MBMesquite::AffineMapMetric Class Reference
Compare targets to affine map to ideal element. More...
#include <AffineMapMetric.hpp>
+ Inheritance diagram for MBMesquite::AffineMapMetric:
+ Collaboration diagram for MBMesquite::AffineMapMetric:
Public Member Functions
MESQUITE_EXPORT AffineMapMetric (TargetCalculator *tc, WeightCalculator *wc, TMetric *target_metric)
MESQUITE_EXPORT AffineMapMetric (TargetCalculator *tc, TMetric *target_metric)
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT void get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
 Get locations at which metric can be evaluated.
virtual MESQUITE_EXPORT void get_element_evaluations (PatchData &pd, size_t elem_index, std::vector< size_t > &handles, MsqError &err)
 Get evaluation point handles for a given element.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
void set_target_calculator (TargetCalculator *tc)
void set_weight_calculator (WeightCalculator *wc)
TargetCalculatorget_target_calculator () const
WeightCalculatorget_weight_calculator () const
TMetricget_target_metric () const
void set_target_metric (TMetric *m)
Private Attributes
TargetCalculatortargetCalc
WeightCalculatorweightCalc
TMetrictargetMetric
Detailed Description
A quality metric defined using 2D and 3D target metrics, where the active (A) matrix is an affine map to the ideal, unit-side element.
Definition at line 53 of file AffineMapMetric.hpp.
Definition at line 59 of file AffineMapMetric.cpp.
    : targetCalc( tc ), weightCalc( wc ), targetMetric( target_metric )
Definition at line 64 of file AffineMapMetric.cpp.
    : targetCalc( tc ), weightCalc( 0 ), targetMetric( target_metric )
Member Function Documentation
bool MBMesquite::AffineMapMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 92 of file AffineMapMetric.cpp.
References MBMesquite::adj(), conn, MBMesquite::Sample::dimension, MBMesquite::ElemSampleQM::elem(), MBMesquite::PatchData::element_by_index(), MBMesquite::TMetric::evaluate(), MBMesquite::TargetCalculator::get_3D_target(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::TargetCalculator::get_surface_target(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::WeightCalculator::get_weight(), MBMesquite::inverse(), MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::Sample::number, MBMesquite::ElemSampleQM::sample(), MBMesquite::MsqMatrix< R, C >::set_column(), MBMesquite::surface_to_2d(), targetCalc, targetMetric, MBMesquite::TET_XFORM, MBMesquite::TETRAHEDRON, MBMesquite::transpose(), MBMesquite::TRI_XFORM, MBMesquite::TRIANGLE, MBMesquite::MsqError::UNSUPPORTED_ELEMENT, MBMesquite::PatchData::vertex_by_index(), and weightCalc.
Referenced by evaluate_with_indices().
    Sample s              = ElemSampleQM::sample( p_handle );
    size_t e              = ElemSampleQM::elem( p_handle );
    MsqMeshEntity& p_elem = pd.element_by_index( e );
    EntityTopology type   = p_elem.get_element_type();
    unsigned edim         = TopologyInfo::dimension( type );
    const size_t* conn    = p_elem.get_vertex_index_array();
    // This metric only supports sampling at corners, except for simplices.
    // If element is a simpex, then the Jacobian is constant over a linear
    // element.  In this case, always evaluate at any vertex.
    // unsigned corner = s.number;
    if( s.dimension != 0 )
        if( type == TRIANGLE || type == TETRAHEDRON )
            /*corner = 0*/;
        else
            MSQ_SETERR( err )
            ( "Invalid sample point for AffineMapMetric", MsqError::UNSUPPORTED_ELEMENT );
            return false;
    bool rval;
    if( edim == 3 )
    {  // 3x3 or 3x2 targets ?
        Vector3D c[3] = { Vector3D( 0, 0, 0 ), Vector3D( 0, 0, 0 ), Vector3D( 0, 0, 0 ) };
        unsigned n;
        const unsigned* adj = TopologyInfo::adjacent_vertices( type, s.number, n );
        c[0]                = pd.vertex_by_index( conn[adj[0]] ) - pd.vertex_by_index( conn[s.number] );
        c[1]                = pd.vertex_by_index( conn[adj[1]] ) - pd.vertex_by_index( conn[s.number] );
        c[2]                = pd.vertex_by_index( conn[adj[2]] ) - pd.vertex_by_index( conn[s.number] );
        MsqMatrix< 3, 3 > A;
        A.set_column( 0, MsqMatrix< 3, 1 >( c[0].to_array() ) );
        A.set_column( 1, MsqMatrix< 3, 1 >( c[1].to_array() ) );
        A.set_column( 2, MsqMatrix< 3, 1 >( c[2].to_array() ) );
        if( type == TETRAHEDRON ) A = A * TET_XFORM;
        MsqMatrix< 3, 3 > W;
        targetCalc->get_3D_target( pd, e, s, W, err );
        MSQ_ERRZERO( err );
        rval = targetMetric->evaluate( A * inverse( W ), value, err );
        MSQ_ERRZERO( err );
    else
        Vector3D c[2] = { Vector3D( 0, 0, 0 ), Vector3D( 0, 0, 0 ) };
        unsigned n;
        MsqMatrix< 3, 2 > App;
        App.set_column( 0, MsqMatrix< 3, 1 >( c[0].to_array() ) );
        App.set_column( 1, MsqMatrix< 3, 1 >( c[1].to_array() ) );
        MsqMatrix< 3, 2 > Wp;
        targetCalc->get_surface_target( pd, e, s, Wp, err );
        MSQ_ERRZERO( err );
        MsqMatrix< 2, 2 > A, W;
        MsqMatrix< 3, 2 > RZ;
        surface_to_2d( App, Wp, W, RZ );
        A = transpose( RZ ) * App;
        if( type == TRIANGLE ) A = A * TRI_XFORM;
        MSQ_ERRZERO( err );
    // apply target weight to value
    if( weightCalc )
        double ck = weightCalc->get_weight( pd, e, s, err );
        MSQ_ERRZERO( err );
        value *= ck;
    return rval;
bool MBMesquite::AffineMapMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
Definition at line 173 of file AffineMapMetric.cpp.
References MBMesquite::adj(), conn, MBMesquite::Sample::dimension, MBMesquite::ElemSampleQM::elem(), MBMesquite::PatchData::element_by_index(), evaluate(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MSQ_SETERR, n, MBMesquite::PatchData::num_free_vertices(), MBMesquite::Sample::number, MBMesquite::ElemSampleQM::sample(), MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
    // this metric only supports sampling at corners
        if( type != TRIANGLE && type != TETRAHEDRON )
            MSQ_SETERR( err )
            return false;
        s.dimension = 0;
        s.number    = 0;
    unsigned n;
    indices.clear();
    if( conn[s.number] < pd.num_free_vertices() ) indices.push_back( conn[s.number] );
    for( unsigned i = 0; i < n; ++i )
        if( conn[adj[i]] < pd.num_free_vertices() ) indices.push_back( conn[adj[i]] );
    return evaluate( pd, p_handle, value, err );
void MBMesquite::AffineMapMetric::get_element_evaluations ( PatchData pd,
size_t  elem_index,
std::vector< size_t > &  handles,
MsqError err
) [virtual]
Similar to QualityMetric::get_evaluations, this method returns a list of handles corresponding to sample points at which the metric may be evaluated. While QualityMetric::get_evaluations returns sample points for all elements in a PatchData, this method returns only the subset corresponding to a single element.
Implements MBMesquite::ElemSampleQM.
Definition at line 84 of file AffineMapMetric.cpp.
References MBMesquite::get_elem_sample_points().
    get_elem_sample_points( pd, p_elem, handles, err );
void MBMesquite::AffineMapMetric::get_evaluations ( PatchData pd,
MsqError err
) [virtual]
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
Parameters:
pdThe patch
handlesOutput list of handles
free_vertices_onlyIf true, only pass back evaluation points that depend on at least one free vertex.
Definition at line 79 of file AffineMapMetric.cpp.
References MBMesquite::get_sample_pt_evaluations().
    get_sample_pt_evaluations( pd, handles, free, err );
std::string MBMesquite::AffineMapMetric::get_name ( ) const [virtual]
Definition at line 74 of file AffineMapMetric.cpp.
References MBMesquite::TMetric::get_name(), and targetMetric.
    return std::string( "AffineMap(" ) + targetMetric->get_name() + ')';
Definition at line 69 of file AffineMapMetric.cpp.
    return 1;
Definition at line 92 of file AffineMapMetric.hpp.
References targetCalc.
        return targetCalc;
Definition at line 101 of file AffineMapMetric.hpp.
References targetMetric.
        return targetMetric;
Definition at line 96 of file AffineMapMetric.hpp.
References weightCalc.
        return weightCalc;
Definition at line 84 of file AffineMapMetric.hpp.
        targetCalc = tc;
Definition at line 105 of file AffineMapMetric.hpp.
        targetMetric = m;
Definition at line 88 of file AffineMapMetric.hpp.
Referenced by run_test().
        weightCalc = wc;
Member Data Documentation
List of all members.
