MBMesquite::ParallelMesh Class Reference
#include <ParallelMeshInterface.hpp>
+ Inheritance diagram for MBMesquite::ParallelMesh:
+ Collaboration diagram for MBMesquite::ParallelMesh:
Public Member Functions
virtual void vertices_get_global_id (const VertexHandle vert_array[], size_t global_id[], size_t num_vtx, MsqError &err)=0
virtual void vertices_get_processor_id (const VertexHandle vert_array[], int proc_id[], size_t num_vtx, MsqError &err)=0
virtual void set_parallel_helper (ParallelHelper *p_helper)
virtual ParallelHelperget_parallel_helper ()
Protected Member Functions
virtual ~ParallelMesh ()
 Don't allow a ParallelMesh to be deleted directly.
Protected Attributes
ParallelHelperhelper
Detailed Description
is an abstract class which defines required methods required for using Mesquite in parallel. It derives from the MBMesquite::Mesh interface so the user must provide implementations of the pure virtual methods in both MBMesquite::Mesh as well as those defined here.
Definition at line 50 of file ParallelMeshInterface.hpp.
virtual MBMesquite::ParallelMesh::~ParallelMesh ( ) [inline, protected, virtual]
Definition at line 84 of file ParallelMeshInterface.hpp.
Member Function Documentation
Get parallel helper
Definition at line 76 of file ParallelMeshInterface.hpp.
        return helper;
virtual void MBMesquite::ParallelMesh::set_parallel_helper ( ParallelHelper p_helper) [inline, virtual]
Set parallel helper
Definition at line 69 of file ParallelMeshInterface.hpp.
Referenced by main(), and test().
        this->helper = p_helper;
virtual void MBMesquite::ParallelMesh::vertices_get_global_id ( const VertexHandle  vert_array[],
size_t  global_id[],
size_t  num_vtx,
MsqError err
) [pure virtual]
Member Data Documentation
List of all members.
