MBMesquite::ElementMaxQM Class Reference
#include <ElementMaxQM.hpp>
+ Inheritance diagram for MBMesquite::ElementMaxQM:
+ Collaboration diagram for MBMesquite::ElementMaxQM:
Public Member Functions
MESQUITE_EXPORT ElementMaxQM (ElemSampleQM *metric)
virtual MESQUITE_EXPORT ~ElementMaxQM ()
MESQUITE_EXPORT ElemSampleQMget_quality_metric () const
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
Private Attributes
ElemSampleQMmMetric
std::vector< size_t > mHandles
Detailed Description
Definition at line 43 of file ElementMaxQM.hpp.
Definition at line 42 of file ElementMaxQM.cpp.
: mMetric( metric ) {}
Definition at line 44 of file ElementMaxQM.cpp.
Member Function Documentation
bool MBMesquite::ElementMaxQM::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 59 of file ElementMaxQM.cpp.
References MBMesquite::QualityMetric::evaluate(), MBMesquite::ElemSampleQM::get_element_evaluations(), get_quality_metric(), mHandles, and MSQ_ERRFALSE.
    ElemSampleQM* qm = get_quality_metric();
    mHandles.clear();
    qm->get_element_evaluations( pd, handle, mHandles, err );
    MSQ_ERRFALSE( err );
    bool valid = true;
    double tmpval;
    bool tmpvalid;
    value = -1.e+100;  // initialize max computation
    for( std::vector< size_t >::iterator h = mHandles.begin(); h != mHandles.end(); ++h )
        tmpvalid = qm->evaluate( pd, *h, tmpval, err );  // MSQ_ERRZERO(err);
        if( !tmpvalid )
            value = +1.e+100;
            return false;  // if any handle within the element makes tmpvalid false, then valid is
                           // false, no matter what the other handles say
        else if( tmpval > value )
            value = tmpval;
    return valid;
std::string MBMesquite::ElementMaxQM::get_name ( ) const [virtual]
Definition at line 46 of file ElementMaxQM.cpp.
References MBMesquite::QualityMetric::get_name(), and mMetric.
    std::string result( "ElementMaxQM(" );
    result += mMetric->get_name();
    result += ")";
    return result;
Definition at line 54 of file ElementMaxQM.cpp.
References MBMesquite::QualityMetric::get_negate_flag(), and get_quality_metric().
Member Data Documentation
std::vector< size_t > MBMesquite::ElementMaxQM::mHandles [mutable, private]
Definition at line 63 of file ElementMaxQM.hpp.
Referenced by evaluate().
Definition at line 62 of file ElementMaxQM.hpp.
Referenced by get_name(), and get_quality_metric().
List of all members.
