MBMesquite::AWSizeB1 Class Reference
#include <AWSizeB1.hpp>
+ Inheritance diagram for MBMesquite::AWSizeB1:
+ Collaboration diagram for MBMesquite::AWSizeB1:
Public Member Functions
virtual MESQUITE_EXPORT ~AWSizeB1 ()
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 2, 2 > &A, const MsqMatrix< 2, 2 > &W, double &result, MsqError &err)
 Evaluate \(\mu(A,W)\).
virtual MESQUITE_EXPORT bool evaluate_with_grad (const MsqMatrix< 2, 2 > &A, const MsqMatrix< 2, 2 > &W, double &result, MsqMatrix< 2, 2 > &deriv_wrt_A, MsqError &err)
 Gradient of \(\mu(A,W)\) with respect to components of A.
virtual MESQUITE_EXPORT bool evaluate (const MsqMatrix< 3, 3 > &A, const MsqMatrix< 3, 3 > &W, double &result, MsqError &err)
virtual MESQUITE_EXPORT bool evaluate_with_grad (const MsqMatrix< 3, 3 > &A, const MsqMatrix< 3, 3 > &W, double &result, MsqMatrix< 3, 3 > &deriv_wrt_A, MsqError &err)
Detailed Description
\( \frac{\alpha}{\omega} - \frac{\omega}{\alpha} - 2 \)
Definition at line 43 of file AWSizeB1.hpp.
Definition at line 47 of file AWSizeB1.cpp.
Member Function Documentation
bool MBMesquite::AWSizeB1::evaluate ( const MsqMatrix< 2, 2 > &  A,
const MsqMatrix< 2, 2 > &  W,
double &  result,
MsqError err
) [virtual]
Parameters:
A2x2 active matrix
W2x2 target matrix
resultOutput: value of function
Returns:
false if function cannot be evaluated for given A and W (e.g. division by zero, etc.), true otherwise.
Reimplemented from MBMesquite::AWMetric.
Definition at line 49 of file AWSizeB1.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg_aw, MBMesquite::det(), MBMesquite::AWMetric::invalid_determinant(), and MSQ_SETERR.
    const double alpha = det( A );
    const double omega = det( W );
    const double prod  = alpha * omega;
    if( AWMetric::invalid_determinant( prod ) )
        MSQ_SETERR( err )( barrier_violated_msg_aw, MsqError::BARRIER_VIOLATED );
        return false;
    result = ( alpha - omega );
    result *= result;
    result /= prod;
    return true;
bool MBMesquite::AWSizeB1::evaluate ( const MsqMatrix< 3, 3 > &  A,
const MsqMatrix< 3, 3 > &  W,
double &  result,
MsqError err
) [virtual]
Parameters:
A3x3 active matrix
W3x3 target matrix
Returns:
Definition at line 89 of file AWSizeB1.cpp.
        return false;
    result *= result;
    result /= prod;
    return true;
bool MBMesquite::AWSizeB1::evaluate_with_grad ( const MsqMatrix< 2, 2 > &  A,
double &  result,
MsqMatrix< 2, 2 > &  deriv_wrt_A,
MsqError err
) [virtual]
Parameters:
A2x2 active matrix
W2x2 target matrix
deriv_wrt_AOutput: partial deriviatve of \(\mu\) wrt each term of A, evaluated at passed A.
\[\left[\begin{array}{cc} \frac{\partial\mu}{\partial A_{0,0}} & \frac{\partial\mu}{\partial A_{0,1}} \\ \frac{\partial\mu}{\partial A_{1,0}} & \frac{\partial\mu}{\partial A_{1,1}} \\ \end{array}\right]\]
Returns:
Definition at line 66 of file AWSizeB1.cpp.
References MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::barrier_violated_msg_aw, MBMesquite::det(), MBMesquite::AWMetric::invalid_determinant(), MSQ_SETERR, and MBMesquite::transpose_adj().
        return false;
    result *= result;
    result /= prod;
    deriv_wrt_A = transpose_adj( A );
    deriv_wrt_A *= ( alpha * alpha - omega * omega ) / ( alpha * prod );
    return true;
bool MBMesquite::AWSizeB1::evaluate_with_grad ( const MsqMatrix< 3, 3 > &  A,
double &  result,
MsqMatrix< 3, 3 > &  deriv_wrt_A,
MsqError err
) [virtual]
Parameters:
A3x3 active matrix
W3x3 target matrix
\[\left[\begin{array}{ccc} \frac{\partial\mu}{\partial A_{0,0}} & \frac{\partial\mu}{\partial A_{0,1}} & \frac{\partial\mu}{\partial A_{0,2}} \\ \frac{\partial\mu}{\partial A_{1,0}} & \frac{\partial\mu}{\partial A_{1,1}} & \frac{\partial\mu}{\partial A_{1,2}} \\ \frac{\partial\mu}{\partial A_{2,0}} & \frac{\partial\mu}{\partial A_{2,1}} & \frac{\partial\mu}{\partial A_{2,2}} \end{array}\right]\]
Returns:
Definition at line 106 of file AWSizeB1.cpp.
        return false;
    result *= result;
    result /= prod;
    return true;
std::string MBMesquite::AWSizeB1::get_name ( ) const [virtual]
Reimplemented from MBMesquite::AWMetricBarrier.
Definition at line 42 of file AWSizeB1.cpp.
    return "AWSizeB1";
List of all members.
