MBMesquite::ParallelHelperImpl Class Reference
#include <ParallelHelper.hpp>
+ Inheritance diagram for MBMesquite::ParallelHelperImpl:
+ Collaboration diagram for MBMesquite::ParallelHelperImpl:
Public Types
enum  CommunicationModel {
  TrulyNonBlocking = 0, TrulyNonBlockingAvoidAllReduce, NonBlocking, NonBlockingAvoidAllReduce,
  Blocking, BlockingAvoidAllReduce
Public Member Functions
 ParallelHelperImpl ()
 ~ParallelHelperImpl ()
void set_parallel_mesh (ParallelMesh *mesh)
void set_communicator (size_t comm)
void set_communicator (const void *comm)
void set_communication_model (int model, MsqError &err)
void set_generate_random_numbers (int grn, MsqError &err)
Protected Member Functions
void smoothing_init (MsqError &err)
void compute_first_independent_set (std::vector< Mesh::VertexHandle > &fixed_vertices)
void communicate_first_independent_set (MsqError &err)
bool compute_next_independent_set ()
bool get_next_partition_boundary_vertex (MBMesquite::Mesh::VertexHandle &vertex_handle)
void communicate_next_independent_set (MsqError &err)
void smoothing_close (MsqError &err)
int get_rank () const
int get_nprocs () const
bool is_our_element (Mesh::ElementHandle element_handle, MsqError &err) const
bool is_our_vertex (Mesh::VertexHandle vertex_handle, MsqError &err) const
void communicate_min_max_to_all (double *minimum, double *maximum, MsqError &) const
void communicate_min_max_to_zero (double *minimum, double *maximum, MsqError &) const
void communicate_sums_to_zero (size_t *freeElementCount, int *invertedElementCount, size_t *elementCount, int *invertedSampleCount, size_t *sampleCount, long unsigned int *count, long unsigned int *invalid, double *sum, double *sqrSum, MsqError &) const
void communicate_power_sum_to_zero (double *pMean, MsqError &) const
void communicate_histogram_to_zero (std::vector< int > &histogram, MsqError &) const
void communicate_any_true (bool &value, MsqError &err) const
 if any proc has a true input
void communicate_all_true (bool &value, MsqError &err) const
Private Member Functions
void compute_independent_set ()
int comm_smoothed_vtx_b (MsqError &err)
int comm_smoothed_vtx_b_no_all (MsqError &err)
int comm_smoothed_vtx_nb (MsqError &err)
int comm_smoothed_vtx_nb_no_all (MsqError &err)
int comm_smoothed_vtx_tnb (MsqError &err)
int comm_smoothed_vtx_tnb_no_all (MsqError &err)
Private Attributes
ParallelMeshmesh
size_t communicator
int communication_model
int rank
int nprocs
int generate_random_numbers
std::vector
< MBMesquite::Mesh::VertexHandle
vertices
int num_vertex
std::vector< char > vtx_in_partition_boundary
int num_vtx_partition_boundary
int num_vtx_partition_boundary_local
int num_vtx_partition_boundary_remote
std::vector
part_vertices
std::vector< int > part_proc_owner
std::vector< size_t > part_gid
std::vector< int > part_smoothed_flag
std::vector< double > part_rand_number
int num_exportVtx
std::vector< size_t > exportVtxGIDs
std::vector< int > exportVtxLIDs
std::vector< int > exportProc
std::vector< bool > in_independent_set
VertexIdMap vid_map
int total_num_vertices_to_smooth
int total_num_vertices_to_recv
std::vector< int > neighbourProcSend
std::vector< int > neighbourProcRecv
std::vector< int > neighbourProcSendRemain
std::vector< int > neighbourProcRecvRemain
int num_already_smoothed_vertices
int num_already_recv_vertices
std::vector< std::vector< int > > vtx_off_proc_list
int iteration
int global_work_remains
int next_vtx_partition_boundary
int unghost_num_vtx
std::vector
unghost_vertices
int unghost_num_procs
std::vector< int > unghost_procs
std::vector< int > unghost_procs_num_vtx
std::vector< int > unghost_procs_offset
int update_num_vtx
std::vector< size_t > update_gid
int update_num_procs
std::vector< int > update_procs
std::vector< int > update_procs_num_vtx
std::vector< int > update_procs_offset
Friends
class VertexMover
class QualityAssessor
Detailed Description
Definition at line 69 of file ParallelHelper.hpp.
Member Enumeration Documentation
Enumerator:
TrulyNonBlocking
NonBlocking
Blocking
Definition at line 72 of file ParallelHelper.hpp.
Member Function Documentation
Definition at line 2286 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI_RZERO, communicator, exportProc, exportVtxGIDs, exportVtxLIDs, iteration, mesh, MSQ_ERRZERO, neighbourProc, num_exportVtx, part_smoothed_flag, part_vertices, rank, MBMesquite::Vector3D::set(), VERTEX_BLOCK, VERTEX_HEADER, MBMesquite::vertex_map_find(), MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), vid_map, MBMesquite::Vector3D::y(), z, and MBMesquite::Vector3D::z().
Referenced by communicate_first_independent_set(), and communicate_next_independent_set().
    int i, j, rval;
    // printf("[%d] %d %d blocking\n",rank, iteration, pass);fflush(NULL);
    /* how many vertices per processor */
    std::vector< int > numVtxPerProc( neighbourProc.size(), 0 );
    for( i = 0; i < num_exportVtx; i++ )
        for( j = 0; j < (long)neighbourProc.size(); j++ )
            if( exportProc[i] == neighbourProc[j] )
                /* increment count */
                numVtxPerProc[j]++;
                /* end loop */
                break;
            /* assert loop did not end without finding the processor */
            assert( j != (long)neighbourProc.size() );
    /* place vertices going to the same processor into consecutive memory space */
    std::vector< VertexPack > vertex_pack( num_exportVtx + 10 ); /* add 10 to have enough memory */
    std::vector< VertexPack* > packed_vertices( neighbourProc.size() );
    VertexPack* packing_vertex;
    packed_vertices[0] = ARRPTR( vertex_pack );
    for( i = 1; i < (long)neighbourProc.size(); i++ )
        packed_vertices[i] = packed_vertices[i - 1] + numVtxPerProc[i - 1];
    std::vector< int > numVtxPackedPerProc( neighbourProc.size(), 0 );
                packing_vertex = packed_vertices[j] + numVtxPackedPerProc[j];
                numVtxPackedPerProc[j]++;
                MBMesquite::MsqVertex coordinates;
                mesh->vertices_get_coordinates( &part_vertices[exportVtxLIDs[i]], &coordinates, 1, err );
                MSQ_ERRZERO( err );
                packing_vertex->x       = coordinates[0];
                packing_vertex->y       = coordinates[1];
                packing_vertex->z       = coordinates[2];
                packing_vertex->glob_id = exportVtxGIDs[i];
    // delete [] numVtxPackedPerProc;
    /* send each block so the corresponding processor preceeded by the number of vertices */
        //    printf("[%d]i%dp%d Announcing %d vertices to proc
        //    %d\n",rank,iteration,pass,numVtxPerProc[j],neighbourProc[j]); fflush(NULL);
        rval = MPI_Send( &( numVtxPerProc[j] ), 1, MPI_INT, neighbourProc[j], VERTEX_HEADER + iteration,
                         (MPI_Comm)communicator );
        CHECK_MPI_RZERO( rval, err );
        // printf("[%d]i%dp%d Sending %d vertices to proc
        /* is there any vertex data to be sent */
        if( numVtxPerProc[j] )
            rval = MPI_Send( packed_vertices[j], 4 * numVtxPerProc[j], MPI_DOUBLE, neighbourProc[j],
                             VERTEX_BLOCK + iteration, (MPI_Comm)communicator );
            // printf("[%d]i%dp%d Sent %d vertices to proc
    int num;
    int proc;
    // int tag;
    int count;
    int numVtxImport = 0;
    MPI_Status status;
    int local_id;
    //  printf("[%d]i%dp%d Waiting to receive vertices from %d processors ...
    //  \n",rank,iteration,pass,neighbourProc.size()); fflush(NULL);
    /* receiving blocks from other processors */
        rval = MPI_Recv( &num,                      /* message buffer */
                         1,                         /* one data item */
                         MPI_INT,                   /* of type int */
                         MPI_ANY_SOURCE,            /* receive from any sender */
                         VERTEX_HEADER + iteration, /* receive only VERTEX HEADERs */
                         (MPI_Comm)communicator,    /* default communicator */
                         &status );                 /* info about the received message */
        proc = status.MPI_SOURCE;
        // tag = status.MPI_TAG;
        MPI_Get_count( &status, MPI_INT, &count );
        //    printf("[%d]i%dp%d Receiving %d vertices from proc
        //    %d/%d/%d\n",rank,iteration,pass,num,proc,tag,count); fflush(NULL);
        /* is there any vertex data to be received */
        if( num )
            numVtxImport += num;
            /* do we have enough space allocated */
            if( num_exportVtx + 10 < num )
                // if (vertex_pack) free(vertex_pack);
                num_exportVtx = num;
                vertex_pack.resize( num_exportVtx + 10 );
                // vertex_pack = (VertexPack*)malloc(sizeof(VertexPack)*(num_exportVtx+10));
            rval = MPI_Recv( ARRPTR( vertex_pack ),    /* message buffer */
                             4 * num,                  /* num data's item with 4 doubles each */
                             MPI_DOUBLE,               /* of type double */
                             proc,                     /* receive from this procesor only */
                             VERTEX_BLOCK + iteration, /* receive only VERTEX BLOCKs */
            MPI_Get_count( &status, MPI_DOUBLE, &count );
            if( count != 4 * num )
                printf( "[%d]i%d WARNING: expected %d vertices = %d bytes from proc %d but only "
                        "got %d bytes\n",
                        rank, iteration, num, num * 4, proc, count );
            fflush( NULL );
            //      printf("[%d]i%d Received %d vertices from proc
            //      %d/%d/%d\n",rank,iteration,num,proc,tag,count); fflush(NULL);
            /* update the received vertices in our boundary mesh */
            for( i = 0; i < num; i++ )
                /*  printf("[%d]i%d updating vertex %d with global_id
                 * %d\n",rank,iteration,i,(int)(vertex_pack[i].glob_id)); fflush(NULL); */
                local_id = vertex_map_find( vid_map, (int)( vertex_pack[i].glob_id ), proc );
                if( local_id )
                    MBMesquite::Vector3D coordinates;
                    coordinates.set( vertex_pack[i].x, vertex_pack[i].y, vertex_pack[i].z );
                    mesh->vertex_set_coordinates( part_vertices[local_id], coordinates, err );
                    MSQ_ERRZERO( err );
                    assert( part_smoothed_flag[local_id] == 0 );
                    part_smoothed_flag[local_id] = 1;
                    if( 0 )
                        printf( "[%d]i%d updating vertex with global_id %d to %g %g %g \n", rank, iteration,
                                (int)( vertex_pack[i].glob_id ), vertex_pack[i].x, vertex_pack[i].y, vertex_pack[i].z );
                else
                    printf( "[%d]i%d vertex with gid %lu and pid %d not in map\n", rank, iteration,
                            vertex_pack[i].glob_id, proc );
    return numVtxImport;
Definition at line 2471 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI_RZERO, communicator, exportProc, exportVtxGIDs, exportVtxLIDs, iteration, mesh, MSQ_ERRZERO, neighbourProc, neighbourProcRecvRemain, neighbourProcSendRemain, num_exportVtx, part_smoothed_flag, part_vertices, rank, MBMesquite::Vector3D::set(), VERTEX_BLOCK, VERTEX_HEADER, MBMesquite::vertex_map_find(), MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), vid_map, MBMesquite::Vector3D::y(), z, and MBMesquite::Vector3D::z().
    int i, j, rval;
    // printf("[%d] %d %d blocking avoid reduce all\n",rank, iteration, pass);fflush(NULL);
                numVtxPerProc[j]++;
                /* end loop */
                break;
                MSQ_ERRZERO( err );
        if( neighbourProcSendRemain[j] )
            assert( neighbourProcSendRemain[j] >= numVtxPerProc[j] );
            neighbourProcSendRemain[j] -= numVtxPerProc[j];
        else
            // printf("[%d]i%dp%d no longer sending to %d\n",rank,iteration,neighbourProc[j]);
            // fflush(NULL);
    int num;
    int proc;
    // int tag;
    int count;
    MPI_Status status;
    int local_id;
    /* receiving blocks in any order from other processors */
    int num_neighbourProcRecvRemain = 0;
        if( neighbourProcRecvRemain[j] )
            num_neighbourProcRecvRemain++;
    for( j = 0; j < num_neighbourProcRecvRemain; j++ )
        if( num )
                        "got %d bytes\n",
            fflush( NULL );
                if( local_id )
                    MSQ_ERRZERO( err );
                    if( 0 && rank == 1 )
                else
        for( i = 0; i < (long)neighbourProc.size(); i++ )
            if( proc == neighbourProc[i] )
                assert( neighbourProcRecvRemain[i] >= num );
                neighbourProcRecvRemain[i] -= num;
                break;
Definition at line 1797 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI_RZERO, communicator, exportProc, exportVtxGIDs, exportVtxLIDs, MBMesquite::VertexPack::glob_id, iteration, mesh, MSQ_ERRZERO, neighbourProc, neighbourProcRecv, num_exportVtx, part_smoothed_flag, part_vertices, rank, MBMesquite::Vector3D::set(), VERTEX_BLOCK, VERTEX_HEADER, MBMesquite::vertex_map_find(), MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), vid_map, MBMesquite::VertexPack::x, MBMesquite::VertexPack::y, z, and MBMesquite::VertexPack::z.
    int i, j, k, rval;
    // printf("[%d] %d %d non blocking\n",rank, iteration, pass);fflush(NULL);
    /* how many vertices will we receive */
    std::vector< int > numVtxPerProcSend( neighbourProc.size() );
        numVtxPerProcSend[i] = 0;
                numVtxPerProcSend[j]++;
                /* end loop */
                break;
        /* assert loop did not end without finding processor */
    /* tell each processor how many vertices to expect */
        rval = MPI_Send( &( numVtxPerProcSend[j] ), 1, MPI_INT, neighbourProc[j], VERTEX_HEADER + iteration,
        //    printf("[%d]i%d Announcing %d vertices to proc
        //    %d\n",rank,iteration,numVtxPerProcSend[j],neighbourProc[j]); fflush(NULL);
    /* place vertex data going to the same processor into consecutive memory space */
    std::vector< VertexPack > vertex_pack_export( num_exportVtx + 10 ); /* add 10 to have enough memory */
    std::vector< VertexPack* > packed_vertices_export( neighbourProc.size() );
    if( neighbourProc.size() ) packed_vertices_export[0] = ARRPTR( vertex_pack_export );
        packed_vertices_export[i] = packed_vertices_export[i - 1] + numVtxPerProcSend[i - 1];
    std::vector< int > numVtxPerProcSendPACKED( neighbourProc.size(), 0 );
                VertexPack* packing_vertex = packed_vertices_export[j] + numVtxPerProcSendPACKED[j];
                numVtxPerProcSendPACKED[j]++;
                MSQ_ERRZERO( err );
    // delete [] numVtxPerProcSendPACKED;
    /* now ask each processor how many vertices to expect */
    int num;
    int proc;
    int num_neighbourProcRecv = 0;
    std::vector< int > numVtxPerProcRecv( neighbourProc.size() );
    MPI_Status status;
        numVtxPerProcRecv[j] = 0;
        /* get the vertex count for some processor */
                         VERTEX_HEADER + iteration, /* receive only VERTEX HEADERs from this iteration */
        /* will we import vertices from this processor */
        //    printf("[%d]i%d Heard we will receive %d vertices from proc
        //    %d\n",rank,iteration,num,proc); fflush(NULL);
        if( num )
            /* increase number of processors we will receive from */
            num_neighbourProcRecv++;
            /* add number of vertices we will receive to the import total */
        /* find this processor in the list */
            if( neighbourProc[i] == proc )
                numVtxPerProcRecv[i] = num;
                break;
        assert( i != (long)neighbourProc.size() );
        if( 0 ) printf( "[%d]i%d Will receive %d vertices from proc %d\n", rank, iteration, num, proc );
        fflush( NULL );
    /* create list of processors we receive from */
    std::vector< int > neighbourProcRecv( num_neighbourProcRecv );
    std::vector< int > numVtxPerProcRecvRecv( num_neighbourProcRecv );
    for( i = 0, k = 0; i < (long)neighbourProc.size(); i++ )
        if( 0 )
            printf( "[%d]i%d Will receive %d vertices from proc %d\n", rank, iteration, numVtxPerProcRecv[i],
                    neighbourProc[i] );
        fflush( NULL );
        if( numVtxPerProcRecv[i] )
            neighbourProcRecv[k]     = neighbourProc[i];
            numVtxPerProcRecvRecv[k] = numVtxPerProcRecv[i];
            k++;
    /* set up memory for the incoming vertex data blocks */
    std::vector< VertexPack > vertex_pack_import( numVtxImport + 10 ); /* add 10 to have enough memory */
    std::vector< VertexPack* > packed_vertices_import( num_neighbourProcRecv );
    if( neighbourProc.size() ) packed_vertices_import[0] = ARRPTR( vertex_pack_import );
    for( i = 1; i < num_neighbourProcRecv; i++ )
        packed_vertices_import[i] = packed_vertices_import[i - 1] + numVtxPerProcRecvRecv[i - 1];
    /* receive from all processors that have something for us */
    std::vector< MPI_Request > request( num_neighbourProcRecv );
    for( j = 0; j < num_neighbourProcRecv; j++ )
        rval = MPI_Irecv( packed_vertices_import[j], 4 * numVtxPerProcRecvRecv[j], MPI_DOUBLE, neighbourProcRecv[j],
                          VERTEX_BLOCK + iteration, (MPI_Comm)communicator, &( request[j] ) );
        if( false )
            printf( "[%d]i%d Scheduling receipt of %d vertices to proc %d\n", rank, iteration, numVtxPerProcRecvRecv[j],
                    neighbourProcRecv[j] );
            fflush( NULL );
    /* now send the data blocks */
    std::vector< MPI_Request > requests_send( neighbourProc.size() );
        if( numVtxPerProcSend[j] )
            rval = MPI_Isend( packed_vertices_export[j], 4 * numVtxPerProcSend[j], MPI_DOUBLE, neighbourProc[j],
                              VERTEX_BLOCK + iteration, (MPI_Comm)communicator, &( requests_send[j] ) );
            if( 0 )
                printf( "[%d]i%d Scheduling send of %d vertices to proc %d\n", rank, iteration, numVtxPerProcSend[j],
                        neighbourProc[j] );
                fflush( NULL );
        else
            requests_send[j] = MPI_REQUEST_NULL;
    /* process messages as they arrive */
    int local_id;
        rval = MPI_Waitany( num_neighbourProcRecv, ARRPTR( request ), &k, &status );
        /* unpack messages */
        int count;
        if( 0 )
            printf( "[%d]i%d Received %d (%d) vertices from proc %d (%d)\n", rank, iteration, numVtxPerProcRecvRecv[k],
                    count, neighbourProcRecv[k], proc );
        fflush( NULL );
        for( i = 0; i < numVtxPerProcRecvRecv[k]; i++ )
            local_id = vertex_map_find( vid_map, packed_vertices_import[k][i].glob_id, neighbourProcRecv[k] );
            if( local_id )
                coordinates.set( packed_vertices_import[k][i].x, packed_vertices_import[k][i].y,
                                 packed_vertices_import[k][i].z );
                MSQ_ERRZERO( err );
                if( 0 )
                            (int)( packed_vertices_import[k][i].glob_id ), packed_vertices_import[k][i].x,
                            packed_vertices_import[k][i].y, packed_vertices_import[k][i].z );
            else
    /* all receives have completed. it is save to release the memory */
    // free(vertex_pack_import);
    /* wait until the sends have completed */
    std::vector< MPI_Status > stati( neighbourProc.size() );
    rval = MPI_Waitall( neighbourProc.size(), ARRPTR( requests_send ), ARRPTR( stati ) );
    /* all sends have completed. it is save to release the memory */
    // free(vertex_pack_export);
Definition at line 2036 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI_RZERO, communicator, exportProc, exportVtxGIDs, exportVtxLIDs, MBMesquite::VertexPack::glob_id, iteration, mesh, MSQ_ERRZERO, neighbourProc, neighbourProcRecv, neighbourProcRecvRemain, neighbourProcSendRemain, num_exportVtx, part_smoothed_flag, part_vertices, rank, MBMesquite::Vector3D::set(), VERTEX_BLOCK, VERTEX_HEADER, MBMesquite::vertex_map_find(), MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), vid_map, MBMesquite::VertexPack::x, MBMesquite::VertexPack::y, z, and MBMesquite::VertexPack::z.
    int i, j, k, rval;
    // printf("[%d] %d %d non blocking avoid reduce all\n",rank, iteration, pass);fflush(NULL);
    std::vector< int > numVtxPerProcSend( neighbourProc.size(), 0 );
                /* end loop */
                break;
            assert( neighbourProcSendRemain[j] >= numVtxPerProcSend[j] );
            neighbourProcSendRemain[j] -= numVtxPerProcSend[j];
        else
            assert( numVtxPerProcSend[j] == 0 );
                MSQ_ERRZERO( err );
    int num;
    int proc;
    std::vector< int > numVtxPerProcRecv( neighbourProc.size(), 0 );
    MPI_Status status;
        if( num )
                break;
        if( false ) printf( "[%d]i%d Will receive %d vertices from proc %d\n", rank, iteration, num, proc );
        fflush( NULL );
        if( 0 )
                    neighbourProc[i] );
        fflush( NULL );
            k++;
        if( false )
            fflush( NULL );
            if( 0 )
                        neighbourProc[j] );
                fflush( NULL );
        else
    int local_id;
        int count;
        if( 0 )
        fflush( NULL );
            if( local_id )
                MSQ_ERRZERO( err );
                if( 0 )
            else
Definition at line 1346 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI_RZERO, communicator, exportProc, exportVtxGIDs, exportVtxLIDs, MBMesquite::VertexPack::glob_id, iteration, mesh, MSQ_ERRZERO, neighbourProc, num_exportVtx, part_smoothed_flag, part_vertices, rank, MBMesquite::Vector3D::set(), VERTEX_BLOCK, VERTEX_HEADER, MBMesquite::vertex_map_find(), MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), vid_map, MBMesquite::VertexPack::x, MBMesquite::VertexPack::y, z, and MBMesquite::VertexPack::z.
    int i, j, k, rval;
    // printf("[%d]i%d truly non blocking\n",rank, iteration);fflush(NULL);
    /* compute how many vertices we send to each processor */
                /* end loop */
                break;
        /* did loop end without finding the processor */
        if( j == (long)neighbourProc.size() )
            printf( "[%d]i%d WARNING: did not find exportProc[%d] = %d in list of %lu processors.\n", rank, iteration,
                    i, exportProc[i], (unsigned long)neighbourProc.size() );
    /* tell each processor how many vertices they can expect from us */
    /* also ask each processor how many vertices we can expect from them */
    int num_neighbourProcSend = 0;
    std::vector< MPI_Request > requests_recv( neighbourProc.size() );
        /* send the vertex count to this processor */
        if( 0 )
            printf( "[%d]i%d Announce send %d vertices from proc %d\n", rank, iteration, numVtxPerProcSend[j],
                    neighbourProc[j] );
            fflush( NULL );
        rval = MPI_Isend( &( numVtxPerProcSend[j] ), 1, MPI_INT, neighbourProc[j], VERTEX_HEADER + iteration,
        num_neighbourProcSend++;
        /* recv the vertex count for this processor */
        if( 0 )
            printf( "[%d]i%d Listen  recv %d vertices from proc %d\n", rank, iteration, numVtxPerProcRecv[j],
                    neighbourProc[j] );
            fflush( NULL );
        rval = MPI_Irecv( &( numVtxPerProcRecv[j] ), 1, MPI_INT, neighbourProc[j], VERTEX_HEADER + iteration,
                          (MPI_Comm)communicator, &( requests_recv[j] ) );
    /* set up memory for the outgoing vertex data blocks */
    std::vector< int > numVtxPerProcSendPACKED( neighbourProc.size() );
        numVtxPerProcSendPACKED[i] = 0;
                MSQ_ERRZERO( err );
    /* wait until we have heard from all processors how many vertices we will receive from them */
    std::vector< MPI_Status > status( neighbourProc.size() );
    if( num_neighbourProcRecv )
        rval = MPI_Waitall( neighbourProc.size(), ARRPTR( requests_recv ), ARRPTR( status ) );
        numVtxImport += numVtxPerProcRecv[i];
    std::vector< VertexPack* > packed_vertices_import( neighbourProc.size() );
        packed_vertices_import[i] = packed_vertices_import[i - 1] + numVtxPerProcRecv[i - 1];
    /* post receives for all processors that have something for us */
    /* post sends for all processors that we have something for */
            if( 0 )
                printf( "[%d]i%d Will recv %d vertices from proc %d\n", rank, iteration, numVtxPerProcRecv[i],
                        neighbourProc[i] );
                fflush( NULL );
            rval = MPI_Irecv( packed_vertices_import[i], 4 * numVtxPerProcRecv[i], MPI_DOUBLE, neighbourProc[i],
                              VERTEX_BLOCK + iteration, (MPI_Comm)communicator, &( requests_recv[i] ) );
        else
            requests_recv[i] = MPI_REQUEST_NULL;
        if( numVtxPerProcSend[i] )
            if( 0 )
                printf( "[%d]i%d Will send %d vertices to proc %d\n", rank, iteration, numVtxPerProcSend[i],
                        neighbourProc[i] );
                fflush( NULL );
            rval = MPI_Isend( packed_vertices_export[i], 4 * numVtxPerProcSend[i], MPI_DOUBLE, neighbourProc[i],
                              VERTEX_BLOCK + iteration, (MPI_Comm)communicator, &( requests_send[i] ) );
        else
            requests_send[i] = MPI_REQUEST_NULL;
    /* wait for some receive to arrive */
    int local_id;
    while( num_neighbourProcRecv )
        rval = MPI_Waitany( neighbourProc.size(), ARRPTR( requests_recv ), &k, ARRPTR( status ) );
        /* unpack all vertices */
        for( i = 0; i < numVtxPerProcRecv[k]; i++ )
            local_id = vertex_map_find( vid_map, packed_vertices_import[k][i].glob_id, neighbourProc[k] );
            if( local_id )
                MSQ_ERRZERO( err );
            else
        num_neighbourProcRecv--;
    if( num_neighbourProcSend )
        rval = MPI_Waitall( neighbourProc.size(), ARRPTR( requests_send ), ARRPTR( status ) );
Definition at line 1563 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI_RZERO, communicator, exportProc, exportVtxGIDs, exportVtxLIDs, MBMesquite::VertexPack::glob_id, iteration, mesh, MSQ_ERRZERO, neighbourProc, neighbourProcRecvRemain, neighbourProcSendRemain, num_exportVtx, part_smoothed_flag, part_vertices, rank, MBMesquite::Vector3D::set(), VERTEX_BLOCK, VERTEX_HEADER, MBMesquite::vertex_map_find(), MBMesquite::Mesh::vertex_set_coordinates(), MBMesquite::Mesh::vertices_get_coordinates(), vid_map, MBMesquite::VertexPack::x, MBMesquite::VertexPack::y, z, and MBMesquite::VertexPack::z.
    int i, j, k, rval;
    // printf("[%d]i%d truly non blocking avoid reduce all\n", rank, iteration); fflush(NULL);
                /* end loop */
                break;
            if( 0 )
                printf( "[%d]i%d Announce send %d vertices to proc %d\n", rank, iteration, numVtxPerProcSend[j],
                        neighbourProc[j] );
                fflush( NULL );
        else
            if( 0 )
                printf( "[%d]i%d Listen recv xx vertices from proc %d\n", rank, iteration, neighbourProc[j] );
                fflush( NULL );
        else
            requests_recv[j] = MPI_REQUEST_NULL;
                MSQ_ERRZERO( err );
                if( 0 )
                    printf( "[%d]i%d vertex %lu packed %g %g %g\n", rank, iteration, (unsigned long)exportVtxGIDs[i],
                            packing_vertex->x, packing_vertex->y, packing_vertex->z );
        neighbourProcRecvRemain[i] -= numVtxPerProcRecv[i];
        neighbourProcSendRemain[i] -= numVtxPerProcSend[i];
        if( 0 )
                    neighbourProc[i] );
            fflush( NULL );
        else
        if( 0 )
                    neighbourProc[i] );
            fflush( NULL );
        else
    int local_id;
            if( local_id )
                if( 0 )
                    printf( "[%d]i%d vertex %d becomes %g %g %g\n", rank, iteration, local_id,
                MSQ_ERRZERO( err );
            else
void MBMesquite::ParallelHelperImpl::communicate_all_true ( bool &  value,
MsqError err
) const [protected, virtual]
srkenno AT sandia.gov 1/19/12: bug fix: changed from MPI_MAX to MIN - this makes the name of the function correct, if all proc's values are true, it returns true.
See also:
communicate_any_true above return true in
Parameters:
valueif all procs have value=true, else if any have it false, return false
Implements MBMesquite::ParallelHelper.
Definition at line 2941 of file ParallelHelper.cpp.
References CHECK_MPI, communicator, and value().
    int byte_out = value, byte_in;
    int rval     = MPI_Allreduce( &byte_out, &byte_in, 1, MPI_INT, MPI_MIN, (MPI_Comm)communicator );
    CHECK_MPI( rval, err );
    value = ( byte_in != 0 );
void MBMesquite::ParallelHelperImpl::communicate_any_true ( bool &  value,
MsqError err
Parameters:
value,returntrue to all
Definition at line 2927 of file ParallelHelper.cpp.
    int rval     = MPI_Allreduce( &byte_out, &byte_in, 1, MPI_INT, MPI_MAX, (MPI_Comm)communicator );
void MBMesquite::ParallelHelperImpl::communicate_histogram_to_zero ( std::vector< int > &  histogram,
MsqError err
Definition at line 2914 of file ParallelHelper.cpp.
References CHECK_MPI, communicator, and rank.
    std::vector< int > histogram_recv( histogram.size() );
    int rval = MPI_Reduce( &( histogram[0] ), &( histogram_recv[0] ), histogram.size(), MPI_INT, MPI_SUM, 0,
    if( rank == 0 )
        histogram.swap( histogram_recv );
void MBMesquite::ParallelHelperImpl::communicate_min_max_to_all ( double *  minimum,
double *  maximum,
MsqError err
Definition at line 2838 of file ParallelHelper.cpp.
References CHECK_MPI, and communicator.
    double d_min[2];
    double d_min_recv[2];
    d_min[0] = -( *maximum );
    d_min[1] = *minimum;
    int rval = MPI_Allreduce( d_min, d_min_recv, 2, MPI_DOUBLE, MPI_MIN, (MPI_Comm)communicator );
    *maximum = -d_min_recv[0];
    *minimum = d_min_recv[1];
void MBMesquite::ParallelHelperImpl::communicate_min_max_to_zero ( double *  minimum,
double *  maximum,
MsqError err
Definition at line 2850 of file ParallelHelper.cpp.
    double d_min[2];
    int rval = MPI_Reduce( d_min, d_min_recv, 2, MPI_DOUBLE, MPI_MIN, 0, (MPI_Comm)communicator );
    if( rank == 0 )
Definition at line 1119 of file ParallelHelper.cpp.
References Blocking, BlockingAvoidAllReduce, CHECK_MPI, comm_smoothed_vtx_b(), comm_smoothed_vtx_b_no_all(), comm_smoothed_vtx_nb(), comm_smoothed_vtx_nb_no_all(), comm_smoothed_vtx_tnb(), comm_smoothed_vtx_tnb_no_all(), communication_model, communicator, global_work_remains, iteration, NonBlocking, NonBlockingAvoidAllReduce, num_already_recv_vertices, num_already_smoothed_vertices, num_vtx_partition_boundary_local, part_smoothed_flag, rank, total_num_vertices_to_recv, total_num_vertices_to_smooth, TrulyNonBlocking, and TrulyNonBlockingAvoidAllReduce.
void MBMesquite::ParallelHelperImpl::communicate_power_sum_to_zero ( double *  pMean,
MsqError err
Definition at line 2906 of file ParallelHelper.cpp.
    double result;
    int rval = MPI_Reduce( pMean, &result, 1, MPI_DOUBLE, MPI_SUM, 0, (MPI_Comm)communicator );
    if( rank == 0 ) *pMean = result;
void MBMesquite::ParallelHelperImpl::communicate_sums_to_zero ( size_t *  freeElementCount,
int *  invertedElementCount,
size_t *  elementCount,
int *  invertedSampleCount,
size_t *  sampleCount,
long unsigned int *  count,
long unsigned int *  invalid,
double *  sum,
double *  sqrSum,
MsqError err
Definition at line 2865 of file ParallelHelper.cpp.
References CHECK_MPI, communicator, rank, and moab::sum().
    double d_sum[9];
    double d_sum_recv[9];
    d_sum[0] = (double)( *freeElementCount );
    d_sum[1] = (double)( *invertedElementCount );
    d_sum[2] = (double)( *elementCount );
    d_sum[3] = (double)( *invertedSampleCount );
    d_sum[4] = (double)( *sampleCount );
    d_sum[5] = (double)( *count );
    d_sum[6] = (double)( *invalid );
    d_sum[7] = *sum;
    d_sum[8] = *sqrSum;
    int rval = MPI_Reduce( d_sum, d_sum_recv, 9, MPI_DOUBLE, MPI_SUM, 0, (MPI_Comm)communicator );
    if( rank == 0 )
        *freeElementCount     = (size_t)d_sum_recv[0];
        *invertedElementCount = (int)d_sum_recv[1];
        *elementCount         = (size_t)d_sum_recv[2];
        *invertedSampleCount  = (int)d_sum_recv[3];
        *sampleCount          = (size_t)d_sum_recv[4];
        *count                = (long unsigned int)d_sum_recv[5];
        *invalid              = (long unsigned int)d_sum_recv[6];
        *sum                  = d_sum_recv[7];
        *sqrSum               = d_sum_recv[8];
void MBMesquite::ParallelHelperImpl::compute_first_independent_set ( std::vector< Mesh::VertexHandle > &  fixed_vertices) [protected, virtual]
Definition at line 977 of file ParallelHelper.cpp.
References communication_model, compute_independent_set(), in_independent_set, iteration, neighbourProc, neighbourProcRecv, neighbourProcRecvRemain, neighbourProcSend, neighbourProcSendRemain, nprocs, num_already_smoothed_vertices, num_vtx_partition_boundary, num_vtx_partition_boundary_local, part_smoothed_flag, part_vertices, rank, and unghost_vertices.
    if( nprocs == 1 ) return;
    int i;
    // to avoid all reduce we need to know how many vertices we send & receive
    if( communication_model & 1 )  // AVOID_ALL_REDUCE
            neighbourProcSendRemain[i] = neighbourProcSend[i];
            neighbourProcRecvRemain[i] = neighbourProcRecv[i];
    // this is iteration zero of the bounday smooting process
    iteration = 0;
    // mark all boundary partition vertices as not smoothed
    for( i = 0; i < num_vtx_partition_boundary; i++ )
        part_smoothed_flag[i] = 0;
    // populates the in_independent_set and the vertex export arrays
    compute_independent_set();
    // counts how many vertices are already smoothed
    num_already_smoothed_vertices = 0;
    fixed_vertices.clear();
    /* mark which local boundary partition vertices are already smoothed (i.e. they are in the 1st
     * independent set) */
    for( i = 0; i < num_vtx_partition_boundary_local; i++ )
        if( in_independent_set[i] )
            part_smoothed_flag[i] = 1;
            num_already_smoothed_vertices++;
        else
            fixed_vertices.push_back( part_vertices[i] );  // fix vertices *not* in the independent set
    if( false )
        printf( "[%d]i%d after first we smoothed %d of %d\n", rank, iteration, num_already_smoothed_vertices,
                num_vtx_partition_boundary_local );
        fflush( NULL );
    // fix the ghost vertices that are smoothed on another processor
    for( i = num_vtx_partition_boundary_local; i < num_vtx_partition_boundary; i++ )
    // fix the ghost vertices that are unused
    for( i = 0; i < (int)( unghost_vertices.size() ); i++ )
        fixed_vertices.push_back( unghost_vertices[i] );
Definition at line 2693 of file ParallelHelper.cpp.
References exportProc, exportVtxGIDs, exportVtxLIDs, in_independent_set, iteration, l, num_exportVtx, num_vtx_partition_boundary, num_vtx_partition_boundary_local, part_gid, part_proc_owner, part_rand_number, part_smoothed_flag, rank, size, and vtx_off_proc_list.
Referenced by compute_first_independent_set(), and compute_next_independent_set().
    int i, j, k, l;
    int incident_vtx;
    bool done;
        in_independent_set[i] = false;
    bool found_more = true;
    int found_iter  = 0;
    num_exportVtx = 0;
    while( found_more )
        found_iter++;
        found_more = false;
            /* if this vertex could become part of the independent set */
            if( part_smoothed_flag[i] == 0 && in_independent_set[i] == false )
                /* assume it's in the independent set */
                done = false;
                /* then loop over the neighbors it has on other processors */
                for( j = 0; !done && j < (long)vtx_off_proc_list[i].size(); j++ )
                    incident_vtx = vtx_off_proc_list[i][j];
                    /* if this neighbour has not yet been smoothed and is not covered and ... */
                    if( part_smoothed_flag[incident_vtx] == 0 )
                        /* ... has a higher rand_number than me */
                        if( part_rand_number[i] < part_rand_number[incident_vtx] )
                            /* then I am not in the independent set */
                            done = true;
                            break;
                        /* ... or has the same rand_number than me but a higher processor id */
                        else if( ( part_rand_number[i] == part_rand_number[incident_vtx] ) &&
                                 ( rank < part_proc_owner[incident_vtx] ) )
                            done = true;
                            break;
                /* if the vertex is in the independent set, add it to the export list */
                if( !done )
                    found_more = true;
                    //  if (found_iter > 1) printf("[%d]i%d found another one %d in iteration
                    //%d\n",rank,iteration,i, found_iter);
                    in_independent_set[i] = true;
                    /* mark vertices with lower random numbers as covered */
                    for( j = 0; j < (long)vtx_off_proc_list[i].size(); j++ )
                        /* if this neighbour has not yet been smoothed or covered mark it as covered
                            part_smoothed_flag[incident_vtx] = 2;
                    k = num_exportVtx;
                        /* check to see if this processor already on the list */
                        done = false;
                        for( l = k; l < num_exportVtx && !done; l++ )
                            if( exportProc[l] == part_proc_owner[incident_vtx] )
                                done = true;
                        /* if it's not on the list add it */
                        if( !done )
                            exportVtxLIDs[num_exportVtx] = i;
                            exportVtxGIDs[num_exportVtx] = part_gid[i];
                            exportProc[num_exportVtx]    = part_proc_owner[incident_vtx];
                            num_exportVtx++;
    if( false )
        int in_set = 0;
            if( in_independent_set[i] ) in_set++;
        printf( "[%d]i%d independent set has %d of %d vertices sent out %d times\n", rank, iteration, in_set,
                num_vtx_partition_boundary_local, num_exportVtx );
        fflush( NULL );
    /* unmark the vertices that have been marked as covered */
        if( part_smoothed_flag[i] == 2 ) part_smoothed_flag[i] = 0;
Definition at line 1073 of file ParallelHelper.cpp.
References compute_independent_set(), global_work_remains, iteration, next_vtx_partition_boundary, nprocs, and rank.
    if( nprocs == 1 ) return false;
    if( global_work_remains && ( iteration < 20 ) )
        iteration++;
        if( false ) printf( "[%d] work remains %d after %d iterations\n", rank, global_work_remains, iteration );
        next_vtx_partition_boundary = 0;
        return true;
    else
        if( global_work_remains )
            printf( "WARNING: global work remains %d after %d iterations\n", global_work_remains, iteration );
        return false;
Definition at line 1095 of file ParallelHelper.cpp.
References in_independent_set, iteration, next_vtx_partition_boundary, num_already_smoothed_vertices, num_vtx_partition_boundary_local, part_smoothed_flag, part_vertices, and rank.
    while( next_vtx_partition_boundary < num_vtx_partition_boundary_local )
        if( in_independent_set[next_vtx_partition_boundary] )
            vertex_handle = part_vertices[next_vtx_partition_boundary];
            assert( part_smoothed_flag[next_vtx_partition_boundary] == 0 );
            part_smoothed_flag[next_vtx_partition_boundary] = 1;
            next_vtx_partition_boundary++;
            return true;
    if( false )
        printf( "[%d]i%d after next we smoothed %d of %d\n", rank, iteration, num_already_smoothed_vertices,
        fflush( NULL );
    return false;
int MBMesquite::ParallelHelperImpl::get_nprocs ( ) const [protected, virtual]
Definition at line 2809 of file ParallelHelper.cpp.
References nprocs.
    return nprocs;
int MBMesquite::ParallelHelperImpl::get_rank ( ) const [protected, virtual]
Definition at line 2804 of file ParallelHelper.cpp.
References rank.
    return rank;
bool MBMesquite::ParallelHelperImpl::is_our_element ( Mesh::ElementHandle  element_handle,
MsqError err
Definition at line 2814 of file ParallelHelper.cpp.
References ARRPTR, MBMesquite::Mesh::elements_get_attached_vertices(), mesh, MSQ_ERRZERO, rank, and MBMesquite::ParallelMesh::vertices_get_processor_id().
    int i;
    std::vector< Mesh::VertexHandle > pvertices;
    std::vector< size_t > junk;
    mesh->elements_get_attached_vertices( &element_handle, 1, pvertices, junk, err );
    MSQ_ERRZERO( err );
    int num_verts = pvertices.size();
    std::vector< int > proc_ids( num_verts );
    mesh->vertices_get_processor_id( ARRPTR( pvertices ), ARRPTR( proc_ids ), num_verts, err );
    MSQ_ERRZERO( err );
    int max_proc_id = proc_ids[0];
    for( i = 1; i < num_verts; i++ )
        if( max_proc_id < proc_ids[i] ) max_proc_id = proc_ids[i];
    return ( max_proc_id == rank );
bool MBMesquite::ParallelHelperImpl::is_our_vertex ( Mesh::VertexHandle  vertex_handle,
MsqError err
Definition at line 2831 of file ParallelHelper.cpp.
References mesh, MSQ_CHKERR, rank, and MBMesquite::ParallelMesh::vertices_get_processor_id().
    int proc_id;
    mesh->vertices_get_processor_id( &vertex_handle, &proc_id, 1, err );
    return !MSQ_CHKERR( err ) && ( proc_id == rank );
void MBMesquite::ParallelHelperImpl::set_communication_model ( int  model,
MsqError err
) [virtual]
Definition at line 351 of file ParallelHelper.cpp.
References communication_model.
    communication_model = model;
void MBMesquite::ParallelHelperImpl::set_communicator ( size_t  comm) [virtual]
Definition at line 344 of file ParallelHelper.cpp.
References communicator, nprocs, and rank.
Referenced by main(), ParallelHelperImpl(), set_communicator(), and test().
    communicator = comm;
    MPI_Comm_rank( (MPI_Comm)communicator, &rank );
    MPI_Comm_size( (MPI_Comm)communicator, &nprocs );
void MBMesquite::ParallelHelperImpl::set_communicator ( const void *  comm) [inline]
Definition at line 88 of file ParallelHelper.hpp.
References set_communicator().
        set_communicator( reinterpret_cast< size_t >( comm ) );
Definition at line 356 of file ParallelHelper.cpp.
References generate_random_numbers.
    this->generate_random_numbers = grn;
Definition at line 339 of file ParallelHelper.cpp.
References mesh.
Referenced by main(), and test().
    this->mesh = pmesh;
void MBMesquite::ParallelHelperImpl::smoothing_close ( MsqError err) [protected, virtual]
Definition at line 1170 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI, communicator, GHOST_NODE_VERTEX_UPDATES, mesh, MBMesquite::MsqVertex::MSQ_CULLED, MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_HARD_FIXED, nprocs, num_vertex, rank, unghost_num_procs, unghost_num_vtx, unghost_procs, unghost_procs_num_vtx, unghost_procs_offset, unghost_vertices, update_gid, update_num_procs, update_num_vtx, update_procs, update_procs_num_vtx, update_procs_offset, MBMesquite::vertex_map_find(), MBMesquite::vertex_map_insert(), MBMesquite::Mesh::vertex_set_coordinates(), vertices, MBMesquite::Mesh::vertices_get_byte(), MBMesquite::Mesh::vertices_get_coordinates(), MBMesquite::ParallelMesh::vertices_get_global_id(), and MBMesquite::ParallelMesh::vertices_get_processor_id().
    int i, j, rval;
    //  printf("[%d] used %d iterations\n", rank, iteration);
    // communicate unused ghost nodes
    std::vector< double > update_updates;
    std::vector< MPI_Request > update_requests;
    if( update_num_procs )
        /* get the tags so we can find the requested vertices */
        std::vector< size_t > gid( num_vertex );
        mesh->vertices_get_global_id( ARRPTR( vertices ), ARRPTR( gid ), num_vertex, err );MSQ_ERRRTN( err );
        std::vector< unsigned char > app_fixed( num_vertex );
        mesh->vertices_get_byte( ARRPTR( vertices ), ARRPTR( app_fixed ), num_vertex, err );MSQ_ERRRTN( err );
        std::vector< int > proc_owner( num_vertex );
        mesh->vertices_get_processor_id( ARRPTR( vertices ), ARRPTR( proc_owner ), num_vertex, err );MSQ_ERRRTN( err );
        if( false )
            int ncull = 0;
            for( i = 0; i < num_vertex; ++i )
                if( app_fixed[i] & MsqVertex::MSQ_CULLED )
                    ++ncull;
            std::cout << "P[" << rank << "] ncull= " << ncull << " num_vertex= " << num_vertex << std::endl;
        /* only interested in fixed flag from vertex byte? Clear others. */
        // srkenno AT sandia.gov 1/19/12: bug fix: changed from |= which makes all vertices fixed
            app_fixed[i] &= MsqVertex::MSQ_HARD_FIXED;
        /* insert all our unfixed vertices into a map so we can find the requested vertices
         * efficiently */
        VertexIdMap temp_vid_map;
        for( j = 0; j < num_vertex; j++ )
            if( proc_owner[j] == rank && app_fixed[j] == false )
                vertex_map_insert( temp_vid_map, gid[j], rank, j );
        /* deallocate the tags */
        // delete [] gid; gid = 0;
        // delete [] app_fixed; app_fixed = 0;
        // delete [] proc_owner; proc_owner = 0;
        /* find the requested updates and collect them into an array */
        update_updates.resize( update_num_vtx * 3 );
        for( i = 0; i < update_num_vtx; i++ )
            j = vertex_map_find( temp_vid_map, update_gid[i], rank );
            mesh->vertices_get_coordinates( &( vertices[j] ), &coordinates, 1, err );MSQ_ERRRTN( err );
            update_updates[3 * i + 0] = coordinates[0];
            update_updates[3 * i + 1] = coordinates[1];
            update_updates[3 * i + 2] = coordinates[2];
            //      printf("[%d] send gid %d with %g %g %g\n", rank, update_gid[i], coordinates[0],
            //      coordinates[1], coordinates[2]);
        /* deallocate the map and the gid array */
        // delete temp_vid_map; temp_vid_map = 0;
        // delete [] update_gid; update_gid = 0;
        update_requests.resize( update_num_procs );
        /* send each processor the unused ghost node updates that they requested */
        for( j = 0; j < update_num_procs; j++ )
            rval = MPI_Isend( &( update_updates[update_procs_offset[j] * 3] ), update_procs_num_vtx[j] * 3, MPI_DOUBLE,
                              update_procs[j], GHOST_NODE_VERTEX_UPDATES, (MPI_Comm)communicator,
                              &( update_requests[j] ) );
            //      printf("[%d] sending %d of %d from %d with offset %d \n", rank,
            //      update_procs_num_vtx[j], update_num_vtx, update_procs[j],
            //      update_procs_offset[j]);
        /* deallocate more arrays that we no longer need */
        // delete [] update_procs_offset; update_procs_offset = 0;
        // delete [] update_procs_num_vtx; update_procs_num_vtx = 0;
        // delete [] update_procs; update_procs = 0;
    if( unghost_num_procs )
        std::vector< MPI_Request > unghost_requests( unghost_num_procs );
        /* receive from each processor the unused ghost nodes updates i want from them */
        std::vector< double > unghost_updates( unghost_num_vtx * 3 );
        for( j = 0; j < unghost_num_procs; j++ )
            rval = MPI_Irecv( &( unghost_updates[unghost_procs_offset[j] * 3] ), unghost_procs_num_vtx[j] * 3,
                              MPI_DOUBLE, unghost_procs[j], GHOST_NODE_VERTEX_UPDATES, (MPI_Comm)communicator,
                              &( unghost_requests[j] ) );
            //      printf("[%d] receiving %d of %d from %d with offset %d \n", rank,
            //      unghost_procs_num_vtx[j], unghost_num_vtx, unghost_procs[j],
            //      unghost_procs_offset[j]);
        // delete [] unghost_procs_offset; unghost_procs_offset = 0;
        // delete [] unghost_procs_num_vtx; unghost_procs_num_vtx = 0;
        // delete [] unghost_procs; unghost_procs = 0;
        std::vector< MPI_Status > status( unghost_num_procs );
        rval = MPI_Waitall( unghost_num_procs, ARRPTR( unghost_requests ), ARRPTR( status ) );
        /* apply the received updates for the unused ghost vertices */
        for( i = 0; i < unghost_num_vtx; i++ )
            coordinates[0] = unghost_updates[3 * i + 0];
            coordinates[1] = unghost_updates[3 * i + 1];
            coordinates[2] = unghost_updates[3 * i + 2];
            //      printf("[%d] recv %g %g %g\n", rank, coordinates[0], coordinates[1],
            //      coordinates[2]);
            mesh->vertex_set_coordinates( unghost_vertices[i], coordinates, err );MSQ_ERRRTN( err );
        // delete unghost_vertices; unghost_vertices = 0;
        // delete [] unghost_updates; unghost_updates = 0;
        // delete [] unghost_requests; unghost_requests = 0;
    // if (update_num_procs)
    //  delete [] update_updates; update_updates = 0;
    //  delete [] update_requests; update_requests = 0;
    // if (vertices) delete vertices; vertices = 0;
    // if (vtx_in_partition_boundary) delete [] vtx_in_partition_boundary; vtx_in_partition_boundary
    // = 0; if (part_vertices) delete part_vertices; part_vertices = 0; if (unghost_vertices) delete
    // unghost_vertices; unghost_vertices = 0; if (part_proc_owner) delete [] part_proc_owner;
    // part_proc_owner = 0; if (part_gid) delete [] part_gid; part_gid = 0; if (part_smoothed_flag)
    // delete [] part_smoothed_flag; part_smoothed_flag = 0; if (part_rand_number) delete []
    // part_rand_number; part_rand_number = 0; if (exportVtxGIDs) delete [] exportVtxGIDs;
    // exportVtxGIDs = 0; if (exportVtxLIDs) delete [] exportVtxLIDs; exportVtxLIDs = 0; if
    // (exportProc) delete [] exportProc; exportProc = 0; if (in_independent_set) delete []
    // in_independent_set; in_independent_set = 0; if (vid_map) delete vid_map; vid_map = 0; if
    // (neighbourProcSend) delete [] neighbourProcSend; neighbourProcSend = 0; if (neighbourProcRecv)
    // delete [] neighbourProcRecv; neighbourProcRecv = 0; if (neighbourProcSendRemain) delete []
    // neighbourProcSendRemain; neighbourProcSendRemain = 0; if (neighbourProcRecvRemain) delete []
    // neighbourProcRecvRemain; neighbourProcRecvRemain = 0; if (vtx_off_proc_list_size) delete []
    // vtx_off_proc_list_size; vtx_off_proc_list_size = 0; if (vtx_off_proc_list) {
    //  for (i = 0; i < num_vtx_partition_boundary_local; i++) free(vtx_off_proc_list[i]);
    //  delete [] vtx_off_proc_list; vtx_off_proc_list = 0;
    // if (neighbourProc) free(neighbourProc); neighbourProc = 0;
void MBMesquite::ParallelHelperImpl::smoothing_init ( MsqError err) [protected, virtual]
Definition at line 361 of file ParallelHelper.cpp.
References ARRPTR, CHECK_MPI, communication_model, communicator, MBMesquite::Mesh::elements_get_attached_vertices(), exportProc, exportVtxGIDs, exportVtxLIDs, MBMesquite::generate_random_number(), generate_random_numbers, MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), GHOST_NODE_INFO, GHOST_NODE_VERTEX_GIDS, GHOST_NODE_VERTICES_WANTED, in_independent_set, MBMesquite::Mesh::INT, MBMesquite::MsqError::INVALID_STATE, iteration, l, mesh, MBMesquite::MsqVertex::MSQ_CULLED, MSQ_ERRRTN, MBMesquite::MsqVertex::MSQ_HARD_FIXED, MSQ_SETERR, MBMesquite::my_quicksort(), neighbourProc, neighbourProcRecv, neighbourProcRecvRemain, neighbourProcSend, neighbourProcSendRemain, nprocs, num_vertex, num_vtx_partition_boundary, num_vtx_partition_boundary_local, num_vtx_partition_boundary_remote, part_gid, part_proc_owner, part_rand_number, part_smoothed_flag, part_vertices, rank, size, MBMesquite::Mesh::tag_create(), MBMesquite::Mesh::tag_delete(), MBMesquite::Mesh::tag_get_vertex_data(), MBMesquite::Mesh::tag_set_vertex_data(), total_num_vertices_to_recv, total_num_vertices_to_smooth, unghost_num_procs, unghost_num_vtx, unghost_procs, unghost_procs_num_vtx, unghost_procs_offset, unghost_vertices, update_gid, update_num_procs, update_num_vtx, update_procs, update_procs_num_vtx, update_procs_offset, MBMesquite::vertex_map_insert(), vertices, MBMesquite::Mesh::vertices_get_attached_elements(), MBMesquite::Mesh::vertices_get_byte(), MBMesquite::ParallelMesh::vertices_get_global_id(), MBMesquite::ParallelMesh::vertices_get_processor_id(), vid_map, vtx_in_partition_boundary, and vtx_off_proc_list.
    int i, j, k, rval;
    size_t l;
    if( !mesh )
        MSQ_SETERR( err )( MsqError::INVALID_STATE );
        return;
    /* get the vertices */
    mesh->get_all_vertices( vertices, err );MSQ_ERRRTN( err );
    num_vertex = vertices.size();
    /* allocate the data arrays we'll use for smoothing */
    /* get the data from the mesquite mesh */
    if( false )
        int ncull = 0;
                ++ncull;
        std::cout << "P[" << rank << "] smoothing_init ncull= " << ncull << " num_vertex= " << num_vertex << std::endl;
    /* create temporary Tag for the local IDs */
    std::vector< int > lid( num_vertex );
    for( i = 0; i < num_vertex; i++ )
        lid[i] = i;
    const char LOCAL_ID_NAME[] = "LOCAL_ID";
    TagHandle lid_tag          = mesh->tag_create( LOCAL_ID_NAME, Mesh::INT, 1, NULL, err );MSQ_ERRRTN( err );
    mesh->tag_set_vertex_data( lid_tag, num_vertex, ARRPTR( vertices ), ARRPTR( lid ), err );MSQ_ERRRTN( err );
    if( false ) printf( "[%d] set local tags on %d vertices\n", rank, num_vertex );
    /* get the elements */
    std::vector< MBMesquite::Mesh::ElementHandle > elements;
    mesh->get_all_elements( elements, err );MSQ_ERRRTN( err );
    int num_elems = elements.size();
    PARTITION BOUNDARY VERTEX DETERMINATION
    /* initialize the vertex partition boundary array */
    vtx_in_partition_boundary.clear();
    vtx_in_partition_boundary.resize( num_vertex, 0 );
    int incident_vtx, vtx_off_proc, vtx_on_proc;
    /* get the array that contains the adjacent vertices for each mesh element */
    std::vector< MBMesquite::Mesh::VertexHandle > adj_vertices;
    std::vector< size_t > vtx_offsets;
    mesh->elements_get_attached_vertices( ARRPTR( elements ), num_elems, adj_vertices, vtx_offsets, err );
    std::vector< int > adj_vertices_lid( adj_vertices.size() );
    mesh->tag_get_vertex_data( lid_tag, adj_vertices.size(), ARRPTR( adj_vertices ), ARRPTR( adj_vertices_lid ), err );
    if( false ) printf( "[%d] gotten adjacent elements for %d elements\n", rank, num_elems );
    /* determine which vertices are smoothed as part of the boundary (and which are unused ghost
     * vertices) */
    num_vtx_partition_boundary_local  = 0;
    num_vtx_partition_boundary_remote = 0;
    for( i = 0; i < num_elems; i++ )
        /* count how many vertices of the current element are on/off a different processor */
        vtx_off_proc = 0;
        vtx_on_proc  = 0;
        for( j = vtx_offsets[i]; j < (int)( vtx_offsets[i + 1] ); j++ )
            incident_vtx = adj_vertices_lid[j];
            /* obviously the vertex only counts if it is not app_fixed */
            if( !app_fixed[incident_vtx] )
                if( proc_owner[incident_vtx] != rank )
                    vtx_off_proc++;
                else
                    vtx_on_proc++;
        /* if vertices are on different processors mark all local vertices as boundary1 and all
         * remote vertices as boundary2 */
        if( vtx_off_proc > 0 && vtx_on_proc > 0 )
            /* collect stats */
            //  smooth_stats.num_part_bndy_elem++;
            /* mark the vertices */
                /* obviously the vertex does not need to be marked if it was already marked or if it
                 * is app_fixed*/
                if( vtx_in_partition_boundary[incident_vtx] <= 0 && app_fixed[incident_vtx] == 0 )
                    /* mark and count the vertex */
                        vtx_in_partition_boundary[incident_vtx] = 2;
                        num_vtx_partition_boundary_remote++;
                    else
                        vtx_in_partition_boundary[incident_vtx] = 1;
                        num_vtx_partition_boundary_local++;
        else if( vtx_off_proc > 0 )
            /* mark the vertices as boundary-1 (aka unused ghost) if the element has only
             * off-processor vertices */
                /* obviously the vertex is not marked if it was already marked or if it is
                 * app_fixed*/
                if( vtx_in_partition_boundary[incident_vtx] == 0 && app_fixed[incident_vtx] == 0 )
                    vtx_in_partition_boundary[incident_vtx] = -1;
    if( false )
        printf( "[%d]i%d local %d remote %d ", rank, iteration, num_vtx_partition_boundary_local,
                num_vtx_partition_boundary_remote );
        printf( "[%d]i%d pb1 ", rank, iteration );
            if( vtx_in_partition_boundary[i] == 1 ) printf( "%d,%lu ", i, gid[i] );
        printf( "\n" );
        printf( "[%d]i%d pb2 ", rank, iteration );
            if( vtx_in_partition_boundary[i] == 2 ) printf( "%d,%lu ", i, gid[i] );
        printf( "\n" );
        fflush( NULL );
    num_vtx_partition_boundary = num_vtx_partition_boundary_local + num_vtx_partition_boundary_remote;
   COLLECT THE PARTITION BOUNDARY VERTICES AND THE UNUSED GHOST VERTICES
    /* create the vectors to store the partition boundary vertex data */
    part_vertices.resize( num_vtx_partition_boundary );
    part_proc_owner.resize( num_vtx_partition_boundary );
    part_gid.resize( num_vtx_partition_boundary );
    part_smoothed_flag.resize( num_vtx_partition_boundary );
    part_rand_number.resize( num_vtx_partition_boundary );
    /* create the partition boundary map and its inverse */
    std::vector< int > vtx_partition_boundary_map_inverse( num_vertex );
    j = 0;
    /* first we map the partition boundary vertices that we will smooth on this processor */
            part_vertices[j]   = vertices[i];
            part_proc_owner[j] = rank;
            assert( proc_owner[i] == rank );
            part_gid[j]                           = gid[i];
            vtx_partition_boundary_map_inverse[i] = j;
            j++;
    vid_map.clear();
    /* then we map the ghost vertices that will be smoothed on other processors */
            part_proc_owner[j] = proc_owner[i];
            assert( proc_owner[i] != rank );
            /* only insert those vertices in the map that are smoothed on other processors */
            vertex_map_insert( vid_map, part_gid[j], part_proc_owner[j], j );
            // printf("[%d] inserting vertex with gid %u and pid %d \n", rank, part_gid[j],
            // part_proc_owner[j]);
            j++;
    /* create our own 'very pseudo random' numbers */
        part_rand_number[i] = generate_random_number( generate_random_numbers, part_proc_owner[i], part_gid[i] );
    /* count the number of unused ghost vertices */
    unghost_num_vtx = 0;
        if( vtx_in_partition_boundary[i] == -1 )
            unghost_num_vtx++;
    // printf("[%d] found %d unused ghost vertices (local %d remote %d)\n",rank, unghost_num_vtx,
    // num_vtx_partition_boundary_local,num_vtx_partition_boundary_remote);
    /* create the vectors to store the unused ghost vertices */
    unghost_vertices.resize( unghost_num_vtx );
    std::vector< int > unghost_proc_owner( unghost_num_vtx );
    std::vector< size_t > unghost_gid( unghost_num_vtx );
    /* store the unused ghost vertices that are copies of vertices from other processors and will
     * need to be received */
    j = 0;
            unghost_vertices[j]   = vertices[i];
            unghost_proc_owner[j] = proc_owner[i];
            unghost_gid[j] = gid[i];
            // printf(" %d", unghost_gid[j]);
            j++;
    /* no longer needed */
    unghost_num_procs = 0;
    unghost_procs.clear();
    unghost_procs_offset.clear();
    unghost_procs_num_vtx.clear();
    if( unghost_num_vtx )
        /* sort the unused ghost vertices by processor */
        my_quicksort( ARRPTR( unghost_proc_owner ), ARRPTR( unghost_gid ), &( unghost_vertices[0] ), 0,
                      unghost_num_vtx - 1 );
        /* count the number of processors we have unused ghost data from that we want to get updated
        unghost_num_procs = 1;
        for( i = 1; i < unghost_num_vtx; i++ )
            if( unghost_proc_owner[i - 1] != unghost_proc_owner[i] ) unghost_num_procs++;
        /* get the ids of those processors and the number of vertices we want from each */
        unghost_procs.resize( unghost_num_procs );
        unghost_procs_offset.resize( unghost_num_procs + 1 );
        unghost_procs_num_vtx.resize( unghost_num_procs );
        unghost_procs[0]        = unghost_proc_owner[0];
        unghost_procs_offset[0] = 0;
        for( i = 1, j = 1; i < unghost_num_vtx; i++ )
                unghost_procs[j]             = unghost_proc_owner[i];
                unghost_procs_offset[j]      = i;
                unghost_procs_num_vtx[j - 1] = unghost_procs_offset[j] - unghost_procs_offset[j - 1];
                assert( unghost_procs_num_vtx[j - 1] > 0 );
                j++;
        assert( j == unghost_num_procs );
        // delete [] unghost_proc_owner; unghost_proc_owner = 0;
        // printf("[%d] have ugns from %d processor(s) (%d,%d,%d)\n", rank, unghost_num_procs,
        // unghost_procs[0], (unghost_num_procs>1) ? unghost_procs[1] : -1, (unghost_num_procs>2) ?
        // unghost_procs[1] : -1);
    /* this will eventually store to how many processors each processor needs to send unused ghost
     * data to */
    std::vector< int > num_sends_of_unghost;
    /* gather the information about how many processors need ghost data */
    if( rank == 0 )
         * ghost data to */
        num_sends_of_unghost.resize( nprocs );
    /* temporary used for the initial gather in which each proc tells the root from how many procs
     * it wants unused ghost data updates */
    rval = MPI_Gather( &unghost_num_procs, 1, MPI_INT, ARRPTR( num_sends_of_unghost ), 1, MPI_INT, 0,
    /* now each processor tells the root node from which processors they want unused ghost nodes
     * information */
    if( rank == 0 )
        int procs_num = 0;
        int procs_max = 0;
        /* first count how many processors will send unused ghost node info and find the maximum
         * they will send */
        for( i = 1; i < nprocs; i++ )
            if( num_sends_of_unghost[i] )
                procs_num++;
                if( num_sends_of_unghost[i] > procs_max ) procs_max = num_sends_of_unghost[i];
        /* clean the temporary used array */
        for( i = 0; i < nprocs; i++ )
            num_sends_of_unghost[i] = 0;
        /* process rank 0's unused ghost nodes procs first */
            num_sends_of_unghost[unghost_procs[j]]++;
        /* now we process messages from all other processors that want unused ghost node information
        int* unghost_procs_array = new int[procs_max];
        for( i = 0; i < procs_num; i++ )
            MPI_Status status;
            rval = MPI_Recv( unghost_procs_array, procs_max, MPI_INT, MPI_ANY_SOURCE, GHOST_NODE_INFO,
                             (MPI_Comm)communicator, &status );
            int count;
            for( j = 0; j < count; j++ )
                num_sends_of_unghost[unghost_procs_array[j]]++;
        delete[] unghost_procs_array;
    else
            rval = MPI_Send( ARRPTR( unghost_procs ), unghost_num_procs, MPI_INT, 0, GHOST_NODE_INFO,
    /* now the root node knows for each processor on how many other processors they have ghost nodes
     * (which need updating) */
    /* the scatter distributes this information to each processor */
    rval = MPI_Scatter( ARRPTR( num_sends_of_unghost ), 1, MPI_INT, &update_num_procs, 1, MPI_INT, 0,
    // if (rank == 0) delete [] num_sends_of_unghost;
    // printf("[%d] i have unused ghost nodes from %d procs and i need to send updates to %d
    // procs\n", rank, unghost_num_procs, update_num_procs);
    /* now the processors can negotiate amongst themselves: */
    /* first tell each processor the number of unused ghost nodes we want from them */
    std::vector< MPI_Request > requests_unghost( unghost_num_procs );
        rval = MPI_Isend( &( unghost_procs_num_vtx[j] ), 1, MPI_INT, unghost_procs[j], GHOST_NODE_VERTICES_WANTED,
                          (MPI_Comm)communicator, &( requests_unghost[j] ) );
    /* then listen to as many processors as there are that want updates from us */
    std::vector< MPI_Request > requests_updates( update_num_procs );
    update_procs_num_vtx.resize( update_num_procs );
        rval = MPI_Irecv( &( update_procs_num_vtx[j] ), 1, MPI_INT, MPI_ANY_SOURCE, GHOST_NODE_VERTICES_WANTED,
                          (MPI_Comm)communicator, &( requests_updates[j] ) );
    /* wait until we have heard from all processors how many ghost nodes updates they want from us
    std::vector< MPI_Status > status_update( update_num_procs );
    update_procs.resize( update_num_procs );
    rval = MPI_Waitall( update_num_procs, ARRPTR( requests_updates ), ARRPTR( status_update ) );
        update_procs[j] = status_update[j].MPI_SOURCE;
        // printf("[%d] i have to send %d vertices to processor %d\n", rank,
        // update_procs_num_vtx[j], update_procs[j]);
    /* count the total number of vertices that we need to update elsewhere */
    update_procs_offset.resize( update_num_procs + 1 );
    update_num_vtx         = 0;
    update_procs_offset[0] = 0;
        update_num_vtx += update_procs_num_vtx[j];
        update_procs_offset[j + 1] = update_num_vtx;
    /* create enough space to receive all the vertex indices */
    update_gid.resize( update_num_vtx );
    /* tell each processor which vertices we want from them */
        rval = MPI_Isend( &( unghost_gid[unghost_procs_offset[j]] ), unghost_procs_num_vtx[j],
                          sizeof( size_t ) == 4 ? MPI_INT : MPI_DOUBLE, unghost_procs[j], GHOST_NODE_VERTEX_GIDS,
    /* receive from each processor the info which vertices they want from us */
        rval = MPI_Irecv( &( update_gid[update_procs_offset[j]] ), update_procs_num_vtx[j],
                          sizeof( size_t ) == 4 ? MPI_INT : MPI_DOUBLE, update_procs[j], GHOST_NODE_VERTEX_GIDS,
    /* wait until we have heard from all processors which vertices they want from us */
    /* wait until we have sent to all processors which vertices we want from them */
    std::vector< MPI_Status > status_unghost( unghost_num_procs );
    rval = MPI_Waitall( unghost_num_procs, ARRPTR( requests_unghost ), ARRPTR( status_unghost ) );
    for (j = 0; j < update_num_procs; j++)
      printf("[%d] will send to proc %d:", rank, update_procs[j]);
      for (i = update_procs_offset[j]; i < update_procs_offset[j+1]; i++) printf(" %d",
    update_gid[i]); printf("\n");
   COMPUTE THE SET OF NEIGHBORS THAT OUR VERTICES HAVE ON OTHER PROCESSORS
                 COMPUTE THE SET OF NEIGHBORS PROCESSORS
    if( num_vtx_partition_boundary_local == 0 )
        /* this processor does not partake in the boundary smoothing */
        neighbourProc.clear();
        mesh->tag_delete( lid_tag, err );
        vtx_partition_boundary_map_inverse.clear();
        return;
    /* init the neighbour processor list */
    /* init the neighbour lists */
    vtx_off_proc_list.clear();
    vtx_off_proc_list.resize( num_vtx_partition_boundary_local );
    /* get the adjacency arrays that we need */
    std::vector< MBMesquite::Mesh::ElementHandle > adj_elements;
    std::vector< MBMesquite::Mesh::VertexHandle > adj_adj_vertices;
    std::vector< size_t > elem_offsets;
    std::vector< size_t > adj_vtx_offsets;
    mesh->vertices_get_attached_elements( ARRPTR( part_vertices ), num_vtx_partition_boundary_local, adj_elements,
                                          elem_offsets, err );
    mesh->elements_get_attached_vertices( ARRPTR( adj_elements ), adj_elements.size(), adj_adj_vertices,
                                          adj_vtx_offsets, err );
    // delete adj_elements; adj_elements = 0;
    std::vector< int > adj_adj_vertices_lid( adj_adj_vertices.size() );
    mesh->tag_get_vertex_data( lid_tag, adj_adj_vertices.size(), ARRPTR( adj_adj_vertices ),
                               ARRPTR( adj_adj_vertices_lid ), err );
    // delete adj_adj_vertices; adj_adj_vertices = 0;
        /* loop over the elements surrounding that vertex */
        for( j = elem_offsets[i]; j < (int)( elem_offsets[i + 1] ); j++ )
            /* loop over the neighbors of the considered vertex (i.e. the vertices of these element)
            for( k = adj_vtx_offsets[j]; k < (int)( adj_vtx_offsets[j + 1] ); k++ )
                /* get the next neighbour */
                incident_vtx = adj_adj_vertices_lid[k];
                /* if this neighbour is a vertex that is smoothed on a different processor */
                if( vtx_in_partition_boundary[incident_vtx] == 2 )
                    /* then map it into our domain */
                    incident_vtx = vtx_partition_boundary_map_inverse[incident_vtx];
                    /* is this vertex already in our neighbour list ? */
                    if( std::find( vtx_off_proc_list[i].begin(), vtx_off_proc_list[i].end(), incident_vtx ) ==
                        vtx_off_proc_list[i].end() )
                        /* if the vertex is not in the list yet ... add it */
                        vtx_off_proc_list[i].push_back( incident_vtx );
                        /* is the processor of this vertex already in the processor list */
                        incident_vtx = part_proc_owner[incident_vtx];
                        /* check by scanning the list for this processor */
                        if( std::find( neighbourProc.begin(), neighbourProc.end(), incident_vtx ) ==
                            neighbourProc.end() )
                            /* the processor is not in the list yet ... add it */
                            neighbourProc.push_back( incident_vtx );
    /* sort the list of neighbour processors */
    std::sort( neighbourProc.begin(), neighbourProc.end() );
      COMPUTE HOW MANY VERTICES WE NEED TO SEND/RECV FROM EACH PROCESSOR
    neighbourProcSend.clear();
    neighbourProcRecv.clear();
    neighbourProcSendRemain.clear();
    neighbourProcRecvRemain.clear();
        total_num_vertices_to_smooth = num_vtx_partition_boundary_local;
        total_num_vertices_to_recv   = num_vtx_partition_boundary_remote;
        neighbourProcSend.resize( neighbourProc.size(), 0 );
        neighbourProcRecv.resize( neighbourProc.size(), 0 );
        /* for each vertex we smooth find the processors we need to send it too */
            /* loop over its adjacent off-processor vertices */
                /* get the processor id of these vertices */
                incident_vtx = part_proc_owner[vtx_off_proc_list[i][j]];
                /* check if we got this processor id before */
                for( k = 0; k < j; k++ )
                    if( incident_vtx == part_proc_owner[vtx_off_proc_list[i][k]] )
                        /* if we have has this procesor id already we do not need to count it again
                        incident_vtx = -1;
                        break;
                /* if this was a new processor id */
                if( incident_vtx != -1 )
                    /* find the processor in the list and increment its counter */
                    for( l = 0; l < neighbourProc.size(); l++ )
                        if( neighbourProc[l] == incident_vtx )
                            neighbourProcSend[l]++;
                            break;
            incident_vtx = part_proc_owner[i];
                    neighbourProcRecv[l]++;
                    break;
        neighbourProcSendRemain.resize( neighbourProc.size() );
        neighbourProcRecvRemain.resize( neighbourProc.size() );
    exportVtxGIDs.resize( num_vtx_partition_boundary );
    exportVtxLIDs.resize( num_vtx_partition_boundary );
    exportProc.resize( num_vtx_partition_boundary );
    in_independent_set.resize( num_vtx_partition_boundary_local );
Friends And Related Function Documentation
friend class QualityAssessor [friend]
Reimplemented from MBMesquite::ParallelHelper.
Definition at line 107 of file ParallelHelper.hpp.
friend class VertexMover [friend]
Definition at line 96 of file ParallelHelper.hpp.
Member Data Documentation
Definition at line 142 of file ParallelHelper.hpp.
Referenced by smoothing_close(), and smoothing_init().
std::vector< size_t > MBMesquite::ParallelHelperImpl::part_gid [private]
Definition at line 149 of file ParallelHelper.hpp.
Referenced by compute_independent_set(), ParallelHelperImpl(), and smoothing_init().
std::vector< double > MBMesquite::ParallelHelperImpl::part_rand_number [private]
Definition at line 151 of file ParallelHelper.hpp.
Definition at line 172 of file ParallelHelper.hpp.
std::vector< int > MBMesquite::ParallelHelperImpl::unghost_procs [private]
Definition at line 175 of file ParallelHelper.hpp.
Definition at line 176 of file ParallelHelper.hpp.
Definition at line 177 of file ParallelHelper.hpp.
std::vector< size_t > MBMesquite::ParallelHelperImpl::update_gid [private]
Definition at line 179 of file ParallelHelper.hpp.
Definition at line 180 of file ParallelHelper.hpp.
Definition at line 178 of file ParallelHelper.hpp.
std::vector< int > MBMesquite::ParallelHelperImpl::update_procs [private]
Definition at line 181 of file ParallelHelper.hpp.
Definition at line 182 of file ParallelHelper.hpp.
Definition at line 183 of file ParallelHelper.hpp.
Definition at line 143 of file ParallelHelper.hpp.
Referenced by ParallelHelperImpl(), and smoothing_init().
std::vector< std::vector< int > > MBMesquite::ParallelHelperImpl::vtx_off_proc_list [private]
Definition at line 166 of file ParallelHelper.hpp.
List of all members.
