MBMesquite::LineDomain Class Reference
#include <MeshDomain1D.hpp>
+ Inheritance diagram for MBMesquite::LineDomain:
+ Collaboration diagram for MBMesquite::LineDomain:
Public Member Functions
 LineDomain (const Vector3D &point, const Vector3D &dir)
 LineDomain (const MsqLine &line)
const MsqLinegeom () const
virtual void snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const
virtual void vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const
virtual void element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const
virtual void vertex_normal_at (const Mesh::VertexHandle *handles, Vector3D coordinates[], unsigned count, MsqError &err) const
 evaluate surface normals
virtual void closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const
 evaluate closest point and normal
virtual void domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t num_handles, MsqError &err) const
virtual double arc_length (const double position1[3], const double position2[3], MsqError &err)
 Measure arc length along curve.
virtual void position_from_length (const double from_here[3], double length, double result_point[3], MsqError &err)
 Get a position on the curve given an arc length.
Private Attributes
MsqLine mGeom
Detailed Description
Definition at line 78 of file MeshDomain1D.hpp.
MBMesquite::LineDomain::LineDomain ( const Vector3D point,
const Vector3D dir
) [inline]
Definition at line 84 of file MeshDomain1D.hpp.
: mGeom( point, dir ) {}
MBMesquite::LineDomain::LineDomain ( const MsqLine line) [inline]
Definition at line 86 of file MeshDomain1D.hpp.
: mGeom( line ) {}
Member Function Documentation
double MBMesquite::LineDomain::arc_length ( const double  position1[3],
MsqError err
) [virtual]
Get the length along a curve between two points on the curve.
Implements MBMesquite::CurveDomain.
Definition at line 124 of file MeshDomain1D.cpp.
References MBMesquite::MsqLine::closest(), and mGeom.
Referenced by MBMesquite::LineDomainTest::test_arc_length().
    double p1 = mGeom.closest( position1 );
    double p2 = mGeom.closest( position2 );
    return p2 - p1;
void MBMesquite::LineDomain::closest_point ( Mesh::VertexHandle  handle,
const Vector3D position,
Vector3D closest,
Vector3D normal,
MsqError err
) const [virtual]
Given a position in space, return the closest position in the domain and the domain normal at that point.
Parameters:
entity_handleEvaluate the subset of the domain contianing this entity
positionInput position for which to evaluate
closestClosest position in the domain.
normalDomain normal at the location of 'closest'
Implements MBMesquite::MeshDomain.
Definition at line 108 of file MeshDomain1D.cpp.
References MBMesquite::MsqLine::direction(), geom(), INTERNAL_ERROR, MSQ_SETERR, and MBMesquite::MsqLine::point().
    closest = geom().point( geom().closest( position ) );
    normal  = geom().direction();
    MSQ_SETERR( err )( "Cannot get normal for LineDomain", MsqError::INTERNAL_ERROR );
void MBMesquite::LineDomain::domain_DoF ( const Mesh::VertexHandle handle_array,
unsigned short *  dof_array,
size_t  num_handles,
MsqError err
) const [virtual]
Definition at line 119 of file MeshDomain1D.cpp.
    std::fill( dof_array, dof_array + num_handles, 1 );
void MBMesquite::LineDomain::element_normal_at ( Mesh::ElementHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Definition at line 93 of file MeshDomain1D.cpp.
References geom.
    coordinate = geom().direction();
const MsqLine& MBMesquite::LineDomain::geom ( ) const [inline]
Definition at line 88 of file MeshDomain1D.hpp.
Referenced by closest_point(), snap_to(), and vertex_normal_at().
        return mGeom;
void MBMesquite::LineDomain::position_from_length ( const double  from_here[3],
double  length,
MsqError err
) [virtual]
Measure a specified arc length along a curve.
Parameters:
from_herePoint on curve from which to measure
lengthLength along curve to move
result_pointOutput. A point on the curve length units from the point from_here in the forward direction along the curve.
Definition at line 131 of file MeshDomain1D.cpp.
References MBMesquite::MsqLine::closest(), MBMesquite::Vector3D::get_coordinates(), mGeom, and MBMesquite::MsqLine::point().
Referenced by MBMesquite::LineDomainTest::test_position_from_length().
    const double param = mGeom.closest( from_here );
    mGeom.point( param + length ).get_coordinates( result_point );
void MBMesquite::LineDomain::snap_to ( Mesh::VertexHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 82 of file MeshDomain1D.cpp.
References geom(), and MBMesquite::MsqLine::point().
Referenced by MBMesquite::LineDomainTest::test_snap_to().
    coordinate = geom().point( geom().closest( coordinate ) );
void MBMesquite::LineDomain::vertex_normal_at ( Mesh::VertexHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 87 of file MeshDomain1D.cpp.
References geom.
void MBMesquite::LineDomain::vertex_normal_at ( const Mesh::VertexHandle handles,
unsigned  count,
MsqError err
) const [virtual]
Returns normals for a domain.
Parameters:
handlesThe domain evaluated is the one in which this mesh entity is constrained.
coordinatesAs input, a list of positions at which to evaluate the domain. As output, the resulting domain normals.
countThe length of the coordinates array.
Definition at line 99 of file MeshDomain1D.cpp.
References geom(), INTERNAL_ERROR, and MSQ_SETERR.
    std::fill( coordinates, coordinates + count, geom().direction() );
Member Data Documentation
Definition at line 81 of file MeshDomain1D.hpp.
Referenced by arc_length(), and position_from_length().
List of all members.
