MBMesquite::MsqSphere Class Reference
Sphere. More...
#include <MsqGeomPrim.hpp>
+ Collaboration diagram for MBMesquite::MsqSphere:
Public Member Functions
 MsqSphere (const Vector3D &p_center, double p_radius)
const Vector3Dcenter () const
double radius () const
Vector3D closest (const Vector3D &point) const
bool closest (const Vector3D &point, Vector3D &point_on_sphere, Vector3D &normal_at_point) const
double distance (const Vector3D &point) const
bool intersect (const MsqPlane &plane, MsqCircle &result) const
bool intersect (const MsqSphere &sphere, MsqCircle &result) const
Private Attributes
Vector3D mCenter
double mRadius
Detailed Description
Sphere.
Definition at line 197 of file MsqGeomPrim.hpp.
MBMesquite::MsqSphere::MsqSphere ( const Vector3D p_center,
double  p_radius
) [inline]
Definition at line 204 of file MsqGeomPrim.hpp.
: mCenter( p_center ), mRadius( p_radius ) {}
Member Function Documentation
Get location on sphere closest to input location. Returns arbitrary point if input location is at center.
Definition at line 158 of file MsqGeomPrim.cpp.
References center(), MBMesquite::Vector3D::length(), and radius().
Referenced by GeomPrimTest::test_sphere_closest_to_point().
    Vector3D diff = point - center();
    double len    = diff.length();
    if( len < DBL_EPSILON )
        // pick any point
        diff = Vector3D( 1, 0, 0 );
        len  = 1;
    return center() + diff * radius() / len;
bool MBMesquite::MsqSphere::closest ( const Vector3D point,
Vector3D point_on_sphere,
Vector3D normal_at_point
) const
Get location on sphere closest to input location, and normal at closest point.
Returns:
false if input point is at center, true otherwise.
Definition at line 172 of file MsqGeomPrim.cpp.
    normal_at_point = point - center();
    double len      = normal_at_point.length();
    if( len < DBL_EPSILON ) return false;
    normal_at_point /= len;
    point_on_sphere = center() + radius() * normal_at_point;
    return true;
double MBMesquite::MsqSphere::distance ( const Vector3D point) const [inline]
Definition at line 224 of file MsqGeomPrim.hpp.
References center(), MBMesquite::length(), and radius.
Referenced by GeomPrimTest::test_sphere_intersect_sphere().
        return fabs( ( center() - point ).length() - radius() );
bool MBMesquite::MsqSphere::intersect ( const MsqPlane plane,
MsqCircle result
) const
Intersect plane with sphere
Returns:
true if intersection exists, false otherwise.
Definition at line 183 of file MsqGeomPrim.cpp.
References center(), MBMesquite::MsqPlane::closest(), MBMesquite::Vector3D::length_squared(), MBMesquite::MsqPlane::normal(), and radius().
Referenced by GeomPrimTest::test_sphere_intersect_plane(), and GeomPrimTest::test_sphere_intersect_sphere().
    const Vector3D plane_pt  = plane.closest( center() );
    const Vector3D plane_dir = plane_pt - center();
    const double dir_sqr     = plane_dir.length_squared();
    if( dir_sqr < DBL_EPSILON )
    {  // plane passes through center of sphere
        result = MsqCircle( center(), plane.normal(), radius() );
        return true;
    double rad_sqr = radius() * radius() - plane_dir.length_squared();
    if( rad_sqr < 0 )  // no intersection
        return false;
    result = MsqCircle( plane_pt, plane_dir, sqrt( rad_sqr ) );
    return true;
bool MBMesquite::MsqSphere::intersect ( const MsqSphere sphere,
MsqCircle result
) const
Intersect spheres
Returns:
Definition at line 202 of file MsqGeomPrim.cpp.
References center(), dist(), MBMesquite::Vector3D::length(), and radius().
    const Vector3D d  = sphere.center() - center();
    const double dist = d.length();
    if( dist > ( radius() + sphere.radius() ) ) return false;
    const double r1_sqr = radius() * radius();
    const double r2_sqr = sphere.radius() * sphere.radius();
    const double f      = ( d % d + r1_sqr - r2_sqr ) / 2;
    // const double d1 = f / dist;
    const double rad = sqrt( r1_sqr - f * f / ( d % d ) );
    Vector3D c       = center() + d * f / ( d % d );
    result           = MsqCircle( c, d, rad );
    return true;
Member Data Documentation
Definition at line 200 of file MsqGeomPrim.hpp.
Definition at line 201 of file MsqGeomPrim.hpp.
List of all members.
