linear_tri_deriv_edges()LinearMappingFunctionTest
test_linear_tri_ideal()LinearMappingFunctionTest [inline]
tetLinearMappingFunctionTest [private]
tet_coeff(double xi[3], double coeff[4])LinearMappingFunctionTest [private, static]
tet_deriv(double xi[3], double coeff_deriv[12])LinearMappingFunctionTest [private, static]
triLinearMappingFunctionTest [private]
tri_coeff(double xi[2], double coeff[3])LinearMappingFunctionTest [private, static]
tri_deriv(double xi[2], double coeff_deriv[6])LinearMappingFunctionTest [private, static]
xi_at_corners(EntityTopology type, double *xi, const int *corners)LinearMappingFunctionTest [private]
xi_at_edges(EntityTopology type, double *xi, const int *corners)LinearMappingFunctionTest [private]
xi_at_faces(EntityTopology type, double *xi, const int *corners)LinearMappingFunctionTest [private]
