MBMesquite::MsqError Class Reference
Used to hold the error state and return it to the application. More...
#include <MsqError.hpp>
+ Inheritance diagram for MBMesquite::MsqError:
+ Collaboration diagram for MBMesquite::MsqError:
Classes
class  Setter
class  Trace
 One line of stack trace data. More...
Public Types
enum  ErrorCode {
  NO_ERROR = 0, UNKNOWN_ERROR, OUT_OF_MEMORY, INVALID_ARG,
  NOT_INITIALIZED, INVALID_STATE, FILE_ACCESS, FILE_FORMAT,
  PARSE_ERROR, IO_ERROR, INVALID_MESH, NO_PD_STORAGE_MODE,
  NOT_IMPLEMENTED, INTERNAL_ERROR, INTERRUPTED, TAG_ALREADY_EXISTS,
  TAG_NOT_FOUND, UNSUPPORTED_ELEMENT, PARALLEL_ERROR, BARRIER_VIOLATED,
  LAST_ERROR_CODE
 Error codes. More...
typedef std::list< TraceStackTrace
Public Member Functions
MESQUITE_EXPORT void clear ()
 resets error object to non-active state (no error).
bool error () const
 Check if an error has occured.
 operator bool () const
MESQUITE_EXPORT MsqError ()
 Initialize to cleared state.
virtual MESQUITE_EXPORT ~MsqError ()
 Destructor - empty but must declar virtual destrucor if virtual functions.
ErrorCode error_code () const
 Get error code.
MESQUITE_EXPORT const char * error_message () const
 Get error message.
const StackTracestack () const
 Get stack trace.
virtual MESQUITE_EXPORT bool push (const char *function, const char *file, int line)
virtual MESQUITE_EXPORT bool set_error (ErrorCode num, const char *msg=0)
 Initialize the error object with the passed data.
Static Public Member Functions
static Setter setter (MsqError &err, const char *function, const char *file, int line)
Private Attributes
ErrorCode errorCode
std::string errorMessage
StackTrace stackTrace
Detailed Description
Author:
Jason Kraftcheck
Date:
2004-09-17
Used to hold error state and related information. Internal Mesquite code should access this object via the MSQ_SETERR() and MSQ_CHKERR() macros.
For applications, the cast-to-bool operator and << operator are provided for convenient, if simple access to this data. E.g.: if (err) cout << err << endl;
There are two options for an application to gain more detailed access to the error data. The application may either access the data stored in this class via the provided methods or subclass MsqError, overriding set_error() and push() to handle the error data as it is generated.
Definition at line 101 of file MsqError.hpp.
Member Typedef Documentation
Container type used to store stack trace. Return type for stack()
Definition at line 181 of file MsqError.hpp.
Member Enumeration Documentation
Error codes.
Enumerator:
NO_ERROR
no error
UNKNOWN_ERROR
unknown error occured
OUT_OF_MEMORY
unable to allocate the necessary memory
INVALID_ARG
invalid function argument passed
NOT_INITIALIZED
object not initialized
INVALID_STATE
object is in an invalid state
FILE_ACCESS
File cannot be opened/created.
FILE_FORMAT
Wrong file type
PARSE_ERROR
Error parsing input (or input file)
IO_ERROR
An I/O error occured (e.g. read from file failed.)
INVALID_MESH
The mesh is invalid
NO_PD_STORAGE_MODE
no storage mode chosen within PatchData
NOT_IMPLEMENTED
requested functionality is not (yet) implemented
INTERNAL_ERROR
A bug in Mesquite
INTERRUPTED
Application or user interrupted operation
TAG_ALREADY_EXISTS
Attempt to create tag that already exists
TAG_NOT_FOUND
Specified tag does not exist
UNSUPPORTED_ELEMENT
the element type is not supported.
PARALLEL_ERROR
an error occurred in parallel >
BARRIER_VIOLATED
barruer violated when processing barrier Target Metric
LAST_ERROR_CODE
Definition at line 110 of file MsqError.hpp.
        NO_ERROR = 0,        /**< no error */
        UNKNOWN_ERROR,       /**< unknown error occured */
        OUT_OF_MEMORY,       /**< unable to allocate the necessary memory */
        INVALID_ARG,         /**< invalid function argument passed */
        NOT_INITIALIZED,     /**< object not initialized */
        INVALID_STATE,       /**< object is in an invalid state */
        FILE_ACCESS,         /**< File cannot be opened/created. */
        FILE_FORMAT,         /**< Wrong file type */
        PARSE_ERROR,         /**< Error parsing input (or input file) */
        IO_ERROR,            /**< An I/O error occured (e.g. read from file failed.) */
        INVALID_MESH,        /**< The mesh is invalid */
        NO_PD_STORAGE_MODE,  /**< no storage mode chosen within PatchData */
        NOT_IMPLEMENTED,     /**< requested functionality is not (yet) implemented */
        INTERNAL_ERROR,      /**< A bug in Mesquite */
        INTERRUPTED,         /**< Application or user interrupted operation */
        TAG_ALREADY_EXISTS,  /**< Attempt to create tag that already exists */
        TAG_NOT_FOUND,       /**< Specified tag does not exist */
        UNSUPPORTED_ELEMENT, /**< the element type is not supported. */
        PARALLEL_ERROR,      /**< an error occurred in parallel > */
        BARRIER_VIOLATED,    /**< barruer violated when processing barrier Target Metric */
        LAST_ERROR_CODE
Definition at line 150 of file MsqError.hpp.
Definition at line 81 of file MsqError.cpp.
Member Function Documentation
Definition at line 145 of file MsqError.cpp.
References errorCode, errorMessage, NO_ERROR, and stackTrace.
Referenced by FileTokenizerTest::boolean_test(), MBMesquite::DomainClassifier::classify_by_tag(), MBMesquite::MeshImplTags::create(), LinearMappingFunctionTest::do_coeff_test(), LinearMappingFunctionTest::do_deriv_test(), FileTokenizerTest::double_test(), MBMesquite::NonGradient::evaluate(), MBMesquite::ObjectiveFunction::evaluate_with_gradient(), MBMesquite::PlanarDomain::fit_vertices(), MBMesquite::geom_classify_vertices(), MBMesquite::ConjugateGradient::get_step(), MBMesquite::QualityAssessor::get_tag(), MBMesquite::TargetWriter::get_tag_handle(), MBMesquite::TagVertexMesh::initialize(), FileTokenizerTest::long_test(), MBMesquite::QualityAssessor::loop_over_mesh_internal(), main(), FileTokenizerTest::match_multiple_test(), FileTokenizerTest::match_one_test(), FileTokenizerTest::newline_test(), MBMesquite::QuasiNewton::optimize_vertex_positions(), MBMesquite::TrustRegion::optimize_vertex_positions(), MBMesquite::SteepestDescent::optimize_vertex_positions(), MBMesquite::FeasibleNewton::optimize_vertex_positions(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::TerminationCriterion::reset_inner(), XYRectangleTest::setUp(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), MBMesquite::MeshImpl::tag_to_bool(), MeshInterfaceTest::tearDown(), InstructionQueueTest::test_add_preconditioner(), InstructionQueueTest::test_add_quality_assessor(), InstructionQueueTest::test_add_remove_vertex_slaver(), PatchSetTest::test_bad_handle(), ObjectiveFunctionTests::test_clone(), LinearMappingFunctionTest::test_coeff_fail(), ArrayMeshTest::test_delete_tag(), LinearMappingFunctionTest::test_deriv_fail(), PatchSetTest::test_fail_entities(), PatchSetTest::test_fail_handles(), SlaveBoundaryVerticesTest::test_fail_if_slaves_not_calculated(), InstructionQueueTest::test_insert_preconditioner(), InstructionQueueTest::test_insert_quality_assessor(), InstructionQueueTest::test_remove_preconditioner(), InstructionQueueTest::test_remove_quality_assessor(), ArrayMeshTest::test_tag_data(), iMeshTest::testDoubleTag(), iMeshTest::testIntTag(), FileTokenizerTest::token_test(), uwt(), MBMesquite::MeshImpl::vtk_read_dataset(), and MBMesquite::MeshImpl::write_vtk().
    errorCode = NO_ERROR;
    // MS VC6 doesn't have string::clear()!
    errorMessage.resize( 0 );
    stackTrace.clear();
bool MBMesquite::MsqError::error ( ) const [inline]
Definition at line 139 of file MsqError.hpp.
References errorCode, and NO_ERROR.
Referenced by MBMesquite::MsqPrintError::~MsqPrintError().
        return NO_ERROR != errorCode;
const char * MBMesquite::MsqError::error_message ( ) const
Get error message.
Definition at line 45 of file MsqError.cpp.
References errorCode, errorMessage, and LAST_ERROR_CODE.
Referenced by MBMesquite::VertexMover::loop_over_mesh(), and MBMesquite::operator<<().
    static const char* const error_messages[] = { "No Error",
                                                  "<unknown>",
                                                  "Out of memory",
                                                  "Invalid argument",
                                                  "Data not initialized",
                                                  "Invalid state",
                                                  "File access error",
                                                  "File format error",
                                                  "Syntax error",
                                                  "I/O error",
                                                  "Invalid mesh",
                                                  "No storage mode for PatchData",
                                                  "Not implemented",
                                                  "Internal error",
                                                  "Interrupted",
                                                  "Duplicate tag name",
                                                  "Tag not found",
                                                  "Unsupported element type",
                                                  "Parallel Error - error occurred on at least one processor",
                                                  "barruer violated when processing barrier Target Metric",
                                                  "Invalid Error Code" };
    /* If this is ever false, it should be caught by a unit test.
       Do an assert here so the unit test fails.
       This asserts that all error codes have a string in the above list. */
    assert( sizeof( error_messages ) == sizeof( char* ) * ( LAST_ERROR_CODE + 1 ) );
    if( !errorMessage.empty() ) return errorMessage.c_str();
    if( errorCode >= 0 && errorCode < LAST_ERROR_CODE ) return error_messages[errorCode];
    return error_messages[LAST_ERROR_CODE];
MBMesquite::MsqError::operator bool ( ) const [inline]
Definition at line 144 of file MsqError.hpp.
bool MBMesquite::MsqError::push ( const char *  function,
const char *  file,
int  line
) [virtual]
Add to back-trace of call stack. Called by MSQ_CHKERR. Must always return true.
Definition at line 125 of file MsqError.cpp.
References stackTrace.
Referenced by MBMesquite::MsqError::Setter::set().
    stackTrace.push_back( Trace( function, file, line ) );
    return true;
static Setter MBMesquite::MsqError::setter ( MsqError err,
const char *  file,
int  line
) [inline, static]
Definition at line 226 of file MsqError.hpp.
        return Setter( err, function, file, line );
const StackTrace& MBMesquite::MsqError::stack ( ) const [inline]
Get stack trace.
Definition at line 184 of file MsqError.hpp.
Referenced by MBMesquite::operator<<().
        return stackTrace;
Member Data Documentation
std::string MBMesquite::MsqError::errorMessage [private]
Definition at line 233 of file MsqError.hpp.
Referenced by clear(), error_message(), and set_error().
Definition at line 234 of file MsqError.hpp.
Referenced by clear(), push(), set_error(), and stack().
List of all members.
