MBMesquite::LambdaTarget Class Reference
Scale a target matrix by the size of another. More...
#include <LambdaTarget.hpp>
+ Inheritance diagram for MBMesquite::LambdaTarget:
+ Collaboration diagram for MBMesquite::LambdaTarget:
Public Member Functions
 LambdaTarget (TargetCalculator *lambda_source, TargetCalculator *composite_source)
 ~LambdaTarget ()
bool get_3D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 3 > &W_out, MsqError &err)
 Get a target matrix.
bool get_2D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 2, 2 > &W_out, MsqError &err)
bool get_surface_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 2 > &W_out, MsqError &err)
bool have_surface_orient () const
 Use 3x2 W for surface elements if true, 2x2 W if false.
Private Attributes
TargetCalculatorlambdaSource
TargetCalculatorcompositeSource
Detailed Description
Combine two target matrices by extracting a scalar representation of the size (lambda) of one and use that value to scale the other. The expected use of this target calculator is to preserve the size of a reference mesh while targeting ideal elements for shape.
Definition at line 48 of file LambdaTarget.hpp.
MBMesquite::LambdaTarget::LambdaTarget ( TargetCalculator lambda_source,
TargetCalculator composite_source
Parameters:
lambda_sourceTarget calculator from which to extract scaling factor (lambda).
composite_sourceTarget calcualtor from which to obtain a target that will be scaled by lambda.
Definition at line 40 of file LambdaTarget.cpp.
    : lambdaSource( lambda_source ), compositeSource( composite_source )
Definition at line 45 of file LambdaTarget.cpp.
Member Function Documentation
bool MBMesquite::LambdaTarget::get_2D_target ( PatchData pd,
size_t  element,
Sample  sample,
MsqMatrix< 2, 2 > &  W_out,
MsqError err
) [virtual]
Parameters:
pdThe current PatchData
elementThe index an element within the patch data.
sampleThe sample point in the element.
W_outThe resulting target matrix.
Implements MBMesquite::TargetCalculator.
Definition at line 67 of file LambdaTarget.cpp.
References compositeSource, MBMesquite::det(), MBMesquite::TargetCalculator::get_2D_target(), lambdaSource, and MSQ_CHKERR.
    bool valid = lambdaSource->get_2D_target( pd, element, sample, W_out, err );
    if( MSQ_CHKERR( err ) && !valid ) return false;
    double det1 = det( W_out );
    valid = compositeSource->get_2D_target( pd, element, sample, W_out, err );
    double det2 = det( W_out );
    if( det2 < 1e-15 ) return false;
    W_out *= sqrt( det1 / det2 );
    return true;
bool MBMesquite::LambdaTarget::get_3D_target ( PatchData pd,
size_t  element,
Sample  sample,
MsqMatrix< 3, 3 > &  W_out,
MsqError err
) [virtual]
Parameters:
Definition at line 47 of file LambdaTarget.cpp.
References MBMesquite::cbrt(), compositeSource, MBMesquite::det(), MBMesquite::TargetCalculator::get_3D_target(), lambdaSource, and MSQ_CHKERR.
    bool valid = lambdaSource->get_3D_target( pd, element, sample, W_out, err );
    valid = compositeSource->get_3D_target( pd, element, sample, W_out, err );
    W_out *= MBMesquite::cbrt( fabs( det1 / det2 ) );
    return true;
bool MBMesquite::LambdaTarget::get_surface_target ( PatchData pd,
size_t  element,
Sample  sample,
MsqMatrix< 3, 2 > &  W_out,
MsqError err
) [virtual]
Parameters:
Definition at line 87 of file LambdaTarget.cpp.
References MBMesquite::MsqMatrix< R, C >::column(), compositeSource, moab::cross(), MBMesquite::TargetCalculator::get_surface_target(), lambdaSource, and MSQ_CHKERR.
    bool valid = lambdaSource->get_surface_target( pd, element, sample, W_out, err );
    MsqVector< 3 > cross = W_out.column( 0 ) * W_out.column( 1 );
    double det1          = cross % cross;  // length squared
    valid = compositeSource->get_surface_target( pd, element, sample, W_out, err );
    double det2 = cross % cross;  // length squared
    W_out *= sqrt( sqrt( det1 / det2 ) );
    return true;
bool MBMesquite::LambdaTarget::have_surface_orient ( ) const [inline, virtual]
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Definition at line 67 of file LambdaTarget.hpp.
References compositeSource, and MBMesquite::TargetCalculator::have_surface_orient().
Member Data Documentation
List of all members.
