MBMesquite::MsqLine Class Reference
Line in R^3. More...
#include <MsqGeomPrim.hpp>
+ Collaboration diagram for MBMesquite::MsqLine:
Public Member Functions
 MsqLine (const Vector3D &p_point, const Vector3D &p_dir)
 MsqLine ()
const Vector3Dpoint () const
const Vector3Ddirection () const
Vector3D point (double param) const
 Get point given parameter (mPoint + param * mDirection)
double closest (const Vector3D &from_point) const
 Get parameter value for location on line closest to input point.
double distance (const Vector3D &from_point) const
bool intersect (const MsqLine &other, double &param, double epsilon) const
bool closest (const MsqLine &other, double &param) const
 Find parameter of closest position on this line to another line.
Static Public Member Functions
static MsqLine two_point (const Vector3D &p1, const Vector3D &p2)
Private Attributes
Vector3D mPoint
Vector3D mDirection
Detailed Description
Line in R^3.
Definition at line 42 of file MsqGeomPrim.hpp.
MBMesquite::MsqLine::MsqLine ( const Vector3D p_point,
const Vector3D p_dir
) [inline]
Definition at line 49 of file MsqGeomPrim.hpp.
                                                              : mPoint( p_point ), mDirection( p_dir / p_dir.length() )
Definition at line 53 of file MsqGeomPrim.hpp.
: mPoint( 0, 0, 0 ), mDirection( 0, 0, 0 ) {}
Member Function Documentation
double MBMesquite::MsqLine::closest ( const Vector3D from_point) const [inline]
bool MBMesquite::MsqLine::closest ( const MsqLine other,
double &  param
) const
Definition at line 46 of file MsqGeomPrim.cpp.
References direction(), moab::dot(), N, and point().
    const Vector3D N = other.direction() * ( direction() * other.direction() );
    const double D   = -( N % other.point() );
    const double dot = N % direction();
    if( dot < DBL_EPSILON ) return false;  // parallel
    param = -( N % point() + D ) / dot;
    return true;
double MBMesquite::MsqLine::distance ( const Vector3D from_point) const [inline]
Definition at line 81 of file MsqGeomPrim.hpp.
        return ( point( closest( from_point ) ) - from_point ).length();
bool MBMesquite::MsqLine::intersect ( const MsqLine other,
double &  param,
double  epsilon
) const
Find intersection between two lines
Returns:
false if no point intersection (skew, parallel, coincident, etc.)
Definition at line 38 of file MsqGeomPrim.cpp.
References closest(), epsilon, MBMesquite::Vector3D::length_squared(), and point().
Referenced by GeomPrimTest::test_line_intersect().
    if( !closest( other, param ) ) return false;
    Vector3D p1 = point( param );
    Vector3D p2 = other.point( other.closest( p1 ) );
    return ( p1 - p2 ).length_squared() < epsilon * epsilon;
Vector3D MBMesquite::MsqLine::point ( double  param) const [inline]
Definition at line 70 of file MsqGeomPrim.hpp.
        return point() + param * direction();
static MsqLine MBMesquite::MsqLine::two_point ( const Vector3D p1,
const Vector3D p2
) [inline, static]
Definition at line 55 of file MsqGeomPrim.hpp.
Referenced by GeomPrimTest::test_line_basic().
        return MsqLine( p1, p2 - p1 );
Member Data Documentation
Definition at line 46 of file MsqGeomPrim.hpp.
Definition at line 45 of file MsqGeomPrim.hpp.
List of all members.
